kenan3 wrote on Monday, June 07, 2010:
As I already wrote in the title, my Problem is that FreeRTOS causes an SIGINT while I’m debugging. I’m using eclipse, the stm32-p103 Board, openocd and gdb for debugging…
I also get some other problems where I don’t know how to solve them.
Here are my commands for GDB:
target remote localhost:3333
reset
load
break main
And here is my Logfile:
Debug: 14 31 configuration.c:45 add_script_search_dir(): adding G:\openocd-0.4.0\0.4.0\bin\…
Debug: 15 31 configuration.c:45 add_script_search_dir(): adding G:/openocd-0.4.0/0.4.0/bin/…/share/openocd/scripts
Debug: 16 31 configuration.c:87 find_file(): found G:\openocd-0.4.0\0.4.0\board\olimex_stm32_h103.cfg
Debug: 17 46 configuration.c:87 find_file(): found G:\openocd-0.4.0\0.4.0\bin\…/target/stm32.cfg
Debug: 18 46 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag_khz 1000
Debug: 19 46 command.c:133 script_debug(): command - jtag_khz ocd_jtag_khz 1000
Debug: 21 46 core.c:1560 jtag_config_khz(): handle jtag khz
Debug: 22 46 core.c:1523 jtag_khz_to_speed(): convert khz to interface specific speed value
User : 23 46 command.c:539 command_print(): 1000 kHz
Debug: 24 46 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag_nsrst_delay 100
Debug: 25 46 command.c:133 script_debug(): command - jtag_nsrst_delay ocd_jtag_nsrst_delay 100
User : 27 46 command.c:539 command_print(): jtag_nsrst_delay: 100
Debug: 28 46 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag_ntrst_delay 100
Debug: 29 46 command.c:133 script_debug(): command - jtag_ntrst_delay ocd_jtag_ntrst_delay 100
User : 31 46 command.c:539 command_print(): jtag_ntrst_delay: 100
Debug: 32 46 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag newtap stm32 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
Debug: 33 46 command.c:133 script_debug(): command - ocd_jtag ocd_jtag newtap stm32 cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x3ba00477
Debug: 34 62 tcl.c:568 jim_newtap_cmd(): Creating New Tap, Chip: stm32, Tap: cpu, Dotted: stm32.cpu, 8 params
Debug: 35 62 tcl.c:585 jim_newtap_cmd(): Processing option: -irlen
Debug: 36 62 tcl.c:585 jim_newtap_cmd(): Processing option: -ircapture
Debug: 37 62 tcl.c:585 jim_newtap_cmd(): Processing option: -irmask
Debug: 38 62 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 39 62 core.c:1300 jtag_tap_init(): Created Tap: stm32.cpu @ abs position 0, irlen 4, capture: 0x1 mask: 0xf
Debug: 40 62 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag newtap stm32 bs -irlen 5 -expected-id 0x06412041 -expected-id 0x06410041 -expected-id 0x16410041 -expected-id 0x06414041 -expected-id 0x06418041
Debug: 41 62 command.c:133 script_debug(): command - ocd_jtag ocd_jtag newtap stm32 bs -irlen 5 -expected-id 0x06412041 -expected-id 0x06410041 -expected-id 0x16410041 -expected-id 0x06414041 -expected-id 0x06418041
Debug: 42 62 tcl.c:568 jim_newtap_cmd(): Creating New Tap, Chip: stm32, Tap: bs, Dotted: stm32.bs, 12 params
Debug: 43 62 tcl.c:585 jim_newtap_cmd(): Processing option: -irlen
Debug: 44 62 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 45 62 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 46 62 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 47 62 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 48 62 tcl.c:585 jim_newtap_cmd(): Processing option: -expected-id
Debug: 49 62 core.c:1300 jtag_tap_init(): Created Tap: stm32.bs @ abs position 0, irlen 5, capture: 0x1 mask: 0x3
Debug: 50 62 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target create stm32.cpu cortex_m3 -endian little -chain-position stm32.cpu
Debug: 51 62 command.c:133 script_debug(): command - ocd_target ocd_target create stm32.cpu cortex_m3 -endian little -chain-position stm32.cpu
Debug: 52 62 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 53 62 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 54 62 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 55 62 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 56 62 command.c:346 register_command_handler(): registering ‘ocd_dap’…
Debug: 57 78 command.c:346 register_command_handler(): registering ‘ocd_cortex_m3’…
Debug: 58 78 command.c:346 register_command_handler(): registering ‘ocd_cortex_m3’…
Debug: 59 78 command.c:346 register_command_handler(): registering ‘ocd_cortex_m3’…
Debug: 60 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 61 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 62 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 63 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 64 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 65 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 66 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 67 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 68 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 69 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 70 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 71 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 72 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 73 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 74 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 75 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 76 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 77 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 78 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 79 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 80 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 81 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 82 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 83 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 84 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 85 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 86 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 87 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 88 78 command.c:346 register_command_handler(): registering ‘ocd_stm32.cpu’…
Debug: 89 93 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu configure -work-area-phys 0x20000000 -work-area-size 0x5000 -work-area-backup 0
Debug: 90 93 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu configure -work-area-phys 0x20000000 -work-area-size 0x5000 -work-area-backup 0
Debug: 91 93 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash bank stm32.flash stm32x 0 0 0 0 stm32.cpu
Debug: 92 93 command.c:133 script_debug(): command - ocd_flash ocd_flash bank stm32.flash stm32x 0 0 0 0 stm32.cpu
Debug: 94 93 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 95 93 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 96 93 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 97 93 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 98 93 command.c:346 register_command_handler(): registering ‘ocd_stm32x’…
Debug: 99 93 configuration.c:87 find_file(): found G:\openocd-0.4.0\0.4.0\interface\olimex-jtag-tiny.cfg
Debug: 100 93 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_interface ft2232
Debug: 101 109 command.c:133 script_debug(): command - interface ocd_interface ft2232
Debug: 103 109 command.c:346 register_command_handler(): registering ‘ocd_ft2232_device_desc’…
Debug: 104 109 command.c:346 register_command_handler(): registering ‘ocd_ft2232_serial’…
Debug: 105 109 command.c:346 register_command_handler(): registering ‘ocd_ft2232_layout’…
Debug: 106 109 command.c:346 register_command_handler(): registering ‘ocd_ft2232_vid_pid’…
Debug: 107 109 command.c:346 register_command_handler(): registering ‘ocd_ft2232_latency’…
Debug: 108 109 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_ft2232_device_desc Olimex OpenOCD JTAG TINY
Debug: 109 109 command.c:133 script_debug(): command - ft2232_device_desc ocd_ft2232_device_desc Olimex OpenOCD JTAG TINY
Debug: 111 109 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_ft2232_layout olimex-jtag
Debug: 112 109 command.c:133 script_debug(): command - ft2232_layout ocd_ft2232_layout olimex-jtag
Debug: 114 109 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_ft2232_vid_pid 0x15ba 0x0004
Debug: 115 109 command.c:133 script_debug(): command - ft2232_vid_pid ocd_ft2232_vid_pid 0x15ba 0x0004
Debug: 117 109 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 118 109 command.c:133 script_debug(): command - init ocd_init
Debug: 120 109 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target init
Debug: 121 109 command.c:133 script_debug(): command - ocd_target ocd_target init
Debug: 123 109 target.c:835 handle_target_init_command(): Initializing targets…
Debug: 124 109 command.c:346 register_command_handler(): registering ‘ocd_target_request’…
Debug: 125 109 command.c:346 register_command_handler(): registering ‘ocd_trace’…
Debug: 126 109 command.c:346 register_command_handler(): registering ‘ocd_trace’…
Debug: 127 109 command.c:346 register_command_handler(): registering ‘ocd_fast_load_image’…
Debug: 128 109 command.c:346 register_command_handler(): registering ‘ocd_fast_load’…
Debug: 129 109 command.c:346 register_command_handler(): registering ‘ocd_profile’…
Debug: 130 109 command.c:346 register_command_handler(): registering ‘ocd_virt2phys’…
Debug: 131 125 command.c:346 register_command_handler(): registering ‘ocd_reg’…
Debug: 132 125 command.c:346 register_command_handler(): registering ‘ocd_poll’…
Debug: 133 125 command.c:346 register_command_handler(): registering ‘ocd_wait_halt’…
Debug: 134 125 command.c:346 register_command_handler(): registering ‘ocd_halt’…
Debug: 135 125 command.c:346 register_command_handler(): registering ‘ocd_resume’…
Debug: 136 125 command.c:346 register_command_handler(): registering ‘ocd_reset’…
Debug: 137 125 command.c:346 register_command_handler(): registering ‘ocd_soft_reset_halt’…
Debug: 138 125 command.c:346 register_command_handler(): registering ‘ocd_step’…
Debug: 139 125 command.c:346 register_command_handler(): registering ‘ocd_mdw’…
Debug: 140 125 command.c:346 register_command_handler(): registering ‘ocd_mdh’…
Debug: 141 125 command.c:346 register_command_handler(): registering ‘ocd_mdb’…
Debug: 142 125 command.c:346 register_command_handler(): registering ‘ocd_mww’…
Debug: 143 125 command.c:346 register_command_handler(): registering ‘ocd_mwh’…
Debug: 144 125 command.c:346 register_command_handler(): registering ‘ocd_mwb’…
Debug: 145 125 command.c:346 register_command_handler(): registering ‘ocd_bp’…
Debug: 146 125 command.c:346 register_command_handler(): registering ‘ocd_rbp’…
Debug: 147 125 command.c:346 register_command_handler(): registering ‘ocd_wp’…
Debug: 148 125 command.c:346 register_command_handler(): registering ‘ocd_rwp’…
Debug: 149 125 command.c:346 register_command_handler(): registering ‘ocd_load_image’…
Debug: 150 125 command.c:346 register_command_handler(): registering ‘ocd_dump_image’…
Debug: 151 125 command.c:346 register_command_handler(): registering ‘ocd_verify_image’…
Debug: 152 125 command.c:346 register_command_handler(): registering ‘ocd_test_image’…
Debug: 153 125 command.c:346 register_command_handler(): registering ‘ocd_reset_nag’…
Debug: 154 125 ft2232.c:2097 ft2232_init(): ft2232 interface using shortest path jtag state transitions
Debug: 155 125 ft2232.c:2011 ft2232_init_libftdi(): ‘ft2232’ interface using libftdi with ‘olimex-jtag’ layout (15ba:0004)
Debug: 156 171 ft2232.c:2055 ft2232_init_libftdi(): current latency timer: 2
Debug: 157 171 ft2232.c:2066 ft2232_init_libftdi(): FTDI chip type: 2 “2232C”
Debug: 158 171 ft2232.c:2443 olimex_jtag_init(): 80 08 1b
Debug: 159 171 ft2232.c:2487 olimex_jtag_init(): 82 09 0f
Debug: 160 171 core.c:1523 jtag_khz_to_speed(): convert khz to interface specific speed value
Debug: 161 171 core.c:1527 jtag_khz_to_speed(): have interface set up
Debug: 162 171 ft2232.c:523 ft2232_speed(): 86 05 00
Debug: 163 187 core.c:1523 jtag_khz_to_speed(): convert khz to interface specific speed value
Debug: 164 187 core.c:1527 jtag_khz_to_speed(): have interface set up
Info : 165 187 core.c:1350 jtag_interface_init(): clock speed 1000 kHz
Debug: 166 187 openocd.c:122 handle_init_command(): jtag interface init complete
Debug: 167 187 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag init
Debug: 168 187 command.c:133 script_debug(): command - ocd_jtag ocd_jtag init
Debug: 170 187 tcl.c:854 handle_jtag_init_command(): Initializing jtag devices…
Debug: 171 187 ft2232.c:1361 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x01, high_direction: 0x0f
Debug: 172 187 core.c:672 jtag_add_reset(): SRST line released
Debug: 173 187 core.c:697 jtag_add_reset(): TRST line released
Debug: 174 187 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 175 406 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init
Debug: 176 406 command.c:133 script_debug(): command - ocd_jtag ocd_jtag arp_init
Debug: 177 406 core.c:1364 jtag_init_inner(): Init JTAG chain
Debug: 178 406 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 179 406 core.c:1017 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 180 406 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 181 421 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : 182 421 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Debug: 183 421 core.c:1182 jtag_validate_ircapture(): IR capture validation scan
Debug: 184 421 core.c:1243 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
Debug: 185 421 core.c:1243 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
Debug: 186 421 openocd.c:132 handle_init_command(): Examining targets…
Debug: 187 437 arm_adi_v5.c:1204 ahbap_debugport_init():
Debug: 188 437 arm_adi_v5.c:1265 ahbap_debugport_init(): MEM-AP #0 ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 189 453 target.c:1488 target_read_u32(): address: 0xe000ed00, value: 0x411fc231
Debug: 190 453 cortex_m3.c:1694 cortex_m3_examine(): Cortex-M3 r1p1 processor detected
Debug: 191 453 cortex_m3.c:1695 cortex_m3_examine(): cpuid: 0x411fc231
Debug: 192 453 target.c:1488 target_read_u32(): address: 0xe0002000, value: 0x00000261
Debug: 193 453 cortex_m3.c:1712 cortex_m3_examine(): FPB fpcr 0x261, numcode 6, numlit 2
Debug: 194 453 target.c:1488 target_read_u32(): address: 0xe0001000, value: 0x40000000
Debug: 195 453 cortex_m3.c:1664 cortex_m3_dwt_setup(): DWT dwtcr 0x40000000, comp 4, watch/trigger
Info : 196 453 cortex_m3.c:1721 cortex_m3_examine(): stm32.cpu: hardware has 6 breakpoints, 4 watchpoints
Debug: 197 453 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash init
Debug: 198 453 command.c:133 script_debug(): command - ocd_flash ocd_flash init
Debug: 200 468 tcl.c:920 handle_flash_init_command(): Initializing flash devices…
Debug: 201 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 202 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 203 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 204 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 205 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 206 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 207 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 208 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 209 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 210 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 211 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 212 468 command.c:346 register_command_handler(): registering ‘ocd_flash’…
Debug: 213 468 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_mflash init
Debug: 214 468 command.c:133 script_debug(): command - ocd_mflash ocd_mflash init
Debug: 216 468 mflash.c:1325 handle_mflash_init_command(): Initializing mflash devices…
Debug: 217 468 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_nand init
Debug: 218 468 command.c:133 script_debug(): command - ocd_nand ocd_nand init
Debug: 220 484 tcl.c:536 handle_nand_init_command(): Initializing NAND devices…
Debug: 221 484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_pld init
Debug: 222 484 command.c:133 script_debug(): command - ocd_pld ocd_pld init
Debug: 224 484 pld.c:231 handle_pld_init_command(): Initializing PLDs…
Debug: 225 500 gdb_server.c:2370 gdb_target_start(): gdb service for target ‘stm32.cpu’ on TCP port 3333
Debug: 226 500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_reset
Debug: 227 500 command.c:133 script_debug(): command - reset ocd_reset
Debug: 229 500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 230 500 command.c:133 script_debug(): command - ocd_target ocd_target names
Debug: 231 500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-start
Debug: 232 500 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-start
Debug: 233 500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 234 500 command.c:133 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 235 515 core.c:1451 jtag_init_reset(): Initializing with hard TRST+SRST reset
Debug: 236 515 core.c:685 jtag_add_reset(): JTAG reset with TLR instead of TRST
Debug: 237 515 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 238 515 core.c:1364 jtag_init_inner(): Init JTAG chain
Debug: 239 515 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 240 515 core.c:1017 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 241 515 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 242 515 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : 243 515 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Debug: 244 515 core.c:1182 jtag_validate_ircapture(): IR capture validation scan
Debug: 245 515 core.c:1243 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
Debug: 246 515 core.c:1243 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
Debug: 247 531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 248 531 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 249 531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 250 531 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 251 531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_examine
Debug: 252 531 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_examine
Debug: 253 531 arm_adi_v5.c:1204 ahbap_debugport_init():
Debug: 254 546 arm_adi_v5.c:1265 ahbap_debugport_init(): MEM-AP #0 ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 255 546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 256 546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 257 546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 258 546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 259 546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 260 546 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 261 546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset assert 0
Debug: 262 546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset assert 0
Debug: 263 546 cortex_m3.c:784 cortex_m3_assert_reset(): target->state: halted
Debug: 264 562 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 265 578 cortex_m3.c:891 cortex_m3_assert_reset(): Using Cortex-M3 SYSRESETREQ
Debug: 267 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-post
Debug: 268 578 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-post
Debug: 269 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 270 578 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 271 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 272 578 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 273 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 274 578 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 275 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset deassert 0
Debug: 276 578 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset deassert 0
Debug: 277 578 cortex_m3.c:921 cortex_m3_deassert_reset(): target->state: reset
Debug: 278 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 279 578 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 280 578 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-end
Debug: 281 578 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-end
Debug: 282 640 cortex_m3.c:452 cortex_m3_poll(): Exit from reset with dcb_dhcsr 0x1010001
Debug: 283 656 cortex_m3.c:195 cortex_m3_endreset_event(): DCB_DEMCR = 0x01000000
Debug: 284 656 target.c:1565 target_write_u32(): address: 0xe0002000, value: 0x00000003
Debug: 285 656 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 286 671 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 287 671 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 288 671 target.c:1565 target_write_u32(): address: 0xe0002014, value: 0x00000000
Debug: 289 671 target.c:1565 target_write_u32(): address: 0xe0002018, value: 0x00000000
Debug: 290 687 target.c:1565 target_write_u32(): address: 0xe000201c, value: 0x00000000
Debug: 291 687 target.c:1565 target_write_u32(): address: 0xe0002020, value: 0x00000000
Debug: 292 687 target.c:1565 target_write_u32(): address: 0xe0002024, value: 0x00000000
Debug: 293 687 target.c:1565 target_write_u32(): address: 0xe0001020, value: 0x00000000
Debug: 294 703 target.c:1565 target_write_u32(): address: 0xe0001024, value: 0x00000000
Debug: 295 703 target.c:1565 target_write_u32(): address: 0xe0001028, value: 0x00000000
Debug: 296 703 target.c:1565 target_write_u32(): address: 0xe0001030, value: 0x00000000
Debug: 297 703 target.c:1565 target_write_u32(): address: 0xe0001034, value: 0x00000000
Debug: 298 718 target.c:1565 target_write_u32(): address: 0xe0001038, value: 0x00000000
Debug: 299 718 target.c:1565 target_write_u32(): address: 0xe0001040, value: 0x00000000
Debug: 300 718 target.c:1565 target_write_u32(): address: 0xe0001044, value: 0x00000000
Debug: 301 734 target.c:1565 target_write_u32(): address: 0xe0001048, value: 0x00000000
Debug: 302 734 target.c:1565 target_write_u32(): address: 0xe0001050, value: 0x00000000
Debug: 303 734 target.c:1565 target_write_u32(): address: 0xe0001054, value: 0x00000000
Debug: 304 734 target.c:1565 target_write_u32(): address: 0xe0001058, value: 0x00000000
Debug: 305 750 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_halt
Debug: 306 750 command.c:133 script_debug(): command - halt ocd_halt
Debug: 308 750 target.c:2062 handle_halt_command(): -
Debug: 309 750 cortex_m3.c:499 cortex_m3_halt(): target->state: running
Debug: 310 765 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 311 781 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 312 796 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 313 796 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 314 812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 315 812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 316 828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 317 843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 318 843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 319 859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 320 859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 321 875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 322 875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 323 890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 324 890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 325 906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 326 906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 327 921 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 328 921 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 329 953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 330 968 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 331 968 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 332 984 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 333 984 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 334 1000 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 335 1000 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 336 1000 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 337 1000 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 338 1000 target.c:968 target_call_event_callbacks(): target event 3 (halted)
User : 339 1000 target.c:1234 target_arch_state(): target state: halted
User : 340 1000 armv7m.c:489 armv7m_arch_state(): target halted due to debug-request, current mode: Handler HardFault
xPSR: 0x21000003 pc: 0x08003008 msp: 0x20004f78
Debug: 341 1000 httpd_stubs.c:28 httpd_start(): libocdserver was built without HTTPD support
Debug: 342 1000 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 343 1000 command.c:133 script_debug(): command - init ocd_init
Info : 345 2406 server.c:81 add_connection(): accepting ‘gdb’ connection from 0
Debug: 346 2406 breakpoints.c:161 breakpoint_clear_target(): Delete all breakpoints for target: stm32.cpu
Debug: 347 2406 breakpoints.c:299 watchpoint_clear_target(): Delete all watchpoints for target: stm32.cpu
Debug: 348 2406 target.c:968 target_call_event_callbacks(): target event 25 (gdb-attach)
Debug: 349 2406 gdb_server.c:856 gdb_new_connection(): New GDB Connection: 1, Target stm32.cpu, state: halted
Debug: 350 2406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSupported’
Debug: 351 2406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘QStartNoAckMode’
Warn : 352 2406 gdb_server.c:649 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 353 2406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hg0’
Debug: 354 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘?’
