Using CCS to open FreeRTOS demo
willylin wrote on Friday, November 30, 2018:
Hello
I use CCSV8 to open CORTEX_R4_RM48_TMS570_CCS5 in FreeRTOS but there is an ERROR when I am doing “Build”.
It like to attachment.
What should I do?
rtel wrote on Friday, November 30, 2018:
That project is quite old so I would not be surprised if there were
incompatibilities in the project file formats for the latest tools -
however in this case the error is saying it can’t find one of the build
tools (‘make’ in this case) - should CCS install that or are you
expected to have it available in your environment path for CCS to be
able to find it already?
willylin wrote on Tuesday, December 04, 2018:
Hello
Can I solve this problem if I use CCSV5?
Or what should I do?
rtel wrote on Tuesday, December 04, 2018:
I assume if you use the same version of CCS then the project will work
fine - it did when it was created.
willylin wrote on Tuesday, December 11, 2018:
Hello
I using CCSv5.2 now, but it does not build success.
And, I do not change any code.
what can i do to solve this problem?
Or, is there an operational process that can be used in this demo?
