I’m trying to run the Web server demo for the AT91SAM7X-EK board, using Rowley CrossStudio 1.7 and a Segger J-Link. Not much luck so far. Has anybody tried this with the latest releases of CrossStudio and the Web server demo?
During downloading, it says that it cannot stop the cpu. I’ve tried lowering the JTAG clock frequency (down to 1 kHz) but to no avail.
I have installed the CrossConnect Lite from Rowley, instead of the Segger J-Link, and now it downloads fine, and everything works fine now: blinkenlights, web server and USB.
Seems to be a J-Link issue. Take a look in your preprocessor definitions for the solution (or is it at the project level?) to see if STARTUP_FROM_RESET is defined. You might like to look for this definition in the manual and startup code to see if the way it is used has changed in 1.7.
To get the demo to work I used the AT91SAM7_Target.js supplied with crossworks and in the project-properties set the configuration to "common" and then selected the AT91SAM7_Target.js file and set it "file type" to "reset script". And of course select the target to connect jlink.
