NRF52840 OTA update
ljaynes wrote on June 27, 2019:
I have a couple questions about the OTA update on the Nordic NRF52840.
  1. I can’t seem to get the OTA update to pass the signature check on the device after downloading. I have generated my certificates using open ssl and uploaded them to AWS ACM using the instructions found here [https://docs.aws.amazon.com/freertos/latest/userguide/ota-code-sign-cert-nordic.html]. I have pasted both the key and and certificate into my aws_clientcredential_keys.h file and pasted how they looked below with edits to block out most of the cert.
#define keyCLIENT_CERTIFICATE_PEM "-----BEGIN CERTIFICATE-----
"MIIBcjCCARigAssssssssssssssssssssssssssssssssssssssssssssssssCgYIKoZIzj0EAwIw
"JjEkMCIGA1sssssssssssssssssssssssssssssssssssssssssssssssssss29tMB4XDTE5MDYy
"NzE2NDQzMssssssssssssssssssssssssssssssssssssssssssssssswwbbGpheW5lc0BhZXYt
"Y29udmVycsssssssssssssssssssssssssssssssssssssssssssssssj0DAQcDQgAE89TdUalA
"Zz1Gr2p9BOlssssssssssssssssssssssssssssssssssssssssssssG6LFyK7Ch1FfMlqEIbCXqfJ
"t4lQG46uUkzHsssssssssssssssssssssssssssssssssssssssssssssMMAoGCCsGAQUFBwMD
"MAoGCCqGSMssssssssssssssssssssssssssssssssssssssssssssssssssssssIb2xptZjWn5qq
"CTM7AiEAx/3SssssssssssssssssssssssscRhW/VROf6Cnk=
"-----END CERTIFICATE-----
#define keyCLIENT_PRIVATE_KEY_PEM "-----BEGIN PRIVATE KEY-----
"MIGHAgEAMBaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaHdcMMzgH9gH4
"VXXaOhbW7/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaxqCnJd7O
"wUvB79mCWaaaaaaaaaaaaaaaaaaaaaaaaasJep8m3iVAbjq5STMdj
"-----END PRIVATE KEY-----
I am not sure where I am going wrong. When I create the job i select the create code signing profile and choose the nRF52840 DK and then select the code siging certificate I imported using the CLI. The only thing I am not sure of is the pathname of the code signing certificate on device. I have just been using / because I don’t think the nordic has a file system.
Failure Log:
1071 17228 [OTA Task] [prvIngestDataBlock] Received file block 305, size 1024
1072 17230 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 312320l address
1073 17230 [OTA Task] [prvIngestDataBlock] Received final expected block of file.
1074 17230 [OTA Task] [prvStopRequestTimer] Stopping file request timer.
1075 17230 [OTA Task] [prvPAL_CloseFile] Erasing the flash memory was successful
1076 17246 [OTA Task] [prvPAL_CheckFileSignature] Signature check failed
1077 17246 [OTA Task] [prvIngestDataBlock] Error (1:0x000000) closing OTA file.
1078 17246 [OTA Task] [prvOTAUpdateTask] Aborting due to IngestResult_t error -2
1079 17246 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"FAILED","statusDetails":{"reason":"0x01000000: 0xfffffffe"}}
  1. I would like the OTA to happen mostly in the background so the user can still use the application while the OTA downloads. This mostly seems to be the case already except that I still need to do MQTT transfers while the OTA is downloading new firmware. I can get MQTT messages to transfer but it is a 45 to 60 second delay after sending the MQTT message when the OTA is transferring. Is there any way to make my MQTT transfers have priority over the OTA so that my messages are immediately received without delay?
Edited by: ljaynes on Jun 27, 2019 10:26 AM
Alexa-AWS wrote on June 29, 2019:
There are a couple of certificates required by your device when connecting and performing OTA.
The first is the device’s certificate which is attached to the thing, and belongs in keyCLIENT_CERTIFICATE_PEM. This contains the public key corresponding to the private key keyCLIENT_PRIVATE_KEY_PEM.
The second is the code signer certificate, which contains the public key which verifies the OTA image and corresponds to the private key which signs the image. This certificate should be placed in signingcredentialSIGNING_CERTIFICATE_PEM in the file aws_ota_codesigner_certificate.h
On the Nordic port, I think that the path to code signing certificate is ignored, so what you type there does not matter as long as you have placed that code signer certificate in aws_ota_codesigner_certificate.h
The error 0x01000000 indicates that the signature check failed. (Error codes for the OTA agent can be found in aws_iot_ota_agent.h and begin with kOTA_Err_*).
  1. For you second question, are you using a project based on the OTA demo provided/does your application have more than one MQTT connection open?
Thanks,
Alexa
ljaynes wrote on July 01, 2019:
  1. Thanks I was missing the signingcredentialSIGNING_CERTIFICATE_PEM in the file aws_ota_codesigner_certificate.h. Signing now works but I am now failing on reboot because the versions are still the same. I have verified the app version of the new firmware is higher than the version I am running. It seems as tho it is just not switching to the new file.
OTA firmware version on the S3 bucket:
5 119 [iot_thread] [INFO ][DEMO][1190] Successfully initialized the demo. Network type for the demo: 2
6 119 [iot_thread] [INFO ][MQTT][1190] MQTT library successfully initialized.
7 119 [iot_thread] OTA demo version 2.1.0
8 119 [iot_thread] Creating MQTT Client...
Running firmware version:
5 369 [iot_thread] [INFO ][DEMO][3690] Successfully initialized the demo. Network type for the demo: 2
6 369 [iot_thread] [INFO ][MQTT][3690] MQTT library successfully initialized.
7 369 [iot_thread] OTA demo version 1.0.1
8 369 [iot_thread] Creating MQTT Client...
29 914 [iot_thread] [OTA_AgentInit] Ready.
30 957 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
31 957 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ jobId: AFR_OTA-failed_test ]
32 957 [OTA Task] [prvParseJSONbyModel] Identified parameter [ self_test ]
33 957 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ updatedBy: 16777217 ]
34 957 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ streamname: AFR_OTA-09f6fde0-66e7-4f1e-80c8-32ee07045891 ]
35 957 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filepath: / ]
36 957 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filesize: 262352 ]
37 958 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ fileid: 0 ]
38 958 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ certfile: / ]
39 958 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ sig-sha256-ecdsa: MEUCIAKulCV/tjoRUNsoHoMb80s4amK8... ]
40 958 [OTA Task] [prvParseJobDoc] In self test mode.
41 958 [OTA Task] [prvParseJobDoc] Failing job. We rebooted and the version is still the same.
  1. Yes my project is based on the OTA demo and I do not believe there is more than one MQTT connection open. Is opening and using another connection the only way to solve the MQTT message latency issue?
SarenaAtAws wrote on July 03, 2019:
Could you please paste the whole OTA log from the start of the image download, to the reboot, to the self-test?
We would like to see possible bootloader error messages.
If there are issues in the bootloader, it may “roll-back” when attempting to commit the downloaded image. Or we may have “rolled-back” to the previous image earlier, right after reboot, for some reason.
ljaynes wrote on July 03, 2019:
Complete Log:
9 549 [iot_thread] [INFO ][MQTT][5490] Establishing new MQTT connection.
10 549 [iot_thread] [INFO ][MQTT][5490] (MQTT connection 20025e38, CONNECT operation 20025f40) Waiting for operation completion.
11 559 [iot_thread] [INFO ][MQTT][5590] (MQTT connection 20025e38, CONNECT operation 20025f40) Wait complete with result SUCCESS.
12 559 [iot_thread] [INFO ][MQTT][5590] New MQTT connection 20008d9c established.
13 559 [iot_thread] [INFO ][MQTT][5590] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
14 559 [iot_thread] [INFO ][MQTT][5590] (MQTT connection 20025e38, SUBSCRIBE operation 20026048) Waiting for operation completion.
15 617 [iot_thread] [INFO ][MQTT][6170] (MQTT connection 20025e38, SUBSCRIBE operation 20026048) Wait complete with result SUCCESS.
16 617 [OTA Task] [INFO ][MQTT][6170] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
17 618 [OTA Task] [INFO ][MQTT][6180] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Waiting for operation completion.
18 676 [OTA Task] [INFO ][MQTT][6760] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Wait complete with result SUCCESS.
19 676 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/$next/get/accepted
20 676 [OTA Task] [INFO ][MQTT][6760] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
21 676 [OTA Task] [INFO ][MQTT][6760] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Waiting for operation completion.
22 734 [OTA Task] [INFO ][MQTT][7340] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Wait complete with result SUCCESS.
23 734 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/notify-next
24 734 [OTA Task] [OTA_CheckForUpdate] Request #0
25 734 [OTA Task] [INFO ][MQTT][7340] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
26 734 [OTA Task] [INFO ][MQTT][7340] (MQTT connection 20025e38, PUBLISH operation 2002e360) Waiting for operation completion.
27 763 [OTA Task] [INFO ][MQTT][7630] (MQTT connection 20025e38, PUBLISH operation 2002e360) Wait complete with result SUCCESS.
28 764 [iot_thread] [OTA_AgentInit] Ready.
29 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
30 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ jobId: AFR_OTA-ota_fourm_log ]
31 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ streamname: AFR_OTA-91504af4-69ad-4aff-a837-221f30af5b35 ]
32 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filepath: / ]
33 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filesize: 317124 ]
34 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ fileid: 0 ]
35 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ certfile: / ]
36 808 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ sig-sha256-ecdsa: MEYCIQCXMU5XA1tycaAu8UXkrd31Rfj+... ]
37 808 [OTA Task] [prvParseJobDoc] Job was accepted. Attempting to start transfer.
38 808 [OTA Task] [INFO ][MQTT][8080] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
39 808 [OTA Task] [INFO ][MQTT][8080] (MQTT connection 20025e38, SUBSCRIBE operation 2002e998) Waiting for operation completion.
40 866 [OTA Task] [INFO ][MQTT][8660] (MQTT connection 20025e38, SUBSCRIBE operation 2002e998) Wait complete with result SUCCESS.
41 866 [OTA Task] [prvSubscribeToDataStream] OK: $aws/things/NRF52840DK/streams/AFR_OTA-91504af4-69ad-4aff-a837-221f30af5b35/data/cbor
42 866 [OTA Task] [prvPAL_CreateFileForRx] Erasing the flash memory
43 911 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
44 1118 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
45 1323 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
46 1527 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
47 1743 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
48 1950 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
49 2156 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
50 2356 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
51 2570 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
52 2732 [OTA Task] [INFO ][MQTT][27320] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
53 2732 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/NRF52840DK/streams/AFR_OTA-91504af4-69ad-4aff-a837-221f30af5b35/get/cbor
54 2778 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 1   Dropped: 0
55 2816 [OTA Task] [prvIngestDataBlock] Received file block 0, size 1024
56 2817 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 0l address
57 2817 [OTA Task] [prvIngestDataBlock] Remaining: 309
58 2864 [OTA Task] [prvIngestDataBlock] Received file block 1, size 1024
59 2865 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 1024l address
60 2865 [OTA Task] [prvIngestDataBlock] Remaining: 308
61 2906 [OTA Task] [prvIngestDataBlock] Received file block 2, size 1024
62 2907 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 2048l address
63 2907 [OTA Task] [prvIngestDataBlock] Remaining: 307
64 2948 [OTA Task] [prvIngestDataBlock] Received file block 4, size 1024
65 2949 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 4096l address
66 2949 [OTA Task] [prvIngestDataBlock] Remaining: 306
67 2978 [app_ota_task] State: Active  Received: 5   Queued: 5   Processed: 5   Dropped: 0
68 2990 [OTA Task] [prvIngestDataBlock] Received file block 5, size 1024
69 2991 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 5120l address
70 2991 [OTA Task] [prvIngestDataBlock] Remaining: 305
71 3032 [OTA Task] [prvIngestDataBlock] Received file block 6, size 1024
72 3033 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 6144l address
73 3033 [OTA Task] [prvIngestDataBlock] Remaining: 304
74 3074 [OTA Task] [prvIngestDataBlock] Received file block 7, size 1024
75 3075 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 7168l address
76 3075 [OTA Task] [prvIngestDataBlock] Remaining: 303
77 3116 [OTA Task] [prvIngestDataBlock] Received file block 8, size 1024
78 3117 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 8192l address
79 3117 [OTA Task] [prvIngestDataBlock] Remaining: 302
80 3161 [OTA Task] [prvIngestDataBlock] Received file block 9, size 1024
81 3162 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 9216l address
82 3162 [OTA Task] [prvIngestDataBlock] Remaining: 301
83 3178 [app_ota_task] State: Active  Received: 10   Queued: 10   Processed: 10   Dropped: 0
84 3203 [OTA Task] [prvIngestDataBlock] Received file block 10, size 1024
85 3204 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 10240l address
86 3204 [OTA Task] [prvIngestDataBlock] Remaining: 300
87 3244 [OTA Task] [prvIngestDataBlock] Received file block 11, size 1024
88 3246 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 11264l address
89 3246 [OTA Task] [prvIngestDataBlock] Remaining: 299
90 3289 [OTA Task] [prvIngestDataBlock] Received file block 13, size 1024
91 3290 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 13312l address
92 3290 [OTA Task] [prvIngestDataBlock] Remaining: 298
93 3331 [OTA Task] [prvIngestDataBlock] Received file block 14, size 1024
94 3333 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 14336l address
95 3333 [OTA Task] [prvIngestDataBlock] Remaining: 297
96 3378 [app_ota_task] State: Active  Received: 14   Queued: 14   Processed: 14   Dropped: 0
97 3379 [OTA Task] [prvIngestDataBlock] Received file block 15, size 1024
98 3380 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 15360l address
99 3380 [OTA Task] [prvIngestDataBlock] Remaining: 296
100 3424 [OTA Task] [prvIngestDataBlock] Received file block 16, size 1024
101 3425 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 16384l address
102 3425 [OTA Task] [prvIngestDataBlock] Remaining: 295
103 3469 [OTA Task] [prvIngestDataBlock] Received file block 17, size 1024
104 3470 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 17408l address
105 3470 [OTA Task] [prvIngestDataBlock] Remaining: 294
106 3511 [OTA Task] [prvIngestDataBlock] Received file block 18, size 1024
107 3512 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 18432l address
108 3512 [OTA Task] [prvIngestDataBlock] Remaining: 293
109 3556 [OTA Task] [prvIngestDataBlock] Received file block 20, size 1024
110 3557 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 20480l address
111 3557 [OTA Task] [prvIngestDataBlock] Remaining: 292
112 3578 [app_ota_task] State: Active  Received: 19   Queued: 19   Processed: 19   Dropped: 0
113 3598 [OTA Task] [prvIngestDataBlock] Received file block 21, size 1024
114 3599 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 21504l address
115 3599 [OTA Task] [prvIngestDataBlock] Remaining: 291
116 3640 [OTA Task] [prvIngestDataBlock] Received file block 22, size 1024
117 3641 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 22528l address
118 3641 [OTA Task] [prvIngestDataBlock] Remaining: 290
119 3682 [OTA Task] [prvIngestDataBlock] Received file block 23, size 1024
120 3683 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 23552l address
121 3683 [OTA Task] [prvIngestDataBlock] Remaining: 289
122 3724 [OTA Task] [prvIngestDataBlock] Received file block 12, size 1024
123 3725 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 12288l address
124 3725 [OTA Task] [prvIngestDataBlock] Remaining: 288
125 3766 [OTA Task] [prvIngestDataBlock] Received file block 25, size 1024
126 3767 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 25600l address
127 3767 [OTA Task] [prvIngestDataBlock] Remaining: 287
128 3778 [app_ota_task] State: Active  Received: 24   Queued: 24   Processed: 24   Dropped: 0
129 3808 [OTA Task] [prvIngestDataBlock] Received file block 26, size 1024
130 3809 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 26624l address
131 3809 [OTA Task] [prvIngestDataBlock] Remaining: 286
132 3850 [OTA Task] [prvIngestDataBlock] Received file block 27, size 1024
133 3851 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 27648l address
134 3851 [OTA Task] [prvIngestDataBlock] Remaining: 285
135 3892 [OTA Task] [prvIngestDataBlock] Received file block 28, size 1024
136 3893 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 28672l address
137 3893 [OTA Task] [prvIngestDataBlock] Remaining: 284
138 3946 [OTA Task] [prvIngestDataBlock] Received file block 29, size 1024
139 3947 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 29696l address
140 3947 [OTA Task] [prvIngestDataBlock] Remaining: 283
141 3978 [app_ota_task] State: Active  Received: 28   Queued: 28   Processed: 28   Dropped: 0
142 3991 [OTA Task] [prvIngestDataBlock] Received file block 30, size 1024
143 3992 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 30720l address
144 3992 [OTA Task] [prvIngestDataBlock] Remaining: 282
145 4033 [OTA Task] [prvIngestDataBlock] Received file block 31, size 1024
146 4034 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 31744l address
147 4034 [OTA Task] [prvIngestDataBlock] Remaining: 281
148 4075 [OTA Task] [prvIngestDataBlock] Received file block 3, size 1024
149 4076 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 3072l address
150 4076 [OTA Task] [prvIngestDataBlock] Remaining: 280
151 4117 [OTA Task] [prvIngestDataBlock] Received file block 32, size 1024
152 4118 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 32768l address
153 4118 [OTA Task] [prvIngestDataBlock] Remaining: 279
154 4159 [OTA Task] [prvIngestDataBlock] Received file block 34, size 1024
155 4160 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 34816l address
156 4160 [OTA Task] [prvIngestDataBlock] Remaining: 278
157 4178 [app_ota_task] State: Active  Received: 33   Queued: 33   Processed: 33   Dropped: 0
158 4201 [OTA Task] [prvIngestDataBlock] Received file block 35, size 1024
159 4202 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 35840l address
160 4202 [OTA Task] [prvIngestDataBlock] Remaining: 277
161 4242 [OTA Task] [prvIngestDataBlock] Received file block 36, size 1024
162 4244 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 36864l address
163 4244 [OTA Task] [prvIngestDataBlock] Remaining: 276
164 4284 [OTA Task] [prvIngestDataBlock] Received file block 37, size 1024
165 4286 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 37888l address
166 4286 [OTA Task] [prvIngestDataBlock] Remaining: 275
167 4326 [OTA Task] [prvIngestDataBlock] Received file block 38, size 1024
168 4328 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 38912l address
169 4328 [OTA Task] [prvIngestDataBlock] Remaining: 274
170 4368 [OTA Task] [prvIngestDataBlock] Received file block 40, size 1024
171 4369 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 40960l address
172 4370 [OTA Task] [prvIngestDataBlock] Remaining: 273
173 4378 [app_ota_task] State: Active  Received: 38   Queued: 38   Processed: 38   Dropped: 0
174 4410 [OTA Task] [prvIngestDataBlock] Received file block 39, size 1024
175 4411 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 39936l address
176 4411 [OTA Task] [prvIngestDataBlock] Remaining: 272
177 4452 [OTA Task] [prvIngestDataBlock] Received file block 41, size 1024
178 4453 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 41984l address
179 4453 [OTA Task] [prvIngestDataBlock] Remaining: 271
180 4494 [OTA Task] [prvIngestDataBlock] Received file block 42, size 1024
181 4495 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 43008l address
182 4495 [OTA Task] [prvIngestDataBlock] Remaining: 270
183 4536 [OTA Task] [prvIngestDataBlock] Received file block 43, size 1024
184 4537 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 44032l address
185 4537 [OTA Task] [prvIngestDataBlock] Remaining: 269
186 4578 [app_ota_task] State: Active  Received: 42   Queued: 42   Processed: 42   Dropped: 0
187 4578 [OTA Task] [prvIngestDataBlock] Received file block 44, size 1024
188 4579 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 45056l address
189 4579 [OTA Task] [prvIngestDataBlock] Remaining: 268
190 4620 [OTA Task] [prvIngestDataBlock] Received file block 24, size 1024
191 4621 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 24576l address
192 4621 [OTA Task] [prvIngestDataBlock] Remaining: 267
193 4662 [OTA Task] [prvIngestDataBlock] Received file block 45, size 1024
194 4663 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 46080l address
195 4663 [OTA Task] [prvIngestDataBlock] Remaining: 266
196 4704 [OTA Task] [prvIngestDataBlock] Received file block 47, size 1024
197 4705 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 48128l address
198 4705 [OTA Task] [prvIngestDataBlock] Remaining: 265
199 4746 [OTA Task] [prvIngestDataBlock] Received file block 48, size 1024
200 4747 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 49152l address
201 4747 [OTA Task] [prvIngestDataBlock] Remaining: 264
202 4778 [app_ota_task] State: Active  Received: 47   Queued: 47   Processed: 47   Dropped: 0
203 4788 [OTA Task] [prvIngestDataBlock] Received file block 49, size 1024
204 4789 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 50176l address
205 4789 [OTA Task] [prvIngestDataBlock] Remaining: 263
206 4830 [OTA Task] [prvIngestDataBlock] Received file block 50, size 1024
207 4831 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 51200l address
208 4831 [OTA Task] [prvIngestDataBlock] Remaining: 262
209 4872 [OTA Task] [prvIngestDataBlock] Received file block 51, size 1024
210 4873 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 52224l address
211 4873 [OTA Task] [prvIngestDataBlock] Remaining: 261
212 4914 [OTA Task] [prvIngestDataBlock] Received file block 52, size 1024
213 4915 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 53248l address
214 4915 [OTA Task] [prvIngestDataBlock] Remaining: 260
215 4962 [OTA Task] [prvIngestDataBlock] Received file block 53, size 1024