Debug: 355 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc-1’
Debug: 356 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qC’
Debug: 357 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qAttached’
Debug: 358 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qOffsets’
Debug: 359 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 360 2421 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qXfer:memory-map:read::0,fff’
Debug: 361 2421 target.c:1488 target_read_u32(): address: 0xe0042000, value: 0x20036410
Info : 362 2421 stm32x.c:678 stm32x_probe(): device id = 0x20036410
Debug: 363 2437 target.c:1516 target_read_u16(): address: 0x1ffff7e0, value: 0x0080
Info : 364 2437 stm32x.c:753 stm32x_probe(): flash size = 128kbytes
Debug: 365 2437 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,4’
Debug: 366 2437 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000004
Debug: 367 2437 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08003008
Debug: 368 2453 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSymbol::’
Debug: 369 2468 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,72657365742068616c74’
Debug: 370 2468 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_reset halt
Debug: 371 2468 command.c:133 script_debug(): command - reset ocd_reset halt
Debug: 373 2484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 374 2484 command.c:133 script_debug(): command - ocd_target ocd_target names
Debug: 375 2484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-start
Debug: 376 2484 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-start
Debug: 377 2484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 378 2484 command.c:133 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 379 2484 core.c:1451 jtag_init_reset(): Initializing with hard TRST+SRST reset
Debug: 380 2484 core.c:685 jtag_add_reset(): JTAG reset with TLR instead of TRST
Debug: 381 2484 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 382 2484 core.c:1364 jtag_init_inner(): Init JTAG chain
Debug: 383 2484 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 384 2484 core.c:1017 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 385 2484 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 386 2500 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : 387 2500 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Debug: 388 2500 core.c:1182 jtag_validate_ircapture(): IR capture validation scan
Debug: 389 2500 core.c:1243 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
Debug: 390 2500 core.c:1243 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
Debug: 391 2500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 392 2500 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 393 2500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 394 2500 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 395 2500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_examine
Debug: 396 2500 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_examine
Debug: 397 2500 arm_adi_v5.c:1204 ahbap_debugport_init():
Debug: 398 2515 arm_adi_v5.c:1265 ahbap_debugport_init(): MEM-AP #0 ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 399 2515 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 400 2515 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 401 2515 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 402 2515 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 403 2515 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 404 2515 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 405 2515 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset assert 1
Debug: 406 2515 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset assert 1
Debug: 407 2515 cortex_m3.c:784 cortex_m3_assert_reset(): target->state: halted
Debug: 408 2531 cortex_m3.c:891 cortex_m3_assert_reset(): Using Cortex-M3 SYSRESETREQ
Debug: 409 2531 cortex_m3.c:499 cortex_m3_halt(): target->state: reset
Debug: 410 2531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-post
Debug: 411 2531 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-post
Debug: 412 2531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 413 2531 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 414 2531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 415 2531 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 416 2531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 417 2531 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 418 2546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset deassert 1
Debug: 419 2546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset deassert 1
Debug: 420 2546 cortex_m3.c:921 cortex_m3_deassert_reset(): target->state: reset
Debug: 421 2546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 422 2546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 423 2546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 424 2546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 425 2546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 426 2546 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 427 2546 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_waitstate halted 1000
Debug: 428 2546 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_waitstate halted 1000
Debug: 429 2609 cortex_m3.c:452 cortex_m3_poll(): Exit from reset with dcb_dhcsr 0x30003
Debug: 430 2609 cortex_m3.c:195 cortex_m3_endreset_event(): DCB_DEMCR = 0x01000501
Debug: 431 2625 target.c:1565 target_write_u32(): address: 0xe0002000, value: 0x00000003
Debug: 432 2625 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 433 2625 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 434 2640 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 435 2640 target.c:1565 target_write_u32(): address: 0xe0002014, value: 0x00000000
Debug: 436 2640 target.c:1565 target_write_u32(): address: 0xe0002018, value: 0x00000000
Debug: 437 2640 target.c:1565 target_write_u32(): address: 0xe000201c, value: 0x00000000
Debug: 438 2656 target.c:1565 target_write_u32(): address: 0xe0002020, value: 0x00000000
Debug: 439 2656 target.c:1565 target_write_u32(): address: 0xe0002024, value: 0x00000000
Debug: 440 2656 target.c:1565 target_write_u32(): address: 0xe0001020, value: 0x00000000
Debug: 441 2656 target.c:1565 target_write_u32(): address: 0xe0001024, value: 0x00000000
Debug: 442 2671 target.c:1565 target_write_u32(): address: 0xe0001028, value: 0x00000000
Debug: 443 2671 target.c:1565 target_write_u32(): address: 0xe0001030, value: 0x00000000
Debug: 444 2671 target.c:1565 target_write_u32(): address: 0xe0001034, value: 0x00000000
Debug: 445 2671 target.c:1565 target_write_u32(): address: 0xe0001038, value: 0x00000000
Debug: 446 2687 target.c:1565 target_write_u32(): address: 0xe0001040, value: 0x00000000
Debug: 447 2687 target.c:1565 target_write_u32(): address: 0xe0001044, value: 0x00000000
Debug: 448 2687 target.c:1565 target_write_u32(): address: 0xe0001048, value: 0x00000000
Debug: 449 2687 target.c:1565 target_write_u32(): address: 0xe0001050, value: 0x00000000
Debug: 450 2703 target.c:1565 target_write_u32(): address: 0xe0001054, value: 0x00000000
Debug: 451 2703 target.c:1565 target_write_u32(): address: 0xe0001058, value: 0x00000000
Debug: 452 2718 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 453 2718 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x9
Debug: 454 2734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 455 2750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 456 2750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 457 2765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 458 2765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 459 2781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 460 2781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 461 2796 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 462 2796 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 463 2812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 464 2812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 465 2828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 466 2828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 467 2843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20005000
Debug: 468 2843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 469 2859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8002fc8
Debug: 470 2859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x1000000
Debug: 471 2875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20005000
Debug: 472 2875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 473 2890 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 474 2890 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 475 2906 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 476 2906 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 477 2906 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8002fc8, target->state: halted
Debug: 478 2921 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 479 2921 target.c:968 target_call_event_callbacks(): target event 3 (halted)
User : 480 2921 target.c:1234 target_arch_state(): target state: halted
User : 481 2921 armv7m.c:489 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08002fc8 msp: 0x20005000
Debug: 482 2921 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 483 2921 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu curstate
Debug: 484 2921 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu curstate
Debug: 485 2921 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-end
Debug: 486 2921 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-end
Debug: 487 2953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qfThreadInfo’
Debug: 488 2953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 489 2953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 490 2953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 491 2953 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 492 2968 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 493 2968 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 494 2968 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 495 2968 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 496 2984 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 497 2984 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 498 2984 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 499 2984 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 500 2984 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 501 2984 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 502 2984 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 503 2984 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 504 3000 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 505 3000 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 506 3000 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 507 3000 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 508 3000 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 509 3000 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 510 3015 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 511 3015 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 512 3015 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 513 3015 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,706f6c6c’
Debug: 514 3015 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_poll
Debug: 515 3015 command.c:133 script_debug(): command - poll ocd_poll
User : 517 3031 command.c:539 command_print(): background polling: on
User : 518 3031 command.c:539 command_print(): TAP: stm32.cpu (enabled)
User : 519 3031 target.c:1234 target_arch_state(): target state: halted
User : 520 3031 armv7m.c:489 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
Debug: 521 3062 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,73746d333278206d6173735f65726173652030’
Debug: 522 3078 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32x mass_erase 0
Debug: 523 3078 command.c:133 script_debug(): command - ocd_stm32x ocd_stm32x mass_erase 0
Debug: 525 3078 target.c:1565 target_write_u32(): address: 0x40022004, value: 0x45670123
Debug: 526 3078 target.c:1565 target_write_u32(): address: 0x40022004, value: 0xcdef89ab
Debug: 527 3093 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000004
Debug: 528 3093 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000044
Debug: 529 3093 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 530 3093 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 531 3109 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 532 3109 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 533 3109 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 534 3109 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 535 3125 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 536 3125 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000080
User : 537 3125 command.c:539 command_print(): stm32x mass erase complete
Debug: 538 3171 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,666c6173682077726974655f696d616765206d61696e2e6f7574’
Debug: 539 3171 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash write_image main.out
Debug: 540 3171 command.c:133 script_debug(): command - ocd_flash ocd_flash write_image main.out
Debug: 542 3187 configuration.c:87 find_file(): found main.out
Debug: 543 3187 image.c:76 autodetect_image_type(): ELF image detected.
Debug: 544 3187 configuration.c:87 find_file(): found main.out
Info : 545 3187 core.c:546 flash_write_unlock(): Padding image section 0 with 0 bytes
Debug: 546 3187 image.c:497 image_elf_read_section(): load segment 0 at 0x0 (sz = 0x304a)
Debug: 547 3187 image.c:505 image_elf_read_section(): read elf: size = 0x12362 at 0x8000
Debug: 548 3187 image.c:497 image_elf_read_section(): load segment 1 at 0x0 (sz = 0x8)
Debug: 549 3187 image.c:505 image_elf_read_section(): read elf: size = 0x8 at 0x10000
Debug: 550 3187 target.c:1565 target_write_u32(): address: 0x40022004, value: 0x45670123
Debug: 551 3203 target.c:1565 target_write_u32(): address: 0x40022004, value: 0xcdef89ab
Debug: 552 3203 target.c:1072 target_alloc_working_area(): MMU disabled, using physical address for working memory 0x20000000
Debug: 553 3203 target.c:1134 target_alloc_working_area(): allocated new working area at address 0x20000000
Debug: 554 3203 target.c:1251 target_write_buffer(): writing buffer of 48 byte at 0x20000000
Debug: 555 3203 target.c:1134 target_alloc_working_area(): allocated new working area at address 0x20000030
Debug: 556 3203 target.c:1251 target_write_buffer(): writing buffer of 12370 byte at 0x20000030
Debug: 557 3437 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 0, Type: 1, Address: 0x20000026 Length: 2 (set=1)
Debug: 558 3437 breakpoints.c:102 breakpoint_add(): added software breakpoint at 0x20000026 of length 0x00000002, (BPID: 0)
Debug: 559 3437 armv7m.c:129 armv7m_restore_context():
Debug: 560 3453 cortex_m3.c:1458 cortex_m3_store_core_reg_u32(): write special reg 19 value 0x1
Debug: 561 3453 armv7m.c:242 armv7m_write_core_reg(): write core reg 19 value 0x1
Debug: 562 3468 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 16 value 0x1000000
Debug: 563 3468 armv7m.c:242 armv7m_write_core_reg(): write core reg 16 value 0x1000000
Debug: 564 3468 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 15 value 0x20000000
Debug: 565 3484 armv7m.c:242 armv7m_write_core_reg(): write core reg 15 value 0x20000000
Debug: 566 3484 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 3 value 0xad2e80
Debug: 567 3484 armv7m.c:242 armv7m_write_core_reg(): write core reg 3 value 0xad2e80
Debug: 568 3500 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 2 value 0x1829
Debug: 569 3500 armv7m.c:242 armv7m_write_core_reg(): write core reg 2 value 0x1829
Debug: 570 3500 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 1 value 0x8000000
Debug: 571 3500 armv7m.c:242 armv7m_write_core_reg(): write core reg 1 value 0x8000000
Debug: 572 3515 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 0 value 0x20000030
Debug: 573 3515 armv7m.c:242 armv7m_write_core_reg(): write core reg 0 value 0x20000030
Debug: 574 3515 target.c:968 target_call_event_callbacks(): target event 22 (debug-resumed)
Debug: 575 3515 cortex_m3.c:703 cortex_m3_resume(): target debug resumed at 0x20000000
Debug: 576 3515 target.c:2041 target_wait_state(): waiting for target halted…
Debug: 577 3843 cortex_m3.c:471 cortex_m3_poll():
Debug: 578 3843 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 579 3859 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 580 3875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20003082
Debug: 581 3875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x8003052
Debug: 582 3890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x0
Debug: 583 3890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x23
Debug: 584 3906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 585 3906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 586 3921 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 587 3921 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 588 3937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 589 3937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 590 3953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 591 3953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 592 3968 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 593 3968 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20005000
Debug: 594 3984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 595 3984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x20000026
Debug: 596 4000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 597 4000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20005000
Debug: 598 4015 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 599 4015 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x1
Debug: 600 4031 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 601 4031 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 602 4046 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 603 4046 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x20000026, target->state: halted
Debug: 604 4046 target.c:968 target_call_event_callbacks(): target event 21 (debug-halted)
Debug: 605 4062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x20000026
Debug: 606 4062 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 0, Type: 1, Address: 0x20000026 Length: 2 (set=1)
Debug: 607 4062 breakpoints.c:127 breakpoint_free(): free BPID: 0 -> 0
Debug: 608 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register primask with value 0x00000000
Debug: 609 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register xPSR with value 0x01000000
Debug: 610 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register pc with value 0x08002fc8
Debug: 611 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register r3 with value 0x00000400
Debug: 612 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register r2 with value 0x00000400
Debug: 613 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register r1 with value 0x000000a5
Debug: 614 4062 armv7m.c:459 armv7m_run_algorithm(): restoring register r0 with value 0x200001f8
Debug: 615 4062 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000080
User : 616 4062 command.c:539 command_print(): wrote 12370 bytes from file main.out in 0.875011s (13.806 kb/s)
Debug: 617 4093 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 618 4171 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8002fc8,4’
Debug: 619 4171 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08002fc8, len: 0x00000004
Debug: 620 4171 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08002fc8
Debug: 621 4187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,2’
Debug: 622 4187 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000002
Debug: 623 4187 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000112
Debug: 624 4375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000168,2’
Debug: 625 4375 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000168, len: 0x00000002
Debug: 626 4375 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000168
Debug: 627 4406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2a,2’
Debug: 628 4406 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2a, len: 0x00000002
Debug: 629 4406 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2a
Debug: 630 4453 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,2’
Debug: 631 4453 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000002
Debug: 632 4453 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08003008
Debug: 633 4484 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,2’
Debug: 634 4484 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000002
Debug: 635 4484 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000112
Debug: 636 4515 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffffe,4’
Debug: 637 4515 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffffe, len: 0x00000004
Debug: 638 4515 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffffe
Error: 639 4515 target.c:1350 target_read_buffer(): address + size wrapped(0xfffffffe, 0x00000004)
Debug: 640 4515 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffffe,4’
Debug: 641 4515 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffffe, len: 0x00000004
Debug: 642 4515 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffffe
Error: 643 4515 target.c:1350 target_read_buffer(): address + size wrapped(0xfffffffe, 0x00000004)
Debug: 644 6312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 645 6312 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 646 6312 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 647 6312 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 648 6312 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 1, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 649 6312 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 1)
Debug: 650 6312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 651 6312 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 652 6312 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 653 6312 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 654 6312 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 2, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 655 6312 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 2)
Debug: 656 6312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 657 6312 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 658 6312 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 659 6328 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 660 6328 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 3, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 661 6328 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 3)
Debug: 662 6328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘vCont?’
