antheri9 wrote on Sunday, September 27, 2015:
Im developing some applicatnion whitch must use FreeRTOS and sample 2 channels ADC. I decided to use DMA mechanism for easier data preparation. Code is fully generated from ST CubeMx and just without FreeRTOS works fine.
Here is same topic but there is no answer:
here
I created few task to refresh LCD, read Touchscreen state and some more… DMA works once and then processor do not goes into DMA interrupt and do not refresh buffer. I have no more ideas. I think FreeRTOS is bad configured for DMA and thats the reason of this behaviour.
Can you help?
#include "stm32f4xx_hal.h"
#include "cmsis_os.h"
/* USER CODE BEGIN Includes */
#include "stm32f429i_discovery_lcd.h"
#include "stm32f429i_discovery_ts.h"
#include "expander_mcp23s17.h"
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc3;
DMA_HandleTypeDef hdma_adc3;
DAC_HandleTypeDef hdac;
SPI_HandleTypeDef hspi4;
UART_HandleTypeDef huart5;
osThreadId defaultTaskHandle;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_ADC3_Init(void);
static void MX_DAC_Init(void);
static void MX_SPI4_Init(void);
static void MX_UART5_Init(void);
void StartDefaultTask(void const * argument);
/* USER CODE BEGIN PFP */
osThreadId ScreenTaskHandle;
osThreadId TouchPanelTaskHandle;
void ScreenTask(void const * argument);
void TouchPanelTask (void const * argument);
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
TS_StateTypeDef touch;
uint32_t g_ADCBuffer[2];
/* USER CODE END 0 */
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC3_Init();
//MX_DAC_Init();
MX_SPI4_Init();
MX_UART5_Init();
/* USER CODE BEGIN 2 */
HAL_ADC_Start_DMA(&hadc3, g_ADCBuffer, 2);
/* USER CODE END 2 */
/* USER CODE BEGIN RTOS_MUTEX */
/* add mutexes, ... */
/* USER CODE END RTOS_MUTEX */
/* USER CODE BEGIN RTOS_SEMAPHORES */
/* add semaphores, ... */
/* USER CODE END RTOS_SEMAPHORES */
/* USER CODE BEGIN RTOS_TIMERS */
/* start timers, add new ones, ... */
/* USER CODE END RTOS_TIMERS */
/* Create the thread(s) */
/* definition and creation of defaultTask */
osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128);
defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
/* USER CODE BEGIN RTOS_THREADS */
osThreadDef(ScreenTask, ScreenTask, osPriorityNormal, 0, 128);
ScreenTaskHandle = osThreadCreate(osThread(ScreenTask), NULL);
osThreadDef(TouchPanelTask, TouchPanelTask, osPriorityNormal, 0, 128);
TouchPanelTaskHandle = osThreadCreate(osThread(TouchPanelTask), NULL);
/* USER CODE END RTOS_THREADS */
/* USER CODE BEGIN RTOS_QUEUES */
/* add queues, ... */
/* USER CODE END RTOS_QUEUES */
/* Start scheduler */
osKernelStart();
/* We should never get here as control is now taken by the scheduler */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
/** System Clock Configuration
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
__PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 10;
RCC_OscInitStruct.PLL.PLLN = 210;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1
|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
PeriphClkInitStruct.PLLSAI.PLLSAIN = 120;
PeriphClkInitStruct.PLLSAI.PLLSAIR = 2;
PeriphClkInitStruct.PLLSAIDivR = RCC_PLLSAIDIVR_2;
HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* ADC3 init function */
ADC_ChannelConfTypeDef sConfig;
/**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc3.Instance = ADC3;
hadc3.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4;
hadc3.Init.Resolution = ADC_RESOLUTION12b;
hadc3.Init.ScanConvMode = ENABLE;
hadc3.Init.ContinuousConvMode = ENABLE;
hadc3.Init.DiscontinuousConvMode = DISABLE;
hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc3.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc3.Init.NbrOfConversion = 2;
hadc3.Init.DMAContinuousRequests = ENABLE;
hadc3.Init.EOCSelection = EOC_SINGLE_CONV;
HAL_ADC_Init(&hadc3);
/**Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_144CYCLES;
HAL_ADC_ConfigChannel(&hadc3, &sConfig);
sConfig.Channel = ADC_CHANNEL_13;
sConfig.Rank = 2;