216 4963 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 54272l address
217 4963 [OTA Task] [prvIngestDataBlock] Remaining: 259
218 4978 [app_ota_task] State: Active  Received: 52   Queued: 52   Processed: 52   Dropped: 0
219 5004 [OTA Task] [prvIngestDataBlock] Received file block 55, size 1024
220 5005 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 56320l address
221 5005 [OTA Task] [prvIngestDataBlock] Remaining: 258
222 5046 [OTA Task] [prvIngestDataBlock] Received file block 56, size 1024
223 5047 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 57344l address
224 5047 [OTA Task] [prvIngestDataBlock] Remaining: 257
225 5088 [OTA Task] [prvIngestDataBlock] Received file block 59, size 1024
226 5089 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 60416l address
227 5089 [OTA Task] [prvIngestDataBlock] Remaining: 256
228 5130 [OTA Task] [prvIngestDataBlock] Received file block 60, size 1024
229 5131 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 61440l address
230 5131 [OTA Task] [prvIngestDataBlock] Remaining: 255
231 5172 [OTA Task] [prvIngestDataBlock] Received file block 61, size 1024
232 5173 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 62464l address
233 5173 [OTA Task] [prvIngestDataBlock] Remaining: 254
234 5178 [app_ota_task] State: Active  Received: 57   Queued: 57   Processed: 57   Dropped: 0
235 5214 [OTA Task] [prvIngestDataBlock] Received file block 62, size 1024
236 5215 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 63488l address
237 5215 [OTA Task] [prvIngestDataBlock] Remaining: 253
238 5255 [OTA Task] [prvIngestDataBlock] Received file block 63, size 1024
239 5257 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 64512l address
240 5257 [OTA Task] [prvIngestDataBlock] Remaining: 252
241 5297 [OTA Task] [prvIngestDataBlock] Received file block 64, size 1024
242 5299 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 65536l address
243 5299 [OTA Task] [prvIngestDataBlock] Remaining: 251
244 5339 [OTA Task] [prvIngestDataBlock] Received file block 65, size 1024
245 5341 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 66560l address
246 5341 [OTA Task] [prvIngestDataBlock] Remaining: 250
247 5378 [app_ota_task] State: Active  Received: 61   Queued: 61   Processed: 61   Dropped: 0
248 5381 [OTA Task] [prvIngestDataBlock] Received file block 66, size 1024
249 5382 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 67584l address
250 5382 [OTA Task] [prvIngestDataBlock] Remaining: 249
251 5423 [OTA Task] [prvIngestDataBlock] Received file block 67, size 1024
252 5424 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 68608l address
253 5424 [OTA Task] [prvIngestDataBlock] Remaining: 248
254 5465 [OTA Task] [prvIngestDataBlock] Received file block 70, size 1024
255 5466 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 71680l address
256 5466 [OTA Task] [prvIngestDataBlock] Remaining: 247
257 5507 [OTA Task] [prvIngestDataBlock] Received file block 72, size 1024
258 5508 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 73728l address
259 5508 [OTA Task] [prvIngestDataBlock] Remaining: 246
260 5508 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"64/310"}}
261 5508 [OTA Task] [INFO ][MQTT][55080] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
262 5508 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-ota_fourm_log/update
263 5558 [OTA Task] [prvIngestDataBlock] Received file block 73, size 1024
264 5559 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 74752l address
265 5559 [OTA Task] [prvIngestDataBlock] Remaining: 245
266 5578 [app_ota_task] State: Active  Received: 66   Queued: 66   Processed: 66   Dropped: 0
267 5600 [OTA Task] [prvIngestDataBlock] Received file block 68, size 1024
268 5601 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 69632l address
269 5601 [OTA Task] [prvIngestDataBlock] Remaining: 244
270 5642 [OTA Task] [prvIngestDataBlock] Received file block 74, size 1024
271 5643 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 75776l address
272 5643 [OTA Task] [prvIngestDataBlock] Remaining: 243
273 5684 [OTA Task] [prvIngestDataBlock] Received file block 33, size 1024
274 5685 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 33792l address
275 5685 [OTA Task] [prvIngestDataBlock] Remaining: 242
276 5726 [OTA Task] [prvIngestDataBlock] Received file block 75, size 1024
277 5727 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 76800l address
278 5727 [OTA Task] [prvIngestDataBlock] Remaining: 241
279 5768 [OTA Task] [prvIngestDataBlock] Received file block 76, size 1024
280 5769 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 77824l address
281 5769 [OTA Task] [prvIngestDataBlock] Remaining: 240
282 5778 [app_ota_task] State: Active  Received: 71   Queued: 71   Processed: 71   Dropped: 0
283 5810 [OTA Task] [prvIngestDataBlock] Received file block 78, size 1024
284 5811 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 79872l address
285 5811 [OTA Task] [prvIngestDataBlock] Remaining: 239
286 5852 [OTA Task] [prvIngestDataBlock] Received file block 79, size 1024
287 5853 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 80896l address
288 5853 [OTA Task] [prvIngestDataBlock] Remaining: 238
289 5894 [OTA Task] [prvIngestDataBlock] Received file block 80, size 1024
290 5895 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 81920l address
291 5895 [OTA Task] [prvIngestDataBlock] Remaining: 237
292 5936 [OTA Task] [prvIngestDataBlock] Received file block 81, size 1024
293 5937 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 82944l address
294 5937 [OTA Task] [prvIngestDataBlock] Remaining: 236
295 5978 [app_ota_task] State: Active  Received: 75   Queued: 75   Processed: 75   Dropped: 0
296 5978 [OTA Task] [prvIngestDataBlock] Received file block 84, size 1024
297 5979 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 86016l address
298 5979 [OTA Task] [prvIngestDataBlock] Remaining: 235
299 6020 [OTA Task] [prvIngestDataBlock] Received file block 85, size 1024
300 6021 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 87040l address
301 6021 [OTA Task] [prvIngestDataBlock] Remaining: 234
302 6062 [OTA Task] [prvIngestDataBlock] Received file block 46, size 1024
303 6063 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 47104l address
304 6063 [OTA Task] [prvIngestDataBlock] Remaining: 233
305 6104 [OTA Task] [prvIngestDataBlock] Received file block 82, size 1024
306 6105 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 83968l address
307 6105 [OTA Task] [prvIngestDataBlock] Remaining: 232
308 6146 [OTA Task] [prvIngestDataBlock] Received file block 86, size 1024
309 6147 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 88064l address
310 6147 [OTA Task] [prvIngestDataBlock] Remaining: 231
311 6178 [app_ota_task] State: Active  Received: 80   Queued: 80   Processed: 80   Dropped: 0
312 6191 [OTA Task] [prvIngestDataBlock] Received file block 87, size 1024
313 6192 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 89088l address
314 6192 [OTA Task] [prvIngestDataBlock] Remaining: 230
315 6233 [OTA Task] [prvIngestDataBlock] Received file block 77, size 1024
316 6234 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 78848l address
317 6234 [OTA Task] [prvIngestDataBlock] Remaining: 229
318 6274 [OTA Task] [prvIngestDataBlock] Received file block 90, size 1024
319 6276 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 92160l address
320 6276 [OTA Task] [prvIngestDataBlock] Remaining: 228
321 6328 [OTA Task] [prvIngestDataBlock] Received file block 91, size 1024
322 6329 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 93184l address
323 6329 [OTA Task] [prvIngestDataBlock] Remaining: 227
324 6373 [OTA Task] [prvIngestDataBlock] Received file block 88, size 1024
325 6374 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 90112l address
326 6375 [OTA Task] [prvIngestDataBlock] Remaining: 226
327 6378 [app_ota_task] State: Active  Received: 85   Queued: 85   Processed: 85   Dropped: 0
328 6418 [OTA Task] [prvIngestDataBlock] Received file block 92, size 1024
329 6419 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 94208l address
330 6419 [OTA Task] [prvIngestDataBlock] Remaining: 225
331 6463 [OTA Task] [prvIngestDataBlock] Received file block 93, size 1024
332 6464 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 95232l address
333 6464 [OTA Task] [prvIngestDataBlock] Remaining: 224
334 6505 [OTA Task] [prvIngestDataBlock] Received file block 94, size 1024
335 6506 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 96256l address
336 6506 [OTA Task] [prvIngestDataBlock] Remaining: 223
337 6553 [OTA Task] [prvIngestDataBlock] Received file block 95, size 1024
338 6554 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 97280l address
339 6554 [OTA Task] [prvIngestDataBlock] Remaining: 222
340 6578 [app_ota_task] State: Active  Received: 89   Queued: 89   Processed: 89   Dropped: 0
341 6595 [OTA Task] [prvIngestDataBlock] Received file block 96, size 1024
342 6596 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 98304l address
343 6596 [OTA Task] [prvIngestDataBlock] Remaining: 221
344 6643 [OTA Task] [prvIngestDataBlock] Received file block 89, size 1024
345 6644 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 91136l address
346 6644 [OTA Task] [prvIngestDataBlock] Remaining: 220
347 6691 [OTA Task] [prvIngestDataBlock] Received file block 97, size 1024
348 6692 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 99328l address
349 6692 [OTA Task] [prvIngestDataBlock] Remaining: 219
350 6733 [OTA Task] [prvIngestDataBlock] Received file block 98, size 1024
351 6734 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 100352l address
352 6734 [OTA Task] [prvIngestDataBlock] Remaining: 218
353 6775 [OTA Task] [prvIngestDataBlock] Received file block 101, size 1024
354 6776 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 103424l address
355 6776 [OTA Task] [prvIngestDataBlock] Remaining: 217
356 6778 [app_ota_task] State: Active  Received: 94   Queued: 94   Processed: 94   Dropped: 0
357 6820 [OTA Task] [prvIngestDataBlock] Received file block 100, size 1024
358 6821 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 102400l address
359 6821 [OTA Task] [prvIngestDataBlock] Remaining: 216
360 6865 [OTA Task] [prvIngestDataBlock] Received file block 102, size 1024
361 6866 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 104448l address
362 6866 [OTA Task] [prvIngestDataBlock] Remaining: 215
363 6910 [OTA Task] [prvIngestDataBlock] Received file block 103, size 1024
364 6911 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 105472l address
365 6911 [OTA Task] [prvIngestDataBlock] Remaining: 214
366 6955 [OTA Task] [prvIngestDataBlock] Received file block 104, size 1024
367 6956 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 106496l address
368 6956 [OTA Task] [prvIngestDataBlock] Remaining: 213
369 6978 [app_ota_task] State: Active  Received: 98   Queued: 98   Processed: 98   Dropped: 0
370 7000 [OTA Task] [prvIngestDataBlock] Received file block 106, size 1024
371 7001 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 108544l address
372 7001 [OTA Task] [prvIngestDataBlock] Remaining: 212
373 7042 [OTA Task] [prvIngestDataBlock] Received file block 109, size 1024
374 7043 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 111616l address
375 7043 [OTA Task] [prvIngestDataBlock] Remaining: 211
376 7087 [OTA Task] [prvIngestDataBlock] Received file block 71, size 1024
377 7088 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 72704l address
378 7088 [OTA Task] [prvIngestDataBlock] Remaining: 210
379 7129 [OTA Task] [prvIngestDataBlock] Received file block 110, size 1024
380 7130 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 112640l address
381 7130 [OTA Task] [prvIngestDataBlock] Remaining: 209
382 7174 [OTA Task] [prvIngestDataBlock] Received file block 111, size 1024
383 7175 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 113664l address
384 7175 [OTA Task] [prvIngestDataBlock] Remaining: 208
385 7178 [app_ota_task] State: Active  Received: 103   Queued: 103   Processed: 103   Dropped: 0
386 7216 [OTA Task] [prvIngestDataBlock] Received file block 108, size 1024
387 7217 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 110592l address
388 7217 [OTA Task] [prvIngestDataBlock] Remaining: 207
389 7257 [OTA Task] [prvIngestDataBlock] Received file block 112, size 1024
390 7259 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 114688l address
391 7259 [OTA Task] [prvIngestDataBlock] Remaining: 206
392 7299 [OTA Task] [prvIngestDataBlock] Received file block 113, size 1024
393 7301 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 115712l address
394 7301 [OTA Task] [prvIngestDataBlock] Remaining: 205
395 7344 [OTA Task] [prvIngestDataBlock] Received file block 114, size 1024
396 7346 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 116736l address
397 7346 [OTA Task] [prvIngestDataBlock] Remaining: 204
398 7378 [app_ota_task] State: Active  Received: 107   Queued: 107   Processed: 107   Dropped: 0
399 7386 [OTA Task] [prvIngestDataBlock] Received file block 115, size 1024
400 7387 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 117760l address
401 7387 [OTA Task] [prvIngestDataBlock] Remaining: 203
402 7428 [OTA Task] [prvIngestDataBlock] Received file block 116, size 1024
403 7429 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 118784l address
404 7429 [OTA Task] [prvIngestDataBlock] Remaining: 202
405 7470 [OTA Task] [prvIngestDataBlock] Received file block 118, size 1024
406 7471 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 120832l address
407 7471 [OTA Task] [prvIngestDataBlock] Remaining: 201
408 7515 [OTA Task] [prvIngestDataBlock] Received file block 119, size 1024
409 7516 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 121856l address
410 7516 [OTA Task] [prvIngestDataBlock] Remaining: 200
411 7557 [OTA Task] [prvIngestDataBlock] Received file block 105, size 1024
412 7558 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 107520l address
413 7558 [OTA Task] [prvIngestDataBlock] Remaining: 199
414 7578 [app_ota_task] State: Active  Received: 112   Queued: 112   Processed: 112   Dropped: 0
415 7599 [OTA Task] [prvIngestDataBlock] Received file block 120, size 1024
416 7600 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 122880l address
417 7600 [OTA Task] [prvIngestDataBlock] Remaining: 198
418 7650 [OTA Task] [prvIngestDataBlock] Received file block 121, size 1024
419 7651 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 123904l address
420 7651 [OTA Task] [prvIngestDataBlock] Remaining: 197
421 7692 [OTA Task] [prvIngestDataBlock] Received file block 122, size 1024
422 7693 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 124928l address
423 7693 [OTA Task] [prvIngestDataBlock] Remaining: 196
424 7734 [OTA Task] [prvIngestDataBlock] Received file block 123, size 1024
425 7735 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 125952l address
426 7735 [OTA Task] [prvIngestDataBlock] Remaining: 195
427 7776 [OTA Task] [prvIngestDataBlock] Received file block 124, size 1024
428 7777 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 126976l address
429 7777 [OTA Task] [prvIngestDataBlock] Remaining: 194
430 7778 [app_ota_task] State: Active  Received: 117   Queued: 117   Processed: 117   Dropped: 0
431 7821 [OTA Task] [prvIngestDataBlock] Received file block 125, size 1024
432 7822 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 128000l address
433 7822 [OTA Task] [prvIngestDataBlock] Remaining: 193
434 7863 [OTA Task] [prvIngestDataBlock] Received file block 126, size 1024
435 7864 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 129024l address
436 7864 [OTA Task] [prvIngestDataBlock] Remaining: 192
437 7911 [OTA Task] [prvIngestDataBlock] Received file block 117, size 1024
438 7912 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 119808l address
439 7912 [OTA Task] [prvIngestDataBlock] Remaining: 191
440 7953 [OTA Task] [prvIngestDataBlock] Received file block 58, size 1024
441 7954 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 59392l address
442 7954 [OTA Task] [prvIngestDataBlock] Remaining: 190
443 7978 [app_ota_task] State: Active  Received: 121   Queued: 121   Processed: 121   Dropped: 0
444 8001 [OTA Task] [prvIngestDataBlock] Received file block 69, size 1024
445 8002 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 70656l address
446 8002 [OTA Task] [prvIngestDataBlock] Remaining: 189
447 8043 [OTA Task] [prvIngestDataBlock] Received file block 19, size 1024
448 8044 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 19456l address
449 8044 [OTA Task] [prvIngestDataBlock] Remaining: 188
450 8088 [OTA Task] [prvIngestDataBlock] Received file block 57, size 1024
451 8089 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 58368l address
452 8089 [OTA Task] [prvIngestDataBlock] Remaining: 187
453 8133 [OTA Task] [prvIngestDataBlock] Received file block 83, size 1024
454 8134 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 84992l address
455 8134 [OTA Task] [prvIngestDataBlock] Remaining: 186
456 8178 [app_ota_task] State: Active  Received: 125   Queued: 125   Processed: 125   Dropped: 0
457 8178 [OTA Task] [prvIngestDataBlock] Received file block 107, size 1024
458 8179 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 109568l address
459 8179 [OTA Task] [prvIngestDataBlock] Remaining: 185
460 8223 [OTA Task] [prvIngestDataBlock] Received file block 54, size 1024
461 8224 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 55296l address
462 8224 [OTA Task] [prvIngestDataBlock] Remaining: 184
463 8267 [OTA Task] [prvIngestDataBlock] Received file block 99, size 1024
464 8269 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 101376l address
465 8269 [OTA Task] [prvIngestDataBlock] Remaining: 183
466 8309 [OTA Task] [prvIngestDataBlock] Received file block 127, size 1024
467 8310 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 130048l address
468 8310 [OTA Task] [prvIngestDataBlock] Remaining: 182
469 8310 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"128/310"}}
470 8310 [OTA Task] [INFO ][MQTT][83100] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
471 8310 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-ota_fourm_log/update
472 8378 [app_ota_task] State: Active  Received: 129   Queued: 129   Processed: 129   Dropped: 0
473 8559 [OTA Task] [INFO ][MQTT][85590] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
474 8559 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/NRF52840DK/streams/AFR_OTA-91504af4-69ad-4aff-a837-221f30af5b35/get/cbor
475 8578 [app_ota_task] State: Active  Received: 129   Queued: 129   Processed: 129   Dropped: 0
476 8687 [OTA Task] [prvIngestDataBlock] Received file block 129, size 1024
477 8688 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 132096l address
478 8688 [OTA Task] [prvIngestDataBlock] Remaining: 181
479 8738 [OTA Task] [prvIngestDataBlock] Received file block 128, size 1024
480 8739 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 131072l address
481 8739 [OTA Task] [prvIngestDataBlock] Remaining: 180
482 8778 [app_ota_task] State: Active  Received: 131   Queued: 131   Processed: 131   Dropped: 0
483 8783 [OTA Task] [prvIngestDataBlock] Received file block 130, size 1024
484 8784 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 133120l address
485 8784 [OTA Task] [prvIngestDataBlock] Remaining: 179
486 8834 [OTA Task] [prvIngestDataBlock] Received file block 131, size 1024
487 8835 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 134144l address
488 8835 [OTA Task] [prvIngestDataBlock] Remaining: 178
489 8879 [OTA Task] [prvIngestDataBlock] Received file block 132, size 1024
490 8880 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 135168l address
491 8880 [OTA Task] [prvIngestDataBlock] Remaining: 177
492 8930 [OTA Task] [prvIngestDataBlock] Received file block 134, size 1024
493 8931 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 137216l address
494 8931 [OTA Task] [prvIngestDataBlock] Remaining: 176
495 8972 [OTA Task] [prvIngestDataBlock] Received file block 135, size 1024
496 8973 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 138240l address
497 8973 [OTA Task] [prvIngestDataBlock] Remaining: 175
498 8978 [app_ota_task] State: Active  Received: 136   Queued: 136   Processed: 136   Dropped: 0
499 9014 [OTA Task] [prvIngestDataBlock] Received file block 136, size 1024
500 9015 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 139264l address
501 9015 [OTA Task] [prvIngestDataBlock] Remaining: 174
502 9059 [OTA Task] [prvIngestDataBlock] Received file block 133, size 1024
503 9060 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 136192l address
504 9060 [OTA Task] [prvIngestDataBlock] Remaining: 173
505 9101 [OTA Task] [prvIngestDataBlock] Received file block 137, size 1024
506 9102 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 140288l address
507 9102 [OTA Task] [prvIngestDataBlock] Remaining: 172
508 9143 [OTA Task] [prvIngestDataBlock] Received file block 138, size 1024
509 9144 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 141312l address
510 9144 [OTA Task] [prvIngestDataBlock] Remaining: 171
511 9178 [app_ota_task] State: Active  Received: 140   Queued: 140   Processed: 140   Dropped: 0
512 9187 [OTA Task] [prvIngestDataBlock] Received file block 139, size 1024
513 9188 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 142336l address
514 9188 [OTA Task] [prvIngestDataBlock] Remaining: 170
515 9230 [OTA Task] [prvIngestDataBlock] Received file block 140, size 1024
516 9231 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 143360l address
517 9231 [OTA Task] [prvIngestDataBlock] Remaining: 169
518 9271 [OTA Task] [prvIngestDataBlock] Received file block 142, size 1024
519 9273 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 145408l address
520 9273 [OTA Task] [prvIngestDataBlock] Remaining: 168
521 9319 [OTA Task] [prvIngestDataBlock] Received file block 143, size 1024
522 9321 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 146432l address
523 9321 [OTA Task] [prvIngestDataBlock] Remaining: 167
524 9361 [OTA Task] [prvIngestDataBlock] Received file block 145, size 1024
525 9362 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 148480l address
526 9363 [OTA Task] [prvIngestDataBlock] Remaining: 166
527 9378 [app_ota_task] State: Active  Received: 145   Queued: 145   Processed: 145   Dropped: 0
528 9409 [OTA Task] [prvIngestDataBlock] Received file block 147, size 1024
529 9410 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 150528l address
