rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:956
load:0x40078000,len:0
load:0x40078000,len:13256
entry 0x40078a90
I (275) cpu_start: Pro cpu up.
I (275) cpu_start: Application information:
I (275) cpu_start: Project name: esp-idf
I (277) cpu_start: App version: 1
I (282) cpu_start: Compile time: Jul 20 2020 14:02:25
I (288) cpu_start: ELF file SHA256: 2feee966c066958a…
I (294) cpu_start: ESP-IDF: v3.3.2-235-ga3ce2f400
I (300) cpu_start: Single core mode
I (304) heap_init: Initializing. RAM available for dynamic allocation:
I (311) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (317) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (323) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (330) heap_init: At 3FFBDB5C len 00000004 (0 KiB): DRAM
I (336) heap_init: At 3FFCC480 len 00013B80 (78 KiB): DRAM
I (342) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM
I (348) heap_init: At 40078000 len 00008000 (32 KiB): IRAM
I (354) heap_init: At 40094F6C len 0000B094 (44 KiB): IRAM
I (361) cpu_start: Pro cpu start user code
I (42) cpu_start: Starting scheduler on PRO CPU.
I (51) PKCS11: Initializing NVS partition: “storage”
E (71) PKCS11: failed nvs get file size 4354 0
0 3 [loopTask] Write certificate…
1 4 [iot_thread] [INFO ][DEMO][40] ---------STARTING DEMO---------
2 4 [iot_thread] [INFO ][INIT][40] SDK successfully initialized.
Hello, from loop!
I (111) wifi:wifi driver task: 3ffb2388, prio:23, stack:3584, core=0
I (111) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (131) wifi:wifi firmware version: 1afdae0
I (131) wifi:config NVS flash: enabled
I (131) wifi:config nano formating: disabled
I (131) wifi:Init dynamic tx buffer num: 32
I (141) wifi:Init data frame dynamic rx buffer num: 32
I (141) wifi:Init management frame dynamic rx buffer num: 32
I (151) wifi:Init management short buffer num: 32
I (151) wifi:Init static rx buffer size: 1600
I (161) wifi:Init static rx buffer num: 10
I (161) wifi:Init dynamic rx buffer num: 32
I (251) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
I (251) wifi:mode : sta (4c:11:ae:61:21:ac)
I (251) WIFI: SYSTEM_EVENT_STA_START
I (1341) wifi:new:<9,0>, old:<1,0>, ap:<255,255>, sta:<9,0>, prof:3
I (2321) wifi:state: init -> auth (b0)
I (2331) wifi:state: auth -> assoc (0)
I (2341) wifi:state: assoc -> run (10)
I (2351) wifi:connected with NETGEAR21, aid = 3, channel 9, BW20, bssid = 50:6a:03:a9:40:a9
I (2351) wifi:security type: 3, phy: bgn, rssi: -38
I (2361) wifi:pm start, type: 1
I (2361) WIFI: SYSTEM_EVENT_STA_CONNECTED
I (2391) wifi:AP’s beacon interval = 102400 us, DTIM period = 2
Hello, from loop!
I (4521) event: sta ip: 192.168.1.12, mask: 255.255.255.0, gw: 192.168.1.1
I (4521) WIFI: SYSTEM_EVENT_STA_GOT_IP
3 447 [iot_thread] [INFO ][DEMO][4470] Successfully initialized the demo. Network type for the demo: 1
4 447 [iot_thread] [INFO ][MQTT][4470] MQTT library successfully initialized.
5 447 [iot_thread] [INFO ][DEMO][4470] OTA demo version 0.0.1
6 447 [iot_thread] [INFO ][DEMO][4470] Connecting to broker…
7 447 [iot_thread] [INFO ][DEMO][4470] MQTT demo client identifier is A12345-67891 (length 12).
Hello, from loop!
E (5281) PKCS11: failed nvs get file size 4354 0
Hello, from loop!
8 1198 [iot_thread] [INFO ][MQTT][11980] Establishing new MQTT connection.
9 1198 [iot_thread] [INFO ][MQTT][11980] Anonymous metrics (SDK language, SDK version) will be provided to AWS IoT. Recompile with AWS_IOT_MQTT_ENABLE_METRICS set to 0 to disable.
10 1198 [iot_thread] [INFO ][MQTT][11980] (MQTT connection 0x3ffd08ec, CONNECT operation 0x3ffd8e48) Waiting for operation completion.
11 1239 [iot_thread] [INFO ][MQTT][12390] (MQTT connection 0x3ffd08ec, CONNECT operation 0x3ffd8e48) Wait complete with result SUCCESS.
12 1239 [iot_thread] [INFO ][MQTT][12390] New MQTT connection 0x3ffc119c established.
13 1240 [iot_thread] [OTA_AgentInit_internal] OTA Task is Ready.
I (12461) ota_pal: prvPAL_GetPlatformImageState
I (12461) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (12471) esp_ota_ops: [0] aflags/seq:0xffffffff/0x1, pflags/seq:0xffffffff/0x0
14 1242 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [Ready] Event [Start] New state [RequestingJob]
15 1244 [OTA Agent Task] [INFO ][MQTT][12420] (MQTT connection 0x3ffd08ec) SUBSCRIBE operation scheduled.
16 1244 [OTA Agent Task] [INFO ][MQTT][12440] (MQTT connection 0x3ffd08ec, SUBSCRIBE operation 0x3ffd8e48) Waiting for operation completion.
17 1280 [OTA Agent Task] [INFO ][MQTT][12800] (MQTT connection 0x3ffd08ec, SUBSCRIBE operation 0x3ffd8e48) Wait complete with result SUCCESS.
18 1280 [OTA Agent Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/A12345-67891/jobs/$next/get/accepted
19 1280 [OTA Agent Task] [INFO ][MQTT][12800] (MQTT connection 0x3ffd08ec) SUBSCRIBE operation scheduled.
20 1280 [OTA Agent Task] [INFO ][MQTT][12800] (MQTT connection 0x3ffd08ec, SUBSCRIBE operation 0x3ffd8e48) Waiting for operation completion.
