I am getting issue while Porting FreeRTOS Demo of MicroBlaze_Spartan-6_EthernetLite Application on virtex-6 Boaard.
(1) Board Target is not ping while using Board IP 192.168.0.200 from PC.Ping from PC Error comes console DegsinationHost unreachable.
(2)RX and TX task in main-full.c.TX is working.RX task always in ready state.XCreate Timer API fails to call second task.What Need to change in the code for Porting LWIP Application on Virex-6 Board.
Please guide me what need to change in FreeRTOS Demo of MicroBlaze_Spartan-6_EthernetLite Demo. I need to be Ported on FreeRTOS on Virtex-6 FPGA Boards I am New User of FreeRTOS…
The Virtex 6 port is not a port to the FPGA, but a port to the Microblaze, the FPGA that the Microblaze is running on should not make any difference.
There are other variables though. For a start, the Microblaze is itself configurable, and there is more than one option for the IP used by the MAC. If you are using the exact same Microblaze configuration, and the exact same MAC IP, and your interconnections are the same, then there should not be any porting to do as far as I am aware. If your hardware design is different (the design running on the FPGA, not the FPGA itself) then you will have ensure that is correct before attempting to add FreeRTOS to it.
As you have Tx working, then the hardware design must be at least partially correct, so I would recommend debugging from the MAC interrupt to see if any Rx interrupts are received, and if they are received, what happens to the data that is received. I think you are a long way from determining that FreeRTOS has anything to do with your connectivity.