530 9410 [OTA Task] [prvIngestDataBlock] Remaining: 165
531 9451 [OTA Task] [prvIngestDataBlock] Received file block 146, size 1024
532 9452 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 149504l address
533 9452 [OTA Task] [prvIngestDataBlock] Remaining: 164
534 9496 [OTA Task] [prvIngestDataBlock] Received file block 148, size 1024
535 9497 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 151552l address
536 9497 [OTA Task] [prvIngestDataBlock] Remaining: 163
537 9538 [OTA Task] [prvIngestDataBlock] Received file block 149, size 1024
538 9539 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 152576l address
539 9539 [OTA Task] [prvIngestDataBlock] Remaining: 162
540 9578 [app_ota_task] State: Active  Received: 149   Queued: 149   Processed: 149   Dropped: 0
541 9580 [OTA Task] [prvIngestDataBlock] Received file block 151, size 1024
542 9581 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 154624l address
543 9581 [OTA Task] [prvIngestDataBlock] Remaining: 161
544 9622 [OTA Task] [prvIngestDataBlock] Received file block 152, size 1024
545 9623 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 155648l address
546 9623 [OTA Task] [prvIngestDataBlock] Remaining: 160
547 9667 [OTA Task] [prvIngestDataBlock] Received file block 153, size 1024
548 9668 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 156672l address
549 9668 [OTA Task] [prvIngestDataBlock] Remaining: 159
550 9712 [OTA Task] [prvIngestDataBlock] Received file block 154, size 1024
551 9713 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 157696l address
552 9713 [OTA Task] [prvIngestDataBlock] Remaining: 158
553 9757 [OTA Task] [prvIngestDataBlock] Received file block 155, size 1024
554 9758 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 158720l address
555 9758 [OTA Task] [prvIngestDataBlock] Remaining: 157
556 9778 [app_ota_task] State: Active  Received: 154   Queued: 154   Processed: 154   Dropped: 0
557 9799 [OTA Task] [prvIngestDataBlock] Received file block 156, size 1024
558 9800 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 159744l address
559 9800 [OTA Task] [prvIngestDataBlock] Remaining: 156
560 9844 [OTA Task] [prvIngestDataBlock] Received file block 150, size 1024
561 9845 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 153600l address
562 9845 [OTA Task] [prvIngestDataBlock] Remaining: 155
563 9886 [OTA Task] [prvIngestDataBlock] Received file block 157, size 1024
564 9887 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 160768l address
565 9887 [OTA Task] [prvIngestDataBlock] Remaining: 154
566 9931 [OTA Task] [prvIngestDataBlock] Received file block 158, size 1024
567 9932 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 161792l address
568 9932 [OTA Task] [prvIngestDataBlock] Remaining: 153
569 9978 [app_ota_task] State: Active  Received: 158   Queued: 158   Processed: 158   Dropped: 0
570 9982 [OTA Task] [prvIngestDataBlock] Received file block 159, size 1024
571 9983 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 162816l address
572 9983 [OTA Task] [prvIngestDataBlock] Remaining: 152
573 10024 [OTA Task] [prvIngestDataBlock] Received file block 161, size 1024
574 10025 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 164864l address
575 10025 [OTA Task] [prvIngestDataBlock] Remaining: 151
576 10069 [OTA Task] [prvIngestDataBlock] Received file block 162, size 1024
577 10070 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 165888l address
578 10070 [OTA Task] [prvIngestDataBlock] Remaining: 150
579 10111 [OTA Task] [prvIngestDataBlock] Received file block 163, size 1024
580 10112 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 166912l address
581 10112 [OTA Task] [prvIngestDataBlock] Remaining: 149
582 10153 [OTA Task] [prvIngestDataBlock] Received file block 164, size 1024
583 10154 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 167936l address
584 10154 [OTA Task] [prvIngestDataBlock] Remaining: 148
585 10178 [app_ota_task] State: Active  Received: 163   Queued: 163   Processed: 163   Dropped: 0
586 10195 [OTA Task] [prvIngestDataBlock] Received file block 165, size 1024
587 10196 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 168960l address
588 10196 [OTA Task] [prvIngestDataBlock] Remaining: 147
589 10240 [OTA Task] [prvIngestDataBlock] Received file block 167, size 1024
590 10241 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 171008l address
591 10241 [OTA Task] [prvIngestDataBlock] Remaining: 146
592 10281 [OTA Task] [prvIngestDataBlock] Received file block 169, size 1024
593 10283 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 173056l address
594 10283 [OTA Task] [prvIngestDataBlock] Remaining: 145
595 10323 [OTA Task] [prvIngestDataBlock] Received file block 168, size 1024
596 10325 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 172032l address
597 10325 [OTA Task] [prvIngestDataBlock] Remaining: 144
598 10365 [OTA Task] [prvIngestDataBlock] Received file block 170, size 1024
599 10366 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 174080l address
600 10367 [OTA Task] [prvIngestDataBlock] Remaining: 143
601 10378 [app_ota_task] State: Active  Received: 168   Queued: 168   Processed: 168   Dropped: 0
602 10416 [OTA Task] [prvIngestDataBlock] Received file block 172, size 1024
603 10417 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 176128l address
604 10417 [OTA Task] [prvIngestDataBlock] Remaining: 142
605 10461 [OTA Task] [prvIngestDataBlock] Received file block 173, size 1024
606 10462 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 177152l address
607 10462 [OTA Task] [prvIngestDataBlock] Remaining: 141
608 10506 [OTA Task] [prvIngestDataBlock] Received file block 144, size 1024
609 10507 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 147456l address
610 10507 [OTA Task] [prvIngestDataBlock] Remaining: 140
611 10548 [OTA Task] [prvIngestDataBlock] Received file block 174, size 1024
612 10549 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 178176l address
613 10549 [OTA Task] [prvIngestDataBlock] Remaining: 139
614 10578 [app_ota_task] State: Active  Received: 172   Queued: 172   Processed: 172   Dropped: 0
615 10593 [OTA Task] [prvIngestDataBlock] Received file block 176, size 1024
616 10594 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 180224l address
617 10594 [OTA Task] [prvIngestDataBlock] Remaining: 138
618 10635 [OTA Task] [prvIngestDataBlock] Received file block 175, size 1024
619 10636 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 179200l address
620 10636 [OTA Task] [prvIngestDataBlock] Remaining: 137
621 10683 [OTA Task] [prvIngestDataBlock] Received file block 177, size 1024
622 10684 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 181248l address
623 10684 [OTA Task] [prvIngestDataBlock] Remaining: 136
624 10728 [OTA Task] [prvIngestDataBlock] Received file block 178, size 1024
625 10729 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 182272l address
626 10729 [OTA Task] [prvIngestDataBlock] Remaining: 135
627 10770 [OTA Task] [prvIngestDataBlock] Received file block 179, size 1024
628 10771 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 183296l address
629 10771 [OTA Task] [prvIngestDataBlock] Remaining: 134
630 10778 [app_ota_task] State: Active  Received: 177   Queued: 177   Processed: 177   Dropped: 0
631 10815 [OTA Task] [prvIngestDataBlock] Received file block 180, size 1024
632 10816 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 184320l address
633 10816 [OTA Task] [prvIngestDataBlock] Remaining: 133
634 10857 [OTA Task] [prvIngestDataBlock] Received file block 181, size 1024
635 10858 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 185344l address
636 10858 [OTA Task] [prvIngestDataBlock] Remaining: 132
637 10905 [OTA Task] [prvIngestDataBlock] Received file block 141, size 1024
638 10906 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 144384l address
639 10906 [OTA Task] [prvIngestDataBlock] Remaining: 131
640 10950 [OTA Task] [prvIngestDataBlock] Received file block 160, size 1024
641 10951 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 163840l address
642 10951 [OTA Task] [prvIngestDataBlock] Remaining: 130
643 10978 [app_ota_task] State: Active  Received: 181   Queued: 181   Processed: 181   Dropped: 0
644 10992 [OTA Task] [prvIngestDataBlock] Received file block 182, size 1024
645 10993 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 186368l address
646 10993 [OTA Task] [prvIngestDataBlock] Remaining: 129
647 11037 [OTA Task] [prvIngestDataBlock] Received file block 171, size 1024
648 11038 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 175104l address
649 11038 [OTA Task] [prvIngestDataBlock] Remaining: 128
650 11079 [OTA Task] [prvIngestDataBlock] Received file block 183, size 1024
651 11080 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 187392l address
652 11080 [OTA Task] [prvIngestDataBlock] Remaining: 127
653 11121 [OTA Task] [prvIngestDataBlock] Received file block 184, size 1024
654 11122 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 188416l address
655 11122 [OTA Task] [prvIngestDataBlock] Remaining: 126
656 11163 [OTA Task] [prvIngestDataBlock] Received file block 185, size 1024
657 11164 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 189440l address
658 11164 [OTA Task] [prvIngestDataBlock] Remaining: 125
659 11178 [app_ota_task] State: Active  Received: 186   Queued: 186   Processed: 186   Dropped: 0
660 11208 [OTA Task] [prvIngestDataBlock] Received file block 186, size 1024
661 11209 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 190464l address
662 11209 [OTA Task] [prvIngestDataBlock] Remaining: 124
663 11249 [OTA Task] [prvIngestDataBlock] Received file block 187, size 1024
664 11251 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 191488l address
665 11251 [OTA Task] [prvIngestDataBlock] Remaining: 123
666 11291 [OTA Task] [prvIngestDataBlock] Received file block 188, size 1024
667 11293 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 192512l address
668 11293 [OTA Task] [prvIngestDataBlock] Remaining: 122
669 11333 [OTA Task] [prvIngestDataBlock] Received file block 166, size 1024
670 11335 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 169984l address
671 11335 [OTA Task] [prvIngestDataBlock] Remaining: 121
672 11375 [OTA Task] [prvIngestDataBlock] Received file block 189, size 1024
673 11376 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 193536l address
674 11377 [OTA Task] [prvIngestDataBlock] Remaining: 120
675 11378 [app_ota_task] State: Active  Received: 191   Queued: 191   Processed: 191   Dropped: 0
676 11420 [OTA Task] [prvIngestDataBlock] Received file block 190, size 1024
677 11421 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 194560l address
678 11421 [OTA Task] [prvIngestDataBlock] Remaining: 119
679 11462 [OTA Task] [prvIngestDataBlock] Received file block 191, size 1024
680 11463 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 195584l address
681 11463 [OTA Task] [prvIngestDataBlock] Remaining: 118
682 11463 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"192/310"}}
683 11464 [OTA Task] [INFO ][MQTT][114630] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
684 11464 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-ota_fourm_log/update
685 11513 [OTA Task] [prvIngestDataBlock] Received file block 192, size 1024
686 11514 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 196608l address
687 11514 [OTA Task] [prvIngestDataBlock] Remaining: 117
688 11555 [OTA Task] [prvIngestDataBlock] Received file block 193, size 1024
689 11556 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 197632l address
690 11556 [OTA Task] [prvIngestDataBlock] Remaining: 116
691 11578 [app_ota_task] State: Active  Received: 195   Queued: 195   Processed: 195   Dropped: 0
692 11600 [OTA Task] [prvIngestDataBlock] Received file block 194, size 1024
693 11601 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 198656l address
694 11601 [OTA Task] [prvIngestDataBlock] Remaining: 115
695 11642 [OTA Task] [prvIngestDataBlock] Received file block 195, size 1024
696 11643 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 199680l address
697 11643 [OTA Task] [prvIngestDataBlock] Remaining: 114
698 11684 [OTA Task] [prvIngestDataBlock] Received file block 196, size 1024
699 11685 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 200704l address
700 11685 [OTA Task] [prvIngestDataBlock] Remaining: 113
701 11732 [OTA Task] [prvIngestDataBlock] Received file block 197, size 1024
702 11733 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 201728l address
703 11733 [OTA Task] [prvIngestDataBlock] Remaining: 112
704 11777 [OTA Task] [prvIngestDataBlock] Received file block 198, size 1024
705 11778 [app_ota_task] State: Active  Received: 200   Queued: 200   Processed: 199   Dropped: 0
706 11778 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 202752l address
707 11778 [OTA Task] [prvIngestDataBlock] Remaining: 111
708 11819 [OTA Task] [prvIngestDataBlock] Received file block 199, size 1024
709 11820 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 203776l address
710 11820 [OTA Task] [prvIngestDataBlock] Remaining: 110
711 11861 [OTA Task] [prvIngestDataBlock] Received file block 200, size 1024
712 11862 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 204800l address
713 11862 [OTA Task] [prvIngestDataBlock] Remaining: 109
714 11906 [OTA Task] [prvIngestDataBlock] Received file block 201, size 1024
715 11907 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 205824l address
716 11907 [OTA Task] [prvIngestDataBlock] Remaining: 108
717 11951 [OTA Task] [prvIngestDataBlock] Received file block 202, size 1024
718 11952 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 206848l address
719 11952 [OTA Task] [prvIngestDataBlock] Remaining: 107
720 11978 [app_ota_task] State: Active  Received: 204   Queued: 204   Processed: 204   Dropped: 0
721 11993 [OTA Task] [prvIngestDataBlock] Received file block 204, size 1024
722 11994 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 208896l address
723 11994 [OTA Task] [prvIngestDataBlock] Remaining: 106
724 12035 [OTA Task] [prvIngestDataBlock] Received file block 205, size 1024
725 12036 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 209920l address
726 12036 [OTA Task] [prvIngestDataBlock] Remaining: 105
727 12080 [OTA Task] [prvIngestDataBlock] Received file block 206, size 1024
728 12081 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 210944l address
729 12081 [OTA Task] [prvIngestDataBlock] Remaining: 104
730 12128 [OTA Task] [prvIngestDataBlock] Received file block 209, size 1024
731 12129 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 214016l address
732 12129 [OTA Task] [prvIngestDataBlock] Remaining: 103
733 12178 [app_ota_task] State: Active  Received: 208   Queued: 208   Processed: 208   Dropped: 0
734 12179 [OTA Task] [prvIngestDataBlock] Received file block 208, size 1024
735 12180 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 212992l address
736 12180 [OTA Task] [prvIngestDataBlock] Remaining: 102
737 12221 [OTA Task] [prvIngestDataBlock] Received file block 210, size 1024
738 12222 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 215040l address
739 12222 [OTA Task] [prvIngestDataBlock] Remaining: 101
740 12265 [OTA Task] [prvIngestDataBlock] Received file block 211, size 1024
741 12267 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 216064l address
742 12267 [OTA Task] [prvIngestDataBlock] Remaining: 100
743 12307 [OTA Task] [prvIngestDataBlock] Received file block 212, size 1024
744 12308 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 217088l address
745 12308 [OTA Task] [prvIngestDataBlock] Remaining: 99
746 12349 [OTA Task] [prvIngestDataBlock] Received file block 207, size 1024
747 12351 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 211968l address
748 12351 [OTA Task] [prvIngestDataBlock] Remaining: 98
749 12378 [app_ota_task] State: Active  Received: 213   Queued: 213   Processed: 213   Dropped: 0
750 12394 [OTA Task] [prvIngestDataBlock] Received file block 213, size 1024
751 12395 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 218112l address
752 12395 [OTA Task] [prvIngestDataBlock] Remaining: 97
753 12439 [OTA Task] [prvIngestDataBlock] Received file block 214, size 1024
754 12440 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 219136l address
755 12440 [OTA Task] [prvIngestDataBlock] Remaining: 96
756 12484 [OTA Task] [prvIngestDataBlock] Received file block 215, size 1024
757 12485 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 220160l address
758 12485 [OTA Task] [prvIngestDataBlock] Remaining: 95
759 12526 [OTA Task] [prvIngestDataBlock] Received file block 217, size 1024
760 12527 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 222208l address
761 12527 [OTA Task] [prvIngestDataBlock] Remaining: 94
762 12568 [OTA Task] [prvIngestDataBlock] Received file block 216, size 1024
763 12569 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 221184l address
764 12569 [OTA Task] [prvIngestDataBlock] Remaining: 93
765 12578 [app_ota_task] State: Active  Received: 218   Queued: 218   Processed: 218   Dropped: 0
766 12619 [OTA Task] [prvIngestDataBlock] Received file block 218, size 1024
767 12620 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 223232l address
768 12620 [OTA Task] [prvIngestDataBlock] Remaining: 92
769 12661 [OTA Task] [prvIngestDataBlock] Received file block 219, size 1024
770 12662 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 224256l address
771 12662 [OTA Task] [prvIngestDataBlock] Remaining: 91
772 12703 [OTA Task] [prvIngestDataBlock] Received file block 220, size 1024
773 12704 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 225280l address
774 12704 [OTA Task] [prvIngestDataBlock] Remaining: 90
775 12748 [OTA Task] [prvIngestDataBlock] Received file block 222, size 1024
776 12749 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 227328l address
777 12749 [OTA Task] [prvIngestDataBlock] Remaining: 89
778 12778 [app_ota_task] State: Active  Received: 222   Queued: 222   Processed: 222   Dropped: 0
779 12790 [OTA Task] [prvIngestDataBlock] Received file block 223, size 1024
780 12791 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 228352l address
781 12791 [OTA Task] [prvIngestDataBlock] Remaining: 88
782 12835 [OTA Task] [prvIngestDataBlock] Received file block 224, size 1024
783 12836 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 229376l address
784 12836 [OTA Task] [prvIngestDataBlock] Remaining: 87
785 12883 [OTA Task] [prvIngestDataBlock] Received file block 226, size 1024
786 12884 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 231424l address
787 12884 [OTA Task] [prvIngestDataBlock] Remaining: 86
788 12931 [OTA Task] [prvIngestDataBlock] Received file block 227, size 1024
789 12932 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 232448l address
790 12932 [OTA Task] [prvIngestDataBlock] Remaining: 85
791 12978 [app_ota_task] State: Active  Received: 226   Queued: 226   Processed: 226   Dropped: 0
792 12979 [OTA Task] [prvIngestDataBlock] Received file block 229, size 1024
793 12980 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 234496l address
794 12980 [OTA Task] [prvIngestDataBlock] Remaining: 84
795 13021 [OTA Task] [prvIngestDataBlock] Received file block 228, size 1024
796 13022 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 233472l address
797 13022 [OTA Task] [prvIngestDataBlock] Remaining: 83
798 13066 [OTA Task] [prvIngestDataBlock] Received file block 230, size 1024
799 13067 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 235520l address
800 13067 [OTA Task] [prvIngestDataBlock] Remaining: 82
801 13114 [OTA Task] [prvIngestDataBlock] Received file block 231, size 1024
802 13115 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 236544l address
803 13115 [OTA Task] [prvIngestDataBlock] Remaining: 81
804 13156 [OTA Task] [prvIngestDataBlock] Received file block 232, size 1024
805 13157 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 237568l address
806 13157 [OTA Task] [prvIngestDataBlock] Remaining: 80
807 13178 [app_ota_task] State: Active  Received: 231   Queued: 231   Processed: 231   Dropped: 0
808 13201 [OTA Task] [prvIngestDataBlock] Received file block 233, size 1024
809 13202 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 238592l address
810 13202 [OTA Task] [prvIngestDataBlock] Remaining: 79
811 13248 [OTA Task] [prvIngestDataBlock] Received file block 234, size 1024
812 13250 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 239616l address
813 13250 [OTA Task] [prvIngestDataBlock] Remaining: 78
814 13293 [OTA Task] [prvIngestDataBlock] Received file block 236, size 1024
815 13295 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 241664l address
816 13295 [OTA Task] [prvIngestDataBlock] Remaining: 77
817 13335 [OTA Task] [prvIngestDataBlock] Received file block 235, size 1024
818 13337 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 240640l address
819 13337 [OTA Task] [prvIngestDataBlock] Remaining: 76
820 13377 [OTA Task] [prvIngestDataBlock] Received file block 237, size 1024
821 13378 [app_ota_task] State: Active  Received: 236   Queued: 236   Processed: 235   Dropped: 0
822 13379 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 242688l address
823 13379 [OTA Task] [prvIngestDataBlock] Remaining: 75
824 13425 [OTA Task] [prvIngestDataBlock] Received file block 238, size 1024
825 13426 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 243712l address
826 13426 [OTA Task] [prvIngestDataBlock] Remaining: 74
827 13473 [OTA Task] [prvIngestDataBlock] Received file block 240, size 1024
828 13474 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 245760l address
829 13474 [OTA Task] [prvIngestDataBlock] Remaining: 73
830 13521 [OTA Task] [prvIngestDataBlock] Received file block 239, size 1024
831 13522 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 244736l address
832 13522 [OTA Task] [prvIngestDataBlock] Remaining: 72
833 13566 [OTA Task] [prvIngestDataBlock] Received file block 242, size 1024
834 13567 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 247808l address
835 13567 [OTA Task] [prvIngestDataBlock] Remaining: 71
836 13578 [app_ota_task] State: Active  Received: 240   Queued: 240   Processed: 240   Dropped: 0
837 13608 [OTA Task] [prvIngestDataBlock] Received file block 243, size 1024
838 13609 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 248832l address
839 13609 [OTA Task] [prvIngestDataBlock] Remaining: 70
840 13650 [OTA Task] [prvIngestDataBlock] Received file block 244, size 1024