21 1340 [iot_thread] [INFO ][DEMO][13400] State: Ready Received: 0 Queued: 0 Processed: 0 Dropped: 0
22 1341 [OTA Agent Task] [INFO ][MQTT][13410] (MQTT connection 0x3ffd08ec, SUBSCRIBE operation 0x3ffd8e48) Wait complete with result SUCCESS.
23 1341 [OTA Agent Task] [prvSubscribeToJobNotificationTopics] OK: $aws/things/A12345-67891/jobs/notify-next
24 1341 [OTA Agent Task] [prvRequestJob_Mqtt] Request #0
25 1341 [OTA Agent Task] [INFO ][MQTT][13410] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
26 1341 [OTA Agent Task] [INFO ][MQTT][13410] (MQTT connection 0x3ffd08ec, PUBLISH operation 0x3ffd8e48) Waiting for operation completion.
Hello, from loop!
27 1402 [OTA Agent Task] [INFO ][MQTT][14020] (MQTT connection 0x3ffd08ec, PUBLISH operation 0x3ffd8e48) Wait complete with result SUCCESS.
28 1402 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [RequestingJob] Event [RequestJobDocument] New state [WaitingForJob]
I (14091) ota_pal: prvPAL_GetPlatformImageState
I (14091) esp_ota_ops: aws_esp_ota_get_boot_flags: 1
I (14101) esp_ota_ops: [0] aflags/seq:0xffffffff/0x1, pflags/seq:0xffffffff/0x0
I (14111) ota_pal: Writing to partition subtype 17 at offset 0x400000
29 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ clientToken: 0:A12345-67891 ]
30 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ jobId: AFR_OTA-H20_2 ]
31 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ protocols: [“MQTT”] ]
32 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ streamname: AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee ]
33 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ filepath: - ]
34 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ filesize: 847504 ]
35 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ fileid: 0 ]
36 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ certfile: C:\Program Files\OpenSSL-Win64\bin ]
37 1404 [OTA Agent Task] [prvParseJSONbyModel] Extracted parameter [ sig-sha256-ecdsa: MEUCIQCeD0d38b9x/wJUWDVXiBpvJ6CV… ]
38 1404 [OTA Agent Task] [prvParseJobDoc] Job was accepted. Attempting to start transfer.
39 1450 [iot_thread] [INFO ][DEMO][14500] State: RequestingJob Received: 1 Queued: 0 Processed: 0 Dropped: 0
40 1557 [iot_thread] [INFO ][DEMO][15570] State: WaitingForJob Received: 1 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
41 1665 [iot_thread] [INFO ][DEMO][16650] State: WaitingForJob Received: 1 Queued: 0 Processed: 0 Dropped: 0
42 1765 [iot_thread] [INFO ][DEMO][17650] State: WaitingForJob Received: 1 Queued: 0 Processed: 0 Dropped: 0
43 1865 [iot_thread] [INFO ][DEMO][18650] State: WaitingForJob Received: 1 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
I (19071) ota_pal: aws_esp_ota_begin succeeded
44 1902 [OTA Agent Task] [prvSetDataInterface] Data interface is set to MQTT.
45 1902 [OTA Agent Task] [prvProcessJobHandler] Setting OTA data inerface.
46 1902 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForJob] Event [ReceivedJobDocument] New state [CreatingFile]
47 1902 [OTA Agent Task] [INFO ][MQTT][19020] (MQTT connection 0x3ffd08ec) SUBSCRIBE operation scheduled.
48 1902 [OTA Agent Task] [INFO ][MQTT][19020] (MQTT connection 0x3ffd08ec, SUBSCRIBE operation 0x3ffd8e48) Waiting for operation completion.
49 1935 [OTA Agent Task] [INFO ][MQTT][19350] (MQTT connection 0x3ffd08ec, SUBSCRIBE operation 0x3ffd8e48) Wait complete with result SUCCESS.
50 1935 [OTA Agent Task] [prvInitFileTransfer_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/data/cbor
51 1935 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [CreatingFile] Event [CreateFile] New state [RequestingFileBlock]
52 1935 [OTA Agent Task] [INFO ][MQTT][19350] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
53 1935 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
54 1935 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [RequestingFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
55 1965 [iot_thread] [INFO ][DEMO][19650] State: WaitingForJob Received: 1 Queued: 0 Processed: 0 Dropped: 0
56 1977 [OTA Agent Task] [prvIngestDataBlock] Received file block 1, size 4096
57 1978 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
58 2018 [OTA Agent Task] [prvIngestDataBlock] Received file block 2, size 4096
59 2019 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
60 2059 [OTA Agent Task] [prvIngestDataBlock] Received file block 4, size 4096
61 2060 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
62 2065 [iot_thread] [INFO ][DEMO][20650] State: WaitingForFileBlock Received: 4 Queued: 0 Processed: 0 Dropped: 0
63 2078 [OTA Agent Task] [prvIngestDataBlock] Received file block 3, size 4096
64 2080 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
65 2081 [OTA Agent Task] [prvIngestDataBlock] Received file block 5, size 4096
66 2082 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
67 2120 [OTA Agent Task] [prvIngestDataBlock] Received file block 6, size 4096
68 2121 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
69 2161 [OTA Agent Task] [prvIngestDataBlock] Received file block 7, size 4096
70 2162 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
71 2165 [iot_thread] [INFO ][DEMO][21650] State: WaitingForFileBlock Received: 8 Queued: 0 Processed: 0 Dropped: 0
72 2201 [OTA Agent Task] [prvIngestDataBlock] Received file block 0, size 4096
73 2202 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
74 2202 [OTA Agent Task] [INFO ][MQTT][22020] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
75 2202 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
76 2202 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
77 2243 [OTA Agent Task] [prvIngestDataBlock] Received file block 8, size 4096
78 2244 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
79 2265 [iot_thread] [INFO ][DEMO][22650] State: WaitingForFileBlock Received: 10 Queued: 0 Processed: 0 Dropped: 0
80 2283 [OTA Agent Task] [prvIngestDataBlock] Received file block 10, size 4096
81 2284 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
82 2325 [OTA Agent Task] [prvIngestDataBlock] Received file block 9, size 4096
83 2326 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
84 2365 [iot_thread] [INFO ][DEMO][23650] State: WaitingForFileBlock Received: 12 Queued: 0 Processed: 0 Dropped: 0
85 2365 [OTA Agent Task] [prvIngestDataBlock] Received file block 11, size 4096
86 2366 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
87 2368 [OTA Agent Task] [prvIngestDataBlock] Received file block 13, size 4096
88 2369 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
89 2407 [OTA Agent Task] [prvIngestDataBlock] Received file block 14, size 4096
90 2408 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
91 2448 [OTA Agent Task] [prvIngestDataBlock] Received file block 15, size 4096
92 2449 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
