nobody wrote on Monday, September 04, 2006:
Please… Send me serial source file and AT91SAM7X256-EK GCC port files.
my e-mail : xpeedholic@hotmail.com
#include "Board.h"
#include "commd.h"
//------------------------------------------------------------------ zamiast comm.c -------------------------------------------- dodalem commd_…
//static xSemaphoreHandle debug_sem;
static char comm_initialized[3] = {0, 0, 0};
void commd_init(int port, int baud) {
switch (port) {
case USART0:
*AT91C_PIOA_PDR = AT91C_PA5_RXD0 | /* Enable RxD0 Pin */
AT91C_PA6_TXD0; /* Enable TxD0 Pin */
AT91C_BASE_US0->US_CR = AT91C_US_RSTRX | /* Reset Receiver */
AT91C_US_RSTTX | /* Reset Transmitter */
AT91C_US_RXDIS | /* Receiver Disable */
AT91C_US_TXDIS; /* Transmitter Disable */
AT91C_BASE_US0->US_MR = AT91C_US_USMODE_NORMAL | /* Normal Mode */
AT91C_US_CLKS_CLOCK | /* Clock = MCK */
AT91C_US_CHRL_8_BITS | /* 8-bit Data */
AT91C_US_PAR_NONE | /* No Parity */
AT91C_US_NBSTOP_1_BIT; /* 1 Stop Bit */
AT91C_BASE_US0->US_BRGR = MCK / 16 / baud; /* Baud Rate Divisor */
AT91C_BASE_US0->US_CR = AT91C_US_RXEN | /* Receiver Enable */
AT91C_US_TXEN; /* Transmitter Enable */
comm_initialized[port] = 1;
break;
case USART1:
*AT91C_PIOA_PDR = AT91C_PA21_RXD1 | /* Enable RxD1 Pin */
AT91C_PA22_TXD1; /* Enable TxD1 Pin */
AT91C_BASE_US1->US_CR = AT91C_US_RSTRX | /* Reset Receiver */
AT91C_BASE_US1->US_MR = AT91C_US_USMODE_NORMAL | /* Normal Mode */
AT91C_BASE_US1->US_BRGR = MCK / 16 / baud; /* Baud Rate Divisor */
AT91C_BASE_US1->US_CR = AT91C_US_RXEN | /* Receiver Enable */
break;
case DUSART:
*AT91C_PIOA_PDR = AT91C_PA9_DRXD | /* Enable RxD1 Pin */
AT91C_PA10_DTXD; /* Enable TxD1 Pin */
AT91C_BASE_DBGU->DBGU_CR = AT91C_US_RSTRX | /* Reset Receiver */
AT91C_BASE_DBGU->DBGU_MR = AT91C_US_USMODE_NORMAL | /* Normal Mode */
AT91C_BASE_DBGU->DBGU_BRGR = MCK / 16 / baud; /* Baud Rate Divisor */
AT91C_BASE_DBGU->DBGU_CR = AT91C_US_RXEN | /* Receiver Enable */
break;
default:
break;
int commd_putc(int port,int ch) {
if (!comm_initialized[port]) return -3;
switch (port) {
case USART0:
while (!(AT91C_BASE_US0->US_CSR & AT91C_US_TXRDY)); /* Wait for Empty Tx Buffer */
return (AT91C_BASE_US0->US_THR = ch); /* Transmit Character */
case USART1:
while (!(AT91C_BASE_US1->US_CSR & AT91C_US_TXRDY)); /* Wait for Empty Tx Buffer */
return (AT91C_BASE_US1->US_THR = ch); /* Transmit Character */
case DUSART:
while (!(AT91C_BASE_DBGU->DBGU_CSR & AT91C_US_TXRDY)); /* Wait for Empty Tx Buffer */
AT91C_BASE_DBGU->DBGU_THR = ch; /* Transmit Character */
return ch;
default:
break;
return -1;
int commd_puts( int port, char* buff) {
while(*buff) {
if (*buff == ‘\n’) commd_putc(port, ‘\r’);
commd_putc(port, *buff++);
return 0;
int commd_getc (int port) {
switch (port) {
case USART0:
while (!(AT91C_BASE_US0->US_CSR & AT91C_US_RXRDY)); /* Wait for Full Rx Buffer */
return (AT91C_BASE_US0->US_RHR); /* Read Character */
case USART1:
while (!(AT91C_BASE_US1->US_CSR & AT91C_US_RXRDY)); /* Wait for Full Rx Buffer */
return (AT91C_BASE_US1->US_RHR); /* Read Character */
case DUSART:
while (!(AT91C_BASE_DBGU->DBGU_CSR & AT91C_US_RXRDY)); /* Wait for Full Rx Buffer */
return (AT91C_BASE_DBGU->DBGU_RHR); /* Read Character */
default:
break;
return -1;
int commd_is_rx_empty(int port) {
switch (port) {
case USART0:
return (!(AT91C_BASE_US0->US_CSR & AT91C_US_RXRDY)); /* Full Rx Buffer */
case USART1:
return (!(AT91C_BASE_US1->US_CSR & AT91C_US_RXRDY)); /* Full Rx Buffer */
case DUSART:
return (!(AT91C_BASE_DBGU->DBGU_CSR & AT91C_US_RXRDY)); /* Full Rx Buffer */
default:
break;
return -1;
//------------------------------------------------------------------------------------------------------- PRINTF -------------------------------------------
#include <stdio.h> /* I/O Functions */
#include <stdarg.h>
#include "FreeRTOS.h"
#include "semphr.h"
static xSemaphoreHandle printf_sem;
void kprintf_init() {
vSemaphoreCreateBinary( printf_sem );
while (printf_sem == NULL); //halt if failed
void kprintfFromISR(const char *format,…) {
static char buf[100];
va_list ap;
va_start(ap, format);
vsnprintf(buf, sizeof(buf), format, ap); //viprintf() - without floating numbers. %f…
va_end(ap);
commd_puts(DBG_DEV, buf);
//comm_puts(DBG_DEV, buf);
void kprintf(const char *format,…) {
va_list ap;
va_end(ap);
while (!xSemaphoreTake(printf_sem, 100)); //block
xSemaphoreGive(printf_sem); //unblock
void ppp_trace(int level, const char *format,…) { // ppp debug
va_list ap;
va_end(ap);
Janusz
nobody wrote on Tuesday, September 05, 2006:
Thank you…
I have tested your source code. Mr Janusz
But It didn’t work.
Can you send all project files related with serial to me?
Best Regards.
