I am working on a project that requires 3 channels of ADC1 and FreeRTOS.
I am using STM32F446RCT6.
I start ADC conversion at the start of the code
HAL_ADC_Start_IT(&hadc1);
Here is my implementation for ADC callback.
whereas array to hold data is described as:
volatile uint16_t ADC_raw[3] = {0};
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
if (__HAL_ADC_GET_FLAG(hadc, ADC_FLAG_EOC)) //if call to end of convesion
ADC_raw[counter] = HAL_ADC_GetValue(hadc); //ADC value stores in array
counter++;
if(counter>2) counter = 0;
Now,
When I do not implement RTOS and just runs normal code in while(1) loop, it works well and values for ADC_raw is updated correctly.
But when I enable RTOS and run the same code, the ADC callback is never getting called and thus ADC_raw values are always zero.
I can’t figure out what can be the issue. Any help would be greatly appreciated.
Here is my configuration for ADC, interrupt is enabled, DMA is not used.
