I am using the Control Panel Demo for my EVK1100 board for the cpu : AVR32UC3A0512.
I am using AVR Studio with GCC which includes Software Framework 1.3 and FreeRTOS v4.7.2 for the example project.
The GCC compiler builds fine without warning but now my control panel demo hangs.
If I try to debug the demo it get stucks at the following module in the file macb.c
// wait for PHY to be ready
do {
status = macb->nsr;
} while (!(status & AVR32_MACB_NSR_IDLE_MASK));
Set xHigherPriorityTaskWoken to false before calling xSemaphoreGiveFromISR, then use its value after the function call to determine if a context switch is required. The return value is now a true or false as to whether the ‘give’ passed or not.
To upgrade the code you should be able to drop the Source directory from the latest FreeRTOS download into your project. Back up your original files first though!
I have tried to use the value of xHigherPriorityTaskWoken to determine if a context switch is required after I am calling xSemaphoreGiveFromISR, but still my application hangs at the same place. I have no idea why it is.
in port.c for freertos v4.7.2 the function prvSetupTimerInterrupt used to call on the following function : INTC_register_interrupt(&vTick, AVR32_CORE_COMPARE_IRQ, AVR32_INTC_INT0);
but in freertos v5.0.0 the function was called like this INTC_register_interrupt(&vTick, AVR32_CORE_COMPARE_IRQ, INT0);
I didnt have the INT0 defined anywhere, so I had to change it back like it was for the version 4.7.2. AVR32_INTC_INT0 I found defined as 0x00000000 in intc.h in my avr toolchain lib.
It feels like my application receives a strange interrupt somewhere, maybe this is why it occurs ?