Debug: 663 6328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 664 6328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 665 6328 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 666 6328 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 667 6328 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 668 6328 target.c:1516 target_read_u16(): address: 0x08002fc8, value: 0x2100
Debug: 669 6328 armv7m.c:129 armv7m_restore_context():
Debug: 670 6343 cortex_m3.c:1458 cortex_m3_store_core_reg_u32(): write special reg 19 value 0x0
Debug: 671 6359 armv7m.c:242 armv7m_write_core_reg(): write core reg 19 value 0x0
Debug: 672 6359 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 16 value 0x1000000
Debug: 673 6359 armv7m.c:242 armv7m_write_core_reg(): write core reg 16 value 0x1000000
Debug: 674 6375 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 15 value 0x8002fc9
Debug: 675 6375 armv7m.c:242 armv7m_write_core_reg(): write core reg 15 value 0x8002fc9
Debug: 676 6375 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 3 value 0x400
Debug: 677 6375 armv7m.c:242 armv7m_write_core_reg(): write core reg 3 value 0x400
Debug: 678 6390 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 2 value 0x400
Debug: 679 6390 armv7m.c:242 armv7m_write_core_reg(): write core reg 2 value 0x400
Debug: 680 6390 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 1 value 0xa5
Debug: 681 6390 armv7m.c:242 armv7m_write_core_reg(): write core reg 1 value 0xa5
Debug: 682 6406 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 0 value 0x200001f8
Debug: 683 6406 armv7m.c:242 armv7m_write_core_reg(): write core reg 0 value 0x200001f8
Debug: 684 6406 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 685 6406 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x8002fc9
Debug: 686 6515 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 687 6531 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 688 6547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20000000
Debug: 689 6547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x8
Debug: 690 6562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200045a8
Debug: 691 6562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200045a8
Debug: 692 6578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 693 6578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 694 6593 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 695 6593 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004ff8
Debug: 696 6609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 697 6625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 698 6625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 699 6640 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 700 6640 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 701 6656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004fe8
Debug: 702 6656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x8002ff3
Debug: 703 6672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8000112
Debug: 704 6672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 705 6687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004fe8
Debug: 706 6687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 707 6703 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 708 6703 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 709 6718 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 710 6718 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 711 6718 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8000112, target->state: halted
Debug: 712 6718 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 713 6718 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 714 6718 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 715 6718 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 716 6734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 717 6734 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 718 6734 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 1, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 719 6734 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 720 6734 breakpoints.c:127 breakpoint_free(): free BPID: 1 -> 0
Debug: 721 6734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 722 6734 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 723 6734 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 2, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 724 6734 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 725 6734 breakpoints.c:127 breakpoint_free(): free BPID: 2 -> 0
Debug: 726 6734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 727 6750 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 728 6750 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 3, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 729 6750 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 730 6750 breakpoints.c:127 breakpoint_free(): free BPID: 3 -> 0
Debug: 731 6750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,4’
Debug: 732 6750 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000004
Debug: 733 6750 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08000112
Debug: 734 6781 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 735 6843 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800010c,2’
Debug: 736 6843 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800010c, len: 0x00000002
Debug: 737 6843 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800010c
Debug: 738 6859 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800010e,2’
Debug: 739 6859 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800010e, len: 0x00000002
Debug: 740 6859 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800010e
Debug: 741 6875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000110,2’
Debug: 742 6875 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000110, len: 0x00000002
Debug: 743 6875 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000110
Debug: 744 6875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,2’
Debug: 745 6875 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000002
Debug: 746 6875 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000112
Debug: 747 6875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000114,2’
Debug: 748 6890 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000114, len: 0x00000002
Debug: 749 6890 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000114
Debug: 750 6890 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000116,2’
Debug: 751 6890 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000116, len: 0x00000002
Debug: 752 6890 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000116
Debug: 753 6890 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000118,2’
Debug: 754 6890 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000118, len: 0x00000002
Debug: 755 6890 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000118
Debug: 756 6906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800011a,2’
Debug: 757 6906 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800011a, len: 0x00000002
Debug: 758 6906 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800011a
Debug: 759 6906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800011c,2’
Debug: 760 6906 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800011c, len: 0x00000002
Debug: 761 6906 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800011c
Debug: 762 6922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800011e,2’
Debug: 763 6922 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800011e, len: 0x00000002
Debug: 764 6922 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800011e
Debug: 765 6922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000120,2’
Debug: 766 6922 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000120, len: 0x00000002
Debug: 767 6922 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000120
Debug: 768 6937 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000122,2’
Debug: 769 6937 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000122, len: 0x00000002
Debug: 770 6937 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000122
Debug: 771 6937 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000124,2’
Debug: 772 6937 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000124, len: 0x00000002
Debug: 773 6937 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000124
Debug: 774 6953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000126,2’
Debug: 775 6953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000126, len: 0x00000002
Debug: 776 6953 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000126
Debug: 777 6953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000128,2’
Debug: 778 6953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000128, len: 0x00000002
Debug: 779 6953 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000128
Debug: 780 6953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800012a,2’
Debug: 781 6968 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800012a, len: 0x00000002
Debug: 782 6968 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800012a
Debug: 783 6968 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800012c,2’
Debug: 784 6968 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800012c, len: 0x00000002
Debug: 785 6968 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800012c
Debug: 786 6968 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800012e,2’
Debug: 787 6968 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800012e, len: 0x00000002
Debug: 788 6968 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800012e
Debug: 789 6984 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000130,2’
Debug: 790 6984 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000130, len: 0x00000002
Debug: 791 6984 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000130
Debug: 792 6984 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000132,2’
Debug: 793 6984 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000132, len: 0x00000002
Debug: 794 6984 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000132
Debug: 795 6984 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000134,2’
Debug: 796 6984 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000134, len: 0x00000002
Debug: 797 7000 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000134
Debug: 798 7000 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000136,2’
Debug: 799 7000 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000136, len: 0x00000002
Debug: 800 7000 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000136
Debug: 801 7000 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000138,2’
Debug: 802 7000 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000138, len: 0x00000002
Debug: 803 7000 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000138
Debug: 804 7015 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800013a,2’
Debug: 805 7015 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800013a, len: 0x00000002
Debug: 806 7015 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800013a
Debug: 807 7015 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800013c,2’
Debug: 808 7015 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800013c, len: 0x00000002
Debug: 809 7015 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800013c
Debug: 810 7031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800013e,2’
Debug: 811 7031 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800013e, len: 0x00000002
Debug: 812 7031 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800013e
Debug: 813 7031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000140,2’
Debug: 814 7031 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000140, len: 0x00000002
Debug: 815 7031 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000140
Debug: 816 7031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000142,2’
Debug: 817 7031 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000142, len: 0x00000002
Debug: 818 7031 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000142
Debug: 819 7047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000144,2’
Debug: 820 7047 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000144, len: 0x00000002
Debug: 821 7047 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000144
Debug: 822 7047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000146,2’
Debug: 823 7047 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000146, len: 0x00000002
Debug: 824 7047 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000146
Debug: 825 7062 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000148,2’
Debug: 826 7062 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000148, len: 0x00000002
Debug: 827 7062 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000148
Debug: 828 7062 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800014a,2’
Debug: 829 7062 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800014a, len: 0x00000002
Debug: 830 7062 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800014a
Debug: 831 7062 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800014c,2’
Debug: 832 7062 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800014c, len: 0x00000002
Debug: 833 7062 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800014c
Debug: 834 7078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800014e,2’
Debug: 835 7078 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800014e, len: 0x00000002
Debug: 836 7078 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800014e
Debug: 837 7078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000150,2’
Debug: 838 7078 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000150, len: 0x00000002
Debug: 839 7078 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000150
Debug: 840 7093 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000152,2’
Debug: 841 7093 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000152, len: 0x00000002
Debug: 842 7093 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000152
Debug: 843 7093 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000154,2’
Debug: 844 7093 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000154, len: 0x00000002
Debug: 845 7093 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000154
Debug: 846 7109 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000156,2’
Debug: 847 7109 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000156, len: 0x00000002
Debug: 848 7109 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000156
Debug: 849 7109 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000158,2’
Debug: 850 7109 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000158, len: 0x00000002
Debug: 851 7109 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000158
Debug: 852 7109 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800015a,2’
Debug: 853 7109 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800015a, len: 0x00000002
Debug: 854 7109 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800015a
Debug: 855 7125 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800015c,2’
Debug: 856 7125 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800015c, len: 0x00000002
Debug: 857 7125 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800015c
Debug: 858 7125 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800015e,2’
Debug: 859 7125 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800015e, len: 0x00000002
Debug: 860 7125 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800015e
Debug: 861 7125 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000160,2’
Debug: 862 7125 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000160, len: 0x00000002
Debug: 863 7125 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000160
Debug: 864 7140 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000162,2’
Debug: 865 7140 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000162, len: 0x00000002
Debug: 866 7140 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000162
Debug: 867 7140 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000164,2’
Debug: 868 7140 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000164, len: 0x00000002
Debug: 869 7140 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000164
Debug: 870 7140 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000166,2’
Debug: 871 7140 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000166, len: 0x00000002
Debug: 872 7156 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000166
Debug: 873 7156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000168,2’
Debug: 874 7156 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000168, len: 0x00000002
Debug: 875 7156 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000168
Debug: 876 7156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800016a,2’
Debug: 877 7156 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800016a, len: 0x00000002
Debug: 878 7156 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800016a
Debug: 879 7172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800016c,2’
Debug: 880 7172 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800016c, len: 0x00000002
Debug: 881 7172 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800016c
Debug: 882 7172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800016e,2’
Debug: 883 7172 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800016e, len: 0x00000002
Debug: 884 7172 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800016e
Debug: 885 7172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000170,2’
Debug: 886 7172 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000170, len: 0x00000002
Debug: 887 7172 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000170
Debug: 888 7187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000172,2’
Debug: 889 7187 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000172, len: 0x00000002
Debug: 890 7187 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000172
Debug: 891 7187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000174,2’
Debug: 892 7187 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000174, len: 0x00000002
Debug: 893 7187 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000174
Debug: 894 7203 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000176,2’
Debug: 895 7203 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000176, len: 0x00000002
Debug: 896 7203 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000176
Debug: 897 8312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 898 8328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 899 8328 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 900 8328 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 901 8328 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 902 8328 target.c:1516 target_read_u16(): address: 0x08000112, value: 0xf000
Debug: 903 8328 armv7m.c:129 armv7m_restore_context():
Debug: 904 8328 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 905 8343 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 906 8343 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 907 8359 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 908 8359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20000000
Debug: 909 8375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x8
Debug: 910 8375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200045a8
Debug: 911 8390 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200045a8
Debug: 912 8390 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 913 8406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 914 8406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 915 8422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004ff8
Debug: 916 8422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 917 8437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 918 8437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 919 8453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 920 8453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 921 8468 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004fe8
Debug: 922 8468 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x8000117
Debug: 923 8484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8000464
Debug: 924 8484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 925 8500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004fe8
Debug: 926 8500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 927 8515 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 928 8515 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 929 8531 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 930 8547 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 931 8547 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8000464, target->state: halted
Debug: 932 8547 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 933 8547 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 934 8547 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 935 8547 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 936 8547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 937 8547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 938 8547 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 939 8547 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 940 8547 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 941 8547 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 4, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 942 8547 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 4)
Debug: 943 8547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 944 8547 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 945 8547 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 946 8562 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 947 8562 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 5, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 948 8562 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 5)
Debug: 949 8562 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 950 8562 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 951 8562 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 952 8562 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 953 8562 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 6, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 954 8562 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 6)
Debug: 955 8562 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 956 8562 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 957 8562 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 958 8562 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 959 8562 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 960 8562 armv7m.c:129 armv7m_restore_context():
Debug: 961 8578 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 962 8578 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x8000465
Debug: 963 8672 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 964 8687 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 965 8703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 966 8703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 967 8718 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 968 8718 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200001f8
Debug: 969 8734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 970 8734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 971 8750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 972 8750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 973 8765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 974 8765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 975 8781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 976 8781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 977 8797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 978 8797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 979 8812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 980 8812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a2a
Debug: 981 8828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 982 8828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 983 8843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 984 8843 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 985 8859 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 986 8875 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 987 8875 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 988 8875 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a2a, target->state: halted
Debug: 989 8875 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 990 8875 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 991 8875 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 992 8875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 993 8875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 994 8875 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 995 8890 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 4, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 996 8890 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 997 8890 breakpoints.c:127 breakpoint_free(): free BPID: 4 -> 0
Debug: 998 8890 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 999 8890 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1000 8890 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 5, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 1001 8890 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 1002 8890 breakpoints.c:127 breakpoint_free(): free BPID: 5 -> 0
Debug: 1003 8890 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 1004 8890 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1005 8890 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 6, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 1006 8890 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 1007 8906 breakpoints.c:127 breakpoint_free(): free BPID: 6 -> 0
Debug: 1008 8906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2a,4’
Debug: 1009 8906 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2a, len: 0x00000004
Debug: 1010 8906 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08001a2a
Debug: 1011 8922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m20004f80,40’
Debug: 1012 8922 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x20004f80, len: 0x00000040
Debug: 1013 8922 target.c:1333 target_read_buffer(): reading buffer of 64 byte at 0x20004f80
Debug: 1014 8937 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 1015 8953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80008fa,4’
Debug: 1016 8953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080008fa, len: 0x00000004
Debug: 1017 8953 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x080008fa
Debug: 1018 8953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m20004fc0,40’
Debug: 1019 8953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x20004fc0, len: 0x00000040
Debug: 1020 8953 target.c:1333 target_read_buffer(): reading buffer of 64 byte at 0x20004fc0
Debug: 1021 8968 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000168,4’
Debug: 1022 8968 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000168, len: 0x00000004
Debug: 1023 8968 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08000168
Debug: 1024 9047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019d4,2’
Debug: 1025 9047 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019d4, len: 0x00000002
Debug: 1026 9047 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019d4
Debug: 1027 9047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019d6,2’
Debug: 1028 9062 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019d6, len: 0x00000002
Debug: 1029 9062 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019d6
Debug: 1030 9062 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019d8,2’
Debug: 1031 9062 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019d8, len: 0x00000002
Debug: 1032 9062 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019d8
Debug: 1033 9078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019da,2’
Debug: 1034 9078 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019da, len: 0x00000002
Debug: 1035 9078 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019da
Debug: 1036 9078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019dc,2’
Debug: 1037 9078 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019dc, len: 0x00000002
Debug: 1038 9078 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019dc
Debug: 1039 9078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019de,2’
Debug: 1040 9093 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019de, len: 0x00000002
Debug: 1041 9093 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019de
Debug: 1042 9093 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e0,2’
Debug: 1043 9093 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e0, len: 0x00000002
Debug: 1044 9093 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e0
Debug: 1045 9093 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e2,2’
Debug: 1046 9109 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e2, len: 0x00000002
Debug: 1047 9109 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e2
Debug: 1048 9109 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e4,2’
Debug: 1049 9109 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e4, len: 0x00000002
Debug: 1050 9109 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e4
Debug: 1051 9109 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e6,2’
Debug: 1052 9109 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e6, len: 0x00000002
Debug: 1053 9109 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e6
Debug: 1054 9125 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e8,2’
Debug: 1055 9125 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e8, len: 0x00000002
Debug: 1056 9125 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e8
Debug: 1057 9125 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019ea,2’
Debug: 1058 9125 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019ea, len: 0x00000002
Debug: 1059 9125 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019ea
Debug: 1060 9125 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019ec,2’
Debug: 1061 9125 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019ec, len: 0x00000002
Debug: 1062 9125 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019ec
Debug: 1063 9140 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019ee,2’
Debug: 1064 9140 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019ee, len: 0x00000002
Debug: 1065 9140 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019ee
Debug: 1066 9140 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f0,2’
Debug: 1067 9140 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f0, len: 0x00000002
Debug: 1068 9140 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f0
Debug: 1069 9140 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f2,2’
Debug: 1070 9140 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f2, len: 0x00000002
Debug: 1071 9156 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f2
Debug: 1072 9156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f4,2’
Debug: 1073 9156 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f4, len: 0x00000002
Debug: 1074 9156 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f4
Debug: 1075 9156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f6,2’
Debug: 1076 9156 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f6, len: 0x00000002
Debug: 1077 9156 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f6
Debug: 1078 9172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f8,2’
Debug: 1079 9172 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f8, len: 0x00000002
Debug: 1080 9172 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f8
Debug: 1081 9172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019fa,2’
Debug: 1082 9172 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019fa, len: 0x00000002
Debug: 1083 9172 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019fa
Debug: 1084 9187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019fc,2’
Debug: 1085 9187 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019fc, len: 0x00000002
Debug: 1086 9187 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019fc
Debug: 1087 9187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019fe,2’
Debug: 1088 9187 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019fe, len: 0x00000002
Debug: 1089 9187 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019fe
Debug: 1090 9187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a00,2’
Debug: 1091 9187 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a00, len: 0x00000002
Debug: 1092 9187 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a00
Debug: 1093 9203 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a02,2’
Debug: 1094 9203 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a02, len: 0x00000002
Debug: 1095 9203 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a02
Debug: 1096 9203 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a04,2’
Debug: 1097 9203 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a04, len: 0x00000002
Debug: 1098 9203 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a04
Debug: 1099 9203 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a06,2’
Debug: 1100 9218 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a06, len: 0x00000002
Debug: 1101 9218 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a06
Debug: 1102 9218 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a08,2’
Debug: 1103 9218 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a08, len: 0x00000002
Debug: 1104 9218 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a08
Debug: 1105 9218 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a0a,2’
Debug: 1106 9218 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a0a, len: 0x00000002
Debug: 1107 9218 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a0a
Debug: 1108 9234 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a0c,2’
Debug: 1109 9234 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a0c, len: 0x00000002
Debug: 1110 9234 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a0c
Debug: 1111 9234 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a0e,2’
Debug: 1112 9234 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a0e, len: 0x00000002
Debug: 1113 9234 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a0e
Debug: 1114 9234 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a10,2’
Debug: 1115 9234 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a10, len: 0x00000002
Debug: 1116 9234 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a10
Debug: 1117 9250 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a12,2’
Debug: 1118 9250 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a12, len: 0x00000002
Debug: 1119 9250 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a12
Debug: 1120 9250 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a14,2’
Debug: 1121 9250 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a14, len: 0x00000002
Debug: 1122 9250 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a14
Debug: 1123 9250 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a16,2’
Debug: 1124 9250 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a16, len: 0x00000002
Debug: 1125 9250 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a16
Debug: 1126 9265 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a18,2’
Debug: 1127 9265 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a18, len: 0x00000002
Debug: 1128 9265 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a18
Debug: 1129 9265 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a1a,2’
Debug: 1130 9265 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a1a, len: 0x00000002
Debug: 1131 9265 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a1a
Debug: 1132 9281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a1c,2’
Debug: 1133 9281 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a1c, len: 0x00000002
Debug: 1134 9281 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a1c
Debug: 1135 9281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a1e,2’
Debug: 1136 9281 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a1e, len: 0x00000002
Debug: 1137 9281 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a1e
Debug: 1138 9281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a20,2’
Debug: 1139 9281 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a20, len: 0x00000002
Debug: 1140 9281 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a20
Debug: 1141 9297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a22,2’
Debug: 1142 9297 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a22, len: 0x00000002
Debug: 1143 9297 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a22
Debug: 1144 9297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a24,2’
Debug: 1145 9297 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a24, len: 0x00000002
Debug: 1146 9297 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a24
Debug: 1147 9297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a26,2’
Debug: 1148 9297 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a26, len: 0x00000002
Debug: 1149 9297 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a26
Debug: 1150 9312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a28,2’
Debug: 1151 9312 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a28, len: 0x00000002
Debug: 1152 9312 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a28
Debug: 1153 9312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2a,2’
Debug: 1154 9312 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2a, len: 0x00000002
Debug: 1155 9312 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2a
Debug: 1156 9312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2c,2’
Debug: 1157 9312 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2c, len: 0x00000002
Debug: 1158 9312 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2c
Debug: 1159 9328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2e,2’
Debug: 1160 9328 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2e, len: 0x00000002
Debug: 1161 9328 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2e
Debug: 1162 9328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a30,2’
Debug: 1163 9328 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a30, len: 0x00000002
Debug: 1164 9328 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a30
Debug: 1165 9328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a32,2’
Debug: 1166 9328 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a32, len: 0x00000002
Debug: 1167 9328 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a32
Debug: 1168 9343 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a34,2’
Debug: 1169 9343 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a34, len: 0x00000002
Debug: 1170 9343 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a34
Debug: 1171 9343 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a36,2’
Debug: 1172 9343 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a36, len: 0x00000002
Debug: 1173 9343 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a36
Debug: 1174 9343 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a38,2’
Debug: 1175 9359 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a38, len: 0x00000002
Debug: 1176 9359 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a38
Debug: 1177 9359 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a3a,2’
Debug: 1178 9359 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a3a, len: 0x00000002
Debug: 1179 9359 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a3a
Debug: 1180 9359 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a3c,2’
Debug: 1181 9359 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a3c, len: 0x00000002
Debug: 1182 9359 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a3c
Debug: 1183 9375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a3e,2’
Debug: 1184 9375 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a3e, len: 0x00000002
Debug: 1185 9375 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a3e
Debug: 1186 9375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a40,2’
Debug: 1187 9375 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a40, len: 0x00000002
Debug: 1188 9375 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a40
Debug: 1189 9375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a42,2’
Debug: 1190 9390 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a42, len: 0x00000002
Debug: 1191 9390 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a42
Debug: 1192 9390 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a44,2’
Debug: 1193 9390 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a44, len: 0x00000002
Debug: 1194 9390 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a44
Debug: 1195 9390 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a46,2’
Debug: 1196 9390 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a46, len: 0x00000002
Debug: 1197 9390 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a46
Debug: 1198 9406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a48,2’
Debug: 1199 9406 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a48, len: 0x00000002
Debug: 1200 9406 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a48
Debug: 1201 9406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a4a,2’
Debug: 1202 9406 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a4a, len: 0x00000002
Debug: 1203 9406 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a4a
Debug: 1204 11047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 1205 11047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1206 11062 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1207 11062 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1208 11062 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1209 11062 target.c:1516 target_read_u16(): address: 0x08001a2a, value: 0x697b
Debug: 1210 11062 armv7m.c:129 armv7m_restore_context():
