Take a look at the SAM7S demo for IAR. This includes a UART example but uses the IAR syntax. You need to convert this to the syntax required by GCC. There are examples of how to write FreeRTOS friendly ISRs in the lwIP demo, for example the EMAC driver and USB driver. Also take a look at the LPC2106 documentation page on the FreeRTOS web site which describes how to write ISRs.
Thanks !
I added the serial.c and serialISR.c task and it has been working successfully.
The Web Server task and USB task has been removed for it will not be required for my application.
I have also making the communication between my Serial port with my GSM modem (AT command) in Normal mode (no handshaking) and it is working OK so far. However, I am anticipating that i will need my serial to work in Modem or at least Hardware Handshaking mode to have a reliable communication with the Modem.
Any idea or any example on how to set up the serial and serialISR in Hardware Handshaking Mode (HWHSH) or modem mode?
