Of course, it would be helpful if you said what the error actually was, but I just tried this in CCS V6.1.0 and didn’t have any problem importing or building. I will try updating to CCS V6.1.2 to see if that makes any difference - but as I recall CCS is huge so it may take a while to download.
i had selected CORTEX_M4F_MSP432_LaunchPad_IAR_CCS_Keil folder’s, but
error said
Import failed for project ‘RTOSDeomo’ because its compiler definition is not available.
The project does not appear to be a ‘CCS Project’. please try importing it through the ‘General>Exisiting Projects into Workspace’ wizard
why RTOSDemo was appeared. i cant understand…
and i had tried through General>Exisiting Projects into Worspace, but it was failed.
Did you make any mofidications to the files in the main FreeRTOS download? For example, did you change the directory structure, or delete any files?
It works fine for me using V6.1.0 and it would seem odd that TI would change the project format enough for it not to work in V6.1.2 (which I am currently installing).
I want to port FreeRTOS to CC2538 - cortex M3 using CCS.
FreeRTOS will run on any Cortex-M that has enough RAM. The following links may help:
As, once again, you have not actually said what the error is, there is no way we can assess what might have gone wrong.
the error was
“Import failed for project ‘RTOSDeomo’ because its compiler definition is not available.
The project does not appear to be a ‘CCS Project’. please try importing it through the ‘General>Exisiting Projects into Workspace’ wizard”
It is a CCS error, not a FreeRTOS error. Perhaps you don’t have the
correct CCS components installed. Particularly, just guessing from the
error message, the correct compiler installed (CCS can be used with more
than one compiler). Do you have the CCS ARM compiler installed?