Debug: 1211 11062 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1212 11062 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1213 11078 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1214 11078 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1215 11093 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1216 11109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 1217 11109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 1218 11125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200001a0
Debug: 1219 11125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1220 11125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1221 11140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1222 11140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1223 11156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1224 11172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1225 11172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1226 11187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1227 11187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1228 11203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1229 11203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1230 11218 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a2c
Debug: 1231 11218 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1232 11234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1233 11234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1234 11250 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1235 11250 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1236 11265 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1237 11265 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1238 11265 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a2c, target->state: halted
Debug: 1239 11265 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1240 11265 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1241 11265 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1242 11281 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1243 11281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1244 11281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 1245 11281 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1246 11281 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 1247 11281 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 1248 11297 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 7, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 1249 11297 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 7)
Debug: 1250 11297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 1251 11297 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1252 11297 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 1253 11297 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 1254 11297 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 8, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 1255 11297 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 8)
Debug: 1256 11297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 1257 11297 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1258 11297 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 1259 11297 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 1260 11297 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 9, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 1261 11297 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 9)
Debug: 1262 11312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 1263 11312 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1264 11312 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1265 11312 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1266 11312 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1267 11312 armv7m.c:129 armv7m_restore_context():
Debug: 1268 11312 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1269 11312 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1270 11312 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1271 11328 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1272 11343 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1273 11343 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 1274 11359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 1275 11359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200001a0
Debug: 1276 11375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1277 11390 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1278 11390 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1279 11406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1280 11406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1281 11422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1282 11422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1283 11437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1284 11437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1285 11453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1286 11453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1287 11468 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a2e
Debug: 1288 11468 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1289 11484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1290 11484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1291 11500 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1292 11500 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1293 11515 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1294 11515 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1295 11515 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a2e, target->state: halted
Debug: 1296 11515 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1297 11515 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1298 11515 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1299 11515 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1300 11515 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1301 11531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1302 11531 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1303 11531 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1304 11531 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1305 11531 armv7m.c:129 armv7m_restore_context():
Debug: 1306 11531 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1307 11531 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1308 11531 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1309 11547 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1310 11562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1311 11578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 1312 11578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 1313 11593 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x100
Debug: 1314 11593 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1315 11609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1316 11609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1317 11625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1318 11625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1319 11640 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1320 11640 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1321 11656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1322 11656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1323 11672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1324 11672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1325 11687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a30
Debug: 1326 11687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1327 11703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1328 11703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1329 11718 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1330 11718 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1331 11734 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1332 11734 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1333 11734 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a30, target->state: halted
Debug: 1334 11734 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1335 11734 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1336 11734 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1337 11734 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1338 11750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1339 11750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1340 11750 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1341 11750 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1342 11750 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1343 11750 armv7m.c:129 armv7m_restore_context():
Debug: 1344 11750 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1345 11765 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1346 11765 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1347 11765 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1348 11781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1349 11797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 1350 11797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 1351 11812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1352 11812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1353 11828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1354 11828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1355 11843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1356 11843 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1357 11859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1358 11859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1359 11875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1360 11875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1361 11890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1362 11890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1363 11906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a34
Debug: 1364 11906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1365 11922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1366 11922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1367 11937 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1368 11937 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1369 11953 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1370 11953 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1371 11953 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a34, target->state: halted
Debug: 1372 11953 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1373 11968 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1374 11968 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1375 11968 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1376 11968 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1377 11968 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1378 11968 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1379 11968 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1380 11968 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1381 11968 armv7m.c:129 armv7m_restore_context():
Debug: 1382 11968 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1383 11984 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1384 11984 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1385 11984 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1386 12000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1387 12015 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 1388 12015 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 1389 12031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1390 12031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1391 12047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1392 12047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1393 12062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1394 12062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1395 12078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1396 12078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1397 12093 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1398 12093 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1399 12109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1400 12109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1401 12125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a36
Debug: 1402 12125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1403 12140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1404 12140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1405 12156 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1406 12156 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1407 12172 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1408 12187 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1409 12187 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a36, target->state: halted
Debug: 1410 12187 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1411 12187 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1412 12187 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1413 12187 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1414 12187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1415 12187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1416 12187 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1417 12187 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1418 12187 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1419 12187 armv7m.c:129 armv7m_restore_context():
Debug: 1420 12187 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1421 12203 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1422 12203 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1423 12218 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1424 12218 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1425 12234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1426 12234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 1427 12250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1428 12250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1429 12265 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1430 12265 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1431 12281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1432 12281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1433 12297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1434 12297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1435 12312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1436 12312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1437 12328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1438 12343 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1439 12343 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a3a
Debug: 1440 12359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1441 12359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1442 12375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1443 12375 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1444 12390 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1445 12390 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1446 12406 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1447 12406 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a3a, target->state: halted
Debug: 1448 12406 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1449 12406 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1450 12406 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1451 12406 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1452 12406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1453 12406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1454 12406 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1455 12406 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1456 12422 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1457 12422 armv7m.c:129 armv7m_restore_context():
Debug: 1458 12422 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1459 12422 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1460 12422 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1461 12437 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1462 12453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1463 12453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1464 12468 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1465 12468 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1466 12484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1467 12484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1468 12500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1469 12500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1470 12515 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1471 12531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1472 12531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1473 12547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1474 12547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1475 12562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 1476 12562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 1477 12578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a3c
Debug: 1478 12578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 1479 12593 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 1480 12593 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1481 12609 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1482 12609 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1483 12625 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1484 12625 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1485 12625 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a3c, target->state: halted
Debug: 1486 12625 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1487 12625 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1488 12625 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1489 12625 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1490 12625 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1491 12640 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1492 12640 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1493 12640 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1494 12640 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1495 12640 armv7m.c:129 armv7m_restore_context():
Debug: 1496 12640 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1497 12656 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1498 12656 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1499 12656 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1500 12672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1501 12687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1502 12687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1503 12703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1504 12703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1505 12718 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1506 12718 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1507 12734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1508 12734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1509 12750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1510 12750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1511 12765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1512 12765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1513 12781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1514 12781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1515 12797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1516 12797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1517 12812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1518 12812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1519 12828 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1520 12828 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1521 12843 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1522 12843 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1523 12859 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1524 12859 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1525 12859 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1526 12859 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1527 12859 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1528 12859 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1529 12859 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1530 12859 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,4’
Debug: 1531 12859 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000004
Debug: 1532 12859 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08003008
Debug: 1533 12875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 1534 12875 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 1535 12875 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 1536 12875 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 1537 12875 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 1538 12875 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 1539 12890 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 1540 12890 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 1541 12890 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 1542 12890 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 1543 12890 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 1544 12890 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 1545 12890 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 1546 12890 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1547 12890 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 7, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 1548 12890 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 1549 12906 breakpoints.c:127 breakpoint_free(): free BPID: 7 -> 0
Debug: 1550 12906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 1551 12906 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1552 12906 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 8, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 1553 12906 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 1554 12906 breakpoints.c:127 breakpoint_free(): free BPID: 8 -> 0
Debug: 1555 12906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 1556 12906 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1557 12906 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 9, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 1558 12906 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 1559 12922 breakpoints.c:127 breakpoint_free(): free BPID: 9 -> 0
Debug: 1560 12937 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 1561 12937 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 1562 12937 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 1563 12937 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 1564 12953 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 1565 12953 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 1566 12953 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 1567 12953 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 1568 12953 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 1569 12953 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 1570 12968 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 1571 12968 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 1572 12968 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 1573 13078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,2’
Debug: 1574 13078 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000002
Debug: 1575 13078 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08003008
Debug: 1576 22031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 1577 22031 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1578 22031 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 1579 22031 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 1580 22031 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 10, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 1581 22031 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 10)
Debug: 1582 22031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 1583 22031 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1584 22031 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 1585 22031 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 1586 22031 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 11, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 1587 22031 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 11)
Debug: 1588 22031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 1589 22031 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 1590 22047 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 1591 22047 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 1592 22047 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 12, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 1593 22047 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 12)
Debug: 1594 22047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1595 22047 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1596 22047 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1597 22047 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1598 22047 armv7m.c:129 armv7m_restore_context():
Debug: 1599 22047 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1600 22062 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1601 22062 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1602 22062 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1603 22078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1604 22094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1605 22094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1606 22109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1607 22109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1608 22125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1609 22125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1610 22140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1611 22140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1612 22156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1613 22172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1614 22172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1615 22187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1616 22187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1617 22203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1618 22203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1619 22219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1620 22219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1621 22234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1622 22234 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1623 22250 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1624 22250 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1625 22265 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1626 22265 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1627 22265 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1628 22265 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1629 22265 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1630 22265 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1631 22265 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1632 22265 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1633 22281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1634 22281 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1635 22281 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1636 22281 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1637 22281 armv7m.c:129 armv7m_restore_context():
Debug: 1638 22281 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1639 22281 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1640 22281 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1641 22297 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1642 22312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1643 22328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1644 22328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1645 22344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1646 22344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1647 22359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1648 22359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1649 22375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1650 22375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1651 22390 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1652 22390 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1653 22406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1654 22406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1655 22422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1656 22422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1657 22437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1658 22437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1659 22453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1660 22453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1661 22469 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1662 22469 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1663 22484 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1664 22484 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1665 22500 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1666 22500 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1667 22500 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1668 22500 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1669 22500 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1670 22500 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1671 22500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1672 22500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1673 22500 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1674 22500 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1675 22500 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1676 22500 armv7m.c:129 armv7m_restore_context():
Debug: 1677 22500 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1678 22515 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1679 22515 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1680 22531 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1681 22547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1682 22547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1683 22562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1684 22562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1685 22578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1686 22578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1687 22594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1688 22594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1689 22609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1690 22609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1691 22625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1692 22625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1693 22640 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1694 22640 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1695 22656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1696 22656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1697 22672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1698 22672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1699 22687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1700 22687 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1701 22703 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1702 22703 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1703 22719 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1704 22734 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1705 22734 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1706 22734 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1707 22734 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1708 22734 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1709 22734 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1710 22734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1711 22734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1712 22734 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1713 22734 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1714 22734 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1715 22734 armv7m.c:129 armv7m_restore_context():
Debug: 1716 22734 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1717 22750 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1718 22750 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1719 22750 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1720 22765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1721 22781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1722 22781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1723 22797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1724 22797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1725 22812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1726 22812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1727 22828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1728 22828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1729 22844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1730 22844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1731 22859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1732 22859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1733 22875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1734 22875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1735 22890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1736 22890 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1737 22906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1738 22906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1739 22922 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1740 22922 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1741 22937 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1742 22937 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1743 22953 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1744 22953 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1745 22953 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1746 22953 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1747 22953 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1748 22953 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1749 22953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1750 22953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1751 22953 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1752 22953 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1753 22953 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1754 22953 armv7m.c:129 armv7m_restore_context():
Debug: 1755 22969 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1756 22969 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1757 22969 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1758 22984 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1759 23000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1760 23000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1761 23015 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1762 23015 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1763 23031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1764 23031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1765 23047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1766 23047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1767 23062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1768 23062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1769 23078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1770 23078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1771 23094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1772 23094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1773 23109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1774 23109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1775 23125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1776 23125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1777 23140 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1778 23140 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1779 23156 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1780 23156 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1781 23172 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1782 23172 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1783 23172 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1784 23172 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1785 23172 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1786 23172 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1787 23172 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1788 23172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1789 23187 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1790 23187 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1791 23187 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1792 23187 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1793 23187 armv7m.c:129 armv7m_restore_context():
Debug: 1794 23187 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1795 23203 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1796 23203 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1797 23203 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1798 23219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1799 23234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1800 23234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1801 23250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1802 23250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1803 23265 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1804 23265 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1805 23281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1806 23281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1807 23297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1808 23297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1809 23312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1810 23312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1811 23328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1812 23328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1813 23344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1814 23344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1815 23359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1816 23359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1817 23375 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1818 23375 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1819 23390 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1820 23390 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1821 23406 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1822 23406 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1823 23406 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1824 23406 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1825 23406 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1826 23406 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1827 23406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1828 23406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1829 23406 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1830 23422 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1831 23422 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1832 23422 armv7m.c:129 armv7m_restore_context():
Debug: 1833 23422 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1834 23422 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1835 23422 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1836 23437 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1837 23453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1838 23453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1839 23469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1840 23469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1841 23484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1842 23484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1843 23500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1844 23500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1845 23515 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1846 23515 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1847 23531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1848 23531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1849 23547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1850 23547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1851 23562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1852 23562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1853 23578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1854 23578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1855 23594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1856 23594 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1857 23609 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1858 23609 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1859 23625 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1860 23625 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1861 23625 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1862 23625 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1863 23625 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1864 23625 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1865 23640 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1866 23640 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1867 23640 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1868 23640 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1869 23640 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1870 23640 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1871 23640 armv7m.c:129 armv7m_restore_context():