93 2465 [iot_thread] [INFO ][DEMO][24650] State: WaitingForFileBlock Received: 16 Queued: 0 Processed: 0 Dropped: 0
94 2488 [OTA Agent Task] [prvIngestDataBlock] Received file block 12, size 4096
95 2489 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
96 2489 [OTA Agent Task] [INFO ][MQTT][24890] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
97 2489 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
98 2489 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
99 2530 [OTA Agent Task] [prvIngestDataBlock] Received file block 16, size 4096
100 2531 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
101 2550 [OTA Agent Task] [prvIngestDataBlock] Received file block 18, size 4096
102 2551 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
103 2565 [iot_thread] [INFO ][DEMO][25650] State: WaitingForFileBlock Received: 19 Queued: 0 Processed: 0 Dropped: 0
104 2570 [OTA Agent Task] [prvIngestDataBlock] Received file block 20, size 4096
105 2572 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
106 2591 [OTA Agent Task] [prvIngestDataBlock] Received file block 21, size 4096
107 2592 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
108 2594 [OTA Agent Task] [prvIngestDataBlock] Received file block 22, size 4096
109 2595 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
110 2612 [OTA Agent Task] [prvIngestDataBlock] Received file block 23, size 4096
111 2613 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
112 2632 [OTA Agent Task] [prvIngestDataBlock] Received file block 19, size 4096
113 2633 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
114 2652 [OTA Agent Task] [prvIngestDataBlock] Received file block 17, size 4096
115 2653 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
116 2655 [OTA Agent Task] [INFO ][MQTT][26550] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
117 2655 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
118 2655 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
119 2665 [iot_thread] [INFO ][DEMO][26650] State: WaitingForFileBlock Received: 25 Queued: 0 Processed: 0 Dropped: 0
120 2694 [OTA Agent Task] [prvIngestDataBlock] Received file block 24, size 4096
121 2695 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
122 2734 [OTA Agent Task] [prvIngestDataBlock] Received file block 25, size 4096
123 2736 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
124 2755 [OTA Agent Task] [prvIngestDataBlock] Received file block 26, size 4096
125 2756 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
126 2765 [iot_thread] [INFO ][DEMO][27650] State: WaitingForFileBlock Received: 28 Queued: 0 Processed: 0 Dropped: 0
127 2775 [OTA Agent Task] [prvIngestDataBlock] Received file block 27, size 4096
128 2776 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
129 2777 [OTA Agent Task] [prvIngestDataBlock] Received file block 28, size 4096
130 2778 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
131 2816 [OTA Agent Task] [prvIngestDataBlock] Received file block 29, size 4096
132 2817 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
133 2857 [OTA Agent Task] [prvIngestDataBlock] Received file block 30, size 4096
134 2858 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
135 2865 [iot_thread] [INFO ][DEMO][28650] State: WaitingForFileBlock Received: 32 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
136 2898 [OTA Agent Task] [prvIngestDataBlock] Received file block 31, size 4096
137 2899 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
138 2899 [OTA Agent Task] [INFO ][MQTT][28990] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
139 2899 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
140 2899 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
141 2919 [OTA Agent Task] [prvIngestDataBlock] Received file block 32, size 4096
142 2920 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
143 2939 [OTA Agent Task] [prvIngestDataBlock] Received file block 33, size 4096
144 2940 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
145 2960 [OTA Agent Task] [prvIngestDataBlock] Received file block 35, size 4096
146 2961 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
147 2965 [iot_thread] [INFO ][DEMO][29650] State: WaitingForFileBlock Received: 36 Queued: 0 Processed: 0 Dropped: 0
148 2979 [OTA Agent Task] [prvIngestDataBlock] Received file block 34, size 4096
149 2981 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
150 2982 [OTA Agent Task] [prvIngestDataBlock] Received file block 36, size 4096
151 2983 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
152 3021 [OTA Agent Task] [prvIngestDataBlock] Received file block 37, size 4096
153 3022 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
154 3062 [OTA Agent Task] [prvIngestDataBlock] Received file block 39, size 4096
155 3063 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
156 3065 [iot_thread] [INFO ][DEMO][30650] State: WaitingForFileBlock Received: 40 Queued: 0 Processed: 0 Dropped: 0
157 3103 [OTA Agent Task] [prvIngestDataBlock] Received file block 38, size 4096
158 3104 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
159 3104 [OTA Agent Task] [INFO ][MQTT][31040] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
160 3104 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
161 3104 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
162 3144 [OTA Agent Task] [prvIngestDataBlock] Received file block 41, size 4096
163 3145 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
164 3165 [iot_thread] [INFO ][DEMO][31650] State: WaitingForFileBlock Received: 42 Queued: 0 Processed: 0 Dropped: 0
165 3165 [OTA Agent Task] [prvIngestDataBlock] Received file block 40, size 4096
166 3166 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
167 3185 [OTA Agent Task] [prvIngestDataBlock] Received file block 44, size 4096
168 3186 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
169 3226 [OTA Agent Task] [prvIngestDataBlock] Received file block 42, size 4096
170 3227 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
171 3229 [OTA Agent Task] [prvIngestDataBlock] Received file block 43, size 4096
172 3230 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
173 3265 [iot_thread] [INFO ][DEMO][32650] State: WaitingForFileBlock Received: 46 Queued: 0 Processed: 0 Dropped: 0
174 3267 [OTA Agent Task] [prvIngestDataBlock] Received file block 45, size 4096
175 3268 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
176 3308 [OTA Agent Task] [prvIngestDataBlock] Received file block 46, size 4096
177 3309 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
178 3348 [OTA Agent Task] [prvIngestDataBlock] Received file block 47, size 4096
179 3349 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
180 3349 [OTA Agent Task] [INFO ][MQTT][33490] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