HAL_ADC_MspInit(&hadc3);
/* DAC init function */
DAC_ChannelConfTypeDef sConfig;
/**DAC Initialization
hdac.Instance = DAC;
HAL_DAC_Init(&hdac);
/**DAC channel OUT2 config
sConfig.DAC_Trigger = DAC_TRIGGER_NONE;
sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
HAL_DAC_ConfigChannel(&hdac, &sConfig, DAC_CHANNEL_2);
/* SPI4 init function */
hspi4.Instance = SPI4;
hspi4.Init.Mode = SPI_MODE_MASTER;
hspi4.Init.Direction = SPI_DIRECTION_2LINES;
hspi4.Init.DataSize = SPI_DATASIZE_8BIT;
hspi4.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi4.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi4.Init.NSS = SPI_NSS_SOFT;
hspi4.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
hspi4.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi4.Init.TIMode = SPI_TIMODE_DISABLED;
hspi4.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLED;
hspi4.Init.CRCPolynomial = 10;
HAL_SPI_Init(&hspi4);
HAL_SPI_MspInit(&hspi4);
/* UART5 init function */
huart5.Instance = UART5;
huart5.Init.BaudRate = 115200;
huart5.Init.WordLength = UART_WORDLENGTH_8B;
huart5.Init.StopBits = UART_STOPBITS_1;
huart5.Init.Parity = UART_PARITY_NONE;
huart5.Init.Mode = UART_MODE_TX_RX;
huart5.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart5.Init.OverSampling = UART_OVERSAMPLING_16;
HAL_UART_Init(&huart5);
HAL_UART_MspInit(&huart5);
* Enable DMA controller clock
/* DMA controller clock enable */
__DMA2_CLK_ENABLE();
/* DMA interrupt init */
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
/** Configure pins as
* Analog
* Input
* Output
* EVENT_OUT
* EXTI
GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO Ports Clock Enable */
__GPIOE_CLK_ENABLE();
__GPIOF_CLK_ENABLE();
__GPIOC_CLK_ENABLE();
__GPIOA_CLK_ENABLE();
__GPIOB_CLK_ENABLE();
__GPIOD_CLK_ENABLE();
__GPIOG_CLK_ENABLE();
/*Configure GPIO pins : PE3 PE4 */
GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FAST;
HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
/*Configure GPIO pin : PA0 */
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/*Configure GPIO pins : PG13 PG14 */
GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14;
GPIO_InitStruct.Pull = GPIO_PULLDOWN;
GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* ScreenTask function */
BSP_LCD_Init();
BSP_LCD_LayerDefaultInit(0, (uint32_t) LCD_FRAME_BUFFER);
BSP_LCD_SetLayerVisible(0, ENABLE);
BSP_LCD_SelectLayer(0);
BSP_LCD_Clear(LCD_COLOR_RED);
BSP_LCD_SetBackColor(LCD_COLOR_RED);
BSP_LCD_SetTextColor(LCD_COLOR_WHITE);
BSP_LCD_DisplayOn();
BSP_LCD_DisplayStringAtLine(1, (uint8_t *) "SAMPLE TEXT");
while(1)
osDelay(200);
/* TouchPanelTask function */
BSP_TS_Init(240, 320);
while(1)
BSP_TS_GetState(&touch);
osDelay(200);
/* USER CODE END 4 */
/* StartDefaultTask function */
/* USER CODE BEGIN 5 */
uint8_t start = 0;
uint8_t fr = 1;
Expander_MCP23s17_Set_Direction(&hspi4, GPIOE, GPIO_PIN_4, VoltageCard, 0, 0);
Expander_MCP23s17_Set_Direction(&hspi4, GPIOE, GPIO_PIN_4, VoltageCard, 0, 1);
Expander_MCP23s17_Set_Pin(&hspi4, GPIOE, GPIO_PIN_4, VoltageCard, 7, 0);
Expander_MCP23s17_Set_Pin(&hspi4, GPIOE, GPIO_PIN_4, VoltageCard, 6, 1);
for(;;)
uint8_t elo[10] = "";
HAL_UART_Transmit(&huart5, elo, sizeof(elo), 1);
sprintf(elo, "%i", g_ADCBuffer[0]);
BSP_LCD_DisplayStringAtLine(11, (uint8_t*)elo);
sprintf(elo, "%i", g_ADCBuffer[1]);
BSP_LCD_DisplayStringAtLine(12, (uint8_t*)elo);
osDelay(200);
HAL_GPIO_TogglePin(GPIOG, GPIO_PIN_14 | GPIO_PIN_13);
if(touch.TouchDetected) {
if((!start && touch.X >= 50 && touch.X <= 150 && touch.Y >= 200 && touch.Y <= 250) || fr) {
BSP_LCD_DrawRect(50, 50, 100, 50);
BSP_LCD_DisplayStringAt(60, 75, (uint8_t*) "BTN1", LEFT_MODE);
if(!fr)
BSP_LCD_DisplayStringAtLine(1, (uint8_t*)"BTN2 pressed");
start = 1;
fr = 0;
else if(start && touch.X >= 50 && touch.X <= 150 && touch.Y >= 50 && touch.Y <= 100){
BSP_LCD_DrawRect(50, 200, 100, 50);
BSP_LCD_DisplayStringAt(60, 210, (uint8_t*) "BTN2", LEFT_MODE);
BSP_LCD_DisplayStringAtLine(1, (uint8_t*)"BTN1 pressed");
start = 0;
/* USER CODE END 5 */
GeSHi
