Unable to compile the code
sanidhyavijaywa wrote on Wednesday, June 06, 2018:
I have included the header files and I have verified if the path of each file is correctly identified by the compiler. Still when I try to build the program it shows undefined reference to ‘vTaskStartSchedular’ and ‘xTaskCreate’.
I am also not sure what to do with timer.c, coroutine.c, and other C files.
here is the screen shot
richard_damon wrote on Wednesday, June 06, 2018:
Have you included the FreeRTOS source files in your project? those would be things like tasks.c, queue.c, timer.c etc. Those are the files where the code for the functions of FreeRTOS are defined.
Yes, all infact I have copied all the header files, source files (.h and .c) in the same folder itself. Then it gives the following error. I don’t where pvPortMalloc is defined.
rtel wrote on Wednesday, June 06, 2018:
Google would probably find it: FreeRTOS - Memory management options for the FreeRTOS small footprint, professional grade, real time kernel (scheduler)
From the screenshot it looks like the following will be helpful too
FreeRTOS - The Free RTOS configuration constants and configuration options - FREE Open Source RTOS for small real time embedded systems
Okay, I managed to solve that errror but now it shows this , undefined reference to ‘ulGetRunTimeCounterValue’.
What have you done to try and rectify this problem. For example, in
your screen shot it shows that this code only builds if
configGENERATE_RUN_TIME_STATS is set to 1. Do you have it set to 1?
Did you intend having it set to 1? Did you google the constant on the
FreeRTOS.org website so you can find its documentation?
