I use Keil and LM3S8962 board and I compiled FreeRTOS+uIP examples \\FreeRTOSV6.1.0\Demo\CORTEX_LM3Sxxxx_IAR_Keil\*.* .
I set the right IP address but I don’t received any response at ping command and also I don’t see any activity from board when I used a network analyzer.
Are you using a cross over cable?
Are you going through a router?
Is the rest of the application running ok?
What is the IP address or the target and the machine you are pinging from?
What is the MAC address you are using on the target?
1)Yes I use a cross cable when I connect the board to PC and normal when a use the router. But I don’t see any network activity. I have tested the board with another TCP/IP firmware and it is ok.
2)The rest application seem to be ok . On LCD it show all time PASS .
3)My PC IP is 192.168.1.24 and board IP is 192.168.1.25 .
I also set a custom MAC but again I don’t see any network activity.
pucMACArray = 0x00;
pucMACArray = 0xaa;
pucMACArray = 0x00;
pucMACArray = 0x62;
pucMACArray = 0xc6;
pucMACArray = 0x09;
At the top of main.c there is a constant mainINCLUDE_WEB_SERVER. By default it is set to 0. It needs to be set to 1 to include the TCP/IP stack. Have you set it to 1?
