HI all,
I’m newbie with FreeRTOS and i’m trying to compile a simply example application.
If i open the demo application with Microsoft Visual Studio, it works greatly, but once i remove all .c leave only main.c with some simply instatements like xTaskCreate(), cause this errors:
undefined reference to: xTaskCreate();
I’ve tried also to create a new project with include all header, but the result it’s the same.
Toolchain tried: Codeblock and Eclipse Luna with MinGW header and Microsoft Visual Studio with header MSVC
I’ve seen that in the source file, there aren’t .lib or .dll but only .h.
You know you use FreeRTOS by including its source files in your project right? So if you remove >all< the files except main.c you will have removed FreeRTOS.
This link http://www.freertos.org/a00017.html tells you about the source files and directories. The Microsoft Visual Studio project probably includes a folder called something similar to “FreeRTOS Source” which includes the FreeRTOS files.
Don’t delete any files from the “FreeRTOS Source” directory in the MSVC
project. They implement the FreeRTOS kernel, so without them your
application will not link.
Really a lot of information has gone into documenting these things. I
think the information you need can be found with a little time
investment reading…
