spoorthymb wrote on Tuesday, April 04, 2017:
FreeRTOS software timer is not calling the callback function and the timer is not running.
dibosco wrote on Tuesday, April 04, 2017:
You’re going to have to give a lot more information than that. Along the lines of (but not limited to):
Which version of FreeRTOS, which processor, which IDE, is this something you built yourself, is it stock FreeRTOS, what have you already tried?
spoorthymb wrote on Wednesday, April 05, 2017:
Version is FreeRTOS - 9.0.0-1, Atmega 32U4 processor, Arduino IDE, I have used FreeRTOS manual as a reference to build the timer.
I have tried giving xTimerPeriod as 100/ portTICK_PERIOD_MS or just the delay in this case 100 and pdMS_TO_TICKS(100)
I tried using xTimerStart( xTimer,0 ) as shown below apart from the standard method given in freertos manual.
xTimer = xTimerCreate( “Timer1Min”,pdMS_TO_TICKS(5000),pdTRUE, (void*) 0,prvTimerCallback);
if( xTimer != NULL )
xTimerStart( xTimer,0 );
heinbali01 wrote on Wednesday, April 05, 2017:
Is the scheduler started?
Can you confirm that your own tasks are running?
And is the timer-task (“Tmr Svc”) running?
Are all of your tasks blocking (sleeping) from time to time? If some task consumes all CPU time, the timer-task won’t get a chance to do its work. Regards.
yeah scheduler is started. ihave given vTashScheduler() after the timer creation. All of my tasks are working according to their functionality.
How to check whether all of my tasks are blocking time to time??
what is “Tmt Svc”?? i have not created any task with that name
If you would do a grep on the string “Tmr Svc”, you would see this line in timers.c :
xReturn = xTaskCreate( prvTimerTask,
"Tmr Svc",
configTIMER_TASK_STACK_DEPTH,
NULL,
( ( UBaseType_t ) configTIMER_TASK_PRIORITY ) | portPRIVILEGE_BIT,
&xTimerTaskHandle );
This task will be created automatically if configUSE_TIMERS = 1
This is an example of a non-blocking task:
void vMyTask( void *pvParameters )
/* This task will not allow any other task to become active, except
for tasks that have a higher priority than this one. */
volatile int counter = 0;
for( ;; )
counter++;
A task can block (sleep) in many different ways, while waiting for a notification, an event group, a queue, a semaphore, and also while calling vTaskDelay() :
const TickType_t xTimeTicks = pdMS_TO_TICKS( 1000 );
for( ;; )
/* Sleep for 1000 ms. */
vTaskDelay( xTimeTicks );
counter++;
spoorthymb wrote on Thursday, April 06, 2017:
My configUSE_TIMERS = 1, then my timer task will be created. still the callback function is not executed. with reference to ur explaination my tasks are not held up in blocked state.
PS: I am using Semaphore scheduling technique in my task. will it hinder the timer creation process.
heinbali01 wrote on Thursday, April 06, 2017:
Would you mind sharing some of your code? It is difficult to assess from a distance why your timer-function wouldn’t be called. The easiest is to attach a ZIP file with the project you’re working on.
I have attaached some part of my code becoz of confidentiality issue with the company. Hope u can help me out with the timers
rtimenoob wrote on Thursday, April 06, 2017:
I did not watch your zip file but have you checked your configTIMER_TASK_PRIORITY? Maybe it is set too low.
hi,
this is my configTIMER_TASK_PRIORITY
#####define configTIMER_TASK_PRIORITY ( ( UBaseType_t ) 3 )
Maybe your timer is just starving because its priority is too low.
Maybe you could try it with this:
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
okay… i will replace this and let you know about the updates
Your project will start 4 tasks:
Prio-1 : The task TaskScanSwitch() is never blocking.
Prio-1 : The task TaskSerial() is not blocking, unless Serial::available() blocks, which I don’t think.
Prio-3 : The task TaskProcessSwitch() blocks in a call to xSemaphoreTake().
Prio-1 : The task TaskSerialConsole() blocks in a call to xSemaphoreTake().
With ‘blocking’ I mean ‘sleeping’, or refrain from using the CPU so that other tasks get a chance to run.
In some embedded RTOS projects, you will find a task that never blocks. It is given the lowest priority, often the “idle priority” ( tskIDLE_PRIORITY ), in order to give priority to all other tasks.
But it is more usual to let each task sleep ( block ) on a semaphore or any other blocking API. Especially when low power consumption becomes important.
I’m not sure if it is OK to call xTimerCreate() and xTimerStart() before the scheduler is started. Try to call these from within any of the running tasks.
There is a lot of excellent documentation about FreeRTOS, e.g. have a look here.
The following items might be interesting to read about:
● Tasks and priorities
● Pre-emption
● Queues, Semaphores, and (recursive) Mutexes
● Task notification
● Event groups
I’m not sure what platform you’re using, but the easiest platform is probably the Windows simulation. You don’t need any special hardware for that.
Regards
spoorthymb wrote on Monday, April 10, 2017:
I made the changes as said by you, it didnt work
heinbali01 wrote on Monday, April 10, 2017:
Does it work already? Did you find the problem?
spoorthymb wrote on Tuesday, April 11, 2017:
no it didnt, platform i am using is windows platform for simulation
heinbali01 wrote on Tuesday, April 11, 2017:
If you’re able to pack (ZIP) your complete project, and attach it to a message, I could look at it and try it out. Regards.
