I have board with SAM7X256 and DP83848 PHY. I’m trying to run lwIP TCP/IP FreeRTOS demo. LEDs and USB work fine, but I have trouble with web server. I changed PHY ID to DP83848 in file SAM7_EMAC.c and emacIPADDRx in SAM7_EMAC.h. When I debug code ID read from PHY is OK, but web does not show in browser. I tested MII and RMII interface. My cable and LAN is OK because I have running LPC2378 web examples and works fine. I will be grateful for any ideas.
Try placing a break point in the EMAC ISR. If it never gets hit then there is an interface problem. If it gets hit you will be able to follow the code through to see at what point it is failing. I should start experimentations with simple PING requests as it is then easier to follow the data path through the code without having to get into the TCP stuff.
