I am having trouble getting the project to work Eclipse.
During the process I have found a couple of things.
1 - The Signalyzer installation will not build the project. The errors involve _sbrk. Or someithing like that. There are many threads saying browse the forum but the upshot is you need to use the Yugarto configuration to be able to build the project from the command line.
2 - The examples at the Yagarto site don’t agree with the latest version of Eclipse so you need to poke around to find some of the equivalent screens. I was able to build and debug one of the examples with some effort.
3 - It appears none of the FreeRTOS project lableled as Eclipse will build from Eclipse as the managed make file is missing. I’m not sure if this is intended.
Does anyone have a suggestion?
I will try to follow the same approach as with the Yagarto code although the start of setting up a project is very broken relative to the example.
The FreeRTOS.org projects do not use the managed make utility. A makefile is supplied with each demo project, which can be built from within the Eclipse framework.
I understand the makefile is there, and from the command prompt, I can build the project.
However when I select the project directory from Eclipse per the example, it complains the managed makefile is missing.
Sorry to be dense but it’s not clear to me anyway how to select and build the project from eclipse using the existing makefile. When I tried following instructions for another non-freertos example, I was successful.
Using the same instructions with the freertos example left me with modified project files and I still couldn’t build the project.
I don’t know whether I’m in a completely different universe but…
When I load the project, there are no files loaded. It won’t clean build or do anything useful.
It would sure help if rather than having the project with a broken project file, to provide the flow used to create the project file in the first place.
For a newbie, the learning curve is past vertical while the people working on the project and with eclipse/OpenOCD have learned things incrementally.
Further, due to the portable structures used in FreeRTOS, and the special setup is seems to require to work with Eclipse reverse engineering this is daunting to say the least.
I’m pretty stubborn but still can’t get it loading in a board properly.
It seems like all the eclipse examples are similarily broken for the currently available Eclipse.
Any thoughts, suggestions???
Looking at it logically, other people are using the projects. You find you cannot open any of the projects. Does this lead to the conclusion that all the projects are broken, or that there is something in your setup that is broken?
Did you set the FREERTOS_ROOT variable in the project before attempting to build? If you attempt to build the project prior to setting this variable then the files will disappear from the Eclipse project view. Odd behavior of Eclipse unfortunately.
Your right. Is everone out of step or is it just me?
Well thats where I was hoping to get some help.
I don’t know what I can do beyond following the instructions at FreeRTOS.
When I do this, Eclipse complains the managed make file is missing and doesn’t load the configuration properly.
Yes I did set the FREERTOS_ROOT variable but when there is no information to do anything, clean, make or otherwise the variable is useless.
There is no managed make project, it uses a standard makefile. You can build the makefile from either within Eclipse or outside of Eclipse (just type “make” from the command line as normal). I don’t know why Eclipse would look for a managed make file I have never received that warning. Are you using the Europa version of Eclipse?
I had that same managed make error when using the Fedora core provided version of eclipse under Linux. When I downloaded the current version from http://www.eclipse.org/ it solved that problem. On the about screen what version does eclipse say it is?
That did the trick.
So it seems the package from Signalyzer can’t build the project and the Yagarto IDE version has issues as well.
Guess it was my bad for trying to mix things.