Debug: 1872 23640 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1873 23656 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1874 23656 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1875 23656 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1876 23672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1877 23687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1878 23687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1879 23703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1880 23703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1881 23719 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1882 23719 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1883 23734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1884 23734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1885 23750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1886 23750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1887 23765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1888 23765 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1889 23781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1890 23781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1891 23797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1892 23797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1893 23812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1894 23812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1895 23828 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1896 23828 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1897 23844 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1898 23844 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1899 23859 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1900 23859 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1901 23859 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1902 23859 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1903 23859 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1904 23859 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1905 23859 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1906 23859 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1907 23859 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1908 23859 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1909 23875 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1910 23875 armv7m.c:129 armv7m_restore_context():
Debug: 1911 23875 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1912 23875 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1913 23875 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1914 23891 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1915 23906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1916 23906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1917 23922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1918 23922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1919 23937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1920 23937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1921 23953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1922 23969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1923 23969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1924 23984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1925 23984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1926 24000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1927 24000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1928 24016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1929 24016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1930 24031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1931 24031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1932 24047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1933 24047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1934 24062 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1935 24062 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1936 24078 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1937 24094 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1938 24094 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1939 24094 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1940 24094 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1941 24094 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1942 24094 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1943 24094 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1944 24094 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1945 24109 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1946 24109 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1947 24109 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1948 24109 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1949 24109 armv7m.c:129 armv7m_restore_context():
Debug: 1950 24109 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1951 24109 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1952 24109 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1953 24125 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1954 24141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1955 24141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1956 24156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1957 24156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1958 24172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1959 24172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1960 24187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 1961 24187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 1962 24203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 1963 24203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 1964 24219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 1965 24219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 1966 24234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 1967 24250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 1968 24250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 1969 24266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 1970 24266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 1971 24281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 1972 24281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 1973 24297 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 1974 24297 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 1975 24312 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 1976 24312 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 1977 24328 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 1978 24328 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 1979 24328 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 1980 24328 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 1981 24328 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 1982 24328 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 1983 24328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 1984 24328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 1985 24328 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 1986 24328 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 1987 24328 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 1988 24328 armv7m.c:129 armv7m_restore_context():
Debug: 1989 24328 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 1990 24344 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 1991 24344 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 1992 24359 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 1993 24375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 1994 24375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 1995 24391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 1996 24391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 1997 24406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 1998 24406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 1999 24422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2000 24422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2001 24437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2002 24437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2003 24453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2004 24453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2005 24469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2006 24469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2007 24484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2008 24500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2009 24500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2010 24516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2011 24516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2012 24531 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2013 24531 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2014 24547 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2015 24547 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2016 24562 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2017 24562 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2018 24562 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2019 24562 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2020 24562 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2021 24562 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2022 24562 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2023 24562 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2024 24562 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2025 24562 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2026 24562 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2027 24562 armv7m.c:129 armv7m_restore_context():
Debug: 2028 24562 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2029 24578 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2030 24578 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2031 24578 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2032 24594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2033 24609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2034 24609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2035 24625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2036 24625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2037 24641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2038 24641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2039 24656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2040 24656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2041 24672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2042 24672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2043 24687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2044 24687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2045 24703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2046 24703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2047 24719 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2048 24719 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2049 24734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2050 24750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2051 24750 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2052 24766 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2053 24766 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2054 24781 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2055 24781 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2056 24781 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2057 24781 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2058 24781 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2059 24781 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2060 24781 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2061 24781 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2062 24797 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2063 24797 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2064 24797 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2065 24797 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2066 24797 armv7m.c:129 armv7m_restore_context():
Debug: 2067 24797 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2068 24797 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2069 24797 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2070 24812 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2071 24828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2072 24828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2073 24844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2074 24844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2075 24859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2076 24859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2077 24875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2078 24875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2079 24891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2080 24891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2081 24906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2082 24906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2083 24922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2084 24922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2085 24937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2086 24937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2087 24953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2088 24953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2089 24969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2090 24969 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2091 24984 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2092 24984 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2093 25000 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2094 25000 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2095 25000 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2096 25000 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2097 25000 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2098 25016 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2099 25016 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2100 25016 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2101 25016 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2102 25016 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2103 25016 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2104 25016 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2105 25016 armv7m.c:129 armv7m_restore_context():
Debug: 2106 25016 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2107 25016 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2108 25016 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2109 25031 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2110 25047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2111 25047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2112 25062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2113 25062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2114 25078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2115 25094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2116 25094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2117 25109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2118 25109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2119 25125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2120 25125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2121 25141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2122 25141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2123 25156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2124 25156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2125 25172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2126 25172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2127 25187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2128 25187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2129 25203 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2130 25203 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2131 25219 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2132 25219 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2133 25234 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2134 25234 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2135 25234 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2136 25234 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2137 25234 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2138 25234 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2139 25234 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2140 25234 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2141 25234 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2142 25234 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2143 25234 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2144 25234 armv7m.c:129 armv7m_restore_context():
Debug: 2145 25234 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2146 25250 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2147 25250 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2148 25266 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2149 25266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2150 25281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2151 25297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2152 25297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2153 25312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2154 25312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2155 25328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2156 25328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2157 25344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2158 25344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2159 25359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2160 25359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2161 25375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2162 25375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2163 25391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2164 25391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2165 25406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2166 25406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2167 25422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2168 25422 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2169 25437 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2170 25437 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2171 25453 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2172 25453 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2173 25453 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2174 25469 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2175 25469 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2176 25469 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2177 25469 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2178 25469 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2179 25469 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2180 25469 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2181 25469 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2182 25469 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2183 25469 armv7m.c:129 armv7m_restore_context():
Debug: 2184 25469 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2185 25469 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2186 25469 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2187 25484 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2188 25500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2189 25500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2190 25516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2191 25531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2192 25531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2193 25547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2194 25547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2195 25562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2196 25562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2197 25578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2198 25578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2199 25594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2200 25594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2201 25609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2202 25609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2203 25625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2204 25625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2205 25641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2206 25641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2207 25656 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2208 25672 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2209 25672 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2210 25687 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2211 25687 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2212 25687 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2213 25687 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2214 25687 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2215 25687 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2216 25687 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2217 25687 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2218 25687 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2219 25687 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2220 25687 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2221 25687 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2222 25687 armv7m.c:129 armv7m_restore_context():
Debug: 2223 25687 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2224 25703 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2225 25703 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2226 25719 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2227 25734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2228 25734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2229 25750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2230 25750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2231 25766 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2232 25766 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2233 25781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2234 25781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2235 25797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2236 25797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2237 25812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2238 25812 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2239 25828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2240 25828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2241 25844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2242 25844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2243 25859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2244 25859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2245 25875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2246 25875 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2247 25891 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2248 25891 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2249 25906 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2250 25922 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2251 25922 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2252 25922 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2253 25922 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2254 25922 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2255 25922 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2256 25922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2257 25922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2258 25922 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2259 25922 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2260 25922 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2261 25922 armv7m.c:129 armv7m_restore_context():
Debug: 2262 25922 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2263 25937 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2264 25937 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2265 25937 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2266 25953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2267 25969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2268 25969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2269 25984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2270 25984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2271 26000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2272 26016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2273 26016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2274 26031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2275 26031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2276 26047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2277 26047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2278 26062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2279 26062 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2280 26078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2281 26094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2282 26094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2283 26109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2284 26109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2285 26125 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2286 26125 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2287 26141 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2288 26141 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2289 26156 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2290 26156 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2291 26156 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2292 26156 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2293 26156 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2294 26156 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2295 26156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2296 26156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2297 26156 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2298 26156 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2299 26156 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2300 26156 armv7m.c:129 armv7m_restore_context():
Debug: 2301 26156 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2302 26172 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2303 26172 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2304 26187 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2305 26187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2306 26203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2307 26203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2308 26219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2309 26219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2310 26234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2311 26234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2312 26250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2313 26250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2314 26266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2315 26266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2316 26281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2317 26281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2318 26297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2319 26297 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2320 26312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2321 26312 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2322 26328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2323 26328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2324 26344 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2325 26344 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2326 26359 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2327 26359 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2328 26375 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2329 26375 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2330 26375 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2331 26375 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2332 26375 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2333 26375 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2334 26375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2335 26375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2336 26375 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2337 26375 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2338 26375 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2339 26375 armv7m.c:129 armv7m_restore_context():
Debug: 2340 26375 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2341 26391 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2342 26391 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2343 26406 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2344 26422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2345 26422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2346 26437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2347 26437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2348 26453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2349 26453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2350 26469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2351 26469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2352 26484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2353 26484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2354 26500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2355 26500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2356 26516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2357 26516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2358 26531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2359 26531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2360 26547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2361 26547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2362 26562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2363 26562 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2364 26578 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2365 26594 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2366 26594 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2367 26609 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2368 26609 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2369 26609 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2370 26609 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2371 26609 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2372 26609 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2373 26609 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2374 26609 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2375 26609 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2376 26609 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2377 26625 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2378 26625 armv7m.c:129 armv7m_restore_context():
Debug: 2379 26625 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2380 26625 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2381 26625 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2382 26641 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2383 26656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2384 26656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2385 26672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2386 26672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2387 26687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2388 26687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2389 26703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2390 26719 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2391 26719 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2392 26734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2393 26734 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2394 26750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2395 26750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2396 26766 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2397 26766 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2398 26781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2399 26781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2400 26797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2401 26797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2402 26812 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2403 26812 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2404 26828 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2405 26828 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2406 26844 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2407 26844 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2408 26844 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2409 26844 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2410 26844 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2411 26844 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2412 26844 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2413 26844 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2414 26844 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2415 26844 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2416 26844 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2417 26844 armv7m.c:129 armv7m_restore_context():
Debug: 2418 26844 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2419 26859 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2420 26859 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2421 26875 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2422 26891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2423 26891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2424 26906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2425 26906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2426 26922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2427 26922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2428 26937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2429 26937 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2430 26953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2431 26953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2432 26969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2433 26969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2434 26984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2435 26984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2436 27000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2437 27000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2438 27016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2439 27016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2440 27031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2441 27031 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2442 27047 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2443 27047 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2444 27062 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2445 27062 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2446 27062 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2447 27062 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2448 27062 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2449 27062 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2450 27062 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2451 27062 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2452 27078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2453 27078 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2454 27078 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2455 27078 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2456 27078 armv7m.c:129 armv7m_restore_context():
Debug: 2457 27078 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2458 27094 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2459 27094 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2460 27109 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2461 27109 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2462 27125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2463 27125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2464 27141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2465 27141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2466 27156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2467 27156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2468 27172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2469 27172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2470 27187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2471 27187 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2472 27203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2473 27203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2474 27219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2475 27219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2476 27234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2477 27234 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2478 27250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2479 27250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2480 27266 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2481 27281 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2482 27281 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2483 27297 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2484 27297 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2485 27297 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2486 27297 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2487 27297 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2488 27297 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2489 27297 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2490 27297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2491 27297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2492 27297 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2493 27297 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2494 27297 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2495 27297 armv7m.c:129 armv7m_restore_context():
Debug: 2496 27312 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2497 27312 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2498 27312 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2499 27328 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2500 27328 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2501 27344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2502 27344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2503 27359 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2504 27375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2505 27375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2506 27391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2507 27391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2508 27406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2509 27406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2510 27422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2511 27422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2512 27437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2513 27437 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2514 27453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2515 27453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2516 27469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2517 27469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2518 27484 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2519 27484 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2520 27500 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2521 27500 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2522 27516 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2523 27516 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2524 27516 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2525 27531 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2526 27531 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2527 27531 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2528 27531 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2529 27531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘’
Info : 2530 27531 gdb_server.c:2328 gdb_input_inner(): The target is not running when halt was requested, stopping GDB.
Debug: 2531 27531 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2532 27531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Info : 2533 27531 gdb_server.c:2328 gdb_input_inner(): The target is not running when halt was requested, stopping GDB.
