Hi Guys
I have simple question.
Has FreeRTOS kernel supprt AArch64?
I didn’t find whether support AArch64 from this FreeRTOS offcial-page.
Hi Guys
Yes, FreeRTOS can support AArch64.
Here is the port for the ARM Cortex-A53 64-bit processor: https://github.com/FreeRTOS/FreeRTOS-Kernel/tree/d43062ba7862f6c354ca414b411958ce12a7187f/portable/GCC/ARM_CA53_64_BIT
Thank you very much for prompt reply.
I will confirm it.
And in case you are using the newer version of GIC, you can use this port -https://github.com/FreeRTOS/FreeRTOS-Kernel/tree/V10.6.1/portable/GCC/ARM_CA53_64_BIT_SRE
Thank you very much for your information.
I will confirm it.