841 13651 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 249856l address
842 13651 [OTA Task] [prvIngestDataBlock] Remaining: 69
843 13692 [OTA Task] [prvIngestDataBlock] Received file block 221, size 1024
844 13693 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 226304l address
845 13693 [OTA Task] [prvIngestDataBlock] Remaining: 68
846 13746 [OTA Task] [prvIngestDataBlock] Received file block 245, size 1024
847 13747 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 250880l address
848 13747 [OTA Task] [prvIngestDataBlock] Remaining: 67
849 13778 [app_ota_task] State: Active  Received: 244   Queued: 244   Processed: 244   Dropped: 0
850 13791 [OTA Task] [prvIngestDataBlock] Received file block 246, size 1024
851 13792 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 251904l address
852 13792 [OTA Task] [prvIngestDataBlock] Remaining: 66
853 13833 [OTA Task] [prvIngestDataBlock] Received file block 203, size 1024
854 13834 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 207872l address
855 13834 [OTA Task] [prvIngestDataBlock] Remaining: 65
856 13875 [OTA Task] [prvIngestDataBlock] Received file block 247, size 1024
857 13876 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 252928l address
858 13876 [OTA Task] [prvIngestDataBlock] Remaining: 64
859 13917 [OTA Task] [prvIngestDataBlock] Received file block 248, size 1024
860 13918 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 253952l address
861 13918 [OTA Task] [prvIngestDataBlock] Remaining: 63
862 13962 [OTA Task] [prvIngestDataBlock] Received file block 250, size 1024
863 13963 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 256000l address
864 13963 [OTA Task] [prvIngestDataBlock] Remaining: 62
865 13978 [app_ota_task] State: Active  Received: 249   Queued: 249   Processed: 249   Dropped: 0
866 14010 [OTA Task] [prvIngestDataBlock] Received file block 251, size 1024
867 14011 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 257024l address
868 14011 [OTA Task] [prvIngestDataBlock] Remaining: 61
869 14052 [OTA Task] [prvIngestDataBlock] Received file block 252, size 1024
870 14053 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 258048l address
871 14053 [OTA Task] [prvIngestDataBlock] Remaining: 60
872 14094 [OTA Task] [prvIngestDataBlock] Received file block 253, size 1024
873 14095 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 259072l address
874 14095 [OTA Task] [prvIngestDataBlock] Remaining: 59
875 14148 [OTA Task] [prvIngestDataBlock] Received file block 254, size 1024
876 14149 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 260096l address
877 14149 [OTA Task] [prvIngestDataBlock] Remaining: 58
878 14178 [app_ota_task] State: Active  Received: 253   Queued: 253   Processed: 253   Dropped: 0
879 14190 [OTA Task] [prvIngestDataBlock] Received file block 255, size 1024
880 14191 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 261120l address
881 14191 [OTA Task] [prvIngestDataBlock] Remaining: 57
882 14232 [OTA Task] [prvIngestDataBlock] Received file block 225, size 1024
883 14233 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 230400l address
884 14233 [OTA Task] [prvIngestDataBlock] Remaining: 56
885 14273 [OTA Task] [prvIngestDataBlock] Received file block 241, size 1024
886 14275 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 246784l address
887 14275 [OTA Task] [prvIngestDataBlock] Remaining: 55
888 14315 [OTA Task] [prvIngestDataBlock] Received file block 249, size 1024
889 14316 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 254976l address
890 14316 [OTA Task] [prvIngestDataBlock] Remaining: 54
891 14316 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"256/310"}}
892 14316 [OTA Task] [INFO ][MQTT][143160] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
893 14316 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-ota_fourm_log/update
894 14378 [app_ota_task] State: Active  Received: 257   Queued: 257   Processed: 257   Dropped: 0
895 14565 [OTA Task] [INFO ][MQTT][145650] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
896 14565 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/NRF52840DK/streams/AFR_OTA-91504af4-69ad-4aff-a837-221f30af5b35/get/cbor
897 14578 [app_ota_task] State: Active  Received: 257   Queued: 257   Processed: 257   Dropped: 0
898 14702 [OTA Task] [prvIngestDataBlock] Received file block 256, size 1024
899 14703 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 262144l address
900 14703 [OTA Task] [prvIngestDataBlock] Remaining: 53
901 14753 [OTA Task] [prvIngestDataBlock] Received file block 257, size 1024
902 14754 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 263168l address
903 14754 [OTA Task] [prvIngestDataBlock] Remaining: 52
904 14778 [app_ota_task] State: Active  Received: 259   Queued: 259   Processed: 259   Dropped: 0
905 14795 [OTA Task] [prvIngestDataBlock] Received file block 258, size 1024
906 14796 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 264192l address
907 14796 [OTA Task] [prvIngestDataBlock] Remaining: 51
908 14837 [OTA Task] [prvIngestDataBlock] Received file block 259, size 1024
909 14838 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 265216l address
910 14838 [OTA Task] [prvIngestDataBlock] Remaining: 50
911 14879 [OTA Task] [prvIngestDataBlock] Received file block 260, size 1024
912 14880 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 266240l address
913 14880 [OTA Task] [prvIngestDataBlock] Remaining: 49
914 14927 [OTA Task] [prvIngestDataBlock] Received file block 261, size 1024
915 14928 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 267264l address
916 14928 [OTA Task] [prvIngestDataBlock] Remaining: 48
917 14969 [OTA Task] [prvIngestDataBlock] Received file block 262, size 1024
918 14970 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 268288l address
919 14970 [OTA Task] [prvIngestDataBlock] Remaining: 47
920 14978 [app_ota_task] State: Active  Received: 264   Queued: 264   Processed: 264   Dropped: 0
921 15011 [OTA Task] [prvIngestDataBlock] Received file block 263, size 1024
922 15012 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 269312l address
923 15012 [OTA Task] [prvIngestDataBlock] Remaining: 46
924 15056 [OTA Task] [prvIngestDataBlock] Received file block 264, size 1024
925 15057 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 270336l address
926 15057 [OTA Task] [prvIngestDataBlock] Remaining: 45
927 15098 [OTA Task] [prvIngestDataBlock] Received file block 265, size 1024
928 15099 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 271360l address
929 15099 [OTA Task] [prvIngestDataBlock] Remaining: 44
930 15140 [OTA Task] [prvIngestDataBlock] Received file block 266, size 1024
931 15141 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 272384l address
932 15141 [OTA Task] [prvIngestDataBlock] Remaining: 43
933 15178 [app_ota_task] State: Active  Received: 268   Queued: 268   Processed: 268   Dropped: 0
934 15182 [OTA Task] [prvIngestDataBlock] Received file block 267, size 1024
935 15183 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 273408l address
936 15183 [OTA Task] [prvIngestDataBlock] Remaining: 42
937 15227 [OTA Task] [prvIngestDataBlock] Received file block 269, size 1024
938 15228 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 275456l address
939 15228 [OTA Task] [prvIngestDataBlock] Remaining: 41
940 15268 [OTA Task] [prvIngestDataBlock] Received file block 270, size 1024
941 15270 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 276480l address
942 15270 [OTA Task] [prvIngestDataBlock] Remaining: 40
943 15313 [OTA Task] [prvIngestDataBlock] Received file block 271, size 1024
944 15314 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 277504l address
945 15314 [OTA Task] [prvIngestDataBlock] Remaining: 39
946 15355 [OTA Task] [prvIngestDataBlock] Received file block 272, size 1024
947 15357 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 278528l address
948 15357 [OTA Task] [prvIngestDataBlock] Remaining: 38
949 15378 [app_ota_task] State: Active  Received: 273   Queued: 273   Processed: 273   Dropped: 0
950 15397 [OTA Task] [prvIngestDataBlock] Received file block 273, size 1024
951 15398 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 279552l address
952 15398 [OTA Task] [prvIngestDataBlock] Remaining: 37
953 15439 [OTA Task] [prvIngestDataBlock] Received file block 274, size 1024
954 15440 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 280576l address
955 15440 [OTA Task] [prvIngestDataBlock] Remaining: 36
956 15481 [OTA Task] [prvIngestDataBlock] Received file block 275, size 1024
957 15482 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 281600l address
958 15482 [OTA Task] [prvIngestDataBlock] Remaining: 35
959 15523 [OTA Task] [prvIngestDataBlock] Received file block 276, size 1024
960 15524 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 282624l address
961 15524 [OTA Task] [prvIngestDataBlock] Remaining: 34
962 15565 [OTA Task] [prvIngestDataBlock] Received file block 277, size 1024
963 15566 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 283648l address
964 15566 [OTA Task] [prvIngestDataBlock] Remaining: 33
965 15578 [app_ota_task] State: Active  Received: 278   Queued: 278   Processed: 278   Dropped: 0
966 15610 [OTA Task] [prvIngestDataBlock] Received file block 278, size 1024
967 15611 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 284672l address
968 15611 [OTA Task] [prvIngestDataBlock] Remaining: 32
969 15652 [OTA Task] [prvIngestDataBlock] Received file block 279, size 1024
970 15653 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 285696l address
971 15653 [OTA Task] [prvIngestDataBlock] Remaining: 31
972 15706 [OTA Task] [prvIngestDataBlock] Received file block 280, size 1024
973 15707 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 286720l address
974 15707 [OTA Task] [prvIngestDataBlock] Remaining: 30
975 15751 [OTA Task] [prvIngestDataBlock] Received file block 281, size 1024
976 15752 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 287744l address
977 15752 [OTA Task] [prvIngestDataBlock] Remaining: 29
978 15778 [app_ota_task] State: Active  Received: 282   Queued: 282   Processed: 282   Dropped: 0
979 15799 [OTA Task] [prvIngestDataBlock] Received file block 282, size 1024
980 15800 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 288768l address
981 15800 [OTA Task] [prvIngestDataBlock] Remaining: 28
982 15841 [OTA Task] [prvIngestDataBlock] Received file block 283, size 1024
983 15842 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 289792l address
984 15842 [OTA Task] [prvIngestDataBlock] Remaining: 27
985 15889 [OTA Task] [prvIngestDataBlock] Received file block 284, size 1024
986 15890 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 290816l address
987 15890 [OTA Task] [prvIngestDataBlock] Remaining: 26
988 15937 [OTA Task] [prvIngestDataBlock] Received file block 285, size 1024
989 15938 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 291840l address
990 15938 [OTA Task] [prvIngestDataBlock] Remaining: 25
991 15978 [app_ota_task] State: Active  Received: 286   Queued: 286   Processed: 286   Dropped: 0
992 15979 [OTA Task] [prvIngestDataBlock] Received file block 288, size 1024
993 15980 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 294912l address
994 15980 [OTA Task] [prvIngestDataBlock] Remaining: 24
995 16021 [OTA Task] [prvIngestDataBlock] Received file block 289, size 1024
996 16022 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 295936l address
997 16022 [OTA Task] [prvIngestDataBlock] Remaining: 23
998 16063 [OTA Task] [prvIngestDataBlock] Received file block 290, size 1024
999 16064 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 296960l address
1000 16064 [OTA Task] [prvIngestDataBlock] Remaining: 22
1001 16108 [OTA Task] [prvIngestDataBlock] Received file block 291, size 1024
1002 16109 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 297984l address
1003 16109 [OTA Task] [prvIngestDataBlock] Remaining: 21
1004 16150 [OTA Task] [prvIngestDataBlock] Received file block 292, size 1024
1005 16151 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 299008l address
1006 16151 [OTA Task] [prvIngestDataBlock] Remaining: 20
1007 16178 [app_ota_task] State: Active  Received: 291   Queued: 291   Processed: 291   Dropped: 0
1008 16195 [OTA Task] [prvIngestDataBlock] Received file block 293, size 1024
1009 16196 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 300032l address
1010 16196 [OTA Task] [prvIngestDataBlock] Remaining: 19
1011 16239 [OTA Task] [prvIngestDataBlock] Received file block 294, size 1024
1012 16241 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 301056l address
1013 16241 [OTA Task] [prvIngestDataBlock] Remaining: 18
1014 16281 [OTA Task] [prvIngestDataBlock] Received file block 295, size 1024
1015 16283 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 302080l address
1016 16283 [OTA Task] [prvIngestDataBlock] Remaining: 17
1017 16326 [OTA Task] [prvIngestDataBlock] Received file block 296, size 1024
1018 16328 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 303104l address
1019 16328 [OTA Task] [prvIngestDataBlock] Remaining: 16
1020 16371 [OTA Task] [prvIngestDataBlock] Received file block 297, size 1024
1021 16372 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 304128l address
1022 16373 [OTA Task] [prvIngestDataBlock] Remaining: 15
1023 16378 [app_ota_task] State: Active  Received: 296   Queued: 296   Processed: 296   Dropped: 0
1024 16419 [OTA Task] [prvIngestDataBlock] Received file block 298, size 1024
1025 16420 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 305152l address
1026 16420 [OTA Task] [prvIngestDataBlock] Remaining: 14
1027 16461 [OTA Task] [prvIngestDataBlock] Received file block 299, size 1024
1028 16462 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 306176l address
1029 16462 [OTA Task] [prvIngestDataBlock] Remaining: 13
1030 16506 [OTA Task] [prvIngestDataBlock] Received file block 301, size 1024
1031 16507 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 308224l address
1032 16507 [OTA Task] [prvIngestDataBlock] Remaining: 12
1033 16548 [OTA Task] [prvIngestDataBlock] Received file block 302, size 1024
1034 16549 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 309248l address
1035 16549 [OTA Task] [prvIngestDataBlock] Remaining: 11
1036 16578 [app_ota_task] State: Active  Received: 300   Queued: 300   Processed: 300   Dropped: 0
1037 16590 [OTA Task] [prvIngestDataBlock] Received file block 268, size 1024
1038 16591 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 274432l address
1039 16591 [OTA Task] [prvIngestDataBlock] Remaining: 10
1040 16635 [OTA Task] [prvIngestDataBlock] Received file block 303, size 1024
1041 16636 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 310272l address
1042 16636 [OTA Task] [prvIngestDataBlock] Remaining: 9
1043 16680 [OTA Task] [prvIngestDataBlock] Received file block 304, size 1024
1044 16681 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 311296l address
1045 16681 [OTA Task] [prvIngestDataBlock] Remaining: 8
1046 16722 [OTA Task] [prvIngestDataBlock] Received file block 287, size 1024
1047 16723 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 293888l address
1048 16723 [OTA Task] [prvIngestDataBlock] Remaining: 7
1049 16767 [OTA Task] [prvIngestDataBlock] Received file block 305, size 1024
1050 16768 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 312320l address
1051 16768 [OTA Task] [prvIngestDataBlock] Remaining: 6
1052 16778 [app_ota_task] State: Active  Received: 305   Queued: 305   Processed: 305   Dropped: 0
1053 16809 [OTA Task] [prvIngestDataBlock] Received file block 306, size 1024
1054 16810 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 313344l address
1055 16810 [OTA Task] [prvIngestDataBlock] Remaining: 5
1056 16851 [OTA Task] [prvIngestDataBlock] Received file block 307, size 1024
1057 16852 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 314368l address
1058 16852 [OTA Task] [prvIngestDataBlock] Remaining: 4
1059 16899 [OTA Task] [prvIngestDataBlock] Received file block 308, size 1024
1060 16900 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 315392l address
1061 16900 [OTA Task] [prvIngestDataBlock] Remaining: 3
1062 16941 [OTA Task] [prvIngestDataBlock] Received file block 300, size 1024
1063 16942 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 307200l address
1064 16942 [OTA Task] [prvIngestDataBlock] Remaining: 2
1065 16978 [app_ota_task] State: Active  Received: 309   Queued: 309   Processed: 309   Dropped: 0
1066 16991 [OTA Task] [prvIngestDataBlock] Received file block 286, size 1024
1067 16993 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 292864l address
1068 16993 [OTA Task] [prvIngestDataBlock] Remaining: 1
1069 17024 [OTA Task] [prvIngestDataBlock] Received file block 309, size 708
1070 17025 [OTA Task] [prvPAL_WriteBlock] Write 708l bytes from the 316416l address
1071 17025 [OTA Task] [prvIngestDataBlock] Received final expected block of file.
1072 17025 [OTA Task] [prvStopRequestTimer] Stopping file request timer.
1073 17025 [OTA Task] [prvPAL_CloseFile] Erasing the flash memory was successful
1074 17050 [OTA Task] [prvPAL_CheckFileSignature] Signature check passed
1075 17051 [OTA Task] [prvIngestDataBlock] File receive complete and signature is valid.
1076 17051 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"self_test":"ready","updatedBy":"0x90002"}}
1077 17051 [OTA Task] [INFO ][MQTT][170510] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
1078 17051 [OTA Task] [INFO ][MQTT][170510] (MQTT connection 20025e38, PUBLISH operation 2002e468) Waiting for operation completion.
1079 17072 [OTA Task] [INFO ][MQTT][170720] (MQTT connection 20025e38, PUBLISH operation 2002e468) Wait complete with result SUCCESS.
1080 17072 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-ota_fourm_log/update
1081 17072 [OTA Task] [prvOTA_Close] Context->0x20035220
1082 17072 [OTA Task] [INFO ][MQTT][170720] (MQTT connection 20025e38) UNSUBSCRIBE operation scheduled.
1083 17072 [OTA Task] [INFO ][MQTT][170720] (MQTT connection 20025e38, UNSUBSCRIBE operation 2002e468) Waiting for operation completion.
The RAM must start at 20004738, it's size must be 3b8c8
0 0 [iot_thread] [INFO ][INIT][0] SDK successfully initialized.
1 3 [iot_thread] [INFO ][DEMO][30] No networks connected for the demo. Waiting for a network connection.
DeviceID: AEBC4471
2 22 [BLE] Requesting to update ATT MTU to 247 bytes on connection 0x0.Generated topic string: cmd/pc2/prod/aebc4471/hsjob
3 22 [BLE] sd_ble_gattc_exchange_mtu_request() on connection 0x0 returned busy, will retry.4 22 [BLE] [INFO ][DEMO][220] BLE Connected to remote device, connId = 0
5 22 [iot_thread] [INFO ][DEMO][220] Successfully initialized application. Network type for the application: 2
6 22 [iot_thread] [INFO ][MQTT][220] MQTT library successfully initialized.
7 22 [iot_thread] [INFO ][DEMO][220] MQTT app client identifier is NRF52840DK (length 10).
8 170 [BLE] UNKNOWN BLE EVENT 35
9 1052 [iot_thread] [INFO ][MQTT][10520] Establishing new MQTT connection.
10 1052 [iot_thread] [INFO ][MQTT][10520] (MQTT connection 20025e38, CONNECT operation 20025f40) Waiting for operation completion.
11 1061 [iot_thread] [INFO ][MQTT][10610] (MQTT connection 20025e38, CONNECT operation 20025f40) Wait complete with result SUCCESS.
12 1061 [iot_thread] [INFO ][MQTT][10610] New MQTT connection 20008d9c established.
13 1062 [iot_thread] [INFO ][MQTT][10620] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
14 1062 [iot_thread] [INFO ][MQTT][10620] (MQTT connection 20025e38, SUBSCRIBE operation 20026048) Waiting for operation completion.
15 1132 [iot_thread] [INFO ][MQTT][11320] (MQTT connection 20025e38, SUBSCRIBE operation 20026048) Wait complete with result SUCCESS.
16 1132 [OTA Task] [INFO ][MQTT][11320] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
17 1132 [OTA Task] [INFO ][MQTT][11320] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Waiting for operation completion.
18 1189 [OTA Task] [INFO ][MQTT][11890] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Wait complete with result SUCCESS.
19 1189 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/$next/get/accepted
20 1189 [OTA Task] [INFO ][MQTT][11890] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
21 1189 [OTA Task] [INFO ][MQTT][11890] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Waiting for operation completion.
22 1252 [OTA Task] [INFO ][MQTT][12520] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Wait complete with result SUCCESS.
23 1252 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/notify-next
24 1252 [OTA Task] [OTA_CheckForUpdate] Request #0
25 1252 [OTA Task] [INFO ][MQTT][12520] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
26 1252 [OTA Task] [INFO ][MQTT][12520] (MQTT connection 20025e38, PUBLISH operation 2002e360) Waiting for operation completion.
27 1270 [OTA Task] [INFO ][MQTT][12700] (MQTT connection 20025e38, PUBLISH operation 2002e360) Wait complete with result SUCCESS.
28 1271 [iot_thread] [OTA_AgentInit] Ready.
29 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
30 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ jobId: AFR_OTA-ota_fourm_log ]
31 1300 [OTA Task] [prvParseJSONbyModel] Identified parameter [ self_test ]
32 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ updatedBy: 589826 ]
33 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ streamname: AFR_OTA-91504af4-69ad-4aff-a837-221f30af5b35 ]
34 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filepath: / ]
35 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filesize: 317124 ]
36 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ fileid: 0 ]
37 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ certfile: / ]
38 1300 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ sig-sha256-ecdsa: MEYCIQCXMU5XA1tycaAu8UXkrd31Rfj+... ]
39 1300 [OTA Task] [prvParseJobDoc] In self test mode.
40 1300 [OTA Task] [prvParseJobDoc] Failing job. We rebooted and the version is still the same.
41 1300 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"FAILED","statusDetails":{"reason":"rejected: 0x23000000"}}
DeviceID: AEBC4471
2 349 [BLE] Requesting to update ATT MTU to 247 bytes on connection 0x0.Generated topic string: cmd/pc2/prod/aebc4471/hsjob
3 349 [BLE] sd_ble_gattc_exchange_mtu_request() on connection 0x0 returned busy, will retry.4 349 [BLE] [INFO ][DEMO][3490] BLE Connected to remote device, connId = 0
5 349 [iot_thread] [INFO ][DEMO][3490] Successfully initialized application. Network type for the application: 2
6 349 [iot_thread] [INFO ][MQTT][3490] MQTT library successfully initialized.
