Porting FreeRTOS for Jailhouse Cell to x86_64 environment
sean6016 wrote on Sunday, March 06, 2016:
I’m trying to port the FreeRTOS cell for Jailhouse to x86_64 environment.
(https://github.com/siemens/freertos-cell)
Currently it can only be run on ARM systems.
Can anyone give me suggestion for what should be considered to achieve this goal?
As the document has mentioned, I should modify the serial interface access for x86 to construct a correct memory map, probably by creating a new file like this
(https://github.com/siemens/freertos-cell/blob/master/jailhouse-configs/bananapi.c) for x86.
But what more should be done?
Best regards,
Sean
rtel wrote on Monday, March 07, 2016:
Don’t know much about Jailhouse, but if you are using FreeRTOS on a 64-bit part then ensure you are using the latest FreeRTOS version as some changes were made to run on the Cortex-A53 in 64-bit mode.
