Recently I am working on the SWO interface of SAM4S Xplained board (Not Xplained Pro). I am running FreeRTOS on this board and trying to work with the integrated Trace tool available in Atmel Studio 6.2. However, I am unable to start the trace recorder after clock initialization because an error message pops up indicating that the connected emulator does not support SWO. I have double checked it on the web documents available for SAM4S Xplained at this link
The message that I am getting is that the emulator does not support SWO output, however I have checked it in the documents on SAM4S Xplained and it clearly indicates that the OB J-Link available on SAM4S Xplained supports SWO Interface. I am using SWD to program the board but still it shows the same message.
It appears as the J-Link version used on the SAM4S Xplained support SWD but not SWO. We have the same issue with this board. If running Seggers own tool J-Link Commander and trying the command “SWOStat” you also get a similar error message, so it is not just Atmel Studio…