7 349 [iot_thread] [INFO ][DEMO][3490] MQTT app client identifier is NRF52840DK (length 10).
8 473 [BLE] UNKNOWN BLE EVENT 35
9 1379 [iot_thread] [INFO ][MQTT][13790] Establishing new MQTT connection.
10 1379 [iot_thread] [INFO ][MQTT][13790] (MQTT connection 20025e38, CONNECT operation 20025f40) Waiting for operation completion.
11 1389 [iot_thread] [INFO ][MQTT][13890] (MQTT connection 20025e38, CONNECT operation 20025f40) Wait complete with result SUCCESS.
12 1389 [iot_thread] [INFO ][MQTT][13890] New MQTT connection 20008d9c established.
13 1389 [iot_thread] [INFO ][MQTT][13890] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
14 1389 [iot_thread] [INFO ][MQTT][13890] (MQTT connection 20025e38, SUBSCRIBE operation 20026048) Waiting for operation completion.
15 1451 [iot_thread] [INFO ][MQTT][14510] (MQTT connection 20025e38, SUBSCRIBE operation 20026048) Wait complete with result SUCCESS.
16 1451 [OTA Task] [INFO ][MQTT][14510] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
17 1451 [OTA Task] [INFO ][MQTT][14510] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Waiting for operation completion.
18 1514 [OTA Task] [INFO ][MQTT][15140] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Wait complete with result SUCCESS.
19 1514 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/$next/get/accepted
20 1514 [OTA Task] [INFO ][MQTT][15140] (MQTT connection 20025e38) SUBSCRIBE operation scheduled.
21 1514 [OTA Task] [INFO ][MQTT][15140] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Waiting for operation completion.
22 1574 [OTA Task] [INFO ][MQTT][15740] (MQTT connection 20025e38, SUBSCRIBE operation 20025cf0) Wait complete with result SUCCESS.
23 1574 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/notify-next
24 1574 [OTA Task] [OTA_CheckForUpdate] Request #0
25 1574 [OTA Task] [INFO ][MQTT][15740] (MQTT connection 20025e38) MQTT PUBLISH operation queued.
26 1574 [OTA Task] [INFO ][MQTT][15740] (MQTT connection 20025e38, PUBLISH operation 2002e360) Waiting for operation completion.
27 1589 [OTA Task] [INFO ][MQTT][15890] (MQTT connection 20025e38, PUBLISH operation 2002e360) Wait complete with result SUCCESS.
28 1590 [iot_thread] [OTA_AgentInit] Ready.
29 1601 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
30 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: execution
31 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: jobId
32 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: jobDocument
33 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: afr_ota
34 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: streamname
35 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: files
36 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: filepath
37 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: filesize
38 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: fileid
39 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: certfile
40 1601 [OTA Task] [prvParseJSONbyModel] parameter not present: sig-sha256-ecdsa
41 1601 [OTA Task] [prvParseJobDoc] Ignoring job without ID.
42 1601 [OTA Task] [prvOTA_Close] Context->0x20035220
43 1711 [app_ota_task] State: Ready  Received: 1   Queued: 1   Processed: 1   Dropped: 0
Edited by: ljaynes on Jul 3, 2019 9:01 AM
SarenaAtAws wrote on July 03, 2019:
Are you running the OTA Update demo? Because I don’t see any feedback in your logs about the current firmware version:
 [iot_thread] OTA demo version 2.1.0
ljaynes wrote on July 05, 2019:
You are correct. That was my modified project. Here is the log from the unmodified OTA demo which does the same thing.
The RAM must start at 200046f8, it's size must be 3b908
1 2 [iot_thread] [INFO ][DEMO][20] No networks connected for the demo. Waiting for a network connection.
2 5289 [BLE] Requesting to update ATT MTU to 247 bytes on connection 0x0.3 5289 [BLE] sd_ble_gattc_exchange_mtu_request() on connection 0x0 returned busy, will retry.4 5289 [BLE] [INFO ][DEMO][52890] BLE Connected to remote device, connId = 0
5 5289 [iot_thread] [INFO ][DEMO][52890] Successfully initialized the demo. Network type for the demo: 2
6 5289 [iot_thread] [INFO ][MQTT][52890] MQTT library successfully initialized.
7 5289 [iot_thread] OTA demo version 1.0.2
8 5289 [iot_thread] Creating MQTT Client...
9 5409 [BLE] UNKNOWN BLE EVENT 35
10 5414 [iot_thread] Connecting to broker...
11 5414 [iot_thread] [INFO ][MQTT][54140] Establishing new MQTT connection.
12 5414 [iot_thread] [INFO ][MQTT][54140] (MQTT connection 20017678, CONNECT operation 200179b8) Waiting for operation completion.
13 5540 [iot_thread] [INFO ][MQTT][55400] (MQTT connection 20017678, CONNECT operation 200179b8) Wait complete with result SUCCESS.
14 5540 [iot_thread] [INFO ][MQTT][55400] New MQTT connection 20004760 established.
15 5540 [iot_thread] Connected to broker.
16 5540 [OTA Task] [INFO ][MQTT][55400] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
17 5541 [OTA Task] [INFO ][MQTT][55410] (MQTT connection 20017678, SUBSCRIBE operation 2001fbd0) Waiting for operation completion.
18 5604 [OTA Task] [INFO ][MQTT][56040] (MQTT connection 20017678, SUBSCRIBE operation 2001fbd0) Wait complete with result SUCCESS.
19 5604 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/$next/get/accepted
20 5604 [OTA Task] [INFO ][MQTT][56040] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
21 5604 [OTA Task] [INFO ][MQTT][56040] (MQTT connection 20017678, SUBSCRIBE operation 20017ac0) Waiting for operation completion.
22 5667 [OTA Task] [INFO ][MQTT][56670] (MQTT connection 20017678, SUBSCRIBE operation 20017ac0) Wait complete with result SUCCESS.
23 5667 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/notify-next
24 5667 [OTA Task] [OTA_CheckForUpdate] Request #0
25 5667 [OTA Task] [INFO ][MQTT][56670] (MQTT connection 20017678) MQTT PUBLISH operation queued.
26 5667 [OTA Task] [INFO ][MQTT][56670] (MQTT connection 20017678, PUBLISH operation 2001fd20) Waiting for operation completion.
27 5691 [OTA Task] [INFO ][MQTT][56910] (MQTT connection 20017678, PUBLISH operation 2001fd20) Wait complete with result SUCCESS.
28 5692 [iot_thread] [OTA_AgentInit] Ready.
29 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
30 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ jobId: AFR_OTA-testee ]
31 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ streamname: AFR_OTA-52458a23-ba09-49e4-ae6a-17b97e896bab ]
32 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filepath: / ]
33 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filesize: 262352 ]
34 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ fileid: 0 ]
35 5740 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ certfile: / ]
36 5741 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ sig-sha256-ecdsa: MEYCIQCmdMH88RiQ9VKMYI5+L7XI8e1s... ]
37 5741 [OTA Task] [prvParseJobDoc] Job was accepted. Attempting to start transfer.
38 5741 [OTA Task] [INFO ][MQTT][57410] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
39 5741 [OTA Task] [INFO ][MQTT][57410] (MQTT connection 20017678, SUBSCRIBE operation 20020458) Waiting for operation completion.
40 5792 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
41 5803 [OTA Task] [INFO ][MQTT][58030] (MQTT connection 20017678, SUBSCRIBE operation 20020458) Wait complete with result SUCCESS.
42 5803 [OTA Task] [prvSubscribeToDataStream] OK: $aws/things/NRF52840DK/streams/AFR_OTA-52458a23-ba09-49e4-ae6a-17b97e896bab/data/cbor
43 5803 [OTA Task] [prvPAL_CreateFileForRx] Erasing the flash memory
44 5892 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
45 5997 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
46 6097 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
47 6197 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
48 6297 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
49 6399 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
50 6499 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
51 6599 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
52 6699 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
53 6801 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
54 6909 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
55 7016 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
56 7116 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
57 7216 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
58 7316 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
59 7416 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
60 7520 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
61 7628 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
62 7736 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 0   Dropped: 0
63 7754 [OTA Task] [INFO ][MQTT][77540] (MQTT connection 20017678) MQTT PUBLISH operation queued.
64 7754 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/NRF52840DK/streams/AFR_OTA-52458a23-ba09-49e4-ae6a-17b97e896bab/get/cbor
65 7836 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 1   Dropped: 0
66 7847 [OTA Task] [prvIngestDataBlock] Received file block 1, size 1024
67 7848 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 1024l address
68 7848 [OTA Task] [prvIngestDataBlock] Remaining: 256
69 7904 [OTA Task] [prvIngestDataBlock] Received file block 2, size 1024
70 7905 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 2048l address
71 7905 [OTA Task] [prvIngestDataBlock] Remaining: 255
72 7936 [iot_thread] State: Active  Received: 3   Queued: 3   Processed: 3   Dropped: 0
73 7946 [OTA Task] [prvIngestDataBlock] Received file block 0, size 1024
74 7947 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 0l address
75 7947 [OTA Task] [prvIngestDataBlock] Remaining: 254
76 7988 [OTA Task] [prvIngestDataBlock] Received file block 3, size 1024
77 7989 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 3072l address
78 7989 [OTA Task] [prvIngestDataBlock] Remaining: 253
79 8030 [OTA Task] [prvIngestDataBlock] Received file block 4, size 1024
80 8031 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 4096l address
81 8031 [OTA Task] [prvIngestDataBlock] Remaining: 252
82 8036 [iot_thread] State: Active  Received: 6   Queued: 6   Processed: 6   Dropped: 0
83 8072 [OTA Task] [prvIngestDataBlock] Received file block 5, size 1024
84 8073 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 5120l address
85 8073 [OTA Task] [prvIngestDataBlock] Remaining: 251
86 8123 [OTA Task] [prvIngestDataBlock] Received file block 6, size 1024
87 8124 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 6144l address
88 8124 [OTA Task] [prvIngestDataBlock] Remaining: 250
89 8136 [iot_thread] State: Active  Received: 8   Queued: 8   Processed: 8   Dropped: 0
90 8170 [OTA Task] [prvIngestDataBlock] Received file block 7, size 1024
91 8172 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 7168l address
92 8172 [OTA Task] [prvIngestDataBlock] Remaining: 249
93 8213 [OTA Task] [prvIngestDataBlock] Received file block 8, size 1024
94 8214 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 8192l address
95 8214 [OTA Task] [prvIngestDataBlock] Remaining: 248
96 8236 [iot_thread] State: Active  Received: 10   Queued: 10   Processed: 10   Dropped: 0
97 8258 [OTA Task] [prvIngestDataBlock] Received file block 10, size 1024
98 8259 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 10240l address
99 8259 [OTA Task] [prvIngestDataBlock] Remaining: 247
100 8300 [OTA Task] [prvIngestDataBlock] Received file block 9, size 1024
101 8301 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 9216l address
102 8301 [OTA Task] [prvIngestDataBlock] Remaining: 246
103 8336 [iot_thread] State: Active  Received: 12   Queued: 12   Processed: 12   Dropped: 0
104 8344 [OTA Task] [prvIngestDataBlock] Received file block 11, size 1024
105 8345 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 11264l address
106 8345 [OTA Task] [prvIngestDataBlock] Remaining: 245
107 8387 [OTA Task] [prvIngestDataBlock] Received file block 12, size 1024
108 8388 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 12288l address
109 8388 [OTA Task] [prvIngestDataBlock] Remaining: 244
110 8428 [OTA Task] [prvIngestDataBlock] Received file block 13, size 1024
111 8430 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 13312l address
112 8430 [OTA Task] [prvIngestDataBlock] Remaining: 243
113 8436 [iot_thread] State: Active  Received: 15   Queued: 15   Processed: 15   Dropped: 0
114 8470 [OTA Task] [prvIngestDataBlock] Received file block 15, size 1024
115 8472 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 15360l address
116 8472 [OTA Task] [prvIngestDataBlock] Remaining: 242
117 8515 [OTA Task] [prvIngestDataBlock] Received file block 14, size 1024
118 8516 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 14336l address
119 8516 [OTA Task] [prvIngestDataBlock] Remaining: 241
120 8536 [iot_thread] State: Active  Received: 17   Queued: 17   Processed: 17   Dropped: 0
121 8572 [OTA Task] [prvIngestDataBlock] Received file block 16, size 1024
122 8573 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 16384l address
123 8573 [OTA Task] [prvIngestDataBlock] Remaining: 240
124 8629 [OTA Task] [prvIngestDataBlock] Received file block 17, size 1024
125 8630 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 17408l address
126 8630 [OTA Task] [prvIngestDataBlock] Remaining: 239
127 8636 [iot_thread] State: Active  Received: 19   Queued: 19   Processed: 19   Dropped: 0
128 8686 [OTA Task] [prvIngestDataBlock] Received file block 18, size 1024
129 8687 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 18432l address
130 8687 [OTA Task] [prvIngestDataBlock] Remaining: 238
131 8731 [OTA Task] [prvIngestDataBlock] Received file block 19, size 1024
132 8732 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 19456l address
133 8732 [OTA Task] [prvIngestDataBlock] Remaining: 237
134 8736 [iot_thread] State: Active  Received: 21   Queued: 21   Processed: 21   Dropped: 0
135 8773 [OTA Task] [prvIngestDataBlock] Received file block 20, size 1024
136 8774 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 20480l address
137 8774 [OTA Task] [prvIngestDataBlock] Remaining: 236
138 8827 [OTA Task] [prvIngestDataBlock] Received file block 21, size 1024
139 8828 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 21504l address
140 8828 [OTA Task] [prvIngestDataBlock] Remaining: 235
141 8836 [iot_thread] State: Active  Received: 23   Queued: 23   Processed: 23   Dropped: 0
142 8884 [OTA Task] [prvIngestDataBlock] Received file block 22, size 1024
143 8885 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 22528l address
144 8885 [OTA Task] [prvIngestDataBlock] Remaining: 234
145 8926 [OTA Task] [prvIngestDataBlock] Received file block 23, size 1024
146 8927 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 23552l address
147 8927 [OTA Task] [prvIngestDataBlock] Remaining: 233
148 8936 [iot_thread] State: Active  Received: 25   Queued: 25   Processed: 25   Dropped: 0
149 8968 [OTA Task] [prvIngestDataBlock] Received file block 24, size 1024
150 8969 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 24576l address
151 8969 [OTA Task] [prvIngestDataBlock] Remaining: 232
152 9010 [OTA Task] [prvIngestDataBlock] Received file block 25, size 1024
153 9011 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 25600l address
154 9011 [OTA Task] [prvIngestDataBlock] Remaining: 231
155 9036 [iot_thread] State: Active  Received: 27   Queued: 27   Processed: 27   Dropped: 0
156 9052 [OTA Task] [prvIngestDataBlock] Received file block 26, size 1024
157 9053 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 26624l address
158 9053 [OTA Task] [prvIngestDataBlock] Remaining: 230
159 9094 [OTA Task] [prvIngestDataBlock] Received file block 27, size 1024
160 9095 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 27648l address
161 9095 [OTA Task] [prvIngestDataBlock] Remaining: 229
162 9136 [iot_thread] State: Active  Received: 29   Queued: 29   Processed: 29   Dropped: 0
163 9142 [OTA Task] [prvIngestDataBlock] Received file block 28, size 1024
164 9143 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 28672l address
165 9143 [OTA Task] [prvIngestDataBlock] Remaining: 228
166 9184 [OTA Task] [prvIngestDataBlock] Received file block 30, size 1024
167 9185 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 30720l address
168 9185 [OTA Task] [prvIngestDataBlock] Remaining: 227
169 9226 [OTA Task] [prvIngestDataBlock] Received file block 29, size 1024
170 9227 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 29696l address
171 9227 [OTA Task] [prvIngestDataBlock] Remaining: 226
172 9236 [iot_thread] State: Active  Received: 32   Queued: 32   Processed: 32   Dropped: 0
173 9268 [OTA Task] [prvIngestDataBlock] Received file block 31, size 1024
174 9269 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 31744l address
175 9269 [OTA Task] [prvIngestDataBlock] Remaining: 225
176 9310 [OTA Task] [prvIngestDataBlock] Received file block 32, size 1024
177 9311 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 32768l address
178 9311 [OTA Task] [prvIngestDataBlock] Remaining: 224
179 9336 [iot_thread] State: Active  Received: 34   Queued: 34   Processed: 34   Dropped: 0
180 9363 [OTA Task] [prvIngestDataBlock] Received file block 34, size 1024
181 9364 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 34816l address
182 9364 [OTA Task] [prvIngestDataBlock] Remaining: 223
183 9412 [OTA Task] [prvIngestDataBlock] Received file block 35, size 1024
184 9413 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 35840l address
185 9413 [OTA Task] [prvIngestDataBlock] Remaining: 222
186 9436 [iot_thread] State: Active  Received: 36   Queued: 36   Processed: 36   Dropped: 0
187 9453 [OTA Task] [prvIngestDataBlock] Received file block 37, size 1024
188 9455 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 37888l address
189 9455 [OTA Task] [prvIngestDataBlock] Remaining: 221
190 9495 [OTA Task] [prvIngestDataBlock] Received file block 38, size 1024
191 9497 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 38912l address
192 9497 [OTA Task] [prvIngestDataBlock] Remaining: 220
193 9536 [iot_thread] State: Active  Received: 38   Queued: 38   Processed: 38   Dropped: 0
194 9537 [OTA Task] [prvIngestDataBlock] Received file block 36, size 1024
195 9538 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 36864l address
196 9539 [OTA Task] [prvIngestDataBlock] Remaining: 219
197 9579 [OTA Task] [prvIngestDataBlock] Received file block 39, size 1024
198 9580 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 39936l address
199 9580 [OTA Task] [prvIngestDataBlock] Remaining: 218
200 9621 [OTA Task] [prvIngestDataBlock] Received file block 41, size 1024
201 9622 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 41984l address
202 9622 [OTA Task] [prvIngestDataBlock] Remaining: 217
203 9636 [iot_thread] State: Active  Received: 41   Queued: 41   Processed: 41   Dropped: 0
204 9663 [OTA Task] [prvIngestDataBlock] Received file block 40, size 1024
205 9664 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 40960l address
206 9664 [OTA Task] [prvIngestDataBlock] Remaining: 216
207 9705 [OTA Task] [prvIngestDataBlock] Received file block 43, size 1024
208 9706 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 44032l address
209 9706 [OTA Task] [prvIngestDataBlock] Remaining: 215
210 9736 [iot_thread] State: Active  Received: 43   Queued: 43   Processed: 43   Dropped: 0
211 9747 [OTA Task] [prvIngestDataBlock] Received file block 42, size 1024
212 9748 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 43008l address
213 9748 [OTA Task] [prvIngestDataBlock] Remaining: 214
214 9789 [OTA Task] [prvIngestDataBlock] Received file block 44, size 1024
215 9790 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 45056l address
216 9790 [OTA Task] [prvIngestDataBlock] Remaining: 213
217 9831 [OTA Task] [prvIngestDataBlock] Received file block 45, size 1024
218 9832 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 46080l address
219 9832 [OTA Task] [prvIngestDataBlock] Remaining: 212
220 9836 [iot_thread] State: Active  Received: 46   Queued: 46   Processed: 46   Dropped: 0
221 9873 [OTA Task] [prvIngestDataBlock] Received file block 46, size 1024
222 9874 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 47104l address
223 9874 [OTA Task] [prvIngestDataBlock] Remaining: 211
224 9915 [OTA Task] [prvIngestDataBlock] Received file block 47, size 1024
225 9916 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 48128l address
226 9916 [OTA Task] [prvIngestDataBlock] Remaining: 210
227 9936 [iot_thread] State: Active  Received: 48   Queued: 48   Processed: 48   Dropped: 0
228 9966 [OTA Task] [prvIngestDataBlock] Received file block 49, size 1024
229 9967 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 50176l address
230 9967 [OTA Task] [prvIngestDataBlock] Remaining: 209
231 10008 [OTA Task] [prvIngestDataBlock] Received file block 50, size 1024
232 10009 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 51200l address
233 10009 [OTA Task] [prvIngestDataBlock] Remaining: 208
234 10036 [iot_thread] State: Active  Received: 50   Queued: 50   Processed: 50   Dropped: 0
235 10050 [OTA Task] [prvIngestDataBlock] Received file block 52, size 1024
236 10051 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 53248l address
237 10051 [OTA Task] [prvIngestDataBlock] Remaining: 207
238 10092 [OTA Task] [prvIngestDataBlock] Received file block 53, size 1024
239 10093 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 54272l address
240 10093 [OTA Task] [prvIngestDataBlock] Remaining: 206
241 10134 [OTA Task] [prvIngestDataBlock] Received file block 54, size 1024
242 10135 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 55296l address
243 10135 [OTA Task] [prvIngestDataBlock] Remaining: 205
244 10136 [iot_thread] State: Active  Received: 53   Queued: 53   Processed: 53   Dropped: 0
245 10176 [OTA Task] [prvIngestDataBlock] Received file block 55, size 1024
246 10177 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 56320l address
247 10177 [OTA Task] [prvIngestDataBlock] Remaining: 204
248 10218 [OTA Task] [prvIngestDataBlock] Received file block 51, size 1024
249 10219 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 52224l address
250 10219 [OTA Task] [prvIngestDataBlock] Remaining: 203
251 10236 [iot_thread] State: Active  Received: 55   Queued: 55   Processed: 55   Dropped: 0
252 10260 [OTA Task] [prvIngestDataBlock] Received file block 57, size 1024
253 10261 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 58368l address
254 10261 [OTA Task] [prvIngestDataBlock] Remaining: 202
255 10302 [OTA Task] [prvIngestDataBlock] Received file block 58, size 1024
256 10303 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 59392l address
257 10303 [OTA Task] [prvIngestDataBlock] Remaining: 201
258 10336 [iot_thread] State: Active  Received: 57   Queued: 57   Processed: 57   Dropped: 0
259 10344 [OTA Task] [prvIngestDataBlock] Received file block 59, size 1024
260 10345 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 60416l address
261 10345 [OTA Task] [prvIngestDataBlock] Remaining: 200
262 10386 [OTA Task] [prvIngestDataBlock] Received file block 60, size 1024
263 10387 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 61440l address
264 10387 [OTA Task] [prvIngestDataBlock] Remaining: 199
265 10428 [OTA Task] [prvIngestDataBlock] Received file block 61, size 1024
266 10429 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 62464l address
267 10429 [OTA Task] [prvIngestDataBlock] Remaining: 198
268 10436 [iot_thread] State: Active  Received: 60   Queued: 60   Processed: 60   Dropped: 0
269 10472 [OTA Task] [prvIngestDataBlock] Received file block 62, size 1024
270 10473 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 63488l address
271 10473 [OTA Task] [prvIngestDataBlock] Remaining: 197
272 10514 [OTA Task] [prvIngestDataBlock] Received file block 63, size 1024
273 10516 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 64512l address
274 10516 [OTA Task] [prvIngestDataBlock] Remaining: 196
275 10536 [iot_thread] State: Active  Received: 62   Queued: 62   Processed: 62   Dropped: 0
276 10556 [OTA Task] [prvIngestDataBlock] Received file block 64, size 1024
277 10557 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 65536l address
278 10557 [OTA Task] [prvIngestDataBlock] Remaining: 195
279 10598 [OTA Task] [prvIngestDataBlock] Received file block 66, size 1024
280 10599 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 67584l address
281 10599 [OTA Task] [prvIngestDataBlock] Remaining: 194
282 10636 [iot_thread] State: Active  Received: 64   Queued: 64   Processed: 64   Dropped: 0
283 10640 [OTA Task] [prvIngestDataBlock] Received file block 67, size 1024
284 10641 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 68608l address
285 10641 [OTA Task] [prvIngestDataBlock] Remaining: 193
286 10641 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"64/257"}}
287 10642 [OTA Task] [INFO ][MQTT][106410] (MQTT connection 20017678) MQTT PUBLISH operation queued.
