I have a problem with the demo example “CORTEX_STM32F107_GCC_Rowley” (7.1.1 version). I have no problem with building and launch the demo on my STM3210C-EVAL board, the LCD displays “www.freertos.org”, the IP of the web server and the status. However, when I ping the web server, it doesn’t work at all. My network configuration is okay. I am convinced it comes from the demo. Everyone already encountered this problem and figured out how to solve it ?
Have you configured a MAC address that is compatible with the computer from which the pings are originating?
Is the network initialising correctly? Put a break point on the line while( xEthInitialise() != pdPASS ) in webserver/uIP_Task.c to see if the loop is ever exited.
If so, put a break point in the function vMAC_ISR() in the file webserver/emac.c, is the break point ever hit?
If so, is data ever received in the handler? (if it is the line xSemaphoreGiveFromISR( xEMACSemaphore, &xHigherPriorityTaskWoken ); will be executed.
If so, is the line if( ( uip_len > 0 ) && ( uip_buf != NULL ) ) ever passing in uIP_Task.c so pass the received data into the uip stack?
Thank you very much for your help.
Hmmm stupid question, how should the MAC address be configured?
For the rest, yes, my network is initialising correctly and I am hitting all the breakpoints you mentionned…
In a real system the MAC address would come from ROM somewhere, as each has to be unique. In test systems the MAC address is just fixed in the C code, but still has to be unique on the network, so connecting two boards to the same network requires two separate configurations.
In your demo the MAC address is defined by the constants:
If data is being received, as it seems it is, the next thing to do would be to follow the packet through the uIP stack using the debugger to see if it gets dropped somewhere (in which case you will see why) or if it generated some output.
Do you have Wireshark connected so you can see the traffic going back and forth?
ok now ping works but when I type the IP address in my browser, the index page doesn’t load… Any suggestion? (I checked the fsdata.c, httpd.c, everything is okay, when I debug and try to access the page in my browser, I reach “fs_opent(file_index_html.name,&file)” so it should work…) Thank you
