stolzie wrote on Tuesday, June 23, 2015:
I have been thrown into the deep end and have been given a project by an engineer that has since left the company. So I have no one to bounce questions off. I am a total beginner to the whole RTOS environment and have no idea .
I am currently looking at implementing some more software timers to handle various timeouts and connections to an FTP Server.
One, one shot Timer all ready exists that sets a flag when the timer expires and this then sends a file to the server, the timer is then reset. This is timing is happening every hour. See code below
} xApplicationFTPSendTimeout = xTimerCreate("FTP Send Timer", // Just a text name, not used by the kernel.
((60 * 60 * 1000) msec), // The timer period.
pdFALSE, // The timers will not auto-reload themselves when they expire.
(void *) ApplicationFTPSendTimeout, // Assign each timer a unique id.
(tmrTIMER_CALLBACK) vApplicationTimerCallback // Timer callback when it expires.
if(xApplicationFTPSendTimeout == NULL)
// The timer was not created.
LOG("Timer Not Initialized...\n\r");
tmrTIMER_CALLBACK vApplicationTimerCallback(xTimerHandle pxTimer)
long lArrayIndex;
// Optionally do something if the pxTimer parameter is NULL.
configASSERT(pxTimer);
// Which timer expired? */
lArrayIndex = (long) pvTimerGetTimerID(pxTimer);
// If the timer has expired stop it from running.
// Do not use a block time if calling a timer API function from a
// timer callback function, as doing so could cause a deadlock!
xTimerStop(pxTimer, 0);
if(lArrayIndex == ApplicationFTPSendTimeout) stApplication.bits.APPLICATION_FTP_SEND_TIMEOUT = TRUE;
If I wanted to implement another timer to check the FTP server say every 10 minutes, I gather that I would need to create another Timer using the xTimerCreate and create another callback function for this new timer? Or can I create this new timer and use the same callback as the previous timer?
Thanks for your time.