288 10642 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-testee/update
289 10694 [OTA Task] [prvIngestDataBlock] Received file block 65, size 1024
290 10695 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 66560l address
291 10695 [OTA Task] [prvIngestDataBlock] Remaining: 192
292 10736 [iot_thread] State: Active  Received: 66   Queued: 66   Processed: 66   Dropped: 0
293 10751 [OTA Task] [prvIngestDataBlock] Received file block 69, size 1024
294 10752 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 70656l address
295 10752 [OTA Task] [prvIngestDataBlock] Remaining: 191
296 10808 [OTA Task] [prvIngestDataBlock] Received file block 68, size 1024
297 10809 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 69632l address
298 10809 [OTA Task] [prvIngestDataBlock] Remaining: 190
299 10836 [iot_thread] State: Active  Received: 68   Queued: 68   Processed: 68   Dropped: 0
300 10865 [OTA Task] [prvIngestDataBlock] Received file block 70, size 1024
301 10866 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 71680l address
302 10866 [OTA Task] [prvIngestDataBlock] Remaining: 189
303 10936 [iot_thread] State: Active  Received: 69   Queued: 69   Processed: 69   Dropped: 0
304 10976 [OTA Task] [prvIngestDataBlock] Received file block 72, size 1024
305 10977 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 73728l address
306 10977 [OTA Task] [prvIngestDataBlock] Remaining: 188
307 11018 [OTA Task] [prvIngestDataBlock] Received file block 73, size 1024
308 11019 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 74752l address
309 11019 [OTA Task] [prvIngestDataBlock] Remaining: 187
310 11036 [iot_thread] State: Active  Received: 71   Queued: 71   Processed: 71   Dropped: 0
311 11060 [OTA Task] [prvIngestDataBlock] Received file block 74, size 1024
312 11061 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 75776l address
313 11061 [OTA Task] [prvIngestDataBlock] Remaining: 186
314 11102 [OTA Task] [prvIngestDataBlock] Received file block 75, size 1024
315 11103 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 76800l address
316 11103 [OTA Task] [prvIngestDataBlock] Remaining: 185
317 11136 [iot_thread] State: Active  Received: 73   Queued: 73   Processed: 73   Dropped: 0
318 11144 [OTA Task] [prvIngestDataBlock] Received file block 76, size 1024
319 11145 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 77824l address
320 11145 [OTA Task] [prvIngestDataBlock] Remaining: 184
321 11186 [OTA Task] [prvIngestDataBlock] Received file block 77, size 1024
322 11187 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 78848l address
323 11187 [OTA Task] [prvIngestDataBlock] Remaining: 183
324 11228 [OTA Task] [prvIngestDataBlock] Received file block 78, size 1024
325 11229 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 79872l address
326 11229 [OTA Task] [prvIngestDataBlock] Remaining: 182
327 11236 [iot_thread] State: Active  Received: 76   Queued: 76   Processed: 76   Dropped: 0
328 11270 [OTA Task] [prvIngestDataBlock] Received file block 80, size 1024
329 11271 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 81920l address
330 11271 [OTA Task] [prvIngestDataBlock] Remaining: 181
331 11312 [OTA Task] [prvIngestDataBlock] Received file block 81, size 1024
332 11313 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 82944l address
333 11313 [OTA Task] [prvIngestDataBlock] Remaining: 180
334 11336 [iot_thread] State: Active  Received: 78   Queued: 78   Processed: 78   Dropped: 0
335 11354 [OTA Task] [prvIngestDataBlock] Received file block 79, size 1024
336 11355 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 80896l address
337 11355 [OTA Task] [prvIngestDataBlock] Remaining: 179
338 11396 [OTA Task] [prvIngestDataBlock] Received file block 84, size 1024
339 11397 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 86016l address
340 11397 [OTA Task] [prvIngestDataBlock] Remaining: 178
341 11436 [iot_thread] State: Active  Received: 80   Queued: 80   Processed: 80   Dropped: 0
342 11443 [OTA Task] [prvIngestDataBlock] Received file block 83, size 1024
343 11444 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 84992l address
344 11444 [OTA Task] [prvIngestDataBlock] Remaining: 177
345 11485 [OTA Task] [prvIngestDataBlock] Received file block 48, size 1024
346 11487 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 49152l address
347 11487 [OTA Task] [prvIngestDataBlock] Remaining: 176
348 11527 [OTA Task] [prvIngestDataBlock] Received file block 85, size 1024
349 11529 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 87040l address
350 11529 [OTA Task] [prvIngestDataBlock] Remaining: 175
351 11536 [iot_thread] State: Active  Received: 83   Queued: 83   Processed: 83   Dropped: 0
352 11569 [OTA Task] [prvIngestDataBlock] Received file block 86, size 1024
353 11570 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 88064l address
354 11570 [OTA Task] [prvIngestDataBlock] Remaining: 174
355 11623 [OTA Task] [prvIngestDataBlock] Received file block 87, size 1024
356 11624 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 89088l address
357 11624 [OTA Task] [prvIngestDataBlock] Remaining: 173
358 11636 [iot_thread] State: Active  Received: 85   Queued: 85   Processed: 85   Dropped: 0
359 11677 [OTA Task] [prvIngestDataBlock] Received file block 88, size 1024
360 11678 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 90112l address
361 11678 [OTA Task] [prvIngestDataBlock] Remaining: 172
362 11736 [iot_thread] State: Active  Received: 86   Queued: 86   Processed: 86   Dropped: 0
363 11836 [iot_thread] State: Active  Received: 86   Queued: 86   Processed: 86   Dropped: 0
364 11863 [OTA Task] [prvIngestDataBlock] Received file block 89, size 1024
365 11864 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 91136l address
366 11864 [OTA Task] [prvIngestDataBlock] Remaining: 171
367 11926 [OTA Task] [prvIngestDataBlock] Received file block 94, size 1024
368 11927 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 96256l address
369 11927 [OTA Task] [prvIngestDataBlock] Remaining: 170
370 11936 [iot_thread] State: Active  Received: 88   Queued: 88   Processed: 88   Dropped: 0
371 11983 [OTA Task] [prvIngestDataBlock] Received file block 95, size 1024
372 11984 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 97280l address
373 11984 [OTA Task] [prvIngestDataBlock] Remaining: 169
374 12036 [iot_thread] State: Active  Received: 89   Queued: 89   Processed: 89   Dropped: 0
375 12040 [OTA Task] [prvIngestDataBlock] Received file block 92, size 1024
376 12041 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 94208l address
377 12041 [OTA Task] [prvIngestDataBlock] Remaining: 168
378 12106 [OTA Task] [prvIngestDataBlock] Received file block 96, size 1024
379 12107 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 98304l address
380 12107 [OTA Task] [prvIngestDataBlock] Remaining: 167
381 12136 [iot_thread] State: Active  Received: 91   Queued: 91   Processed: 91   Dropped: 0
382 12162 [OTA Task] [prvIngestDataBlock] Received file block 97, size 1024
383 12164 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 99328l address
384 12164 [OTA Task] [prvIngestDataBlock] Remaining: 166
385 12219 [OTA Task] [prvIngestDataBlock] Received file block 99, size 1024
386 12221 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 101376l address
387 12221 [OTA Task] [prvIngestDataBlock] Remaining: 165
388 12236 [iot_thread] State: Active  Received: 93   Queued: 93   Processed: 93   Dropped: 0
389 12276 [OTA Task] [prvIngestDataBlock] Received file block 82, size 1024
390 12277 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 83968l address
391 12277 [OTA Task] [prvIngestDataBlock] Remaining: 164
392 12325 [OTA Task] [prvIngestDataBlock] Received file block 100, size 1024
393 12326 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 102400l address
394 12326 [OTA Task] [prvIngestDataBlock] Remaining: 163
395 12336 [iot_thread] State: Active  Received: 95   Queued: 95   Processed: 95   Dropped: 0
396 12372 [OTA Task] [prvIngestDataBlock] Received file block 101, size 1024
397 12373 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 103424l address
398 12373 [OTA Task] [prvIngestDataBlock] Remaining: 162
399 12429 [OTA Task] [prvIngestDataBlock] Received file block 56, size 1024
400 12430 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 57344l address
401 12430 [OTA Task] [prvIngestDataBlock] Remaining: 161
402 12436 [iot_thread] State: Active  Received: 97   Queued: 97   Processed: 97   Dropped: 0
403 12477 [OTA Task] [prvIngestDataBlock] Received file block 93, size 1024
404 12479 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 95232l address
405 12479 [OTA Task] [prvIngestDataBlock] Remaining: 160
406 12519 [OTA Task] [prvIngestDataBlock] Received file block 102, size 1024
407 12521 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 104448l address
408 12521 [OTA Task] [prvIngestDataBlock] Remaining: 159
409 12536 [iot_thread] State: Active  Received: 99   Queued: 99   Processed: 99   Dropped: 0
410 12570 [OTA Task] [prvIngestDataBlock] Received file block 104, size 1024
411 12571 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 106496l address
412 12571 [OTA Task] [prvIngestDataBlock] Remaining: 158
413 12624 [OTA Task] [prvIngestDataBlock] Received file block 105, size 1024
414 12625 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 107520l address
415 12625 [OTA Task] [prvIngestDataBlock] Remaining: 157
416 12636 [iot_thread] State: Active  Received: 101   Queued: 101   Processed: 101   Dropped: 0
417 12666 [OTA Task] [prvIngestDataBlock] Received file block 106, size 1024
418 12667 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 108544l address
419 12667 [OTA Task] [prvIngestDataBlock] Remaining: 156
420 12711 [OTA Task] [prvIngestDataBlock] Received file block 109, size 1024
421 12712 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 111616l address
422 12712 [OTA Task] [prvIngestDataBlock] Remaining: 155
423 12736 [iot_thread] State: Active  Received: 103   Queued: 103   Processed: 103   Dropped: 0
424 12807 [OTA Task] [prvIngestDataBlock] Received file block 110, size 1024
425 12808 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 112640l address
426 12808 [OTA Task] [prvIngestDataBlock] Remaining: 154
427 12836 [iot_thread] State: Active  Received: 104   Queued: 104   Processed: 104   Dropped: 0
428 12849 [OTA Task] [prvIngestDataBlock] Received file block 98, size 1024
429 12850 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 100352l address
430 12850 [OTA Task] [prvIngestDataBlock] Remaining: 153
431 12912 [OTA Task] [prvIngestDataBlock] Received file block 112, size 1024
432 12913 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 114688l address
433 12913 [OTA Task] [prvIngestDataBlock] Remaining: 152
434 12936 [iot_thread] State: Active  Received: 106   Queued: 106   Processed: 106   Dropped: 0
435 12963 [OTA Task] [prvIngestDataBlock] Received file block 111, size 1024
436 12964 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 113664l address
437 12964 [OTA Task] [prvIngestDataBlock] Remaining: 151
438 13026 [OTA Task] [prvIngestDataBlock] Received file block 113, size 1024
439 13027 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 115712l address
440 13027 [OTA Task] [prvIngestDataBlock] Remaining: 150
441 13036 [iot_thread] State: Active  Received: 108   Queued: 108   Processed: 108   Dropped: 0
442 13113 [OTA Task] [prvIngestDataBlock] Received file block 116, size 1024
443 13114 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 118784l address
444 13114 [OTA Task] [prvIngestDataBlock] Remaining: 149
445 13136 [iot_thread] State: Active  Received: 109   Queued: 109   Processed: 109   Dropped: 0
446 13172 [OTA Task] [prvIngestDataBlock] Received file block 117, size 1024
447 13174 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 119808l address
448 13174 [OTA Task] [prvIngestDataBlock] Remaining: 148
449 13229 [OTA Task] [prvIngestDataBlock] Received file block 118, size 1024
450 13231 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 120832l address
451 13231 [OTA Task] [prvIngestDataBlock] Remaining: 147
452 13236 [iot_thread] State: Active  Received: 111   Queued: 111   Processed: 111   Dropped: 0
453 13278 [OTA Task] [prvIngestDataBlock] Received file block 107, size 1024
454 13279 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 109568l address
455 13279 [OTA Task] [prvIngestDataBlock] Remaining: 146
456 13322 [OTA Task] [prvIngestDataBlock] Received file block 120, size 1024
457 13323 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 122880l address
458 13323 [OTA Task] [prvIngestDataBlock] Remaining: 145
459 13336 [iot_thread] State: Active  Received: 113   Queued: 113   Processed: 113   Dropped: 0
460 13368 [OTA Task] [prvIngestDataBlock] Received file block 121, size 1024
461 13369 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 123904l address
462 13369 [OTA Task] [prvIngestDataBlock] Remaining: 144
463 13410 [OTA Task] [prvIngestDataBlock] Received file block 122, size 1024
464 13411 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 124928l address
465 13411 [OTA Task] [prvIngestDataBlock] Remaining: 143
466 13436 [iot_thread] State: Active  Received: 115   Queued: 115   Processed: 115   Dropped: 0
467 13451 [OTA Task] [prvIngestDataBlock] Received file block 123, size 1024
468 13453 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 125952l address
469 13453 [OTA Task] [prvIngestDataBlock] Remaining: 142
470 13493 [OTA Task] [prvIngestDataBlock] Received file block 124, size 1024
471 13495 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 126976l address
472 13495 [OTA Task] [prvIngestDataBlock] Remaining: 141
473 13536 [iot_thread] State: Active  Received: 117   Queued: 117   Processed: 117   Dropped: 0
474 13559 [OTA Task] [prvIngestDataBlock] Received file block 108, size 1024
475 13560 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 110592l address
476 13560 [OTA Task] [prvIngestDataBlock] Remaining: 140
477 13636 [iot_thread] State: Active  Received: 118   Queued: 118   Processed: 118   Dropped: 0
478 13643 [OTA Task] [prvIngestDataBlock] Received file block 126, size 1024
479 13644 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 129024l address
480 13644 [OTA Task] [prvIngestDataBlock] Remaining: 139
481 13685 [OTA Task] [prvIngestDataBlock] Received file block 33, size 1024
482 13686 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 33792l address
483 13686 [OTA Task] [prvIngestDataBlock] Remaining: 138
484 13736 [iot_thread] State: Active  Received: 120   Queued: 120   Processed: 120   Dropped: 0
485 13736 [OTA Task] [prvIngestDataBlock] Received file block 127, size 1024
486 13737 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 130048l address
487 13737 [OTA Task] [prvIngestDataBlock] Remaining: 137
488 13790 [OTA Task] [prvIngestDataBlock] Received file block 119, size 1024
489 13791 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 121856l address
490 13791 [OTA Task] [prvIngestDataBlock] Remaining: 136
491 13836 [iot_thread] State: Active  Received: 122   Queued: 122   Processed: 122   Dropped: 0
492 13880 [OTA Task] [prvIngestDataBlock] Received file block 91, size 1024
493 13881 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 93184l address
494 13881 [OTA Task] [prvIngestDataBlock] Remaining: 135
495 13936 [iot_thread] State: Active  Received: 123   Queued: 123   Processed: 123   Dropped: 0
496 13937 [OTA Task] [prvIngestDataBlock] Received file block 114, size 1024
497 13938 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 116736l address
498 13938 [OTA Task] [prvIngestDataBlock] Remaining: 134
499 13994 [OTA Task] [prvIngestDataBlock] Received file block 71, size 1024
500 13995 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 72704l address
501 13995 [OTA Task] [prvIngestDataBlock] Remaining: 133
502 14036 [iot_thread] State: Active  Received: 125   Queued: 125   Processed: 125   Dropped: 0
503 14051 [OTA Task] [prvIngestDataBlock] Received file block 115, size 1024
504 14052 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 117760l address
505 14052 [OTA Task] [prvIngestDataBlock] Remaining: 132
506 14108 [OTA Task] [prvIngestDataBlock] Received file block 90, size 1024
507 14109 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 92160l address
508 14109 [OTA Task] [prvIngestDataBlock] Remaining: 131
509 14136 [iot_thread] State: Active  Received: 127   Queued: 127   Processed: 127   Dropped: 0
510 14164 [OTA Task] [prvIngestDataBlock] Received file block 103, size 1024
511 14166 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 105472l address
512 14166 [OTA Task] [prvIngestDataBlock] Remaining: 130
513 14221 [OTA Task] [prvIngestDataBlock] Received file block 125, size 1024
514 14223 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 128000l address
515 14223 [OTA Task] [prvIngestDataBlock] Remaining: 129
516 14223 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"128/257"}}
517 14223 [OTA Task] [INFO ][MQTT][142230] (MQTT connection 20017678) MQTT PUBLISH operation queued.
518 14223 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-testee/update
519 14236 [iot_thread] State: Active  Received: 129   Queued: 129   Processed: 129   Dropped: 0
520 14336 [iot_thread] State: Active  Received: 129   Queued: 129   Processed: 129   Dropped: 0
521 14436 [iot_thread] State: Active  Received: 129   Queued: 129   Processed: 129   Dropped: 0
522 14471 [OTA Task] [INFO ][MQTT][144710] (MQTT connection 20017678) MQTT PUBLISH operation queued.
