csorvagep wrote on Saturday, October 19, 2013:
Hi everyone!
I’ve just found out, that the OpenOCD has this feature, to support, and debug RTOSes. I’m trying to make it work, but I stuck.
The problem is that, the OpenOCD (0.7.0) says: “Error: No symbols for FreeRTOS”, and there is only one visible thread in the eclipse (kepler - cdt) I’ve check it with gdb and it has the same result. Btw: The FreeRTOS kernel runs fine, there’s no problem on that side.
I use the Sourcery CodeBench with Eclipse to compile. I’ve checked the symbols with the arm-none-eabi-nm command, and I found all the symbols what this page (http://openocd.sourceforge.net/doc/html/GDB-and-OpenOCD.html#gdbrtossupport) says, except one. This one was the “uxTopUsedPriority”. (Latest version of FreeRTOS 7.5.3) I’ve tried with an older version (7.2.0) and I found that in there. So every symbols should be there.
I think, the problem is with my FreeRTOS config, or with the compiler settings. They say the FreeRTOS and OpenOCD should work well. Has anyone had this problem? Where sould I start to check, or is there a good tutorial to read?
Thanks, Gabor