181 3349 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
182 3349 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
183 3365 [iot_thread] [INFO ][DEMO][33650] State: WaitingForFileBlock Received: 49 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
184 3390 [OTA Agent Task] [prvIngestDataBlock] Received file block 48, size 4096
185 3391 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
186 3431 [OTA Agent Task] [prvIngestDataBlock] Received file block 49, size 4096
187 3432 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
188 3465 [iot_thread] [INFO ][DEMO][34650] State: WaitingForFileBlock Received: 51 Queued: 0 Processed: 0 Dropped: 0
189 3472 [OTA Agent Task] [prvIngestDataBlock] Received file block 50, size 4096
190 3473 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
191 3513 [OTA Agent Task] [prvIngestDataBlock] Received file block 51, size 4096
192 3514 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
193 3553 [OTA Agent Task] [prvIngestDataBlock] Received file block 53, size 4096
194 3555 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
195 3565 [iot_thread] [INFO ][DEMO][35650] State: WaitingForFileBlock Received: 54 Queued: 0 Processed: 0 Dropped: 0
196 3594 [OTA Agent Task] [prvIngestDataBlock] Received file block 54, size 4096
197 3595 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
198 3597 [OTA Agent Task] [prvIngestDataBlock] Received file block 55, size 4096
199 3598 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
200 3636 [OTA Agent Task] [prvIngestDataBlock] Received file block 52, size 4096
201 3637 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
202 3637 [OTA Agent Task] [INFO ][MQTT][36370] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
203 3637 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
204 3637 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
205 3665 [iot_thread] [INFO ][DEMO][36650] State: WaitingForFileBlock Received: 57 Queued: 0 Processed: 0 Dropped: 0
206 3676 [OTA Agent Task] [prvIngestDataBlock] Received file block 59, size 4096
207 3678 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
208 3697 [OTA Agent Task] [prvIngestDataBlock] Received file block 56, size 4096
209 3698 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
210 3717 [OTA Agent Task] [prvIngestDataBlock] Received file block 58, size 4096
211 3718 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
212 3758 [OTA Agent Task] [prvIngestDataBlock] Received file block 61, size 4096
213 3759 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
214 3760 [OTA Agent Task] [prvIngestDataBlock] Received file block 60, size 4096
215 3761 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
216 3765 [iot_thread] [INFO ][DEMO][37650] State: WaitingForFileBlock Received: 62 Queued: 0 Processed: 0 Dropped: 0
217 3779 [OTA Agent Task] [prvIngestDataBlock] Received file block 62, size 4096
218 3780 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
219 3820 [OTA Agent Task] [prvIngestDataBlock] Received file block 63, size 4096
220 3821 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
221 3860 [OTA Agent Task] [prvIngestDataBlock] Received file block 57, size 4096
222 3861 [OTA Agent Task] [prvPublishStatusMessage] Msg: {“status”:“IN_PROGRESS”,“statusDetails”:{“receive”:“64/207”}}
223 3861 [OTA Agent Task] [INFO ][MQTT][38610] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
224 3861 [OTA Agent Task] [prvPublishStatusMessage] ‘IN_PROGRESS’ to $aws/things/A12345-67891/jobs/AFR_OTA-H20_2/update
225 3861 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
226 3863 [OTA Agent Task] [INFO ][MQTT][38630] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
227 3863 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
228 3863 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
229 3865 [iot_thread] [INFO ][DEMO][38650] State: WaitingForFileBlock Received: 65 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
230 3943 [OTA Agent Task] [prvIngestDataBlock] Received file block 64, size 4096
231 3944 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
232 3963 [OTA Agent Task] [prvIngestDataBlock] Received file block 65, size 4096
233 3964 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
234 3965 [iot_thread] [INFO ][DEMO][39650] State: WaitingForFileBlock Received: 67 Queued: 0 Processed: 0 Dropped: 0
235 3983 [OTA Agent Task] [prvIngestDataBlock] Received file block 66, size 4096
236 3984 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
237 4024 [OTA Agent Task] [prvIngestDataBlock] Received file block 67, size 4096
238 4025 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
239 4027 [OTA Agent Task] [prvIngestDataBlock] Received file block 68, size 4096
240 4028 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
241 4065 [iot_thread] [INFO ][DEMO][40650] State: WaitingForFileBlock Received: 70 Queued: 0 Processed: 0 Dropped: 0
242 4066 [OTA Agent Task] [prvIngestDataBlock] Received file block 69, size 4096
243 4067 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
244 4106 [OTA Agent Task] [prvIngestDataBlock] Received file block 70, size 4096
245 4108 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
246 4147 [OTA Agent Task] [prvIngestDataBlock] Received file block 71, size 4096
247 4148 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
248 4148 [OTA Agent Task] [INFO ][MQTT][41480] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
249 4148 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
250 4148 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
251 4165 [iot_thread] [INFO ][DEMO][41650] State: WaitingForFileBlock Received: 73 Queued: 0 Processed: 0 Dropped: 0
252 4189 [OTA Agent Task] [prvIngestDataBlock] Received file block 72, size 4096
253 4190 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
254 4230 [OTA Agent Task] [prvIngestDataBlock] Received file block 73, size 4096
255 4231 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
256 4265 [iot_thread] [INFO ][DEMO][42650] State: WaitingForFileBlock Received: 75 Queued: 0 Processed: 0 Dropped: 0
257 4271 [OTA Agent Task] [prvIngestDataBlock] Received file block 74, size 4096
258 4272 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
259 4311 [OTA Agent Task] [prvIngestDataBlock] Received file block 75, size 4096
260 4313 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
261 4314 [OTA Agent Task] [prvIngestDataBlock] Received file block 76, size 4096
262 4315 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
263 4352 [OTA Agent Task] [prvIngestDataBlock] Received file block 77, size 4096
264 4354 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
265 4365 [iot_thread] [INFO ][DEMO][43650] State: WaitingForFileBlock Received: 79 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
