system
(system)
March 15, 2011, 12:57am
1
mr68360 wrote on Tuesday, March 15, 2011 :
Greetings.
Out of the box, using Ride tools v7.30.10.0159 (RKit-ARM v 1.30.10.0356), the build fails at lcd.c:
Building C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\led.c
Running: ARM Compiler
"C:\Program Files\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe" -MD -D_STM32F103ZET6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\led.c" -o "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\led.o" -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\..\..\Source\include" -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\..\Common\include" -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code" -I "C:\Program Files\Raisonance\Ride\Lib\ARM\include" -I "." -c -fsigned-char -D GCC_ARMCM3 -g -O1 -ffunction-sections -mlittle-endian
In file included from C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\/circle.h:18:0,
from C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\led.c:13:
C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\/scheduler.h:18:27: fatal error: stm32f10x_lib.h: No such file or directory
compilation terminated.
Build failed
The include path the project provides is this:
$(ApplicationDir)\..\..\Source\include;$(ApplicationDir)\..\Common\include;$(ApplicationDir)\ST_Code;$(RkitLib)\ARM\include;.
stm32f10x_lib.h exists in other cortex demos (Rowley, IAR, and Keil STM32F103 demos), and in the Demo\Common\drivers\ST\STM32F10xFWLib\inc directory. When I add the latter to the include path, Ride finds the include file, but chokes:
Building C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c
"C:\Program Files\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe" -MD -D_STM32F103ZET6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c" -o "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\lcd.o" -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\..\..\Source\include" -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\..\Common\include" -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code" -I "C:\Program Files\Raisonance\Ride\Lib\ARM\include" -I "." -I "C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\Common\drivers\ST\STM32F10xFWLib\inc" -c -fsigned-char -D GCC_ARMCM3 -g -O1 -ffunction-sections -mlittle-endian
C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c: In function 'LCD_BackLightConfig':
C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c:564:23: error: 'TIM_OCInitTypeDef' has no member named 'TIM_OutputState'
C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c:564:42: error: 'TIM_OutputState_Enable' undeclared (first use in this function)
C:\projects\FreeRtos\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c:564:42: note: each undeclared identifier is reported only once for each function it appears in
Build failed
Can someone else verify this failure using the Ride tools?
Is the demo missing an up-to-date STM32F10x_StdPeriph_Driver directory from STMicro? If that seems to be the case, and can investigate further and attempt a demo repair.
Regards,
Chuck
rtel
(Richard Barry)
March 15, 2011, 4:54pm
2
rtel wrote on Tuesday, March 15, 2011 :
I just tried a clean build using Ride 7 version 1.22.09.0254, RKit-ARM version 7.24.09.0251, the successful build output is shown below.
I have two copies of stm32f10x_lib.h in the Ride installation directory itself, one in C:\devtools\Raisonance\Ride\lib\ARM\include, and the other in C:\devtools\Raisonance\Ride\lib\ARM\STM32F10x_Lib\library\inc so presume it is picking it up from one of those (without actually investigating which).
