rtel wrote on Monday, May 13, 2013:
Clicked Add Reply before I had finished!
The warnings in the previous post where left from when I tried this myself the first time you posted your question. Interesting as I had never seen this project. Below is the full build output I just regenerated now which might not be comprehensible but allow you to see the command line (which is not changed).
from …/Common/ethernet/openPOWERLINK/Include/Epl.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplApiProcessImage.c:71:
…/Common/ethernet/openPOWERLINK/Include/global.h:160: warning: extra tokens at end of #ifdef directive
…/Common/ethernet/openPOWERLINK/Include/global.h:656: warning: #warning “CORTEXM3 FREERTOS”
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c “->” Debug/EplDllk.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c -o Debug/EplDllk.o
In file included from ./EplCfg.h:74,
from …/Common/ethernet/openPOWERLINK/Include/EplInc.h:128,
from …/Common/ethernet/openPOWERLINK/Include/EplDll.h:75,
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplDllk.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:71:
In file included from …/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:85:
…/Common/ethernet/openPOWERLINK/Include/kernel/EplDllkTgt.h:108: warning: data definition has no type or storage class
…/Common/ethernet/openPOWERLINK/Include/kernel/EplDllkTgt.h:111: warning: data definition has no type or storage class
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:423: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:480: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkConfig’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:940: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkSetIdentity’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:991: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkProcessCreate’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:1661: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:1720: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkCbFrameTransmitted’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:4121: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:4142: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkCreateTxFrame’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:4737: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:4748: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c: In function ‘EplDllkCheckFrame’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllk.c:4905: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c “->” Debug/EplDllkCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c -o Debug/EplDllkCal.o
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplDllkCal.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c: In function ‘EplDllkCalAsyncGetTxFrame’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c:579: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c: In function ‘EplDllkCalAsyncSend’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c:700: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c:713: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplDllkCal.c:729: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c “->” Debug/EplDlluCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c -o Debug/EplDlluCal.o
…/Common/ethernet/openPOWERLINK/EplStack/EplErrorHandlerk.c “->” Debug/EplErrorHandlerk.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplErrorHandlerk.c -o Debug/EplErrorHandlerk.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplDlluCal.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c: In function ‘EplDlluCalAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c:183: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c: In function ‘EplDlluCalDelInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplDlluCal.c:208: warning: incompatible implicit declaration of built-in function ‘memset’
from …/Common/ethernet/openPOWERLINK/Include/EplEvent.h:75,
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplErrorHandlerk.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplErrorHandlerk.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplEventk.c “->” Debug/EplEventk.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplEventk.c -o Debug/EplEventk.o
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplEventk.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplEventk.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplEventk.c: In function ‘EplEventkPostError’:
…/Common/ethernet/openPOWERLINK/EplStack/EplEventk.c:777: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplEventk.c:782: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplEventu.c “->” Debug/EplEventu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplEventu.c -o Debug/EplEventu.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplEventu.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplEventu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplEventu.c: In function ‘EplEventuPostError’:
…/Common/ethernet/openPOWERLINK/EplStack/EplEventu.c:727: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplEventu.c:732: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c “->” Debug/EplIdentu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c -o Debug/EplIdentu.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplIdentu.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c: In function ‘EplIdentuAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c:205: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c: In function ‘EplIdentuReset’:
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c:282: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c: In function ‘EplIdentuCbIdentResponse’:
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c:481: warning: assignment makes pointer from integer without a cast