266 4393 [OTA Agent Task] [prvIngestDataBlock] Received file block 79, size 4096
267 4394 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
268 4434 [OTA Agent Task] [prvIngestDataBlock] Received file block 78, size 4096
269 4435 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
270 4435 [OTA Agent Task] [INFO ][MQTT][44350] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
271 4435 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
272 4435 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
273 4465 [iot_thread] [INFO ][DEMO][44650] State: WaitingForFileBlock Received: 81 Queued: 0 Processed: 0 Dropped: 0
274 4476 [OTA Agent Task] [prvIngestDataBlock] Received file block 80, size 4096
275 4477 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
276 4516 [OTA Agent Task] [prvIngestDataBlock] Received file block 81, size 4096
277 4517 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
278 4557 [OTA Agent Task] [prvIngestDataBlock] Received file block 82, size 4096
279 4558 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
280 4565 [iot_thread] [INFO ][DEMO][45650] State: WaitingForFileBlock Received: 84 Queued: 0 Processed: 0 Dropped: 0
281 4597 [OTA Agent Task] [prvIngestDataBlock] Received file block 83, size 4096
282 4599 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
283 4600 [OTA Agent Task] [prvIngestDataBlock] Received file block 84, size 4096
284 4601 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
285 4639 [OTA Agent Task] [prvIngestDataBlock] Received file block 85, size 4096
286 4640 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
287 4665 [iot_thread] [INFO ][DEMO][46650] State: WaitingForFileBlock Received: 87 Queued: 0 Processed: 0 Dropped: 0
288 4680 [OTA Agent Task] [prvIngestDataBlock] Received file block 86, size 4096
289 4681 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
290 4720 [OTA Agent Task] [prvIngestDataBlock] Received file block 87, size 4096
291 4721 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
292 4721 [OTA Agent Task] [INFO ][MQTT][47210] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
293 4721 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
294 4721 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
295 4762 [OTA Agent Task] [prvIngestDataBlock] Received file block 88, size 4096
296 4763 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
297 4765 [iot_thread] [INFO ][DEMO][47650] State: WaitingForFileBlock Received: 90 Queued: 0 Processed: 0 Dropped: 0
298 4782 [OTA Agent Task] [prvIngestDataBlock] Received file block 89, size 4096
299 4783 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
300 4805 [OTA Agent Task] [prvIngestDataBlock] Received file block 90, size 4096
301 4806 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
302 4823 [OTA Agent Task] [prvIngestDataBlock] Received file block 91, size 4096
303 4825 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
304 4826 [OTA Agent Task] [prvIngestDataBlock] Received file block 92, size 4096
305 4827 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
306 4864 [OTA Agent Task] [prvIngestDataBlock] Received file block 93, size 4096
307 4866 [iot_thread] [INFO ][DEMO][48660] State: WaitingForFileBlock Received: 95 Queued: 0 Processed: 0 Dropped: 0
308 4866 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
309 4885 [OTA Agent Task] [prvIngestDataBlock] Received file block 94, size 4096
310 4886 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
311 4925 [OTA Agent Task] [prvIngestDataBlock] Received file block 95, size 4096
312 4926 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
313 4926 [OTA Agent Task] [INFO ][MQTT][49260] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
314 4926 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
315 4926 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
316 4966 [iot_thread] [INFO ][DEMO][49660] State: WaitingForFileBlock Received: 97 Queued: 0 Processed: 0 Dropped: 0
317 4967 [OTA Agent Task] [prvIngestDataBlock] Received file block 96, size 4096
318 4968 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
319 4988 [OTA Agent Task] [prvIngestDataBlock] Received file block 97, size 4096
320 4989 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
321 5008 [OTA Agent Task] [prvIngestDataBlock] Received file block 98, size 4096
322 5010 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
323 5048 [OTA Agent Task] [prvIngestDataBlock] Received file block 99, size 4096
324 5049 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
325 5051 [OTA Agent Task] [prvIngestDataBlock] Received file block 100, size 4096
326 5052 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
327 5066 [iot_thread] [INFO ][DEMO][50660] State: WaitingForFileBlock Received: 102 Queued: 0 Processed: 0 Dropped: 0
328 5089 [OTA Agent Task] [prvIngestDataBlock] Received file block 101, size 4096
329 5090 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
330 5130 [OTA Agent Task] [prvIngestDataBlock] Received file block 102, size 4096
331 5132 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
332 5166 [iot_thread] [INFO ][DEMO][51660] State: WaitingForFileBlock Received: 104 Queued: 0 Processed: 0 Dropped: 0
333 5192 [OTA Agent Task] [prvIngestDataBlock] Received file block 103, size 4096
334 5193 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
335 5193 [OTA Agent Task] [INFO ][MQTT][51930] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
336 5193 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
337 5193 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
338 5253 [OTA Agent Task] [prvIngestDataBlock] Received file block 106, size 4096
339 5255 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
340 5266 [iot_thread] [INFO ][DEMO][52660] State: WaitingForFileBlock Received: 106 Queued: 0 Processed: 0 Dropped: 0
341 5294 [OTA Agent Task] [prvIngestDataBlock] Received file block 109, size 4096
342 5296 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
343 5335 [OTA Agent Task] [prvIngestDataBlock] Received file block 110, size 4096
344 5336 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
345 5366 [iot_thread] [INFO ][DEMO][53660] State: WaitingForFileBlock Received: 108 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
346 5376 [OTA Agent Task] [prvIngestDataBlock] Received file block 107, size 4096
347 5377 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
348 5379 [OTA Agent Task] [prvIngestDataBlock] Received file block 104, size 4096
349 5380 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
350 5438 [OTA Agent Task] [prvIngestDataBlock] Received file block 111, size 4096
351 5439 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
352 5466 [iot_thread] [INFO ][DEMO][54660] State: WaitingForFileBlock Received: 111 Queued: 0 Processed: 0 Dropped: 0
