fabtor wrote on Tuesday, October 03, 2006:
Actually i aven’t a decent debugger because the Ride Raisonance toolkit that i use doesn’t provide a rom debugger and the ram debugger is limited to 16k. What i must used?
The startup file are provided by Raisonance and modified by me as follows:
.extern main
.extern exit
.extern VIC0_BASE
.extern VIC1_BASE
.code 32
.align 0
.extern _sidata
.extern _sdata
.extern _edata
.extern _sbss
.extern _ebss
;/* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs */
.set Mode_USR, 0x10 ;/* User Mode */
.set Mode_FIQ, 0x11 ;/* FIQ Mode */
.set Mode_IRQ, 0x12 ;/* IRQ Mode */
.set Mode_SVC, 0x13 ;/* Supervisor Mode */
.set Mode_ABT, 0x17 ;/* Abort Mode */
.set Mode_UND, 0x1B ;/* Undefined Mode */
.set Mode_SYS, 0x1F ;/* System Mode */
.equ I_Bit, 0x80 ;/* when I bit is set, IRQ is disabled */
.equ F_Bit, 0x40 ;/* when F bit is set, FIQ is disabled */
/*; — System memory locations */
;/* init value for the stack pointer. defined in linker script */
.extern _estack
;/* Stack Sizes. The default values are in the linker script, but they can be overriden. */
SRAM_Base = 0x04000000
SRAM_Limit= 0x04018000
.set UND_Stack_Size, 0x00000004
.set ABT_Stack_Size, 0x00000004
.set FIQ_Stack_Size, 0x00000004
.set IRQ_Stack_Size, 0x00000400
.set SVC_Stack_Size, 0x00000400
.section .flashtext
.code 32
.align 0
.globl _start
.globl _startup
_startup:
_start:
ldr PC, Reset_Addr
ldr PC, Undefined_Addr
ldr PC, SWI_Addr
ldr PC, Prefetch_Addr
ldr PC, Abort_Addr
nop /*; Reserved vector*/
ldr pc, [pc,#-0xFF0] /*; IRQ Handler ***I use this but i think that isn’t correct ***
ldr PC, Fiq_Addr
Reset_Addr : .long Reset_Handler
Undefined_Addr : .long UndefinedHandler
SWI_Addr : .long vPortYieldProcessor
Prefetch_Addr : .long PrefetchAbortHandler
Abort_Addr : .long DataAbortHandler
Fiq_Addr : .long FIQHandler
.long 0 /*; Reserved vector*/
UndefinedHandler : b . /* undefined */
PrefetchAbortHandler : b . /* program abort */
DataAbortHandler : b . /* data abort */
FIQHandler : b . /* FIQ */
Reset_Handler:
/* Setup a stack for each mode - note that this only sets up a usable stack
for system/user, SWI and IRQ modes. Also each mode is setup with
interrupts initially disabled. */
ldr r0, =_estack
msr CPSR_c, #Mode_FIQ|I_Bit|F_Bit
ldr SP, =FIQ_Stack_Size
msr CPSR_c, #Mode_IRQ|I_Bit|F_Bit
ldr SP, =IRQ_Stack_Size
msr CPSR_c, #Mode_ABT|I_Bit|F_Bit
ldr SP, =ABT_Stack_Size
msr CPSR_c, #Mode_UND|I_Bit|F_Bit
ldr SP, =UND_Stack_Size
msr CPSR_c, #Mode_SVC|I_Bit|F_Bit
ldr SP, =SVC_Stack_Size
msr CPSR_c, #Mode_SYS|I_Bit|F_Bit
/* We want to start in supervisor mode. Operation will switch to system
mode when the first task starts. */
;/* copy the initial values for .data section from FLASH to RAM */
ldr R1, =_sidata
ldr R2, =_sdata
ldr R3, =_edata
_reset_inidata_loop:
cmp R2, R3
ldrlO R0, [R1], #4
strlO R0, [R2], #4
blO _reset_inidata_loop
;/* Clear the .bss section */
mov r0,#0 ;/* get a zero */
ldr r1,=_sbss ;/* point to bss start */
ldr r2,=_ebss ;/* point to bss end */
_reset_inibss_loop:
cmp r1,r2 ;/* check if some data remains to clear */
strlo r0,[r1],#4 ;/* clear 4 bytes */
blo _reset_inibss_loop ;/* loop until done */
/*; — Now enter the C code */
/* ldr PC, ___main
___main : .long main*/
b main
The only problem is to handle the interrupt entry and exit. IAR use the IRQ_Handler function in 91x_vect.c and the portSAVE_Context and portRESTORE_Context are in the ISR_Support.h file.
In gcc port this file doesn’t exist and the fuctions are included in portmacro.h as #define. if i use the IRQ_Handler on my startup file i obtain undefined reference error to portSAVE and portRESTORE from the compiler. For the rest, the file seems to be correct. Please take a look to the file. It’s most important to me to know that is correct. Thanks!