…/Common/ethernet/openPOWERLINK/EplStack/EplIdentu.c:493: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplLedu.c “->” Debug/EplLedu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplLedu.c -o Debug/EplLedu.o
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c “->” Debug/EplNmtCnu.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplLedu.c:71:
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c -o Debug/EplNmtCnu.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c: In function ‘EplNmtCnuAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c:174: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c: In function ‘EplNmtCnuSendNmtRequest’:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtCnu.c:254: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtk.c “->” Debug/EplNmtk.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplNmtk.c -o Debug/EplNmtk.o
from …/Common/ethernet/openPOWERLINK/Include/EplNmt.h:75,
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplNmtk.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplNmtk.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtk.c: In function ‘EplNmtkProcess’:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtk.c:1604: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtkCal.c “->” Debug/EplNmtkCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplNmtkCal.c -o Debug/EplNmtkCal.o
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplNmtkCal.h:76,
from …/Common/ethernet/openPOWERLINK/EplStack/EplNmtkCal.c:72:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtMnu.c “->” Debug/EplNmtMnu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplNmtMnu.c -o Debug/EplNmtMnu.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplNmtu.h:75,
from …/Common/ethernet/openPOWERLINK/Include/user/EplNmtMnu.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplNmtMnu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtu.c “->” Debug/EplNmtu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplNmtu.c -o Debug/EplNmtu.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplNmtu.c:72:
…/Common/ethernet/openPOWERLINK/EplStack/EplNmtuCal.c “->” Debug/EplNmtuCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplNmtuCal.c -o Debug/EplNmtuCal.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplNmtuCal.h:76,
from …/Common/ethernet/openPOWERLINK/EplStack/EplNmtuCal.c:72:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c “->” Debug/EplObd.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplObd.c -o Debug/EplObd.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplObd.c:72:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c: In function ‘EplObdAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c:297: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c: In function ‘EplObdReadEntry’:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c:496: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c: In function ‘EplObdReadEntryToLe’:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c:1252: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c: In function ‘EplObdWriteEntryPost’:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c:2366: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c: In function ‘EplObdCopyObjectData’:
…/Common/ethernet/openPOWERLINK/EplStack/EplObd.c:3462: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplObdkCal.c “->” Debug/EplObdkCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplObdkCal.c -o Debug/EplObdkCal.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplObdkCal.c:72:
…/Common/ethernet/openPOWERLINK/EplStack/EplObdu.c “->” Debug/EplObdu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplObdu.c -o Debug/EplObdu.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplObdu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplObduCal.c “->” Debug/EplObduCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplObduCal.c -o Debug/EplObduCal.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplObduCal.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c “->” Debug/EplPdok.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c -o Debug/EplPdok.o
from …/Common/ethernet/openPOWERLINK/Include/EplPdo.h:75,
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplPdok.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c: In function ‘EplPdokAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:202: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c: In function ‘EplPdokAlloc’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:315: warning: assignment makes pointer from integer without a cast
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:324: warning: assignment makes pointer from integer without a cast
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:362: warning: assignment makes pointer from integer without a cast
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:370: warning: assignment makes pointer from integer without a cast
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c: In function ‘EplPdokConfigureChannel’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:448: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:487: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c: In function ‘EplPdokCopyVarToPdo’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:769: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c: In function ‘EplPdokCopyVarFromPdo’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdok.c:894: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplPdokCal.c “->” Debug/EplPdokCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplPdokCal.c -o Debug/EplPdokCal.o
