kg4ysn wrote on Tuesday, September 16, 2008:
Hey all,
I posted a message the other day regarding problems with the PIC32 and the MPLAB SIM environment. As I poked around some more, it turns out that the problem may be more involved.
Within a single time slice, prvIdleTask performs as expected – the PC works down through the function to vApplicationIdleHook and then loops. I was able to confirm this by toggling some GPIO pins and watching them with an oscilloscope.
During the evaluation of line 1699 in tasks.c, a “sltiu v0,v0,2” instruction is issued. The next command should be “bne v0,zero,0x9d0014f4.” However, the PC instead jumps to 9FC0_1200, which is the location for portSAVE_CONTEXT from ISR_Support.h. So I’m guessing that some kind of timer triggered off an asynchronous event, and we’re now entering vTaskSwitchContext.
vTaskSwitchContext processes through, and as portRESTORE_CONTEXT is called, we end with our "ERET" instruction at 9D00_4B78. But instead of jumping back to where we were at 9D00_14F4, we jump right back to portSAVE_CONTEXT and begin the process anew. This continues ad infinium, causing the simulator to crash (due to a spurious error related to "sd ra,-1(ra)" being processed as NOP) and the real PIC32 board to hang.
The full contents of FreeRTOSConfig.h are below. Anyone have an idea on how to solve this one? Is this a bug in v5.0.3, or is it a user error?
Thanks,
Chris
#define configUSE_IDLE_HOOK 1
#define configUSE_TICK_HOOK 0
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configCPU_CLOCK_HZ ( ( unsigned portLONG ) 80000000UL )
#define configPERIPHERAL_CLOCK_HZ ( ( unsigned portLONG ) 40000000UL )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 5 )
#define configMINIMAL_STACK_SIZE ( 400 )
#define configISR_STACK_SIZE ( 500 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) 28000 )
#define configMAX_TASK_NAME_LEN ( 8 )
#define configUSE_TRACE_FACILITY 0
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 0
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define configKERNEL_INTERRUPT_PRIORITY 0x01
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 0x03
