Quick question … I have to use FreeRTOS on a Cortex-M4 STM32f407ZG processor and the Keil compiler. Could somebody tell me which startup file .S I have to use for Keil? I checked one of the demos for IAR but it looks tailored for IAR only.
Thanks for any help in advance,
Regards,
Create a new project in Keil that targets the hardware you want to use. Then copy the start up files and linker script settings from that. You will have to populate the vector table with the FreeRTOS interrupt handlers, or add the following lines to FreeRTOSConifg.h (if they are not already there).
I really appreciate your help. I love this OS but I am missing some details about porting and setting this particular files. Actually I checked the demo CORTEX_M4F_STM32F407ZG-SK which is for the exactly the same board I use, but Keil as compiler this time. I will try to set it as you mentioned and get back to you in case I can not make it works.
For the time being, thanks.
