I’m using Eclipse to compile FreeRTOS demo application for ARM7 and Eclipse (ARM7_AT91SAM7X256_Eclipse) but when I build it one error occur:
cc1.exe: error: unrecognized command line option “-fno-dwarf2-cfi-asm”
I tried to comment the -fno-dwarf2-cfi-asm CFLAGS and it works, compile without errors. But I don’t know if I can do this. When I try Run the demo using the OpenOCD Programmer a message appears saying:
terminate, exit value: -1073741515
Can any one help me with configuring the eclipse. I tried to follow the FreeRTOS instructions but it doesn’t work.
edwards3 I tried to use google translator and it works well. But I’m using OLIMEX AMR-USB-OCD and SAM7-EX256 Olimex development board (AT91SAM7X256 ARM7TDMI-S MICROCONTROLLER) that is different from the Cortex M4 that you use, and the tollchain seems to be different.
I need the FreeRTOS to complete one school project, that I need the arm board connected to internet via ethernet, and FreeRTOS.
Can anybody help me configuring eclipse for FreeRTOS and OLIMEX development board?
