jarielmar wrote on Monday, February 09, 2009:
I want to use a soft interrupt on PIC32 with FreeRTOS. But when I adds it the soft interrupt handler, the kernal crash, even without the interrupt be enable.
I know that the soft interrupt handler is right, because I tested it on a short program without FreeRTOS and worked perfectly.
This is the handler.
void __ISR(_CORE_SOFTWARE_0_VECTOR, ipl2) Soft0Interrupcion(void)
IFS0bits.CS0IF = 0;
// INTClearFlag(INT_CS0);
mPORTAToggleBits(BIT_2);
I know that the program go into the soft interrupt handler only once (there is a toggle led inside).
When I says that the kernal crash I mean that it never go into a context switch any more, although the tick interrupt is working.
Any idea?. Thank you.
