The functionality to have an array of timers is extremely valuable. However the example posted in timers.h has an error.
The original contains the following code to create a timer. This will attempt to create a timer with a tick period of 0, which will generate an error.
for( x = 0; x < NUM_TIMERS; x++ )
xTimers[ x ] = xTimerCreate( "Timer", // Just a text name, not used by the kernel.
( 100 * x ), // The timer period in ticks.
pdTRUE, // The timers will auto-reload themselves when they expire.
( void * ) x, // Assign each timer a unique id equal to its array index.
vTimerCallback // Each timer calls the same callback when it expires.
The code should be
( 100 * (x+1) ), // The timer period in ticks.