353 5479 [OTA Agent Task] [prvIngestDataBlock] Received file block 105, size 4096
354 5480 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
355 5519 [OTA Agent Task] [prvIngestDataBlock] Received file block 108, size 4096
356 5520 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
357 5520 [OTA Agent Task] [INFO ][MQTT][55200] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
358 5520 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
359 5520 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
360 5561 [OTA Agent Task] [prvIngestDataBlock] Received file block 112, size 4096
361 5562 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
362 5566 [iot_thread] [INFO ][DEMO][55660] State: WaitingForFileBlock Received: 114 Queued: 0 Processed: 0 Dropped: 0
363 5602 [OTA Agent Task] [prvIngestDataBlock] Received file block 113, size 4096
364 5603 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
365 5643 [OTA Agent Task] [prvIngestDataBlock] Received file block 114, size 4096
366 5644 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
367 5666 [iot_thread] [INFO ][DEMO][56660] State: WaitingForFileBlock Received: 116 Queued: 0 Processed: 0 Dropped: 0
368 5684 [OTA Agent Task] [prvIngestDataBlock] Received file block 115, size 4096
369 5685 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
370 5686 [OTA Agent Task] [prvIngestDataBlock] Received file block 116, size 4096
371 5687 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
372 5725 [OTA Agent Task] [prvIngestDataBlock] Received file block 117, size 4096
373 5726 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
374 5766 [iot_thread] [INFO ][DEMO][57660] State: WaitingForFileBlock Received: 119 Queued: 0 Processed: 0 Dropped: 0
375 5766 [OTA Agent Task] [prvIngestDataBlock] Received file block 118, size 4096
376 5767 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
377 5806 [OTA Agent Task] [prvIngestDataBlock] Received file block 119, size 4096
378 5807 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
379 5807 [OTA Agent Task] [INFO ][MQTT][58070] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
380 5807 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
381 5807 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
382 5847 [OTA Agent Task] [prvIngestDataBlock] Received file block 120, size 4096
383 5848 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
384 5866 [iot_thread] [INFO ][DEMO][58660] State: WaitingForFileBlock Received: 122 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
385 5888 [OTA Agent Task] [prvIngestDataBlock] Received file block 121, size 4096
386 5889 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
387 5929 [OTA Agent Task] [prvIngestDataBlock] Received file block 122, size 4096
388 5930 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
389 5966 [iot_thread] [INFO ][DEMO][59660] State: WaitingForFileBlock Received: 124 Queued: 0 Processed: 0 Dropped: 0
390 5990 [OTA Agent Task] [prvIngestDataBlock] Received file block 124, size 4096
391 5991 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
392 5993 [OTA Agent Task] [prvIngestDataBlock] Received file block 126, size 4096
393 5994 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
394 6052 [OTA Agent Task] [prvIngestDataBlock] Received file block 125, size 4096
395 6053 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
396 6066 [iot_thread] [INFO ][DEMO][60660] State: WaitingForFileBlock Received: 127 Queued: 0 Processed: 0 Dropped: 0
397 6093 [OTA Agent Task] [prvIngestDataBlock] Received file block 123, size 4096
398 6094 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
399 6133 [OTA Agent Task] [prvIngestDataBlock] Received file block 127, size 4096
400 6134 [OTA Agent Task] [prvPublishStatusMessage] Msg: {“status”:“IN_PROGRESS”,“statusDetails”:{“receive”:“128/207”}}
401 6134 [OTA Agent Task] [INFO ][MQTT][61340] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
402 6136 [OTA Agent Task] [prvPublishStatusMessage] ‘IN_PROGRESS’ to $aws/things/A12345-67891/jobs/AFR_OTA-H20_2/update
403 6136 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
404 6137 [OTA Agent Task] [INFO ][MQTT][61370] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
405 6137 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
406 6137 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
407 6166 [iot_thread] [INFO ][DEMO][61660] State: WaitingForFileBlock Received: 129 Queued: 0 Processed: 0 Dropped: 0
408 6236 [OTA Agent Task] [prvIngestDataBlock] Received file block 128, size 4096
409 6237 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
410 6266 [iot_thread] [INFO ][DEMO][62660] State: WaitingForFileBlock Received: 130 Queued: 0 Processed: 0 Dropped: 0
411 6318 [OTA Agent Task] [prvIngestDataBlock] Received file block 129, size 4096
412 6319 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
413 6366 [iot_thread] [INFO ][DEMO][63660] State: WaitingForFileBlock Received: 131 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
414 6401 [OTA Agent Task] [prvIngestDataBlock] Received file block 130, size 4096
415 6402 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
416 6466 [iot_thread] [INFO ][DEMO][64660] State: WaitingForFileBlock Received: 132 Queued: 0 Processed: 0 Dropped: 0
417 6482 [OTA Agent Task] [prvIngestDataBlock] Received file block 131, size 4096
418 6483 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
419 6484 [OTA Agent Task] [prvIngestDataBlock] Received file block 132, size 4096
420 6485 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
421 6544 [OTA Agent Task] [prvIngestDataBlock] Received file block 133, size 4096
422 6545 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
423 6566 [iot_thread] [INFO ][DEMO][65660] State: WaitingForFileBlock Received: 135 Queued: 0 Processed: 0 Dropped: 0
424 6605 [OTA Agent Task] [prvIngestDataBlock] Received file block 134, size 4096
425 6606 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
426 6666 [iot_thread] [INFO ][DEMO][66660] State: WaitingForFileBlock Received: 136 Queued: 0 Processed: 0 Dropped: 0
427 6666 [OTA Agent Task] [prvIngestDataBlock] Received file block 135, size 4096
428 6667 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
429 6667 [OTA Agent Task] [INFO ][MQTT][66670] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
430 6667 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
431 6667 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
432 6748 [OTA Agent Task] [prvIngestDataBlock] Received file block 136, size 4096
433 6750 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
434 6766 [iot_thread] [INFO ][DEMO][67660] State: WaitingForFileBlock Received: 138 Queued: 0 Processed: 0 Dropped: 0
435 6811 [OTA Agent Task] [prvIngestDataBlock] Received file block 137, size 4096
