I am running RTOS Demo on RX63N .RTOS is working and LEDs are blinking but when comes to vuIP_Task , it is coming at below instructions again and again:
Have you stepped through the lEMACWaitForLink() function to see what it
is doing? As far as I can see all it is doing is calling
phy_set_autonegotiate(), which is a Renesas library fucntion, and the
function is failing. Therefore your network initialisation is failing -
which could be a cabling problem, or perhaps your hardware has a
different PHY to the hardware on which the demo was created.
[the demo you are using is making use of uIP - all the demos we create
these days use our own TCP/IP stack called FreeRTOS+TCP. See http://www.freertos.org/tcp ]
Actually I am using RX62N RDK but FreeRTOSV9.0.0rc1\FreeRTOSV9.0.0rc1\FreeRTOS\Demo\RX600_RX62N-RDK_Renesas
demo is giving compiler not found error on HEW IDE.
so i had tried RX63N demo.
I had also tried a demo without FreeRTOS which runs uIP stack on RX62N . I see same ethernet phy driver is being used with FreeRTOS demo.
While developing demo on RX62N and RX63N , did you see any difference in ethernet phy driver in RX62N and RX63N RDK?
