I have a task that is called out by an ISR, when i press a button. This task creates another task. When i press the second button, ISR calls a third task that uses vTaskDelete to delete the second task.
Now before I create the second task, im checking available stack size by calling xPortGetFreeHeapSize(). I’m calling it again just after vTaskDelete deletes the second task. And the numbers don’t match. Why is that? I thought all the memory should be freed after calling vTaskDelete. After few ISR’s I’m getting a stack overflow. I’m using heap_2.c
Do you mean unblocked by an ISR? I don’t know what called out means.
Again I don’t really understand what you mean in this sentence. Tasks should not be called by an ISR so I suspect I just don’t understand your terminology.
xPortGetFreeHeapSize() tells you the heap size, not the stack size.
When a task is deleted the heap memory that was allocated to the task is freed from inside the idle task (by default anyway). Therefore you would not expect the numbers to match until the idle task had executed at least one cycle.
