ganix22 wrote on Monday, December 01, 2014:
I have a simple project for STM32L-Discovery board which uses FreeRTOS and I want to delete “Task 2” but it seems that memory is not freed after calling vTaskDelete(), even after replacing memory management scheme from heap_1.c to heap_2.c (I also tried heap_3.c and heap_4.c without success). I tried using debugger but there is no sign that vPortFree() is called anyway.
void Task_1(void* pvParameters){
  int i;
  unsigned portBASE_TYPE uxPriority;
  volatile size_t xHeapSize;
  uxPriority = uxTaskPriorityGet(NULL);
  while(1){
    LED_1_ON();
    xHeapSize = xPortGetFreeHeapSize();
    // Create task
    xTaskCreate(Task_2, "Task 2", configMINIMAL_STACK_SIZE, NULL, uxPriority+1, &xTask2Handle);
    LED_1_OFF();
    for(i=0; i<0xAFFFF; ++i);
  // Delete current task
  vTaskDelete(NULL);
void Task_2(void* pvParameters){
  // Do something...
  vTaskDelete(NULL);
Some configs from FreeRTOSConfig.h:
#define configCPU_CLOCK_HZ						SystemCoreClock
#define configUSE_PREEMPTION					1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION	1
#define configUSE_IDLE_HOOK						1
#define configUSE_TICK_HOOK						1
#define configMAX_PRIORITIES					( 5 )
#define configMINIMAL_STACK_SIZE				( ( unsigned short ) 70 )
#define configTOTAL_HEAP_SIZE					( ( size_t ) ( 14 * 1024 ) )
#define configMAX_TASK_NAME_LEN					( 16 )
#define configUSE_TRACE_FACILITY				1
#define configUSE_16_BIT_TICKS					0
#define configIDLE_SHOULD_YIELD					1
#define configUSE_MUTEXES						1
#define configQUEUE_REGISTRY_SIZE				5
#define configCHECK_FOR_STACK_OVERFLOW			2
#define configUSE_RECURSIVE_MUTEXES				1
#define configUSE_MALLOC_FAILED_HOOK			1
#define configUSE_APPLICATION_TASK_TAG			0
#define configUSE_COUNTING_SEMAPHORES			1
/* Software timer related definitions. */
#define configTIMER_TASK_PRIORITY				( configMAX_PRIORITIES - 1 )
#define configTIMER_QUEUE_LENGTH				10
#define configTIMER_TASK_STACK_DEPTH			configMINIMAL_STACK_SIZE
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES 			0
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet		1
#define INCLUDE_uxTaskPriorityGet		1
#define INCLUDE_vTaskDelete				1
#define INCLUDE_vTaskCleanUpResources	0
#define INCLUDE_vTaskSuspend			1
#define INCLUDE_vTaskDelayUntil			1
#define INCLUDE_vTaskDelay				1
