Is it on my responsibility to free all memory usage before delete the task (using vTaskDelete()) or it is done automatically by freeRTOS kernel ?
Is it on my responsibility to free all task stack and task TCB before delete the task (using vTaskDelete()) or it is done automatically by freeRTOS kernel ?
vTaskDelete will delete the task stack and TCB (either immediately if deleting another task, or deferred to the I(dle task if a task is deleting itself), assuming the task was created with dynamic memory (for a statically created task, vTaskDelete() will have FreeRTOS stop using that space, so it is now available to use to create another static task), All other resorces that the task has allocated need to be handled by your program, as FreeRTOS doesn’t know if they are still needed.
I recommend stepping through the very simple vTaskDelete() function in
the debugger, or simply just looking at the short piece of source code
that implements it, so you can see that Richard Damon’s clear answer is
correct and holds in all cases - you will be able to see see exactly
what the function does and does not do. FreeRTOS has no idea about any
memory you allocated from Newlib.
