imajeff wrote on Friday, July 01, 2005:
I didn’t mention before that I was working on the unsupported version before the supported version appeared. I realized that the supported version would be the better base, although I figure it will take some getting used to since 3.0 had significant changes. I will include the patch below (sorry if it’s not very readable).
I felt like my work was ready for a first test, but didn’t test it. Here are some issues with portability:
I addressed some interrupt details as you mentioned. I found that the gcc-m68hc1x port does not support the “naked” attribute, so I can’t tell it not to generate it’s own interrupt code. Also the code would need changed if the number of software registers (such as “._d0”) changed
The example is changed for no longer for CodeWarrior. The leftovers might make it hard to read. I tried to keep the port files switchable, but not sure since it’s not tested.
The method of addressing IO ports is from the Ipac port in GEL examples. The file there is "gel-1.6.1/include/asm-m68hc12/arch-Ipac/arch/iodg256b.h". I added some defines to it for some popular bits used.
======== patch =========
Only in FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources: Makefile
diff -r -u FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/port.c FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/port.c
— FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/port.c 2005-07-01 13:37:45.587354171 -0600
+++ FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/port.c 2005-04-08 14:48:51.000000000 -0600
@@ -1,5 +1,7 @@
/* This file is part of an "unsupported" FreeRTOS port distribution for
* Freescale MC9S12DP256B CPU.
+ * 2004-04-06 imajeff: modify to work with GCC
/* Scheduler include files. */
@@ -14,7 +16,7 @@
#pragma MESSAGE DISABLE C12053
#include "6812dp256b.h"
#else
- #include "port.h"
+ #include <arch/iodg256b.h>
volatile unsigned char vPortSchRunning = 0;
@@ -231,7 +233,7 @@
CRGINT = (unsigned char) 0x80;
/* clear overflow interrupt flag */
- CRGFLG_RTIF = 1;
+ CRGFLG = RTIF;
diff -r -u FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/portmacro.h FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/portmacro.h
— FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/portmacro.h 2005-07-01 13:37:45.584354465 -0600
+++ FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/portmacro.h 2005-04-19 09:44:36.000000000 -0600
@@ -1,5 +1,7 @@
+ * 2005-04-06 gcc fixes, imajeff
#ifndef PORTMACRO_H
@@ -42,7 +44,7 @@
* or a 32 bit value. See documentation on http://www.FreeRTOS.org to decide
* which to use.
-#define USE_16_BIT_TICKS 0
+#define USE_16_BIT_TICKS 1
@@ -72,8 +74,13 @@
+#ifdef __HIWARE__
#define portDISABLE_RTI_INTERRUPT() CRGINT_RTIE = 0
#define portENABLE_RTI_INTERRUPT() CRGINT_RTIE = 1
+#else
+#define portDISABLE_RTI_INTERRUPT() CRGINT &= ~RTIE
+#define portENABLE_RTI_INTERRUPT() CRGINT |= RTIE
+#endif
void vPortEnterCritical(void);
void vPortExitCritical(void);
@@ -118,7 +125,7 @@
#define vPortIsrTail()
/* reset pending RTI interrupt */
- CRGFLG_RTIF = 1;
+ CRGFLG = RTIF;
__asm__("rti");
@@ -126,6 +133,7 @@
/* hardware interrupt handler saves CCR, A, B, X, Y, so there’s no need to save
* them one more time */
+#ifdef __HIWARE__
#define portSAVE_CONTEXT()
extern volatile void * pxCurrentTCB;
@@ -144,5 +152,34 @@
__asm__(“stab 0x30”);
+#else /* GNUC */
+#define portSAVE_CONTEXT()
+ __asm__(" \n
+ .globl pxCurrentTCB \n
+ movw _.frame, 2,-sp \n
+ movw _.tmp, 2,-sp \n
+ movw _.xy, 2,-sp \n
+ movw _.z, 2,-sp \n
+ movb 0x30, 1,-sp ; PPAGE \n
+ sts pxCurrentTCB \n
+#define portRESTORE_CONTEXT()
+ __asm__(" \n
+ lds pxCurrentTCB \n
+ movb 1,+sp, 0x30 ; PPAGE \n
+ movw _.z, 2,+sp \n
+ movw _.xy, 2,+sp \n
+ movw _.tmp, 2,+sp \n
+ movw _.frame, 2,+sp \n
+#endif
#endif /* PORTMACRO_H */
diff -r -u FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/queue.c FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/queue.c
— FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/queue.c 2005-07-01 13:37:45.594353485 -0600
+++ FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/queue.c 2005-04-14 12:22:08.000000000 -0600
@@ -109,6 +109,7 @@
void vQueueDelete( xQueueHandle xQueue );
signed portCHAR cQueueSendFromISR( xQueueHandle pxQueue, const void *pvItemToQueue, signed portCHAR cTaskPreviouslyWoken );
signed portCHAR cQueueReceive( xQueueHandle pxQueue, void *pcBuffer, portTickType xTicksToWait );
+signed portCHAR cQueueReceiveFromISR( xQueueHandle pxQueue, void *pcBuffer, signed portCHAR *pcTaskWoken );
* Unlocks a queue locked by a call to prvLockQueue. Locking a queue does not
diff -r -u FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/test.c FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/test.c
— FreeRTOS-2.6.1/Source/portable/CodeWarrior/HCS12/sources/test.c 2005-07-01 13:37:45.589353975 -0600
+++ FreeRTOS-2.6.1-m/Source/portable/CodeWarrior/HCS12/sources/test.c 2005-04-18 17:22:43.000000000 -0600
@@ -1,36 +1,37 @@
-#include <6812dp256b.h> /* derivative information */
+ * 2004-04-06 imajeff: modifying to test FreeRTOS with HC12/GCC
+#include <arch/iodg256b.h> /* derivative information */
#include <stddef.h>
#include <stdio.h>
+#include <string.h>
#include "task.h"
#include "semphr.h"
-#pragma MESSAGE DISABLE C4002
-const char message[] = "This is a FreeRTOS test program. ";
-const char message2[] = "Semaphore work demonstration. ";
-const char charTable[] = "0123456789abcdef";
+void isrDefault7 (void);
+void testTask (void *);
+void testTask2 (void *);
+void pllConfig (void);
+const portCHAR message[] = "This is a FreeRTOS test program. ";
+const portCHAR message2[] = "Semaphore work demonstration. ";
+const portCHAR charTable[] = "0123456789abcdef";
xSemaphoreHandle xSemaphore;
-#pragma CODE_SEG NON_BANKED
-#pragma MESSAGE DISABLE C12053
-/* pay attention to _VECTOR section in PRM file */
-#pragma NO_EXIT
-__interrupt void isrDefault7(void)
vPortIsrHead();
/* do interrupt stuff… */
- vPortIsrTail();
+ vPortIsrTail();
-#pragma MESSAGE DEFAULT C12053
-#pragma CODE_SEG DEFAULT
-void testTask(void * p)
+void testTask (void * p)
static const char * strMsg = message;
static unsigned int count = 0;
@@ -38,11 +39,6 @@
(void) p;
- /* initialize SCI: baud rate = 115200 with bus clock 16MHz */
- SCI1CR1 = 0x00;
- SCI1CR2 = 0x0c;
- SCI1BD = 0x09;
while (cSemaphoreTake(xSemaphore, 100) != pdTRUE)
portYIELD();
@@ -50,8 +46,9 @@
for (;![:wink: :wink:](/images/emoji/twitter/wink.png?v=9)
- while (!SCI1SR1_TDRE)
+ while (!SCI1SR1 & TDRE)
+ // waiting for byte on SCI
portYIELD();
SCI1DRL = *strMsg;
@@ -60,10 +57,11 @@
if (*strMsg == ‘\0’)
- sprintf(msg, "0x%04x\r", count);
+ strcpy(msg, ", So ha\r");
+// sprintf(msg, "0x%04x\r", count);
for (strMsg = msg; *strMsg > 0; strMsg++)
portYIELD();
@@ -83,7 +81,7 @@
-void testTask2(void * p)
+void testTask2 (void * p)
static const char * strMsg = message2;
static unsigned int count;
@@ -91,11 +89,6 @@
(void) p;
- SCI1CR1 = 0x00;
- SCI1CR2 = 0x0c;
- SCI1BD = 0x09;
portYIELD();
@@ -103,7 +96,7 @@
portYIELD();
@@ -112,10 +105,11 @@
strMsg++;
- sprintf(msg, “0x%04x\r”, count);
+ strcpy(msg, “, So there\r”);
+// sprintf(msg, “0x%04x\r”, count);
portYIELD();
@@ -135,24 +129,26 @@
-void pllConfig(void)
+void sciConfig ()
- SYNR = 0x07;
- REFDV = 0x01;
- while (!CRGFLG_LOCK);
- PLLCTL_AUTO = 1;
- CLKSEL_PLLSEL = 1;
+ /* initialize SCI1: baud rate = 9615 with bus clock 24MHz */
+ SCI1CR1 = 0x00;
+ SCI1CR2 = 0x0c;
+ SCI1BD = 0x009c;
-void main(void)
+int main (void)
xTaskHandle xHandle;
- pllConfig();
+ sciConfig();
vSemaphoreCreateBinary(xSemaphore);
(void) sTaskCreate(testTask, "test", 100, NULL, tskIDLE_PRIORITY, &xHandle);
(void) sTaskCreate(testTask2, "test2", 100, NULL, tskIDLE_PRIORITY, &xHandle);
vTaskStartScheduler(portUSE_PREEMPTION);
+ return 0; // never does