-----------Build Started: ‘RTOSDemo’ in configuration ‘Standard’-----------------
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\led.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\led.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\led.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\led.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\led.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\led.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\led.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\crt0_STM32x.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\crt0_STM32x.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\crt0_STM32x.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\crt0_STM32x.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\crt0_STM32x.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\crt0_STM32x.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\crt0_STM32x.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\lcd.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\lcd.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\lcd.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\lcd.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\lcd.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\lcd.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\Util.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\Util.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\Util.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\Util.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\Util.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\Util.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\Util.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\draw.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\draw.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\draw.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\draw.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\draw.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\draw.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\draw.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\mems.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\mems.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\mems.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\mems.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\mems.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\mems.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\mems.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\buzzer.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\buzzer.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\buzzer.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\buzzer.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\buzzer.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\buzzer.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\buzzer.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\pointer.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code\pointer.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\pointer.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\pointer.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\pointer.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\pointer.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\pointer.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\main.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest\ParTest.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest\ParTest.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ParTest.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\timertest.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\printf-stdarg.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\GenQTest.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\GenQTest.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\GenQTest.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\GenQTest.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\GenQTest.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\GenQTest.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\GenQTest.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\BlockQ.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\BlockQ.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\BlockQ.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\BlockQ.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\BlockQ.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\BlockQ.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\BlockQ.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\blocktim.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\blocktim.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\blocktim.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\blocktim.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\blocktim.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\blocktim.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\blocktim.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\QPeek.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\QPeek.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\QPeek.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\QPeek.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\QPeek.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\QPeek.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\QPeek.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\PollQ.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\Common\Minimal\PollQ.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\PollQ.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\PollQ.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\PollQ.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\PollQ.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\PollQ.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\syscalls.o”
Building C:\temp\611\FreeRTOSV6.1.1\Source\tasks.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Source\tasks.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\tasks.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\tasks.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\tasks.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\tasks.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\tasks.o”
Building C:\temp\611\FreeRTOSV6.1.1\Source\list.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Source\list.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\list.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\list.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\list.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\list.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\list.o”
Building C:\temp\611\FreeRTOSV6.1.1\Source\queue.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Source\queue.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\queue.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\queue.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\queue.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\queue.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\queue.o”
Building C:\temp\611\FreeRTOSV6.1.1\Source\portable\GCC\ARM_CM3\port.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Source\portable\GCC\ARM_CM3\port.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\port.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\port.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\port.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\port.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\port.o”
Building C:\temp\611\FreeRTOSV6.1.1\Source\portable\MemMang\heap_2.c
Running: GCC
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -MD -D_STM32F103RBT6_ -D_STM3x_ -D_STM32x_ -mthumb -mcpu=cortex-m3 “C:\temp\611\FreeRTOSV6.1.1\Source\portable\MemMang\heap_2.c” -o “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\heap_2.o” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\…\Source\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\…\Common\include” -I “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\ST_Code” -I “C:\devtools\Raisonance\Ride\Lib\ARM\include” -I “.” -c -fsigned-char -D GCC_ARMCM3 -D OLD_STM32LIB_USED -g -O1 -ffunction-sections -mlittle-endian
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\heap_2.lst” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objdump.exe” -disassemble -all -source “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\heap_2.o”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\heap_2.o.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\heap_2.o”
Building C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.rapp
Running: LD
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-gcc.exe” -mcpu=cortex-m3 -mthumb -Wl,-T -Xlinker “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.elf.ld” -u _start -Wl,-static -Wl,-gc-sections -nostartfiles -Wl,-Map -Xlinker “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.map”
“C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-objcopy.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.elf” -target=ihex “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.hex”
“C:\devtools\Raisonance\Ride\Bin\rexrdr.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.elf.sizetmp” 0 “C:\devtools\Raisonance\Ride\arm-gcc\bin\arm-none-eabi-size.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.elf”
“C:\devtools\Raisonance\Ride\Bin\dwf2xml.exe” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.dbi” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo-globals.Standard.xml” “C:\temp\611\FreeRTOSV6.1.1\Demo\CORTEX_STM32F103_Primer_GCC\RTOSDemo.Standard.xml” ARM
DWF2XML 2.00.01 - Raisonance Dwarf information extractor
Copyright © Raisonance S.A.S. 2007-2009. All rights reserved.
Build successful
system
(system)
March 15, 2011, 9:05pm
3
Thank you for your output, Richard. I note that your versions of the Ride tools are back a bit from the current Raisonance web-site offerings (the versions I am using).
Indeed, my version of Ride does not even have a Raisonance/Ride/lib/ARM/STM32F10x_Lib directory-there are only two STM32F10x-specific files in the lib/ARM directory: STM32F10x_COMMON.ld and STM32F10x_thumb.lib.
There is a stm32f10x_lib.h file, but its location is: Raisonance/Ride/Examples/ARM/ST\STM32Lib-v203/library/inc
I have discussed Ride with others, and they confirm that about a year or so ago, Raisonance modified the Ride tool set significantly. If I can emend the current demo so that it fits with my current version of Ride, I will be happy to send in the modifications (as a tool-version-conditional build). It would be nice to know the Ride versions in which the ‘big change’ occurred-Raisonance does not appear to supply tool archives).
(I may ping you after I read the contributor’s instructions, and I am still unsure of modification/addition procedures.)
Regards,
Chuck