Debug: 2534 27531 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2535 27531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 2536 27531 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2537 27531 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2538 27531 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 2539 27531 armv7m.c:129 armv7m_restore_context():
Debug: 2540 27531 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2541 27531 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 2542 27531 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2543 27547 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2544 27562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2545 27562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2546 27578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2547 27594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2548 27594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2549 27609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2550 27609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2551 27625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2552 27625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2553 27641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2554 27641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2555 27656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2556 27656 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2557 27672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2558 27672 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2559 27687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2560 27687 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2561 27703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2562 27703 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2563 27719 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2564 27719 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2565 27734 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2566 27734 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2567 27750 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2568 27750 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2569 27750 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2570 27750 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2571 27750 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2572 27750 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 2573 27750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2574 27766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 2575 27766 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2576 27766 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 10, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 2577 27766 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 2578 27766 breakpoints.c:127 breakpoint_free(): free BPID: 10 -> 0
Debug: 2579 27766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 2580 27766 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2581 27766 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 11, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 2582 27766 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 2583 27766 breakpoints.c:127 breakpoint_free(): free BPID: 11 -> 0
Debug: 2584 27766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 2585 27766 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2586 27766 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 12, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 2587 27781 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 2588 27781 breakpoints.c:127 breakpoint_free(): free BPID: 12 -> 0
Debug: 2589 27781 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,4’
Debug: 2590 27781 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000004
Debug: 2591 27781 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08003008
Debug: 2592 27797 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 2593 27812 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 2594 27812 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 2595 27812 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 2596 27812 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2597 27812 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2598 27812 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2599 27828 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 2600 27828 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2601 27828 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2602 27828 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2603 27828 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 2604 27828 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 2605 27844 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 2606 27844 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 2607 27844 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 2608 27844 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2609 27844 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2610 27844 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2611 27844 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 2612 27859 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2613 27859 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2614 27859 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2615 27859 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 2616 27859 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 2617 29484 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 2618 29484 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2619 29484 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 2620 29484 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 2621 29500 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 13, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 2622 29500 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 13)
Debug: 2623 29500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 2624 29500 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2625 29500 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 2626 29500 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 2627 29500 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 14, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 2628 29500 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 14)
Debug: 2629 29500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 2630 29500 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2631 29500 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 2632 29500 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 2633 29500 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 15, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 2634 29500 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 15)
Debug: 2635 29500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 2636 29516 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 2637 29516 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 2638 29516 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 2639 29516 armv7m.c:129 armv7m_restore_context():
Debug: 2640 29516 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 2641 29516 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x8003009
Debug: 2642 31359 gdb_server.c:2147 gdb_input_inner(): received packet: ‘’
Debug: 2643 31359 cortex_m3.c:499 cortex_m3_halt(): target->state: running
Debug: 2644 31484 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2645 31484 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 2646 31500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2647 31516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2648 31516 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2649 31531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2650 31531 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2651 31547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2652 31547 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2653 31562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2654 31562 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2655 31578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2656 31578 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2657 31594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2658 31594 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2659 31609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 2660 31609 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 2661 31625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 2662 31625 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 2663 31641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 2664 31641 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2665 31656 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2666 31656 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 2667 31672 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2668 31672 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2669 31687 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 2670 31687 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 2671 31687 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2672 31687 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 2673 31687 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2674 31687 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2675 31687 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 2676 31687 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2677 31687 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 13, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 2678 31687 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 2679 31703 breakpoints.c:127 breakpoint_free(): free BPID: 13 -> 0
Debug: 2680 31703 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 2681 31703 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2682 31703 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 14, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 2683 31703 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 2684 31703 breakpoints.c:127 breakpoint_free(): free BPID: 14 -> 0
Debug: 2685 31703 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 2686 31703 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 2687 31703 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 15, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 2688 31703 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 2689 31703 breakpoints.c:127 breakpoint_free(): free BPID: 15 -> 0
Debug: 2690 31703 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,4’
Debug: 2691 31703 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000004
Debug: 2692 31719 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08003008
Debug: 2693 31734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 2694 31734 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 2695 31734 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 2696 31734 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 2697 31750 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2698 31750 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2699 31750 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2700 31750 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 2701 31766 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2702 31766 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2703 31766 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2704 31766 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 2705 31766 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 2706 31766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 2707 31766 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 2708 31766 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 2709 31766 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2710 31766 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2711 31781 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2712 31781 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 2713 31781 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2714 31781 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2715 31781 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2716 31797 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 2717 31797 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 2718 34984 gdb_server.c:2147 gdb_input_inner(): received packet: ‘k’
Debug: 2719 34984 gdb_server.c:875 gdb_connection_closed(): GDB Close, Target: stm32.cpu, state: halted, gdb_actual_connections=0
Debug: 2720 34984 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2721 34984 target.c:968 target_call_event_callbacks(): target event 26 (gdb-detach)
Info : 2722 34984 server.c:455 server_loop(): dropped ‘gdb’ connection - error -400
Info : 2723 40406 server.c:81 add_connection(): accepting ‘gdb’ connection from 0
Debug: 2724 40406 breakpoints.c:161 breakpoint_clear_target(): Delete all breakpoints for target: stm32.cpu
Debug: 2725 40406 breakpoints.c:299 watchpoint_clear_target(): Delete all watchpoints for target: stm32.cpu
Debug: 2726 40406 target.c:968 target_call_event_callbacks(): target event 25 (gdb-attach)
Debug: 2727 40406 gdb_server.c:856 gdb_new_connection(): New GDB Connection: 1, Target stm32.cpu, state: halted
Debug: 2728 40406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSupported’
Debug: 2729 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘QStartNoAckMode’
Warn : 2730 40422 gdb_server.c:649 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 2731 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hg0’
Debug: 2732 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘?’
Debug: 2733 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc-1’
Debug: 2734 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qC’
Debug: 2735 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qAttached’
Debug: 2736 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qOffsets’
Debug: 2737 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2738 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qXfer:memory-map:read::0,fff’
Debug: 2739 40422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,4’
Debug: 2740 40422 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000004
Debug: 2741 40422 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08003008
Debug: 2742 40438 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSymbol::’
Debug: 2743 40469 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,72657365742068616c74’
Debug: 2744 40469 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_reset halt
Debug: 2745 40469 command.c:133 script_debug(): command - reset ocd_reset halt
Debug: 2747 40484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 2748 40484 command.c:133 script_debug(): command - ocd_target ocd_target names
Debug: 2749 40484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-start
Debug: 2750 40484 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-start
Debug: 2751 40484 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 2752 40484 command.c:133 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 2753 40484 core.c:1451 jtag_init_reset(): Initializing with hard TRST+SRST reset
Debug: 2754 40484 core.c:685 jtag_add_reset(): JTAG reset with TLR instead of TRST
Debug: 2755 40484 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 2756 40484 core.c:1364 jtag_init_inner(): Init JTAG chain
Debug: 2757 40484 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 2758 40484 core.c:1017 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS
Debug: 2759 40484 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Info : 2760 40500 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : 2761 40500 core.c:917 jtag_examine_chain_display(): JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Debug: 2762 40500 core.c:1182 jtag_validate_ircapture(): IR capture validation scan
Debug: 2763 40500 core.c:1243 jtag_validate_ircapture(): stm32.cpu: IR capture 0x01
Debug: 2764 40500 core.c:1243 jtag_validate_ircapture(): stm32.bs: IR capture 0x01
Debug: 2765 40500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 2766 40500 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 2767 40500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 2768 40500 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 2769 40500 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_examine
Debug: 2770 40500 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_examine
Debug: 2771 40500 arm_adi_v5.c:1204 ahbap_debugport_init():
Debug: 2772 40516 arm_adi_v5.c:1265 ahbap_debugport_init(): MEM-AP #0 ID Register 0x14770011, Debug ROM Address 0xe00ff003
Debug: 2773 40516 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 2774 40516 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-pre
Debug: 2775 40516 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 2776 40516 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 2777 40516 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 2778 40516 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 2779 40516 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset assert 1
Debug: 2780 40516 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset assert 1
Debug: 2781 40516 cortex_m3.c:784 cortex_m3_assert_reset(): target->state: halted
Debug: 2782 40531 cortex_m3.c:891 cortex_m3_assert_reset(): Using Cortex-M3 SYSRESETREQ
Debug: 2783 40531 cortex_m3.c:499 cortex_m3_halt(): target->state: reset
Debug: 2784 40531 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-assert-post
Debug: 2785 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-assert-post
Debug: 2786 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 2787 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-pre
Debug: 2788 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 2789 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 2790 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 2791 40547 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 2792 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_reset deassert 1
Debug: 2793 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_reset deassert 1
Debug: 2794 40547 cortex_m3.c:921 cortex_m3_deassert_reset(): target->state: reset
Debug: 2795 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 2796 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-deassert-post
Debug: 2797 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu cget -chain-position
Debug: 2798 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu cget -chain-position
Debug: 2799 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32.cpu
Debug: 2800 40547 command.c:133 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32.cpu
Debug: 2801 40547 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu arp_waitstate halted 1000
Debug: 2802 40547 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu arp_waitstate halted 1000
Debug: 2803 40609 cortex_m3.c:452 cortex_m3_poll(): Exit from reset with dcb_dhcsr 0x30003
Debug: 2804 40625 cortex_m3.c:195 cortex_m3_endreset_event(): DCB_DEMCR = 0x01000501
Debug: 2805 40625 target.c:1565 target_write_u32(): address: 0xe0002000, value: 0x00000003
Debug: 2806 40625 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 2807 40641 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 2808 40641 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 2809 40641 target.c:1565 target_write_u32(): address: 0xe0002014, value: 0x00000000
Debug: 2810 40641 target.c:1565 target_write_u32(): address: 0xe0002018, value: 0x00000000
Debug: 2811 40656 target.c:1565 target_write_u32(): address: 0xe000201c, value: 0x00000000
Debug: 2812 40656 target.c:1565 target_write_u32(): address: 0xe0002020, value: 0x00000000
Debug: 2813 40656 target.c:1565 target_write_u32(): address: 0xe0002024, value: 0x00000000
Debug: 2814 40656 target.c:1565 target_write_u32(): address: 0xe0001020, value: 0x00000000
Debug: 2815 40672 target.c:1565 target_write_u32(): address: 0xe0001024, value: 0x00000000
Debug: 2816 40672 target.c:1565 target_write_u32(): address: 0xe0001028, value: 0x00000000
Debug: 2817 40672 target.c:1565 target_write_u32(): address: 0xe0001030, value: 0x00000000
Debug: 2818 40688 target.c:1565 target_write_u32(): address: 0xe0001034, value: 0x00000000
Debug: 2819 40688 target.c:1565 target_write_u32(): address: 0xe0001038, value: 0x00000000
Debug: 2820 40688 target.c:1565 target_write_u32(): address: 0xe0001040, value: 0x00000000
Debug: 2821 40688 target.c:1565 target_write_u32(): address: 0xe0001044, value: 0x00000000
Debug: 2822 40703 target.c:1565 target_write_u32(): address: 0xe0001048, value: 0x00000000
Debug: 2823 40703 target.c:1565 target_write_u32(): address: 0xe0001050, value: 0x00000000
Debug: 2824 40703 target.c:1565 target_write_u32(): address: 0xe0001054, value: 0x00000000
Debug: 2825 40703 target.c:1565 target_write_u32(): address: 0xe0001058, value: 0x00000000
Debug: 2826 40719 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2827 40734 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x9
Debug: 2828 40750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 2829 40750 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 2830 40766 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 2831 40766 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 2832 40781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2833 40781 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2834 40797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2835 40797 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2836 40813 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2837 40813 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2838 40828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2839 40828 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2840 40844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2841 40844 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20005000
Debug: 2842 40859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 2843 40859 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8002fc8
Debug: 2844 40875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x1000000
Debug: 2845 40875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20005000
Debug: 2846 40891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2847 40891 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 2848 40906 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 2849 40906 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2850 40922 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2851 40922 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8002fc8, target->state: halted
Debug: 2852 40922 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 2853 40922 target.c:968 target_call_event_callbacks(): target event 3 (halted)
User : 2854 40922 target.c:1234 target_arch_state(): target state: halted
User : 2855 40922 armv7m.c:489 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08002fc8 msp: 0x20005000
Debug: 2856 40922 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 2857 40922 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu curstate
Debug: 2858 40922 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu curstate
Debug: 2859 40922 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32.cpu invoke-event reset-end
Debug: 2860 40922 command.c:133 script_debug(): command - ocd_stm32.cpu ocd_stm32.cpu invoke-event reset-end
Debug: 2861 40953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qfThreadInfo’
Debug: 2862 40953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 2863 40953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 2864 40953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 2865 40953 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 2866 40969 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2867 40969 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2868 40969 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2869 40969 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 2870 40969 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2871 40984 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2872 40984 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2873 40984 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 2874 40984 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 2875 40984 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 2876 40984 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 2877 40984 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 2878 40984 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2879 40984 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2880 41000 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2881 41000 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 2882 41000 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 2883 41000 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 2884 41000 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 2885 41016 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 2886 41016 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 2887 41016 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,706f6c6c’
Debug: 2888 41031 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_poll
Debug: 2889 41031 command.c:133 script_debug(): command - poll ocd_poll
User : 2891 41031 command.c:539 command_print(): background polling: on
User : 2892 41031 command.c:539 command_print(): TAP: stm32.cpu (enabled)
User : 2893 41063 target.c:1234 target_arch_state(): target state: halted
User : 2894 41063 armv7m.c:489 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
Debug: 2895 41078 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,73746d333278206d6173735f65726173652030’
Debug: 2896 41078 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_stm32x mass_erase 0
Debug: 2897 41078 command.c:133 script_debug(): command - ocd_stm32x ocd_stm32x mass_erase 0
Debug: 2899 41094 target.c:1565 target_write_u32(): address: 0x40022004, value: 0x45670123
Debug: 2900 41094 target.c:1565 target_write_u32(): address: 0x40022004, value: 0xcdef89ab
Debug: 2901 41094 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000004
Debug: 2902 41094 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000044
Debug: 2903 41109 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 2904 41109 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 2905 41109 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 2906 41109 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 2907 41125 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000003
Debug: 2908 41125 stm32x.c:75 stm32x_wait_status_busy(): status: 0x3
Debug: 2909 41125 target.c:1488 target_read_u32(): address: 0x4002200c, value: 0x00000020
Debug: 2910 41125 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000080
User : 2911 41125 command.c:539 command_print(): stm32x mass erase complete
Debug: 2912 41172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,666c6173682077726974655f696d616765206d61696e2e6f7574’
Debug: 2913 41172 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_flash write_image main.out
Debug: 2914 41172 command.c:133 script_debug(): command - ocd_flash ocd_flash write_image main.out
Debug: 2916 41188 configuration.c:87 find_file(): found main.out
Debug: 2917 41188 image.c:76 autodetect_image_type(): ELF image detected.
