damienhoyen wrote on Friday, July 11, 2008:
Hi every body,
Well, i m sticky with a GCC port and a interrupt (an RTC, from 2Hz to 128Hz) problem which reset my software.
For user of IAR, the GCC port seems be more or less the same as yours…
I m sure this interrupt is responsible of the crash because the interrupt frequency of this RTC is connected to the frequency of FreeRTOS reset.
On the same way, a disabling of this interrupt and the software runs without problem.
Important : The execution of the same interrupt in "FIQ Mode" runs without problem.
This interrupt is empty : just clear and reenable, nothing else…
I’m supposing maybe something is wrong with the GCC interrupt management,
maybe in the FreeRTOS port task swap (GCC Port) or in the assembler file (CPSR register or macro Save-Restore Context)
If every body use interrupt on the STR91x port and GCC compilation, could you share with me your feedback.
Others ideas welcomed
Thanks in advance.
Damien
Context : FreeRTOS (5.0.0), GCC Yagarto, Eclipse, ARM9 STR912 and Board Olimex
To follow the following Thread : http://sourceforge.net/forum/forum.php?thread_id=2109568&forum_id=382005