436 6812 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
437 6866 [iot_thread] [INFO ][DEMO][68660] State: WaitingForFileBlock Received: 139 Queued: 0 Processed: 0 Dropped: 0
438 6871 [OTA Agent Task] [prvIngestDataBlock] Received file block 138, size 4096
439 6872 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
440 6953 [OTA Agent Task] [prvIngestDataBlock] Received file block 139, size 4096
441 6954 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
442 6956 [OTA Agent Task] [prvIngestDataBlock] Received file block 141, size 4096
443 6957 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
444 6966 [iot_thread] [INFO ][DEMO][69660] State: WaitingForFileBlock Received: 142 Queued: 0 Processed: 0 Dropped: 0
445 7035 [OTA Agent Task] [prvIngestDataBlock] Received file block 142, size 4096
446 7036 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
447 7066 [iot_thread] [INFO ][DEMO][70660] State: WaitingForFileBlock Received: 143 Queued: 0 Processed: 0 Dropped: 0
448 7100 [OTA Agent Task] [prvIngestDataBlock] Received file block 143, size 4096
449 7101 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
450 7166 [iot_thread] [INFO ][DEMO][71660] State: WaitingForFileBlock Received: 144 Queued: 0 Processed: 0 Dropped: 0
451 7179 [OTA Agent Task] [prvIngestDataBlock] Received file block 140, size 4096
452 7180 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
453 7180 [OTA Agent Task] [INFO ][MQTT][71800] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
454 7180 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
455 7180 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
456 7199 [OTA Agent Task] [prvIngestDataBlock] Received file block 144, size 4096
457 7200 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
458 7220 [OTA Agent Task] [prvIngestDataBlock] Received file block 145, size 4096
459 7221 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
460 7241 [OTA Agent Task] [prvIngestDataBlock] Received file block 146, size 4096
461 7242 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
462 7266 [iot_thread] [INFO ][DEMO][72660] State: WaitingForFileBlock Received: 148 Queued: 0 Processed: 0 Dropped: 0
463 7281 [OTA Agent Task] [prvIngestDataBlock] Received file block 147, size 4096
464 7282 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
465 7284 [OTA Agent Task] [prvIngestDataBlock] Received file block 148, size 4096
466 7285 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
467 7322 [OTA Agent Task] [prvIngestDataBlock] Received file block 150, size 4096
468 7323 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
469 7363 [OTA Agent Task] [prvIngestDataBlock] Received file block 149, size 4096
470 7364 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
471 7366 [iot_thread] [INFO ][DEMO][73660] State: WaitingForFileBlock Received: 152 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
472 7403 [OTA Agent Task] [prvIngestDataBlock] Received file block 151, size 4096
473 7404 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
474 7404 [OTA Agent Task] [INFO ][MQTT][74040] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
475 7404 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
476 7404 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
477 7445 [OTA Agent Task] [prvIngestDataBlock] Received file block 152, size 4096
478 7446 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
479 7466 [iot_thread] [INFO ][DEMO][74660] State: WaitingForFileBlock Received: 154 Queued: 0 Processed: 0 Dropped: 0
480 7486 [OTA Agent Task] [prvIngestDataBlock] Received file block 153, size 4096
481 7487 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
482 7506 [OTA Agent Task] [prvIngestDataBlock] Received file block 154, size 4096
483 7508 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
484 7527 [OTA Agent Task] [prvIngestDataBlock] Received file block 155, size 4096
485 7528 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
486 7547 [OTA Agent Task] [prvIngestDataBlock] Received file block 156, size 4096
487 7548 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
488 7566 [iot_thread] [INFO ][DEMO][75660] State: WaitingForFileBlock Received: 158 Queued: 0 Processed: 0 Dropped: 0
489 7567 [OTA Agent Task] [prvIngestDataBlock] Received file block 157, size 4096
490 7568 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
491 7570 [OTA Agent Task] [prvIngestDataBlock] Received file block 158, size 4096
492 7571 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
493 7609 [OTA Agent Task] [prvIngestDataBlock] Received file block 159, size 4096
494 7610 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
495 7610 [OTA Agent Task] [INFO ][MQTT][76100] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
496 7610 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
497 7610 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
498 7650 [OTA Agent Task] [prvIngestDataBlock] Received file block 162, size 4096
499 7651 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
500 7666 [iot_thread] [INFO ][DEMO][76660] State: WaitingForFileBlock Received: 162 Queued: 0 Processed: 0 Dropped: 0
501 7691 [OTA Agent Task] [prvIngestDataBlock] Received file block 161, size 4096
502 7692 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
503 7711 [OTA Agent Task] [prvIngestDataBlock] Received file block 163, size 4096
504 7712 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
505 7731 [OTA Agent Task] [prvIngestDataBlock] Received file block 164, size 4096
506 7732 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
507 7734 [OTA Agent Task] [prvIngestDataBlock] Received file block 165, size 4096
508 7735 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
509 7752 [OTA Agent Task] [prvIngestDataBlock] Received file block 166, size 4096
510 7753 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
511 7766 [iot_thread] [INFO ][DEMO][77660] State: WaitingForFileBlock Received: 167 Queued: 0 Processed: 0 Dropped: 0
512 7792 [OTA Agent Task] [prvIngestDataBlock] Received file block 167, size 4096
513 7794 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
514 7834 [OTA Agent Task] [prvIngestDataBlock] Received file block 160, size 4096
515 7835 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
516 7835 [OTA Agent Task] [INFO ][MQTT][78350] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
517 7835 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
518 7835 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
519 7866 [iot_thread] [INFO ][DEMO][78660] State: WaitingForFileBlock Received: 169 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
520 7875 [OTA Agent Task] [prvIngestDataBlock] Received file block 168, size 4096
521 7876 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