Debug: 2918 41188 configuration.c:87 find_file(): found main.out
Info : 2919 41188 core.c:546 flash_write_unlock(): Padding image section 0 with 0 bytes
Debug: 2920 41188 image.c:497 image_elf_read_section(): load segment 0 at 0x0 (sz = 0x304a)
Debug: 2921 41188 image.c:505 image_elf_read_section(): read elf: size = 0x12362 at 0x8000
Debug: 2922 41188 image.c:497 image_elf_read_section(): load segment 1 at 0x0 (sz = 0x8)
Debug: 2923 41188 image.c:505 image_elf_read_section(): read elf: size = 0x8 at 0x10000
Debug: 2924 41188 target.c:1565 target_write_u32(): address: 0x40022004, value: 0x45670123
Debug: 2925 41188 target.c:1565 target_write_u32(): address: 0x40022004, value: 0xcdef89ab
Debug: 2926 41203 target.c:1072 target_alloc_working_area(): MMU disabled, using physical address for working memory 0x20000000
Debug: 2927 41203 target.c:1134 target_alloc_working_area(): allocated new working area at address 0x20000000
Debug: 2928 41203 target.c:1251 target_write_buffer(): writing buffer of 48 byte at 0x20000000
Debug: 2929 41203 target.c:1134 target_alloc_working_area(): allocated new working area at address 0x20000030
Debug: 2930 41203 target.c:1251 target_write_buffer(): writing buffer of 12370 byte at 0x20000030
Debug: 2931 41438 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 16, Type: 1, Address: 0x20000026 Length: 2 (set=1)
Debug: 2932 41438 breakpoints.c:102 breakpoint_add(): added software breakpoint at 0x20000026 of length 0x00000002, (BPID: 16)
Debug: 2933 41438 armv7m.c:129 armv7m_restore_context():
Debug: 2934 41453 cortex_m3.c:1458 cortex_m3_store_core_reg_u32(): write special reg 19 value 0x1
Debug: 2935 41453 armv7m.c:242 armv7m_write_core_reg(): write core reg 19 value 0x1
Debug: 2936 41469 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 16 value 0x1000000
Debug: 2937 41469 armv7m.c:242 armv7m_write_core_reg(): write core reg 16 value 0x1000000
Debug: 2938 41484 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 15 value 0x20000000
Debug: 2939 41484 armv7m.c:242 armv7m_write_core_reg(): write core reg 15 value 0x20000000
Debug: 2940 41484 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 3 value 0xad2e80
Debug: 2941 41484 armv7m.c:242 armv7m_write_core_reg(): write core reg 3 value 0xad2e80
Debug: 2942 41500 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 2 value 0x1829
Debug: 2943 41500 armv7m.c:242 armv7m_write_core_reg(): write core reg 2 value 0x1829
Debug: 2944 41500 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 1 value 0x8000000
Debug: 2945 41500 armv7m.c:242 armv7m_write_core_reg(): write core reg 1 value 0x8000000
Debug: 2946 41516 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 0 value 0x20000030
Debug: 2947 41516 armv7m.c:242 armv7m_write_core_reg(): write core reg 0 value 0x20000030
Debug: 2948 41516 target.c:968 target_call_event_callbacks(): target event 22 (debug-resumed)
Debug: 2949 41516 cortex_m3.c:703 cortex_m3_resume(): target debug resumed at 0x20000000
Debug: 2950 41516 target.c:2041 target_wait_state(): waiting for target halted…
Debug: 2951 41844 cortex_m3.c:471 cortex_m3_poll():
Debug: 2952 41844 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 2953 41859 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 2954 41875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20003082
Debug: 2955 41875 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x8003052
Debug: 2956 41891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x0
Debug: 2957 41891 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x23
Debug: 2958 41906 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 2959 41922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 2960 41922 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 2961 41938 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 2962 41938 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 2963 41953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 2964 41953 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 2965 41969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 2966 41969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 2967 41984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20005000
Debug: 2968 41984 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 2969 42000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x20000026
Debug: 2970 42000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 2971 42016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20005000
Debug: 2972 42016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 2973 42031 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x1
Debug: 2974 42031 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 2975 42047 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 2976 42047 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 2977 42047 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x20000026, target->state: halted
Debug: 2978 42047 target.c:968 target_call_event_callbacks(): target event 21 (debug-halted)
Debug: 2979 42063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x20000026
Debug: 2980 42063 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 16, Type: 1, Address: 0x20000026 Length: 2 (set=1)
Debug: 2981 42063 breakpoints.c:127 breakpoint_free(): free BPID: 16 -> 0
Debug: 2982 42063 armv7m.c:459 armv7m_run_algorithm(): restoring register primask with value 0x00000000
Debug: 2983 42063 armv7m.c:459 armv7m_run_algorithm(): restoring register xPSR with value 0x01000000
Debug: 2984 42063 armv7m.c:459 armv7m_run_algorithm(): restoring register pc with value 0x08002fc8
Debug: 2985 42063 armv7m.c:459 armv7m_run_algorithm(): restoring register r3 with value 0x00000400
Debug: 2986 42063 armv7m.c:459 armv7m_run_algorithm(): restoring register r2 with value 0x00000400
Debug: 2987 42078 armv7m.c:459 armv7m_run_algorithm(): restoring register r1 with value 0x000000a5
Debug: 2988 42078 armv7m.c:459 armv7m_run_algorithm(): restoring register r0 with value 0x200001f8
Debug: 2989 42078 target.c:1565 target_write_u32(): address: 0x40022010, value: 0x00000080
User : 2990 42078 command.c:539 command_print(): wrote 12370 bytes from file main.out in 0.890637s (13.563 kb/s)
Debug: 2991 42188 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 2992 42281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8002fc8,4’
Debug: 2993 42281 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08002fc8, len: 0x00000004
Debug: 2994 42281 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08002fc8
Debug: 2995 42297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,2’
Debug: 2996 42297 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000002
Debug: 2997 42297 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000112
Debug: 2998 42484 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000168,2’
Debug: 2999 42484 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000168, len: 0x00000002
Debug: 3000 42484 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000168
Debug: 3001 42516 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2a,2’
Debug: 3002 42516 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2a, len: 0x00000002
Debug: 3003 42516 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2a
Debug: 3004 42563 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,2’
Debug: 3005 42563 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000002
Debug: 3006 42563 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08003008
Debug: 3007 42578 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,2’
Debug: 3008 42594 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000002
Debug: 3009 42594 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000112
Debug: 3010 42609 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffffe,4’
Debug: 3011 42609 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffffe, len: 0x00000004
Debug: 3012 42609 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffffe
Error: 3013 42609 target.c:1350 target_read_buffer(): address + size wrapped(0xfffffffe, 0x00000004)
Debug: 3014 42609 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffffe,4’
Debug: 3015 42609 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffffe, len: 0x00000004
Debug: 3016 42609 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffffe
Error: 3017 42609 target.c:1350 target_read_buffer(): address + size wrapped(0xfffffffe, 0x00000004)
Debug: 3018 46719 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 3019 46735 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3020 46735 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 3021 46735 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 3022 46735 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 17, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 3023 46735 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 17)
Debug: 3024 46735 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 3025 46735 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3026 46735 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 3027 46735 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 3028 46735 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 18, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 3029 46735 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 18)
Debug: 3030 46735 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 3031 46735 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3032 46735 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 3033 46750 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 3034 46750 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 19, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 3035 46750 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 19)
Debug: 3036 46750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘vCont?’
Debug: 3037 46750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 3038 46750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 3039 46750 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 3040 46750 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 3041 46750 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 3042 46750 target.c:1516 target_read_u16(): address: 0x08002fc8, value: 0x2100
Debug: 3043 46750 armv7m.c:129 armv7m_restore_context():
Debug: 3044 46766 cortex_m3.c:1458 cortex_m3_store_core_reg_u32(): write special reg 19 value 0x0
Debug: 3045 46766 armv7m.c:242 armv7m_write_core_reg(): write core reg 19 value 0x0
Debug: 3046 46781 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 16 value 0x1000000
Debug: 3047 46781 armv7m.c:242 armv7m_write_core_reg(): write core reg 16 value 0x1000000
Debug: 3048 46797 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 15 value 0x8002fc9
Debug: 3049 46797 armv7m.c:242 armv7m_write_core_reg(): write core reg 15 value 0x8002fc9
Debug: 3050 46797 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 3 value 0x400
Debug: 3051 46797 armv7m.c:242 armv7m_write_core_reg(): write core reg 3 value 0x400
Debug: 3052 46813 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 2 value 0x400
Debug: 3053 46813 armv7m.c:242 armv7m_write_core_reg(): write core reg 2 value 0x400
Debug: 3054 46813 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 1 value 0xa5
Debug: 3055 46813 armv7m.c:242 armv7m_write_core_reg(): write core reg 1 value 0xa5
Debug: 3056 46828 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 0 value 0x200001f8
Debug: 3057 46828 armv7m.c:242 armv7m_write_core_reg(): write core reg 0 value 0x200001f8
Debug: 3058 46828 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 3059 46828 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x8002fc9
Debug: 3060 46938 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 3061 46953 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 3062 46969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20000000
Debug: 3063 46969 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x8
Debug: 3064 46985 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200045a8
Debug: 3065 46985 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200045a8
Debug: 3066 47000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 3067 47000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 3068 47016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 3069 47016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004ff8
Debug: 3070 47031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 3071 47031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 3072 47047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 3073 47047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 3074 47063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 3075 47063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004fe8
Debug: 3076 47078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x8002ff3
Debug: 3077 47078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8000112
Debug: 3078 47094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 3079 47094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004fe8
Debug: 3080 47110 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 3081 47110 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 3082 47125 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 3083 47141 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 3084 47141 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 3085 47141 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8000112, target->state: halted
Debug: 3086 47141 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 3087 47141 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 3088 47141 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 3089 47141 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 3090 47141 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 3091 47141 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3092 47156 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 17, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 3093 47156 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 3094 47156 breakpoints.c:127 breakpoint_free(): free BPID: 17 -> 0
Debug: 3095 47156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 3096 47156 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3097 47156 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 18, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 3098 47156 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 3099 47156 breakpoints.c:127 breakpoint_free(): free BPID: 18 -> 0
Debug: 3100 47156 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 3101 47156 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3102 47156 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 19, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 3103 47156 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 3104 47172 breakpoints.c:127 breakpoint_free(): free BPID: 19 -> 0
Debug: 3105 47172 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,4’
Debug: 3106 47172 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000004
Debug: 3107 47172 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08000112
Debug: 3108 47188 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 3109 47266 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800010c,2’
Debug: 3110 47266 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800010c, len: 0x00000002
Debug: 3111 47266 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800010c
Debug: 3112 47281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800010e,2’
Debug: 3113 47281 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800010e, len: 0x00000002
Debug: 3114 47281 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800010e
Debug: 3115 47281 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000110,2’
Debug: 3116 47281 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000110, len: 0x00000002
Debug: 3117 47281 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000110
Debug: 3118 47297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000112,2’
Debug: 3119 47297 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000112, len: 0x00000002
Debug: 3120 47297 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000112
Debug: 3121 47297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000114,2’
Debug: 3122 47297 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000114, len: 0x00000002
Debug: 3123 47297 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000114
Debug: 3124 47313 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000116,2’
Debug: 3125 47313 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000116, len: 0x00000002
Debug: 3126 47313 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000116
Debug: 3127 47313 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000118,2’
Debug: 3128 47313 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000118, len: 0x00000002
Debug: 3129 47313 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000118
Debug: 3130 47328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800011a,2’
Debug: 3131 47328 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800011a, len: 0x00000002
Debug: 3132 47328 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800011a
Debug: 3133 47328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800011c,2’
Debug: 3134 47328 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800011c, len: 0x00000002
Debug: 3135 47328 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800011c
Debug: 3136 47344 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800011e,2’
Debug: 3137 47344 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800011e, len: 0x00000002
Debug: 3138 47344 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800011e
Debug: 3139 47344 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000120,2’
Debug: 3140 47344 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000120, len: 0x00000002
Debug: 3141 47344 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000120
Debug: 3142 47344 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000122,2’
Debug: 3143 47344 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000122, len: 0x00000002
Debug: 3144 47344 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000122
Debug: 3145 47360 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000124,2’
Debug: 3146 47360 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000124, len: 0x00000002
Debug: 3147 47360 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000124
Debug: 3148 47375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000126,2’
Debug: 3149 47375 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000126, len: 0x00000002
Debug: 3150 47375 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000126
Debug: 3151 47375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000128,2’
Debug: 3152 47375 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000128, len: 0x00000002
Debug: 3153 47375 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000128
Debug: 3154 47375 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800012a,2’
Debug: 3155 47375 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800012a, len: 0x00000002
Debug: 3156 47391 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800012a
Debug: 3157 47391 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800012c,2’
Debug: 3158 47391 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800012c, len: 0x00000002
Debug: 3159 47391 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800012c
Debug: 3160 47391 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800012e,2’
Debug: 3161 47391 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800012e, len: 0x00000002
Debug: 3162 47391 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800012e
Debug: 3163 47406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000130,2’
Debug: 3164 47406 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000130, len: 0x00000002
Debug: 3165 47406 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000130
Debug: 3166 47406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000132,2’
Debug: 3167 47406 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000132, len: 0x00000002
Debug: 3168 47406 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000132
Debug: 3169 47406 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000134,2’
Debug: 3170 47406 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000134, len: 0x00000002
Debug: 3171 47406 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000134
Debug: 3172 47422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000136,2’
Debug: 3173 47422 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000136, len: 0x00000002
Debug: 3174 47422 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000136
Debug: 3175 47422 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000138,2’
Debug: 3176 47422 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000138, len: 0x00000002
Debug: 3177 47422 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000138
Debug: 3178 47438 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800013a,2’
Debug: 3179 47438 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800013a, len: 0x00000002
Debug: 3180 47438 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800013a
Debug: 3181 47438 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800013c,2’
Debug: 3182 47438 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800013c, len: 0x00000002
Debug: 3183 47438 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800013c
Debug: 3184 47438 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800013e,2’
Debug: 3185 47438 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800013e, len: 0x00000002
Debug: 3186 47438 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800013e
Debug: 3187 47453 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000140,2’
Debug: 3188 47453 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000140, len: 0x00000002
Debug: 3189 47453 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000140
Debug: 3190 47453 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000142,2’
Debug: 3191 47453 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000142, len: 0x00000002
Debug: 3192 47453 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000142
Debug: 3193 47453 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000144,2’
Debug: 3194 47453 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000144, len: 0x00000002
Debug: 3195 47453 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000144
Debug: 3196 47469 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000146,2’
Debug: 3197 47469 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000146, len: 0x00000002
Debug: 3198 47469 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000146
Debug: 3199 47469 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000148,2’
Debug: 3200 47469 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000148, len: 0x00000002
Debug: 3201 47469 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000148
Debug: 3202 47485 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800014a,2’
Debug: 3203 47485 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800014a, len: 0x00000002
Debug: 3204 47485 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800014a
Debug: 3205 47485 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800014c,2’
Debug: 3206 47485 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800014c, len: 0x00000002
Debug: 3207 47485 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800014c
Debug: 3208 47485 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800014e,2’
Debug: 3209 47485 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800014e, len: 0x00000002
Debug: 3210 47485 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800014e
Debug: 3211 47500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000150,2’
Debug: 3212 47500 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000150, len: 0x00000002
Debug: 3213 47500 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000150
Debug: 3214 47500 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000152,2’
Debug: 3215 47500 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000152, len: 0x00000002
Debug: 3216 47500 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000152
Debug: 3217 47516 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000154,2’
Debug: 3218 47516 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000154, len: 0x00000002
Debug: 3219 47516 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000154
Debug: 3220 47516 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000156,2’
Debug: 3221 47516 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000156, len: 0x00000002
Debug: 3222 47516 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000156
Debug: 3223 47516 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000158,2’
Debug: 3224 47516 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000158, len: 0x00000002
Debug: 3225 47516 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000158
Debug: 3226 47531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800015a,2’
Debug: 3227 47531 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800015a, len: 0x00000002
Debug: 3228 47531 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800015a
Debug: 3229 47531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800015c,2’
Debug: 3230 47531 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800015c, len: 0x00000002
Debug: 3231 47531 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800015c
Debug: 3232 47531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800015e,2’
Debug: 3233 47531 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800015e, len: 0x00000002
Debug: 3234 47531 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800015e
Debug: 3235 47547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000160,2’
Debug: 3236 47547 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000160, len: 0x00000002
Debug: 3237 47547 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000160
Debug: 3238 47547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000162,2’
Debug: 3239 47547 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000162, len: 0x00000002
Debug: 3240 47547 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000162
Debug: 3241 47547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000164,2’
Debug: 3242 47547 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000164, len: 0x00000002
Debug: 3243 47547 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000164
Debug: 3244 47563 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000166,2’
Debug: 3245 47563 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000166, len: 0x00000002
Debug: 3246 47563 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000166
Debug: 3247 47563 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000168,2’
Debug: 3248 47563 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000168, len: 0x00000002
Debug: 3249 47563 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000168
Debug: 3250 47563 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800016a,2’
Debug: 3251 47578 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800016a, len: 0x00000002
Debug: 3252 47578 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800016a
Debug: 3253 47578 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800016c,2’
Debug: 3254 47578 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800016c, len: 0x00000002
Debug: 3255 47578 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800016c
Debug: 3256 47578 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m800016e,2’
Debug: 3257 47578 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x0800016e, len: 0x00000002
Debug: 3258 47578 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x0800016e
Debug: 3259 47594 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000170,2’
Debug: 3260 47594 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000170, len: 0x00000002
Debug: 3261 47594 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000170
Debug: 3262 47594 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000172,2’
Debug: 3263 47594 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000172, len: 0x00000002
Debug: 3264 47594 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000172
Debug: 3265 47594 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000174,2’
Debug: 3266 47594 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000174, len: 0x00000002
Debug: 3267 47594 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000174
Debug: 3268 47610 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000176,2’
Debug: 3269 47610 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000176, len: 0x00000002
Debug: 3270 47610 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08000176
Debug: 3271 48969 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 3272 48969 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 3273 48969 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 3274 48969 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 3275 48969 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 3276 48969 target.c:1516 target_read_u16(): address: 0x08000112, value: 0xf000
Debug: 3277 48969 armv7m.c:129 armv7m_restore_context():
Debug: 3278 48969 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 3279 48985 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 3280 48985 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 3281 49000 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 3282 49000 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20000000
Debug: 3283 49016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x8
Debug: 3284 49016 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200045a8
Debug: 3285 49031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200045a8
Debug: 3286 49031 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 3287 49047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 3288 49047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 3289 49063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004ff8
Debug: 3290 49063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 3291 49078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 3292 49078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 3293 49094 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 3294 49110 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 3295 49110 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004fe8
Debug: 3296 49125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x8000117
Debug: 3297 49125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8000464
Debug: 3298 49141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 3299 49141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004fe8
Debug: 3300 49156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 3301 49156 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 3302 49172 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 3303 49172 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 3304 49188 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 3305 49188 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8000464, target->state: halted
Debug: 3306 49188 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 3307 49188 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 3308 49188 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 3309 49188 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 3310 49188 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 3311 49188 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 3312 49188 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3313 49188 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 3314 49203 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 3315 49203 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 20, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 3316 49203 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 20)