523 14471 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/NRF52840DK/streams/AFR_OTA-52458a23-ba09-49e4-ae6a-17b97e896bab/get/cbor
524 14536 [iot_thread] State: Active  Received: 129   Queued: 129   Processed: 129   Dropped: 0
525 14560 [OTA Task] [prvIngestDataBlock] Received file block 130, size 1024
526 14561 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 133120l address
527 14561 [OTA Task] [prvIngestDataBlock] Remaining: 128
528 14608 [OTA Task] [prvIngestDataBlock] Received file block 129, size 1024
529 14609 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 132096l address
530 14609 [OTA Task] [prvIngestDataBlock] Remaining: 127
531 14636 [iot_thread] State: Active  Received: 131   Queued: 131   Processed: 131   Dropped: 0
532 14650 [OTA Task] [prvIngestDataBlock] Received file block 128, size 1024
533 14651 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 131072l address
534 14651 [OTA Task] [prvIngestDataBlock] Remaining: 126
535 14701 [OTA Task] [prvIngestDataBlock] Received file block 131, size 1024
536 14702 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 134144l address
537 14702 [OTA Task] [prvIngestDataBlock] Remaining: 125
538 14736 [iot_thread] State: Active  Received: 133   Queued: 133   Processed: 133   Dropped: 0
539 14746 [OTA Task] [prvIngestDataBlock] Received file block 132, size 1024
540 14747 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 135168l address
541 14747 [OTA Task] [prvIngestDataBlock] Remaining: 124
542 14788 [OTA Task] [prvIngestDataBlock] Received file block 133, size 1024
543 14789 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 136192l address
544 14789 [OTA Task] [prvIngestDataBlock] Remaining: 123
545 14830 [OTA Task] [prvIngestDataBlock] Received file block 134, size 1024
546 14831 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 137216l address
547 14831 [OTA Task] [prvIngestDataBlock] Remaining: 122
548 14836 [iot_thread] State: Active  Received: 136   Queued: 136   Processed: 136   Dropped: 0
549 14872 [OTA Task] [prvIngestDataBlock] Received file block 135, size 1024
550 14873 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 138240l address
551 14873 [OTA Task] [prvIngestDataBlock] Remaining: 121
552 14914 [OTA Task] [prvIngestDataBlock] Received file block 136, size 1024
553 14915 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 139264l address
554 14915 [OTA Task] [prvIngestDataBlock] Remaining: 120
555 14936 [iot_thread] State: Active  Received: 138   Queued: 138   Processed: 138   Dropped: 0
556 14956 [OTA Task] [prvIngestDataBlock] Received file block 137, size 1024
557 14957 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 140288l address
558 14957 [OTA Task] [prvIngestDataBlock] Remaining: 119
559 14998 [OTA Task] [prvIngestDataBlock] Received file block 138, size 1024
560 14999 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 141312l address
561 14999 [OTA Task] [prvIngestDataBlock] Remaining: 118
562 15036 [iot_thread] State: Active  Received: 140   Queued: 140   Processed: 140   Dropped: 0
563 15040 [OTA Task] [prvIngestDataBlock] Received file block 139, size 1024
564 15041 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 142336l address
565 15041 [OTA Task] [prvIngestDataBlock] Remaining: 117
566 15082 [OTA Task] [prvIngestDataBlock] Received file block 140, size 1024
567 15083 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 143360l address
568 15083 [OTA Task] [prvIngestDataBlock] Remaining: 116
569 15124 [OTA Task] [prvIngestDataBlock] Received file block 141, size 1024
570 15125 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 144384l address
571 15125 [OTA Task] [prvIngestDataBlock] Remaining: 115
572 15136 [iot_thread] State: Active  Received: 143   Queued: 143   Processed: 143   Dropped: 0
573 15166 [OTA Task] [prvIngestDataBlock] Received file block 142, size 1024
574 15167 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 145408l address
575 15167 [OTA Task] [prvIngestDataBlock] Remaining: 114
576 15208 [OTA Task] [prvIngestDataBlock] Received file block 143, size 1024
577 15209 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 146432l address
578 15209 [OTA Task] [prvIngestDataBlock] Remaining: 113
579 15236 [iot_thread] State: Active  Received: 145   Queued: 145   Processed: 145   Dropped: 0
580 15250 [OTA Task] [prvIngestDataBlock] Received file block 144, size 1024
581 15251 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 147456l address
582 15251 [OTA Task] [prvIngestDataBlock] Remaining: 112
583 15292 [OTA Task] [prvIngestDataBlock] Received file block 145, size 1024
584 15293 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 148480l address
585 15293 [OTA Task] [prvIngestDataBlock] Remaining: 111
586 15334 [OTA Task] [prvIngestDataBlock] Received file block 147, size 1024
587 15335 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 150528l address
588 15335 [OTA Task] [prvIngestDataBlock] Remaining: 110
589 15336 [iot_thread] State: Active  Received: 148   Queued: 148   Processed: 148   Dropped: 0
590 15376 [OTA Task] [prvIngestDataBlock] Received file block 148, size 1024
591 15377 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 151552l address
592 15377 [OTA Task] [prvIngestDataBlock] Remaining: 109
593 15418 [OTA Task] [prvIngestDataBlock] Received file block 149, size 1024
594 15419 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 152576l address
595 15419 [OTA Task] [prvIngestDataBlock] Remaining: 108
596 15436 [iot_thread] State: Active  Received: 150   Queued: 150   Processed: 150   Dropped: 0
597 15459 [OTA Task] [prvIngestDataBlock] Received file block 150, size 1024
598 15461 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 153600l address
599 15461 [OTA Task] [prvIngestDataBlock] Remaining: 107
600 15501 [OTA Task] [prvIngestDataBlock] Received file block 151, size 1024
601 15503 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 154624l address
602 15503 [OTA Task] [prvIngestDataBlock] Remaining: 106
603 15536 [iot_thread] State: Active  Received: 152   Queued: 152   Processed: 152   Dropped: 0
604 15543 [OTA Task] [prvIngestDataBlock] Received file block 152, size 1024
605 15545 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 155648l address
606 15545 [OTA Task] [prvIngestDataBlock] Remaining: 105
607 15585 [OTA Task] [prvIngestDataBlock] Received file block 153, size 1024
608 15586 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 156672l address
609 15586 [OTA Task] [prvIngestDataBlock] Remaining: 104
610 15627 [OTA Task] [prvIngestDataBlock] Received file block 154, size 1024
611 15628 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 157696l address
612 15628 [OTA Task] [prvIngestDataBlock] Remaining: 103
613 15636 [iot_thread] State: Active  Received: 155   Queued: 155   Processed: 155   Dropped: 0
614 15669 [OTA Task] [prvIngestDataBlock] Received file block 155, size 1024
615 15670 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 158720l address
616 15670 [OTA Task] [prvIngestDataBlock] Remaining: 102
617 15711 [OTA Task] [prvIngestDataBlock] Received file block 157, size 1024
618 15712 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 160768l address
619 15712 [OTA Task] [prvIngestDataBlock] Remaining: 101
620 15736 [iot_thread] State: Active  Received: 157   Queued: 157   Processed: 157   Dropped: 0
621 15759 [OTA Task] [prvIngestDataBlock] Received file block 156, size 1024
622 15760 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 159744l address
623 15760 [OTA Task] [prvIngestDataBlock] Remaining: 100
624 15801 [OTA Task] [prvIngestDataBlock] Received file block 158, size 1024
625 15802 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 161792l address
626 15802 [OTA Task] [prvIngestDataBlock] Remaining: 99
627 15836 [iot_thread] State: Active  Received: 159   Queued: 159   Processed: 159   Dropped: 0
628 15849 [OTA Task] [prvIngestDataBlock] Received file block 161, size 1024
629 15850 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 164864l address
630 15850 [OTA Task] [prvIngestDataBlock] Remaining: 98
631 15894 [OTA Task] [prvIngestDataBlock] Received file block 162, size 1024
632 15895 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 165888l address
633 15895 [OTA Task] [prvIngestDataBlock] Remaining: 97
634 15936 [iot_thread] State: Active  Received: 161   Queued: 161   Processed: 161   Dropped: 0
635 15945 [OTA Task] [prvIngestDataBlock] Received file block 164, size 1024
636 15946 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 167936l address
637 15946 [OTA Task] [prvIngestDataBlock] Remaining: 96
638 15987 [OTA Task] [prvIngestDataBlock] Received file block 165, size 1024
639 15988 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 168960l address
640 15988 [OTA Task] [prvIngestDataBlock] Remaining: 95
641 16029 [OTA Task] [prvIngestDataBlock] Received file block 166, size 1024
642 16030 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 169984l address
643 16030 [OTA Task] [prvIngestDataBlock] Remaining: 94
644 16036 [iot_thread] State: Active  Received: 164   Queued: 164   Processed: 164   Dropped: 0
645 16074 [OTA Task] [prvIngestDataBlock] Received file block 167, size 1024
646 16075 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 171008l address
647 16075 [OTA Task] [prvIngestDataBlock] Remaining: 93
648 16131 [OTA Task] [prvIngestDataBlock] Received file block 168, size 1024
649 16132 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 172032l address
650 16132 [OTA Task] [prvIngestDataBlock] Remaining: 92
651 16136 [iot_thread] State: Active  Received: 166   Queued: 166   Processed: 166   Dropped: 0
652 16173 [OTA Task] [prvIngestDataBlock] Received file block 170, size 1024
653 16174 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 174080l address
654 16174 [OTA Task] [prvIngestDataBlock] Remaining: 91
655 16215 [OTA Task] [prvIngestDataBlock] Received file block 171, size 1024
656 16216 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 175104l address
657 16216 [OTA Task] [prvIngestDataBlock] Remaining: 90
658 16236 [iot_thread] State: Active  Received: 168   Queued: 168   Processed: 168   Dropped: 0
659 16257 [OTA Task] [prvIngestDataBlock] Received file block 172, size 1024
660 16258 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 176128l address
661 16258 [OTA Task] [prvIngestDataBlock] Remaining: 89
662 16299 [OTA Task] [prvIngestDataBlock] Received file block 173, size 1024
663 16300 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 177152l address
664 16300 [OTA Task] [prvIngestDataBlock] Remaining: 88
665 16336 [iot_thread] State: Active  Received: 170   Queued: 170   Processed: 170   Dropped: 0
666 16349 [OTA Task] [prvIngestDataBlock] Received file block 174, size 1024
667 16350 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 178176l address
668 16350 [OTA Task] [prvIngestDataBlock] Remaining: 87
669 16398 [OTA Task] [prvIngestDataBlock] Received file block 175, size 1024
670 16399 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 179200l address
671 16399 [OTA Task] [prvIngestDataBlock] Remaining: 86
672 16436 [iot_thread] State: Active  Received: 172   Queued: 172   Processed: 172   Dropped: 0
673 16442 [OTA Task] [prvIngestDataBlock] Received file block 176, size 1024
674 16443 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 180224l address
675 16443 [OTA Task] [prvIngestDataBlock] Remaining: 85
676 16499 [OTA Task] [prvIngestDataBlock] Received file block 179, size 1024
677 16500 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 183296l address
678 16500 [OTA Task] [prvIngestDataBlock] Remaining: 84
679 16536 [iot_thread] State: Active  Received: 174   Queued: 174   Processed: 174   Dropped: 0
680 16544 [OTA Task] [prvIngestDataBlock] Received file block 180, size 1024
681 16546 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 184320l address
682 16546 [OTA Task] [prvIngestDataBlock] Remaining: 83
683 16592 [OTA Task] [prvIngestDataBlock] Received file block 181, size 1024
684 16593 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 185344l address
685 16593 [OTA Task] [prvIngestDataBlock] Remaining: 82
686 16634 [OTA Task] [prvIngestDataBlock] Received file block 182, size 1024
687 16635 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 186368l address
688 16635 [OTA Task] [prvIngestDataBlock] Remaining: 81
689 16636 [iot_thread] State: Active  Received: 177   Queued: 177   Processed: 177   Dropped: 0
690 16676 [OTA Task] [prvIngestDataBlock] Received file block 183, size 1024
691 16677 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 187392l address
692 16677 [OTA Task] [prvIngestDataBlock] Remaining: 80
693 16727 [OTA Task] [prvIngestDataBlock] Received file block 185, size 1024
694 16728 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 189440l address
695 16728 [OTA Task] [prvIngestDataBlock] Remaining: 79
696 16736 [iot_thread] State: Active  Received: 179   Queued: 179   Processed: 179   Dropped: 0
697 16836 [iot_thread] State: Active  Received: 179   Queued: 179   Processed: 179   Dropped: 0
698 16850 [OTA Task] [prvIngestDataBlock] Received file block 187, size 1024
699 16851 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 191488l address
700 16851 [OTA Task] [prvIngestDataBlock] Remaining: 78
701 16907 [OTA Task] [prvIngestDataBlock] Received file block 188, size 1024
702 16908 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 192512l address
703 16908 [OTA Task] [prvIngestDataBlock] Remaining: 77
704 16936 [iot_thread] State: Active  Received: 181   Queued: 181   Processed: 181   Dropped: 0
705 16952 [OTA Task] [prvIngestDataBlock] Received file block 190, size 1024
706 16953 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 194560l address
707 16953 [OTA Task] [prvIngestDataBlock] Remaining: 76
708 16997 [OTA Task] [prvIngestDataBlock] Received file block 191, size 1024
709 16998 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 195584l address
710 16998 [OTA Task] [prvIngestDataBlock] Remaining: 75
711 17036 [iot_thread] State: Active  Received: 183   Queued: 183   Processed: 183   Dropped: 0
712 17039 [OTA Task] [prvIngestDataBlock] Received file block 192, size 1024
713 17040 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 196608l address
714 17040 [OTA Task] [prvIngestDataBlock] Remaining: 74
715 17081 [OTA Task] [prvIngestDataBlock] Received file block 146, size 1024
716 17082 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 149504l address
717 17082 [OTA Task] [prvIngestDataBlock] Remaining: 73
718 17123 [OTA Task] [prvIngestDataBlock] Received file block 193, size 1024
719 17124 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 197632l address
720 17124 [OTA Task] [prvIngestDataBlock] Remaining: 72
721 17136 [iot_thread] State: Active  Received: 186   Queued: 186   Processed: 186   Dropped: 0
722 17165 [OTA Task] [prvIngestDataBlock] Received file block 194, size 1024
723 17166 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 198656l address
724 17166 [OTA Task] [prvIngestDataBlock] Remaining: 71
725 17207 [OTA Task] [prvIngestDataBlock] Received file block 196, size 1024
726 17208 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 200704l address
727 17208 [OTA Task] [prvIngestDataBlock] Remaining: 70
728 17236 [iot_thread] State: Active  Received: 188   Queued: 188   Processed: 188   Dropped: 0
729 17249 [OTA Task] [prvIngestDataBlock] Received file block 195, size 1024
730 17250 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 199680l address
731 17250 [OTA Task] [prvIngestDataBlock] Remaining: 69
732 17291 [OTA Task] [prvIngestDataBlock] Received file block 197, size 1024
733 17292 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 201728l address
734 17292 [OTA Task] [prvIngestDataBlock] Remaining: 68
735 17336 [iot_thread] State: Active  Received: 190   Queued: 190   Processed: 190   Dropped: 0
736 17341 [OTA Task] [prvIngestDataBlock] Received file block 178, size 1024
737 17342 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 182272l address
738 17342 [OTA Task] [prvIngestDataBlock] Remaining: 67
739 17384 [OTA Task] [prvIngestDataBlock] Received file block 198, size 1024
740 17385 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 202752l address
741 17385 [OTA Task] [prvIngestDataBlock] Remaining: 66
742 17432 [OTA Task] [prvIngestDataBlock] Received file block 200, size 1024
743 17433 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 204800l address
744 17433 [OTA Task] [prvIngestDataBlock] Remaining: 65
745 17433 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"192/257"}}
746 17433 [OTA Task] [INFO ][MQTT][174330] (MQTT connection 20017678) MQTT PUBLISH operation queued.
747 17433 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-testee/update
748 17436 [iot_thread] State: Active  Received: 193   Queued: 193   Processed: 193   Dropped: 0
749 17479 [OTA Task] [prvIngestDataBlock] Received file block 202, size 1024
750 17481 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 206848l address
751 17481 [OTA Task] [prvIngestDataBlock] Remaining: 64
752 17521 [OTA Task] [prvIngestDataBlock] Received file block 203, size 1024
753 17523 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 207872l address
754 17523 [OTA Task] [prvIngestDataBlock] Remaining: 63
755 17536 [iot_thread] State: Active  Received: 195   Queued: 195   Processed: 195   Dropped: 0
756 17566 [OTA Task] [prvIngestDataBlock] Received file block 204, size 1024
757 17567 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 208896l address
758 17567 [OTA Task] [prvIngestDataBlock] Remaining: 62
759 17614 [OTA Task] [prvIngestDataBlock] Received file block 205, size 1024
760 17615 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 209920l address
761 17615 [OTA Task] [prvIngestDataBlock] Remaining: 61
762 17636 [iot_thread] State: Active  Received: 197   Queued: 197   Processed: 197   Dropped: 0
763 17662 [OTA Task] [prvIngestDataBlock] Received file block 206, size 1024
764 17663 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 210944l address
765 17663 [OTA Task] [prvIngestDataBlock] Remaining: 60
766 17704 [OTA Task] [prvIngestDataBlock] Received file block 209, size 1024
767 17705 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 214016l address
768 17705 [OTA Task] [prvIngestDataBlock] Remaining: 59
769 17736 [iot_thread] State: Active  Received: 199   Queued: 199   Processed: 199   Dropped: 0
770 17752 [OTA Task] [prvIngestDataBlock] Received file block 207, size 1024
771 17753 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 211968l address
772 17753 [OTA Task] [prvIngestDataBlock] Remaining: 58
773 17803 [OTA Task] [prvIngestDataBlock] Received file block 208, size 1024
774 17804 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 212992l address
775 17804 [OTA Task] [prvIngestDataBlock] Remaining: 57
776 17836 [iot_thread] State: Active  Received: 201   Queued: 201   Processed: 201   Dropped: 0
777 17845 [OTA Task] [prvIngestDataBlock] Received file block 210, size 1024
778 17846 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 215040l address
779 17846 [OTA Task] [prvIngestDataBlock] Remaining: 56
780 17896 [OTA Task] [prvIngestDataBlock] Received file block 211, size 1024
781 17897 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 216064l address
782 17897 [OTA Task] [prvIngestDataBlock] Remaining: 55
783 17936 [iot_thread] State: Active  Received: 203   Queued: 203   Processed: 203   Dropped: 0
784 18036 [iot_thread] State: Active  Received: 203   Queued: 203   Processed: 203   Dropped: 0
785 18112 [OTA Task] [prvIngestDataBlock] Received file block 212, size 1024
786 18113 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 217088l address
787 18113 [OTA Task] [prvIngestDataBlock] Remaining: 54
788 18136 [iot_thread] State: Active  Received: 204   Queued: 204   Processed: 204   Dropped: 0
789 18154 [OTA Task] [prvIngestDataBlock] Received file block 213, size 1024
790 18155 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 218112l address
791 18155 [OTA Task] [prvIngestDataBlock] Remaining: 53
792 18201 [OTA Task] [prvIngestDataBlock] Received file block 215, size 1024
793 18203 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 220160l address
794 18203 [OTA Task] [prvIngestDataBlock] Remaining: 52
795 18236 [iot_thread] State: Active  Received: 206   Queued: 206   Processed: 206   Dropped: 0
796 18253 [OTA Task] [prvIngestDataBlock] Received file block 214, size 1024
797 18254 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 219136l address
798 18254 [OTA Task] [prvIngestDataBlock] Remaining: 51
799 18295 [OTA Task] [prvIngestDataBlock] Received file block 216, size 1024
800 18296 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 221184l address
801 18296 [OTA Task] [prvIngestDataBlock] Remaining: 50
802 18336 [iot_thread] State: Active  Received: 208   Queued: 208   Processed: 208   Dropped: 0
803 18337 [OTA Task] [prvIngestDataBlock] Received file block 217, size 1024
804 18338 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 222208l address
805 18338 [OTA Task] [prvIngestDataBlock] Remaining: 49
806 18384 [OTA Task] [prvIngestDataBlock] Received file block 220, size 1024
807 18385 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 225280l address
808 18385 [OTA Task] [prvIngestDataBlock] Remaining: 48
809 18430 [OTA Task] [prvIngestDataBlock] Received file block 221, size 1024
810 18431 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 226304l address
811 18431 [OTA Task] [prvIngestDataBlock] Remaining: 47
812 18436 [iot_thread] State: Active  Received: 211   Queued: 211   Processed: 211   Dropped: 0
813 18471 [OTA Task] [prvIngestDataBlock] Received file block 160, size 1024
814 18473 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 163840l address
815 18473 [OTA Task] [prvIngestDataBlock] Remaining: 46
816 18513 [OTA Task] [prvIngestDataBlock] Received file block 223, size 1024
817 18515 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 228352l address
818 18515 [OTA Task] [prvIngestDataBlock] Remaining: 45
819 18536 [iot_thread] State: Active  Received: 213   Queued: 213   Processed: 213   Dropped: 0
820 18555 [OTA Task] [prvIngestDataBlock] Received file block 222, size 1024
821 18557 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 227328l address
822 18557 [OTA Task] [prvIngestDataBlock] Remaining: 44
823 18597 [OTA Task] [prvIngestDataBlock] Received file block 224, size 1024
824 18598 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 229376l address