from …/Common/ethernet/openPOWERLINK/Include/kernel/EplPdokCal.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplPdokCal.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdouCal.c “->” Debug/EplPdouCal.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplPdouCal.c -o Debug/EplPdouCal.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplPdouCal.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplPdouCal.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c “->” Debug/EplPdou.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c -o Debug/EplPdou.o
from …/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c:75:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c: In function ‘EplPdouAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c:228: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c: In function ‘EplPdouAlloc’:
…/Common/ethernet/openPOWERLINK/EplStack/EplPdou.c:469: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsndu.c “->” Debug/EplSdoAsndu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsndu.c -o Debug/EplSdoAsndu.o
from …/Common/ethernet/openPOWERLINK/Include/EplSdo.h:75,
from …/Common/ethernet/openPOWERLINK/Include/user/EplSdoAsndu.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsndu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsndu.c: In function ‘EplSdoAsnduAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsndu.c:192: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c “->” Debug/EplSdoAsySequ.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c -o Debug/EplSdoAsySequ.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplSdoAsySequ.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c: In function ‘EplSdoAsySeqAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c:337: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c: In function ‘EplSdoAsySeqDelInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c:427: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c: In function ‘EplSdoAsySeqDelCon’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c:823: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c: In function ‘EplSdoAsySeqSendIntern’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c:1893: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c: In function ‘EplSdoAsyAddFrameToHistory’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoAsySequ.c:2197: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c “->” Debug/EplSdoComu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c -o Debug/EplSdoComu.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplSdoComu.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:340: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComUndefineCon’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:691: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComProcessIntern’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:1264: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:1338: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:1410: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComServerSendFrameIntern’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2045: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2130: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2157: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2188: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComServerInitWriteByIndex’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2467: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComClientSend’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2535: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2599: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2619: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2657: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2675: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComClientProcessFrame’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2831: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2864: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2886: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2907: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c: In function ‘EplSdoComClientSendAbort’:
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoComu.c:2966: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplSdoUdpu.c “->” Debug/EplSdoUdpu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplSdoUdpu.c -o Debug/EplSdoUdpu.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplSdoUdpu.h:76,
from …/Common/ethernet/openPOWERLINK/EplStack/EplSdoUdpu.c:72:
…/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c “->” Debug/EplStatusu.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c -o Debug/EplStatusu.o
from …/Common/ethernet/openPOWERLINK/Include/user/EplStatusu.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c:71:
…/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c: In function ‘EplStatusuAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c:204: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c: In function ‘EplStatusuReset’:
…/Common/ethernet/openPOWERLINK/EplStack/EplStatusu.c:268: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c “->” Debug/EplTimeruGeneric.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c -o Debug/EplTimeruGeneric.o
from …/Common/ethernet/openPOWERLINK/Include/EplTimer.h:75,
from …/Common/ethernet/openPOWERLINK/Include/user/EplTimeru.h:75,
from …/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c:73:
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c: In function ‘EplTimeruAddInstance’:
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c:212: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c:214: warning: assignment makes pointer from integer without a cast
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c: In function ‘EplTimeruProcess’:
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c:368: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c:372: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c: In function ‘EplTimeruSetTimerMs’:
…/Common/ethernet/openPOWERLINK/EplStack/EplTimeruGeneric.c:439: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c “->” Debug/EplApiFreeRTOS.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c -o Debug/EplApiFreeRTOS.o
from …/Common/ethernet/openPOWERLINK/Include/EplApiFreeRTOS.h:14,
from …/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c:1:
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c: In function ‘EplApiReadLocalObjectFreeRTOS’:
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c:27: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c: In function ‘EplApiWriteLocalObjectFreeRTOS’:
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c:56: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c: In function ‘EplApiReadObjectFreeRTOS’:
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c:89: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c: In function ‘EplApiWriteObjectFreeRTOS’:
…/Common/ethernet/openPOWERLINK/EplStack/EplApiFreeRTOS.c:125: warning: incompatible implicit declaration of built-in function ‘memcpy’
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/Objdict.c “->” Debug/Objdict.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/Objdict.c -o Debug/Objdict.o
from …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/Objdict.c:18:
In file included from …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:26,
from …/Common/ethernet/openPOWERLINK/Include/EplObjDef.h:144,
from …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/Objdict.c:22:
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:8: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:8: warning: (near initialization for ‘aObdSubEntry0x1000Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:13: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:13: warning: (near initialization for ‘aObdSubEntry0x1001Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:23: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:23: warning: (near initialization for ‘aObdSubEntry0x1006Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:28: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:28: warning: (near initialization for ‘aObdSubEntry0x1008Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:33: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:33: warning: (near initialization for ‘aObdSubEntry0x1009Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:38: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:38: warning: (near initialization for ‘aObdSubEntry0x100ARam_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:47: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:47: warning: (near initialization for ‘aObdSubEntry0x1018Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:56: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:56: warning: (near initialization for ‘aObdSubEntry0x1020Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:70: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:70: warning: (near initialization for ‘aObdSubEntry0x1030Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:75: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1000-13ff.h:75: warning: (near initialization for ‘aObdSubEntry0x1300Ram_g’)
In file included from …/Common/ethernet/openPOWERLINK/Include/EplObjDef.h:144,
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:138: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:138: warning: (near initialization for ‘aObdSubEntry0x1400Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:145: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:145: warning: (near initialization for ‘aObdSubEntry0x1600Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:152: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:152: warning: (near initialization for ‘aObdSubEntry0x1800Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:159: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:159: warning: (near initialization for ‘aObdSubEntry0x1A00Ram_g’)
In file included from …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:168,
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:38: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:38: warning: (near initialization for ‘aObdSubEntry0x1C0BRam_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:46: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:46: warning: (near initialization for ‘aObdSubEntry0x1C0DRam_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:54: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:54: warning: (near initialization for ‘aObdSubEntry0x1C0FRam_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:59: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:59: warning: (near initialization for ‘aObdSubEntry0x1C14Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:94: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:94: warning: (near initialization for ‘aObdSubEntry0x1F82Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:99: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:99: warning: (near initialization for ‘aObdSubEntry0x1F83Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:129: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:129: warning: (near initialization for ‘aObdSubEntry0x1F8CRam_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:152: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:152: warning: (near initialization for ‘aObdSubEntry0x1F93Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:166: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:166: warning: (near initialization for ‘aObdSubEntry0x1F98Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:171: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:171: warning: (near initialization for ‘aObdSubEntry0x1F99Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:183: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/…/Generic/objdict_1b00-1fff.h:183: warning: (near initialization for ‘aObdSubEntry0x1F9ERam_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:182: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:182: warning: (near initialization for ‘aObdSubEntry0x6000Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:187: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:187: warning: (near initialization for ‘aObdSubEntry0x6003Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:191: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:191: warning: (near initialization for ‘aObdSubEntry0x6100Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:196: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:196: warning: (near initialization for ‘aObdSubEntry0x6200Ram_g’)
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:201: warning: excess elements in array initializer
…/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/objdict.h:201: warning: (near initialization for ‘aObdSubEntry0x6203Ram_g’)
In file included from …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN/Objdict.c:22:
…/Common/ethernet/openPOWERLINK/Include/EplObjDef.h: In function ‘EplObdInitRam’:
…/Common/ethernet/openPOWERLINK/Include/EplObjDef.h:187: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/Edrv/EdrvF107.c “->” Debug/EdrvF107.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/Edrv/EdrvF107.c -o Debug/EdrvF107.o
In file included from …/Common/ethernet/openPOWERLINK/Include/EdrvF107.h:20,
from …/Common/ethernet/openPOWERLINK/Edrv/EdrvF107.c:1:
…/Common/ethernet/openPOWERLINK/Include/global.h:160: warning: extra tokens at end of #ifdef directive
…/Common/ethernet/openPOWERLINK/Include/global.h:656: warning: #warning “CORTEXM3 FREERTOS”
…/Common/ethernet/openPOWERLINK/Edrv/EdrvF107.c: In function ‘EdrvInit’:
…/Common/ethernet/openPOWERLINK/Edrv/EdrvF107.c:45: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c “->” Debug/STM32Timer.o
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections …/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c -o Debug/STM32Timer.o
In file included from ./EplCfg.h:74,
from …/Common/ethernet/openPOWERLINK/Target/STM32F107/…/…/Include/EplInc.h:128,
from …/Common/ethernet/openPOWERLINK/Target/STM32F107/…/…/Include/EplTarget.h:76,
from …/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.h:11,
from …/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c:13:
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c: In function ‘EplTimerHighReskAddInstance’:
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c:32: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c: In function ‘EplTimerHighReskDelInstance’:
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c:47: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c: In function ‘EplTimerHighReskDeleteTimer’:
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c:131: warning: incompatible implicit declaration of built-in function ‘memset’
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c: At top level:
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c:137: warning: conflicting types for ‘initializeTimer’
…/Common/ethernet/openPOWERLINK/Target/STM32F107/STM32Timer.c:118: note: previous implicit declaration of ‘initializeTimer’ was here
arm-none-eabi-gcc -c -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections -O1 startup_stm32f10x.c -o Debug/startup_stm32f10x.o
arm-none-eabi-gcc -ggdb -O0 -std=gnu89 -Tstm32_flash.ld -I . -I …/FreeRTOS/Source/include -I …/FreeRTOS/Source/portable/GCC/ARM_CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/STM32F10x_StdPeriph_Driver/inc -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Libraries/CMSIS/Core/CM3 -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL -I …/Common/drivers/ST/STM32F10xFWLib/v3_1_2/Utilities/STM32_EVAL/STM3210C_EVAL -I …/Common/ethernet/openPOWERLINK/Include -I …/Common/ethernet/openPOWERLINK/Include/kernel -I …/Common/ethernet/openPOWERLINK/Include/user -I …/Common/ethernet/openPOWERLINK/ObjDicts/Api_CN -I …/Common/ethernet/openPOWERLINK/ObjDicts/Generic -I …/Common/ethernet/openPOWERLINK/Target/STM32F107 -D STM32F10X_CL -D USE_STDPERIPH_DRIVER -D VECT_TAB_FLASH -D GCC_ARMCM3 -D inline= -mthumb -mcpu=cortex-m3 -ffunction-sections -fdata-sections Debug/main.o Debug/stm32f10x_it.o Debug/stf_syscalls_minimal.o Debug/ledTask.o Debug/stm3210c_eval_lcd.o Debug/drvTask.o Debug/debugging.o Debug/LedHandler.o Debug/PushButton.o Debug/core_cm3.o Debug/system_stm32f10x.o Debug/misc.o Debug/stm32f10x_rcc.o Debug/stm32f10x_flash.o Debug/stm32f10x_gpio.o Debug/stm32f10x_tim.o Debug/stm32f10x_spi.o Debug/stm32_eth.o Debug/list.o Debug/queue.o Debug/tasks.o Debug/port.o Debug/heap_2.o Debug/amiarm.o Debug/EplApiGeneric.o Debug/EplApiProcessImage.o Debug/EplDllk.o Debug/EplDllkCal.o Debug/EplDlluCal.o Debug/EplErrorHandlerk.o Debug/EplEventk.o Debug/EplEventu.o Debug/EplIdentu.o Debug/EplLedu.o Debug/EplNmtCnu.o Debug/EplNmtk.o Debug/EplNmtkCal.o Debug/EplNmtMnu.o Debug/EplNmtu.o Debug/EplNmtuCal.o Debug/EplObd.o Debug/EplObdkCal.o Debug/EplObdu.o Debug/EplObduCal.o Debug/EplPdok.o Debug/EplPdokCal.o Debug/EplPdouCal.o Debug/EplPdou.o Debug/EplSdoAsndu.o Debug/EplSdoAsySequ.o Debug/EplSdoComu.o Debug/EplSdoUdpu.o Debug/EplStatusu.o Debug/EplTimeruGeneric.o Debug/EplApiFreeRTOS.o Debug/Objdict.o Debug/EdrvF107.o Debug/STM32Timer.o Debug/startup_stm32f10x.o -nostartfiles -Xlinker -oRTOSDemo.axf -Xlinker -M -Xlinker -Map=RTOSDemo.map -Xlinker -no-gc-sections
arm-none-eabi-objcopy RTOSDemo.axf -O binary RTOSDemo.bin
----- end -----
Regards