Debug: 3317 49203 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 3318 49203 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3319 49203 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 3320 49203 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 3321 49203 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 21, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 3322 49203 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 21)
Debug: 3323 49203 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 3324 49203 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3325 49203 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 3326 49203 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 3327 49203 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 22, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 3328 49203 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 22)
Debug: 3329 49219 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 3330 49219 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 3331 49219 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 3332 49219 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 3333 49219 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 3334 49219 armv7m.c:129 armv7m_restore_context():
Debug: 3335 49219 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 3336 49219 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x8000465
Debug: 3337 49328 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 3338 49328 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 3339 49344 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 3340 49360 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 3341 49360 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 3342 49375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200001f8
Debug: 3343 49375 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 3344 49391 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 3345 49406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 3346 49406 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 3347 49422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 3348 49422 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 3349 49438 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 3350 49438 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 3351 49453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 3352 49453 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 3353 49469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 3354 49469 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a2a
Debug: 3355 49485 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 3356 49485 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 3357 49500 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 3358 49500 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 3359 49516 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 3360 49516 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 3361 49531 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 3362 49531 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a2a, target->state: halted
Debug: 3363 49531 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 3364 49531 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 3365 49531 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 3366 49531 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 3367 49547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 3368 49547 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3369 49547 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 20, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 3370 49547 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 3371 49547 breakpoints.c:127 breakpoint_free(): free BPID: 20 -> 0
Debug: 3372 49547 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 3373 49547 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3374 49547 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 21, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 3375 49547 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 3376 49563 breakpoints.c:127 breakpoint_free(): free BPID: 21 -> 0
Debug: 3377 49563 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 3378 49563 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3379 49563 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 22, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 3380 49563 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 3381 49563 breakpoints.c:127 breakpoint_free(): free BPID: 22 -> 0
Debug: 3382 49563 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2a,4’
Debug: 3383 49563 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2a, len: 0x00000004
Debug: 3384 49563 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08001a2a
Debug: 3385 49578 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m20004f80,40’
Debug: 3386 49578 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x20004f80, len: 0x00000040
Debug: 3387 49578 target.c:1333 target_read_buffer(): reading buffer of 64 byte at 0x20004f80
Debug: 3388 49594 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 3389 49610 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80008fa,4’
Debug: 3390 49610 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080008fa, len: 0x00000004
Debug: 3391 49610 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x080008fa
Debug: 3392 49625 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m20004fc0,40’
Debug: 3393 49625 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x20004fc0, len: 0x00000040
Debug: 3394 49625 target.c:1333 target_read_buffer(): reading buffer of 64 byte at 0x20004fc0
Debug: 3395 49625 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000168,4’
Debug: 3396 49625 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000168, len: 0x00000004
Debug: 3397 49625 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08000168
Debug: 3398 49703 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019d4,2’
Debug: 3399 49703 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019d4, len: 0x00000002
Debug: 3400 49703 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019d4
Debug: 3401 49719 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019d6,2’
Debug: 3402 49719 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019d6, len: 0x00000002
Debug: 3403 49719 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019d6
Debug: 3404 49719 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019d8,2’
Debug: 3405 49719 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019d8, len: 0x00000002
Debug: 3406 49719 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019d8
Debug: 3407 49735 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019da,2’
Debug: 3408 49735 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019da, len: 0x00000002
Debug: 3409 49735 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019da
Debug: 3410 49735 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019dc,2’
Debug: 3411 49735 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019dc, len: 0x00000002
Debug: 3412 49735 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019dc
Debug: 3413 49735 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019de,2’
Debug: 3414 49735 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019de, len: 0x00000002
Debug: 3415 49735 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019de
Debug: 3416 49750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e0,2’
Debug: 3417 49750 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e0, len: 0x00000002
Debug: 3418 49750 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e0
Debug: 3419 49750 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e2,2’
Debug: 3420 49750 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e2, len: 0x00000002
Debug: 3421 49750 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e2
Debug: 3422 49766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e4,2’
Debug: 3423 49766 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e4, len: 0x00000002
Debug: 3424 49766 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e4
Debug: 3425 49766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e6,2’
Debug: 3426 49766 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e6, len: 0x00000002
Debug: 3427 49766 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e6
Debug: 3428 49766 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019e8,2’
Debug: 3429 49766 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019e8, len: 0x00000002
Debug: 3430 49766 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019e8
Debug: 3431 49781 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019ea,2’
Debug: 3432 49781 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019ea, len: 0x00000002
Debug: 3433 49781 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019ea
Debug: 3434 49781 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019ec,2’
Debug: 3435 49781 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019ec, len: 0x00000002
Debug: 3436 49781 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019ec
Debug: 3437 49781 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019ee,2’
Debug: 3438 49781 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019ee, len: 0x00000002
Debug: 3439 49781 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019ee
Debug: 3440 49797 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f0,2’
Debug: 3441 49797 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f0, len: 0x00000002
Debug: 3442 49797 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f0
Debug: 3443 49797 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f2,2’
Debug: 3444 49797 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f2, len: 0x00000002
Debug: 3445 49797 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f2
Debug: 3446 49797 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f4,2’
Debug: 3447 49797 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f4, len: 0x00000002
Debug: 3448 49813 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f4
Debug: 3449 49813 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f6,2’
Debug: 3450 49813 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f6, len: 0x00000002
Debug: 3451 49813 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f6
Debug: 3452 49813 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019f8,2’
Debug: 3453 49813 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019f8, len: 0x00000002
Debug: 3454 49813 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019f8
Debug: 3455 49813 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019fa,2’
Debug: 3456 49828 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019fa, len: 0x00000002
Debug: 3457 49828 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019fa
Debug: 3458 49828 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019fc,2’
Debug: 3459 49828 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019fc, len: 0x00000002
Debug: 3460 49828 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019fc
Debug: 3461 49828 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m80019fe,2’
Debug: 3462 49828 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x080019fe, len: 0x00000002
Debug: 3463 49828 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x080019fe
Debug: 3464 49828 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a00,2’
Debug: 3465 49828 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a00, len: 0x00000002
Debug: 3466 49828 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a00
Debug: 3467 49844 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a02,2’
Debug: 3468 49844 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a02, len: 0x00000002
Debug: 3469 49844 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a02
Debug: 3470 49844 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a04,2’
Debug: 3471 49844 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a04, len: 0x00000002
Debug: 3472 49844 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a04
Debug: 3473 49844 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a06,2’
Debug: 3474 49844 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a06, len: 0x00000002
Debug: 3475 49844 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a06
Debug: 3476 49860 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a08,2’
Debug: 3477 49860 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a08, len: 0x00000002
Debug: 3478 49860 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a08
Debug: 3479 49860 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a0a,2’
Debug: 3480 49860 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a0a, len: 0x00000002
Debug: 3481 49860 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a0a
Debug: 3482 49875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a0c,2’
Debug: 3483 49875 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a0c, len: 0x00000002
Debug: 3484 49875 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a0c
Debug: 3485 49875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a0e,2’
Debug: 3486 49875 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a0e, len: 0x00000002
Debug: 3487 49875 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a0e
Debug: 3488 49875 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a10,2’
Debug: 3489 49875 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a10, len: 0x00000002
Debug: 3490 49875 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a10
Debug: 3491 49891 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a12,2’
Debug: 3492 49891 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a12, len: 0x00000002
Debug: 3493 49891 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a12
Debug: 3494 49891 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a14,2’
Debug: 3495 49891 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a14, len: 0x00000002
Debug: 3496 49891 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a14
Debug: 3497 49891 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a16,2’
Debug: 3498 49891 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a16, len: 0x00000002
Debug: 3499 49891 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a16
Debug: 3500 49906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a18,2’
Debug: 3501 49906 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a18, len: 0x00000002
Debug: 3502 49906 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a18
Debug: 3503 49906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a1a,2’
Debug: 3504 49906 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a1a, len: 0x00000002
Debug: 3505 49906 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a1a
Debug: 3506 49906 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a1c,2’
Debug: 3507 49906 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a1c, len: 0x00000002
Debug: 3508 49906 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a1c
Debug: 3509 49922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a1e,2’
Debug: 3510 49922 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a1e, len: 0x00000002
Debug: 3511 49922 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a1e
Debug: 3512 49922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a20,2’
Debug: 3513 49922 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a20, len: 0x00000002
Debug: 3514 49922 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a20
Debug: 3515 49922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a22,2’
Debug: 3516 49922 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a22, len: 0x00000002
Debug: 3517 49922 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a22
Debug: 3518 49938 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a24,2’
Debug: 3519 49938 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a24, len: 0x00000002
Debug: 3520 49938 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a24
Debug: 3521 49938 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a26,2’
Debug: 3522 49938 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a26, len: 0x00000002
Debug: 3523 49938 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a26
Debug: 3524 49938 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a28,2’
Debug: 3525 49938 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a28, len: 0x00000002
Debug: 3526 49938 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a28
Debug: 3527 49953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2a,2’
Debug: 3528 49953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2a, len: 0x00000002
Debug: 3529 49953 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2a
Debug: 3530 49953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2c,2’
Debug: 3531 49953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2c, len: 0x00000002
Debug: 3532 49953 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2c
Debug: 3533 49953 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a2e,2’
Debug: 3534 49953 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a2e, len: 0x00000002
Debug: 3535 49953 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a2e
Debug: 3536 49969 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a30,2’
Debug: 3537 49969 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a30, len: 0x00000002
Debug: 3538 49969 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a30
Debug: 3539 49969 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a32,2’
Debug: 3540 49969 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a32, len: 0x00000002
Debug: 3541 49969 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a32
Debug: 3542 49985 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a34,2’
Debug: 3543 49985 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a34, len: 0x00000002
Debug: 3544 49985 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a34
Debug: 3545 49985 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a36,2’
Debug: 3546 49985 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a36, len: 0x00000002
Debug: 3547 49985 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a36
Debug: 3548 49985 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a38,2’
Debug: 3549 49985 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a38, len: 0x00000002
Debug: 3550 49985 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a38
Debug: 3551 50000 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a3a,2’
Debug: 3552 50000 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a3a, len: 0x00000002
Debug: 3553 50000 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a3a
Debug: 3554 50000 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a3c,2’
Debug: 3555 50000 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a3c, len: 0x00000002
Debug: 3556 50000 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a3c
Debug: 3557 50000 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a3e,2’
Debug: 3558 50000 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a3e, len: 0x00000002
Debug: 3559 50000 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a3e
Debug: 3560 50016 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a40,2’
Debug: 3561 50016 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a40, len: 0x00000002
Debug: 3562 50016 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a40
Debug: 3563 50016 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a42,2’
Debug: 3564 50016 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a42, len: 0x00000002
Debug: 3565 50016 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a42
Debug: 3566 50016 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a44,2’
Debug: 3567 50031 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a44, len: 0x00000002
Debug: 3568 50031 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a44
Debug: 3569 50031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a46,2’
Debug: 3570 50031 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a46, len: 0x00000002
Debug: 3571 50031 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a46
Debug: 3572 50031 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a48,2’
Debug: 3573 50031 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a48, len: 0x00000002
Debug: 3574 50031 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a48
Debug: 3575 50047 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001a4a,2’
Debug: 3576 50047 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001a4a, len: 0x00000002
Debug: 3577 50047 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08001a4a
Debug: 3578 51094 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 3579 51094 gdb_server.c:2147 gdb_input_inner(): received packet: ‘s’
Debug: 3580 51094 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 3581 51094 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 3582 51094 gdb_server.c:1433 gdb_step_continue_packet(): step
Debug: 3583 51094 target.c:1516 target_read_u16(): address: 0x08001a2a, value: 0x697b
Debug: 3584 51094 armv7m.c:129 armv7m_restore_context():
Debug: 3585 51094 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 3586 51110 cortex_m3.c:765 cortex_m3_step(): target stepped dcb_dhcsr = 0x1030007 nvic_icsr = 0x0
Debug: 3587 51110 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 3588 51125 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 3589 51141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 3590 51141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 3591 51156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x200001f8
Debug: 3592 51156 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x200001a0
Debug: 3593 51172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 3594 51172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 3595 51188 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 3596 51188 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 3597 51203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 3598 51203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 3599 51219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 3600 51219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 3601 51235 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 3602 51235 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f98
Debug: 3603 51250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x80012e5
Debug: 3604 51250 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001a2c
Debug: 3605 51266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000000
Debug: 3606 51266 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f98
Debug: 3607 51281 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 3608 51281 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 3609 51297 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 3610 51297 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 3611 51313 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 3612 51313 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001a2c, target->state: halted
Debug: 3613 51313 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 3614 51313 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 3615 51313 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 3616 51313 cortex_m3.c:772 cortex_m3_step(): target stepped dcb_dhcsr = 0x30003 nvic_icsr = 0x0
Debug: 3617 51313 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 3618 51313 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000112,2’
Debug: 3619 51313 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3620 51313 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88000111
Debug: 3621 51328 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88000111
Debug: 3622 51328 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 23, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 3623 51328 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000112 of length 0x00000002, (BPID: 23)
Debug: 3624 51328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8000168,2’
Debug: 3625 51328 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3626 51328 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x48000169
Debug: 3627 51328 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 1 fpcr_value 0x48000169
Debug: 3628 51328 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 24, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 3629 51328 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08000168 of length 0x00000002, (BPID: 24)
Debug: 3630 51328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001a2a,2’
Debug: 3631 51328 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3632 51328 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x88001a29
Debug: 3633 51328 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x88001a29
Debug: 3634 51328 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 25, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 3635 51344 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001a2a of length 0x00000002, (BPID: 25)
Debug: 3636 51344 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 3637 51344 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 3638 51344 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 3639 51344 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 3640 51344 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 3641 51344 armv7m.c:129 armv7m_restore_context():
Debug: 3642 51344 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 3643 51344 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x8001a2d
Debug: 3644 55922 gdb_server.c:2147 gdb_input_inner(): received packet: ‘’
Debug: 3645 55922 cortex_m3.c:499 cortex_m3_halt(): target->state: running
Debug: 3646 56032 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 3647 56047 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x1
Debug: 3648 56047 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x200001f8
Debug: 3649 56063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0xa5
Debug: 3650 56063 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x400
Debug: 3651 56078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x400
Debug: 3652 56078 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x40022010
Debug: 3653 56110 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0x4002200c
Debug: 3654 56110 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0x622480
Debug: 3655 56125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x20004f98
Debug: 3656 56125 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0x3fffdfdd
Debug: 3657 56141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffff3e0d
Debug: 3658 56141 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x88044d40
Debug: 3659 56157 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x202d0dd0
Debug: 3660 56157 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xceffbffd
Debug: 3661 56172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x20004f78
Debug: 3662 56172 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 3663 56188 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8003008
Debug: 3664 56203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x21000003
Debug: 3665 56203 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x20004f78
Debug: 3666 56219 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0xc0a42f20
Debug: 3667 56219 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 3668 56235 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0xb0
Debug: 3669 56235 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 3670 56250 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 3671 56250 cortex_m3.c:322 cortex_m3_examine_exception_reason(): HardFault SHCSR 0x0, SR 0x40000000, CFSR 0x10000, AR 0xffffffff
Debug: 3672 56250 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Handler at PC 0x8003008, target->state: halted
Debug: 3673 56250 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 3674 56250 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 3675 56250 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 3676 56250 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 3677 56266 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000112,2’
Debug: 3678 56266 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3679 56266 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 23, Type: 0, Address: 0x08000112 Length: 2 (set=1)
Debug: 3680 56266 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 3681 56266 breakpoints.c:127 breakpoint_free(): free BPID: 23 -> 0
Debug: 3682 56266 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8000168,2’
Debug: 3683 56266 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3684 56266 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 24, Type: 0, Address: 0x08000168 Length: 2 (set=2)
Debug: 3685 56266 target.c:1565 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 3686 56266 breakpoints.c:127 breakpoint_free(): free BPID: 24 -> 0
Debug: 3687 56266 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001a2a,2’
Debug: 3688 56266 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 3689 56266 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 25, Type: 0, Address: 0x08001a2a Length: 2 (set=3)
Debug: 3690 56266 target.c:1565 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 3691 56282 breakpoints.c:127 breakpoint_free(): free BPID: 25 -> 0
Debug: 3692 56282 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,4’
Debug: 3693 56282 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000004
Debug: 3694 56282 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08003008
Debug: 3695 56297 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qL1200000000000000000’
Debug: 3696 56313 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 3697 56313 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 3698 56313 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 3699 56313 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 3700 56313 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 3701 56313 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 3702 56328 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 3703 56328 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 3704 56328 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 3705 56328 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 3706 56328 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 3707 56328 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 3708 56328 gdb_server.c:2147 gdb_input_inner(): received packet: ‘mfffffff8,4’
Debug: 3709 56328 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0xfffffff8, len: 0x00000004
Debug: 3710 56328 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0xfffffff8
Debug: 3711 56344 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 3712 56344 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 3713 56344 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 3714 56344 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Debug: 3715 56344 arm_adi_v5.c:335 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT error, 0xf0000021
Error: 3716 56360 arm_adi_v5.c:361 jtagdp_transaction_endcheck(): JTAG-DP STICKY ERROR
Debug: 3717 56360 arm_adi_v5.c:373 jtagdp_transaction_endcheck(): jtag-dp: CTRL/STAT 0xf0000001
Error: 3718 56360 arm_adi_v5.c:380 jtagdp_transaction_endcheck(): MEM_AP_CSW 0x23000052, MEM_AP_TAR 0xfffffffc
Warn : 3719 56360 arm_adi_v5.c:989 mem_ap_read_buf_u32(): Block read error address 0xfffffff8, count 0x1
Debug: 3720 56485 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8003008,2’
Debug: 3721 56485 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08003008, len: 0x00000002
Debug: 3722 56485 target.c:1333 target_read_buffer(): reading buffer of 2 byte at 0x08003008
I tried to find a solution for this, but nobody could help me out…
Thx for any help…
