nobody wrote on Sunday, May 13, 2007:
I want compile uIP Embedded WEB Server Demo on an LPC2368 but I don’t use CrossStudio.
I will be grateful for GCC makefile for this examples.
Regards
David
Regards
David
If you look at the lwIP CrossWorks demo you will see that there is both a CrossWorks project and a makefile. I would suggest taking that makefile as a starting point, then edit it to include the correct files and compiler settings. You can get an evaluation version of CrossWorks so you can open the project file and see what is needed.