825 18598 [OTA Task] [prvIngestDataBlock] Remaining: 43
826 18636 [iot_thread] State: Active  Received: 215   Queued: 215   Processed: 215   Dropped: 0
827 18639 [OTA Task] [prvIngestDataBlock] Received file block 226, size 1024
828 18640 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 231424l address
829 18640 [OTA Task] [prvIngestDataBlock] Remaining: 42
830 18681 [OTA Task] [prvIngestDataBlock] Received file block 227, size 1024
831 18682 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 232448l address
832 18682 [OTA Task] [prvIngestDataBlock] Remaining: 41
833 18729 [OTA Task] [prvIngestDataBlock] Received file block 228, size 1024
834 18730 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 233472l address
835 18730 [OTA Task] [prvIngestDataBlock] Remaining: 40
836 18736 [iot_thread] State: Active  Received: 218   Queued: 218   Processed: 218   Dropped: 0
837 18771 [OTA Task] [prvIngestDataBlock] Received file block 229, size 1024
838 18772 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 234496l address
839 18772 [OTA Task] [prvIngestDataBlock] Remaining: 39
840 18813 [OTA Task] [prvIngestDataBlock] Received file block 230, size 1024
841 18814 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 235520l address
842 18814 [OTA Task] [prvIngestDataBlock] Remaining: 38
843 18836 [iot_thread] State: Active  Received: 220   Queued: 220   Processed: 220   Dropped: 0
844 18855 [OTA Task] [prvIngestDataBlock] Received file block 231, size 1024
845 18856 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 236544l address
846 18856 [OTA Task] [prvIngestDataBlock] Remaining: 37
847 18906 [OTA Task] [prvIngestDataBlock] Received file block 169, size 1024
848 18907 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 173056l address
849 18907 [OTA Task] [prvIngestDataBlock] Remaining: 36
850 18936 [iot_thread] State: Active  Received: 222   Queued: 222   Processed: 222   Dropped: 0
851 18948 [OTA Task] [prvIngestDataBlock] Received file block 232, size 1024
852 18949 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 237568l address
853 18949 [OTA Task] [prvIngestDataBlock] Remaining: 35
854 18996 [OTA Task] [prvIngestDataBlock] Received file block 233, size 1024
855 18997 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 238592l address
856 18997 [OTA Task] [prvIngestDataBlock] Remaining: 34
857 19036 [iot_thread] State: Active  Received: 224   Queued: 224   Processed: 224   Dropped: 0
858 19038 [OTA Task] [prvIngestDataBlock] Received file block 234, size 1024
859 19039 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 239616l address
860 19039 [OTA Task] [prvIngestDataBlock] Remaining: 33
861 19083 [OTA Task] [prvIngestDataBlock] Received file block 235, size 1024
862 19084 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 240640l address
863 19084 [OTA Task] [prvIngestDataBlock] Remaining: 32
864 19125 [OTA Task] [prvIngestDataBlock] Received file block 238, size 1024
865 19126 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 243712l address
866 19126 [OTA Task] [prvIngestDataBlock] Remaining: 31
867 19136 [iot_thread] State: Active  Received: 227   Queued: 227   Processed: 227   Dropped: 0
868 19167 [OTA Task] [prvIngestDataBlock] Received file block 237, size 1024
869 19168 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 242688l address
870 19168 [OTA Task] [prvIngestDataBlock] Remaining: 30
871 19209 [OTA Task] [prvIngestDataBlock] Received file block 239, size 1024
872 19210 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 244736l address
873 19210 [OTA Task] [prvIngestDataBlock] Remaining: 29
874 19236 [iot_thread] State: Active  Received: 229   Queued: 229   Processed: 229   Dropped: 0
875 19251 [OTA Task] [prvIngestDataBlock] Received file block 240, size 1024
876 19252 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 245760l address
877 19252 [OTA Task] [prvIngestDataBlock] Remaining: 28
878 19293 [OTA Task] [prvIngestDataBlock] Received file block 186, size 1024
879 19294 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 190464l address
880 19294 [OTA Task] [prvIngestDataBlock] Remaining: 27
881 19335 [OTA Task] [prvIngestDataBlock] Received file block 242, size 1024
882 19336 [iot_thread] State: Active  Received: 232   Queued: 232   Processed: 231   Dropped: 0
883 19336 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 247808l address
884 19336 [OTA Task] [prvIngestDataBlock] Remaining: 26
885 19386 [OTA Task] [prvIngestDataBlock] Received file block 243, size 1024
886 19387 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 248832l address
887 19387 [OTA Task] [prvIngestDataBlock] Remaining: 25
888 19428 [OTA Task] [prvIngestDataBlock] Received file block 236, size 1024
889 19429 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 241664l address
890 19429 [OTA Task] [prvIngestDataBlock] Remaining: 24
891 19436 [iot_thread] State: Active  Received: 234   Queued: 234   Processed: 234   Dropped: 0
892 19469 [OTA Task] [prvIngestDataBlock] Received file block 201, size 1024
893 19471 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 205824l address
894 19471 [OTA Task] [prvIngestDataBlock] Remaining: 23
895 19511 [OTA Task] [prvIngestDataBlock] Received file block 244, size 1024
896 19513 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 249856l address
897 19513 [OTA Task] [prvIngestDataBlock] Remaining: 22
898 19536 [iot_thread] State: Active  Received: 236   Queued: 236   Processed: 236   Dropped: 0
899 19553 [OTA Task] [prvIngestDataBlock] Received file block 246, size 1024
900 19555 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 251904l address
901 19555 [OTA Task] [prvIngestDataBlock] Remaining: 21
902 19595 [OTA Task] [prvIngestDataBlock] Received file block 248, size 1024
903 19596 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 253952l address
904 19596 [OTA Task] [prvIngestDataBlock] Remaining: 20
905 19636 [iot_thread] State: Active  Received: 238   Queued: 238   Processed: 238   Dropped: 0
906 19637 [OTA Task] [prvIngestDataBlock] Received file block 184, size 1024
907 19638 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 188416l address
908 19638 [OTA Task] [prvIngestDataBlock] Remaining: 19
909 19679 [OTA Task] [prvIngestDataBlock] Received file block 249, size 1024
910 19680 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 254976l address
911 19680 [OTA Task] [prvIngestDataBlock] Remaining: 18
912 19727 [OTA Task] [prvIngestDataBlock] Received file block 252, size 1024
913 19728 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 258048l address
914 19728 [OTA Task] [prvIngestDataBlock] Remaining: 17
915 19736 [iot_thread] State: Active  Received: 241   Queued: 241   Processed: 241   Dropped: 0
916 19769 [OTA Task] [prvIngestDataBlock] Received file block 251, size 1024
917 19770 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 257024l address
918 19770 [OTA Task] [prvIngestDataBlock] Remaining: 16
919 19817 [OTA Task] [prvIngestDataBlock] Received file block 253, size 1024
920 19818 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 259072l address
921 19818 [OTA Task] [prvIngestDataBlock] Remaining: 15
922 19836 [iot_thread] State: Active  Received: 243   Queued: 243   Processed: 243   Dropped: 0
923 19859 [OTA Task] [prvIngestDataBlock] Received file block 254, size 1024
924 19860 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 260096l address
925 19860 [OTA Task] [prvIngestDataBlock] Remaining: 14
926 19901 [OTA Task] [prvIngestDataBlock] Received file block 255, size 1024
927 19902 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 261120l address
928 19902 [OTA Task] [prvIngestDataBlock] Remaining: 13
929 19936 [iot_thread] State: Active  Received: 245   Queued: 245   Processed: 245   Dropped: 0
930 19943 [OTA Task] [prvIngestDataBlock] Received file block 159, size 1024
931 19944 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 162816l address
932 19944 [OTA Task] [prvIngestDataBlock] Remaining: 12
933 19985 [OTA Task] [prvIngestDataBlock] Received file block 241, size 1024
934 19986 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 246784l address
935 19986 [OTA Task] [prvIngestDataBlock] Remaining: 11
936 20027 [OTA Task] [prvIngestDataBlock] Received file block 189, size 1024
937 20028 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 193536l address
938 20028 [OTA Task] [prvIngestDataBlock] Remaining: 10
939 20036 [iot_thread] State: Active  Received: 248   Queued: 248   Processed: 248   Dropped: 0
940 20069 [OTA Task] [prvIngestDataBlock] Received file block 163, size 1024
941 20070 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 166912l address
942 20070 [OTA Task] [prvIngestDataBlock] Remaining: 9
943 20111 [OTA Task] [prvIngestDataBlock] Received file block 177, size 1024
944 20112 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 181248l address
945 20112 [OTA Task] [prvIngestDataBlock] Remaining: 8
946 20136 [iot_thread] State: Active  Received: 250   Queued: 250   Processed: 250   Dropped: 0
947 20153 [OTA Task] [prvIngestDataBlock] Received file block 219, size 1024
948 20154 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 224256l address
949 20154 [OTA Task] [prvIngestDataBlock] Remaining: 7
950 20195 [OTA Task] [prvIngestDataBlock] Received file block 199, size 1024
951 20196 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 203776l address
952 20196 [OTA Task] [prvIngestDataBlock] Remaining: 6
953 20236 [iot_thread] State: Active  Received: 252   Queued: 252   Processed: 252   Dropped: 0
954 20237 [OTA Task] [prvIngestDataBlock] Received file block 218, size 1024
955 20238 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 223232l address
956 20238 [OTA Task] [prvIngestDataBlock] Remaining: 5
957 20285 [OTA Task] [prvIngestDataBlock] Received file block 245, size 1024
958 20286 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 250880l address
959 20286 [OTA Task] [prvIngestDataBlock] Remaining: 4
960 20327 [OTA Task] [prvIngestDataBlock] Received file block 250, size 1024
961 20328 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 256000l address
962 20328 [OTA Task] [prvIngestDataBlock] Remaining: 3
963 20336 [iot_thread] State: Active  Received: 255   Queued: 255   Processed: 255   Dropped: 0
964 20374 [OTA Task] [prvIngestDataBlock] Received file block 247, size 1024
965 20375 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 252928l address
966 20375 [OTA Task] [prvIngestDataBlock] Remaining: 2
967 20426 [OTA Task] [prvIngestDataBlock] Received file block 225, size 1024
968 20427 [OTA Task] [prvPAL_WriteBlock] Write 1024l bytes from the 230400l address
969 20427 [OTA Task] [prvIngestDataBlock] Remaining: 1
970 20427 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"receive":"256/257"}}
971 20427 [OTA Task] [INFO ][MQTT][204270] (MQTT connection 20017678) MQTT PUBLISH operation queued.
972 20427 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-testee/update
973 20436 [iot_thread] State: Active  Received: 257   Queued: 257   Processed: 257   Dropped: 0
974 20536 [iot_thread] State: Active  Received: 257   Queued: 257   Processed: 257   Dropped: 0
975 20636 [iot_thread] State: Active  Received: 257   Queued: 257   Processed: 257   Dropped: 0
976 20675 [OTA Task] [INFO ][MQTT][206750] (MQTT connection 20017678) MQTT PUBLISH operation queued.
977 20675 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/NRF52840DK/streams/AFR_OTA-52458a23-ba09-49e4-ae6a-17b97e896bab/get/cbor
978 20710 [OTA Task] [prvIngestDataBlock] Received file block 256, size 208
979 20710 [OTA Task] [prvPAL_WriteBlock] Write 208l bytes from the 262144l address
980 20710 [OTA Task] [prvIngestDataBlock] Received final expected block of file.
981 20710 [OTA Task] [prvStopRequestTimer] Stopping file request timer.
982 20710 [OTA Task] [prvPAL_CloseFile] Erasing the flash memory was successful
983 20735 [OTA Task] [prvPAL_CheckFileSignature] Signature check passed
984 20735 [OTA Task] [prvIngestDataBlock] File receive complete and signature is valid.
985 20735 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"IN_PROGRESS","statusDetails":{"self_test":"ready","updatedBy":"0x1000002"}}
986 20735 [OTA Task] [INFO ][MQTT][207350] (MQTT connection 20017678) MQTT PUBLISH operation queued.
987 20735 [OTA Task] [INFO ][MQTT][207350] (MQTT connection 20017678, PUBLISH operation 2001fe28) Waiting for operation completion.
988 20736 [iot_thread] State: Active  Received: 258   Queued: 258   Processed: 257   Dropped: 0
989 20746 [OTA Task] [INFO ][MQTT][207460] (MQTT connection 20017678, PUBLISH operation 2001fe28) Wait complete with result SUCCESS.
990 20746 [OTA Task] [prvUpdateJobStatus] 'IN_PROGRESS' to $aws/things/NRF52840DK/jobs/AFR_OTA-testee/update
991 20746 [OTA Task] [prvOTA_Close] Context->0x200328c4
992 20746 [OTA Task] [INFO ][MQTT][207460] (MQTT connection 20017678) UNSUBSCRIBE operation scheduled.
993 20746 [OTA Task] [INFO ][MQTT][207460] (MQTT connection 20017678, UNSUBSCRIBE operation 2001ff30) Waiting for operation completion.
The RAM must start at 200046f8, it's size must be 3b908
0 0 [iot_thread] [INFO ][INIT][0] SDK successfully initialized.
1 2 [iot_thread] [INFO ][DEMO][20] No networks connected for the demo. Waiting for a network connection.
2 290 [BLE] Requesting to update ATT MTU to 247 bytes on connection 0x0.3 290 [BLE] sd_ble_gattc_exchange_mtu_request() on connection 0x0 returned busy, will retry.4 290 [BLE] [INFO ][DEMO][2900] BLE Connected to remote device, connId = 0
5 290 [iot_thread] [INFO ][DEMO][2900] Successfully initialized the demo. Network type for the demo: 2
6 290 [iot_thread] [INFO ][MQTT][2900] MQTT library successfully initialized.
7 290 [iot_thread] OTA demo version 1.0.2
8 290 [iot_thread] Creating MQTT Client...
9 410 [BLE] UNKNOWN BLE EVENT 35
10 415 [iot_thread] Connecting to broker...
11 415 [iot_thread] [INFO ][MQTT][4150] Establishing new MQTT connection.
12 415 [iot_thread] [INFO ][MQTT][4150] (MQTT connection 20017678, CONNECT operation 200179b8) Waiting for operation completion.
13 435 [iot_thread] [INFO ][MQTT][4350] (MQTT connection 20017678, CONNECT operation 200179b8) Wait complete with result SUCCESS.
14 435 [iot_thread] [INFO ][MQTT][4350] New MQTT connection 20004760 established.
15 435 [iot_thread] Connected to broker.
16 435 [OTA Task] [INFO ][MQTT][4350] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
17 435 [OTA Task] [INFO ][MQTT][4350] (MQTT connection 20017678, SUBSCRIBE operation 2001fbd0) Waiting for operation completion.
18 498 [OTA Task] [INFO ][MQTT][4980] (MQTT connection 20017678, SUBSCRIBE operation 2001fbd0) Wait complete with result SUCCESS.
19 498 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/$next/get/accepted
20 498 [OTA Task] [INFO ][MQTT][4980] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
21 498 [OTA Task] [INFO ][MQTT][4980] (MQTT connection 20017678, SUBSCRIBE operation 20017ac0) Waiting for operation completion.
22 566 [OTA Task] [INFO ][MQTT][5660] (MQTT connection 20017678, SUBSCRIBE operation 20017ac0) Wait complete with result SUCCESS.
23 566 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/notify-next
24 566 [OTA Task] [OTA_CheckForUpdate] Request #0
25 566 [OTA Task] [INFO ][MQTT][5660] (MQTT connection 20017678) MQTT PUBLISH operation queued.
26 567 [OTA Task] [INFO ][MQTT][5670] (MQTT connection 20017678, PUBLISH operation 2001fd20) Waiting for operation completion.
27 581 [OTA Task] [INFO ][MQTT][5810] (MQTT connection 20017678, PUBLISH operation 2001fd20) Wait complete with result SUCCESS.
28 582 [iot_thread] [OTA_AgentInit] Ready.
29 625 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
30 625 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ jobId: AFR_OTA-testee ]
31 625 [OTA Task] [prvParseJSONbyModel] Identified parameter [ self_test ]
32 625 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ updatedBy: 16777218 ]
33 625 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ streamname: AFR_OTA-52458a23-ba09-49e4-ae6a-17b97e896bab ]
34 625 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filepath: / ]
35 626 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ filesize: 262352 ]
36 626 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ fileid: 0 ]
37 626 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ certfile: / ]
38 626 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ sig-sha256-ecdsa: MEYCIQCmdMH88RiQ9VKMYI5+L7XI8e1s... ]
39 626 [OTA Task] [prvParseJobDoc] In self test mode.
40 626 [OTA Task] [prvParseJobDoc] Failing job. We rebooted and the version is still the same.
41 626 [OTA Task] [prvUpdateJobStatus] Msg: {"status":"FAILED","statusDetails":{"reason":"rejected: 0x23000000"}}
2 598 [BLE] Requesting to update ATT MTU to 247 bytes on connection 0x0.3 598 [BLE] sd_ble_gattc_exchange_mtu_request() on connection 0x0 returned busy, will retry.4 598 [BLE] [INFO ][DEMO][5980] BLE Connected to remote device, connId = 0
5 598 [iot_thread] [INFO ][DEMO][5980] Successfully initialized the demo. Network type for the demo: 2
6 598 [iot_thread] [INFO ][MQTT][5980] MQTT library successfully initialized.
7 598 [iot_thread] OTA demo version 1.0.2
8 598 [iot_thread] Creating MQTT Client...
9 724 [BLE] UNKNOWN BLE EVENT 35
10 729 [iot_thread] Connecting to broker...
11 729 [iot_thread] [INFO ][MQTT][7290] Establishing new MQTT connection.
12 729 [iot_thread] [INFO ][MQTT][7290] (MQTT connection 20017678, CONNECT operation 200179b8) Waiting for operation completion.
13 748 [iot_thread] [INFO ][MQTT][7480] (MQTT connection 20017678, CONNECT operation 200179b8) Wait complete with result SUCCESS.
14 748 [iot_thread] [INFO ][MQTT][7480] New MQTT connection 20004760 established.
15 748 [iot_thread] Connected to broker.
16 748 [OTA Task] [INFO ][MQTT][7480] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
17 748 [OTA Task] [INFO ][MQTT][7480] (MQTT connection 20017678, SUBSCRIBE operation 2001fbd0) Waiting for operation completion.
18 807 [OTA Task] [INFO ][MQTT][8070] (MQTT connection 20017678, SUBSCRIBE operation 2001fbd0) Wait complete with result SUCCESS.
19 807 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/$next/get/accepted
20 807 [OTA Task] [INFO ][MQTT][8070] (MQTT connection 20017678) SUBSCRIBE operation scheduled.
21 807 [OTA Task] [INFO ][MQTT][8070] (MQTT connection 20017678, SUBSCRIBE operation 20017ac0) Waiting for operation completion.
22 865 [OTA Task] [INFO ][MQTT][8650] (MQTT connection 20017678, SUBSCRIBE operation 20017ac0) Wait complete with result SUCCESS.
23 865 [OTA Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/NRF52840DK/jobs/notify-next
24 865 [OTA Task] [OTA_CheckForUpdate] Request #0
25 865 [OTA Task] [INFO ][MQTT][8650] (MQTT connection 20017678) MQTT PUBLISH operation queued.
26 865 [OTA Task] [INFO ][MQTT][8650] (MQTT connection 20017678, PUBLISH operation 2001fd20) Waiting for operation completion.
27 880 [OTA Task] [INFO ][MQTT][8800] (MQTT connection 20017678, PUBLISH operation 2001fd20) Wait complete with result SUCCESS.
28 881 [iot_thread] [OTA_AgentInit] Ready.
29 894 [OTA Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:NRF52840DK ]
30 894 [OTA Task] [prvParseJSONbyModel] parameter not present: execution
31 894 [OTA Task] [prvParseJSONbyModel] parameter not present: jobId
32 894 [OTA Task] [prvParseJSONbyModel] parameter not present: jobDocument
33 894 [OTA Task] [prvParseJSONbyModel] parameter not present: afr_ota
34 894 [OTA Task] [prvParseJSONbyModel] parameter not present: streamname
35 894 [OTA Task] [prvParseJSONbyModel] parameter not present: files
36 894 [OTA Task] [prvParseJSONbyModel] parameter not present: filepath
37 894 [OTA Task] [prvParseJSONbyModel] parameter not present: filesize
38 894 [OTA Task] [prvParseJSONbyModel] parameter not present: fileid
39 894 [OTA Task] [prvParseJSONbyModel] parameter not present: certfile
40 894 [OTA Task] [prvParseJSONbyModel] parameter not present: sig-sha256-ecdsa
41 894 [OTA Task] [prvParseJobDoc] Ignoring job without ID.
42 894 [OTA Task] [prvOTA_Close] Context->0x200328c4
43 981 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 1   Dropped: 0
44 1081 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 1   Dropped: 0
45 1181 [iot_thread] State: Ready  Received: 1   Queued: 1   Processed: 1   Dropped: 0
ljaynes wrote on July 08, 2019:
Thanks Hugues. Reflashing the bootloader fixed the OTA failing issue.
Any idea on the second part of my question? Do I need to open a second MQTT connection for OTA to avoid a huge delay in my custom messages being transferred to the device while an OTA downloads in the background?
hbouvier-AWS wrote on July 08, 2019:
Hey,
There is a way to send message out but to my knowledge no reliable way to get message in with the same MQTT client.
OTA sends a huge batch of message “in” but few message out.
You could set the QOS to 0 and you would be able to send messages. Since receiving is not prioritized it is more complicated.
Another way could be to have another connection, however, you would need to modify the APP side (on android/IOS) to prioritize the traffic.
Hugues
I think you just need to reflash your bootloader.
I checked the messages. You added codesignerCERTIFICATE afterward.
That code signer is used by the bootloader too. You need to reflash the bootloader, compiled with your signer cert. Otherwise bootload will fail and you code won’t get updated.
Best,
Hugues
Alright thanks, we will explore our options and see what will work best for us.
Hi there,
I am wondering how do you get nrf52840 connect to the internet? There are only two ways I would assume: 1) android 2) ios. Did you use an android phone app? I couldn’t find either apps in the stores. I tried to compile the IOS app but it failed the compilation.
Hi Aikudo,
If you are looking to connect nrf52840 to AWS IoT services then please refer the AWS docs here :
Noridic nrf52840 getting started - https://docs.aws.amazon.com/freertos/latest/userguide/getting_started_nordic.html
BLE Demo Application - https://docs.aws.amazon.com/freertos/latest/userguide/ble-demo.html#set-up-ble-demo-aws
Proxy App - https://docs.aws.amazon.com/freertos/latest/userguide/ble-demo.html#ble-sdk-app
You can create a separate post for any new topics you have in this forum and share any build failure logs.
Hello Aikudo,
What compilation issues are you facing with the iOS app? Can you tell me what version of the App, and XCode you are using?
Hi lundic,
I opened a new thread here: Compile amazon-freertos-ble-ios-sdk AmazonFreeRTOSDemo problem