522 7901 [OTA Agent Task] [prvIngestDataBlock] Received file block 169, size 4096
523 7902 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
524 7936 [OTA Agent Task] [prvIngestDataBlock] Received file block 170, size 4096
525 7937 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
526 7966 [iot_thread] [INFO ][DEMO][79660] State: WaitingForFileBlock Received: 172 Queued: 0 Processed: 0 Dropped: 0
527 7977 [OTA Agent Task] [prvIngestDataBlock] Received file block 171, size 4096
528 7978 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
529 7979 [OTA Agent Task] [prvIngestDataBlock] Received file block 172, size 4096
530 7980 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
531 8018 [OTA Agent Task] [prvIngestDataBlock] Received file block 173, size 4096
532 8019 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
533 8059 [OTA Agent Task] [prvIngestDataBlock] Received file block 174, size 4096
534 8060 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
535 8066 [iot_thread] [INFO ][DEMO][80660] State: WaitingForFileBlock Received: 176 Queued: 0 Processed: 0 Dropped: 0
536 8099 [OTA Agent Task] [prvIngestDataBlock] Received file block 175, size 4096
537 8100 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
538 8101 [OTA Agent Task] [INFO ][MQTT][81010] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
539 8101 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
540 8101 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
541 8141 [OTA Agent Task] [prvIngestDataBlock] Received file block 182, size 4096
542 8143 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
543 8166 [iot_thread] [INFO ][DEMO][81660] State: WaitingForFileBlock Received: 178 Queued: 0 Processed: 0 Dropped: 0
544 8182 [OTA Agent Task] [prvIngestDataBlock] Received file block 177, size 4096
545 8183 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
546 8223 [OTA Agent Task] [prvIngestDataBlock] Received file block 181, size 4096
547 8224 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
548 8229 [OTA Agent Task] [prvIngestDataBlock] Received file block 180, size 4096
549 8230 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
550 8235 [OTA Agent Task] [prvIngestDataBlock] Received file block 179, size 4096
551 8236 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
552 8264 [OTA Agent Task] [prvIngestDataBlock] Received file block 183, size 4096
553 8265 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
554 8266 [iot_thread] [INFO ][DEMO][82660] State: WaitingForFileBlock Received: 183 Queued: 0 Processed: 0 Dropped: 0
555 8285 [OTA Agent Task] [prvIngestDataBlock] Received file block 178, size 4096
556 8286 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
557 8304 [OTA Agent Task] [prvIngestDataBlock] Received file block 176, size 4096
558 8305 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
559 8305 [OTA Agent Task] [INFO ][MQTT][83050] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
560 8305 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
561 8305 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
562 8325 [OTA Agent Task] [prvIngestDataBlock] Received file block 184, size 4096
563 8327 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
564 8346 [OTA Agent Task] [prvIngestDataBlock] Received file block 185, size 4096
565 8347 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
566 8366 [iot_thread] [INFO ][DEMO][83660] State: WaitingForFileBlock Received: 187 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
567 8386 [OTA Agent Task] [prvIngestDataBlock] Received file block 186, size 4096
568 8388 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
569 8427 [OTA Agent Task] [prvIngestDataBlock] Received file block 187, size 4096
570 8428 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
571 8430 [OTA Agent Task] [prvIngestDataBlock] Received file block 188, size 4096
572 8431 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
573 8466 [iot_thread] [INFO ][DEMO][84660] State: WaitingForFileBlock Received: 190 Queued: 0 Processed: 0 Dropped: 0
574 8469 [OTA Agent Task] [prvIngestDataBlock] Received file block 189, size 4096
575 8470 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
576 8510 [OTA Agent Task] [prvIngestDataBlock] Received file block 190, size 4096
577 8511 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
578 8530 [OTA Agent Task] [prvIngestDataBlock] Received file block 191, size 4096
579 8531 [OTA Agent Task] [prvPublishStatusMessage] Msg: {“status”:“IN_PROGRESS”,“statusDetails”:{“receive”:“192/207”}}
580 8531 [OTA Agent Task] [INFO ][MQTT][85310] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
581 8531 [OTA Agent Task] [prvPublishStatusMessage] ‘IN_PROGRESS’ to $aws/things/A12345-67891/jobs/AFR_OTA-H20_2/update
582 8531 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
583 8531 [OTA Agent Task] [INFO ][MQTT][85310] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
584 8531 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
585 8531 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
586 8566 [iot_thread] [INFO ][DEMO][85660] State: WaitingForFileBlock Received: 193 Queued: 0 Processed: 0 Dropped: 0
587 8571 [OTA Agent Task] [prvIngestDataBlock] Received file block 199, size 4096
588 8572 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
589 8581 [OTA Agent Task] [prvIngestDataBlock] Received file block 197, size 4096
590 8582 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
591 8589 [OTA Agent Task] [prvIngestDataBlock] Received file block 192, size 4096
592 8590 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
593 8612 [OTA Agent Task] [prvIngestDataBlock] Received file block 198, size 4096
594 8613 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
595 8615 [OTA Agent Task] [prvIngestDataBlock] Received file block 195, size 4096
596 8616 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
Hello, from loop!
597 8653 [OTA Agent Task] [prvIngestDataBlock] Received file block 196, size 4096
598 8654 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
599 8666 [iot_thread] [INFO ][DEMO][86660] State: WaitingForFileBlock Received: 199 Queued: 0 Processed: 0 Dropped: 0
600 8694 [OTA Agent Task] [prvIngestDataBlock] Received file block 193, size 4096
601 8695 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
602 8734 [OTA Agent Task] [prvIngestDataBlock] Received file block 194, size 4096
603 8735 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
604 8735 [OTA Agent Task] [INFO ][MQTT][87350] (MQTT connection 0x3ffd08ec) MQTT PUBLISH operation queued.
605 8735 [OTA Agent Task] [prvRequestFileBlock_Mqtt] OK: $aws/things/A12345-67891/streams/AFR_OTA-5082f59e-2e70-478b-83b2-06612ce8d9ee/get/cbor
606 8735 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [RequestFileBlock] New state [WaitingForFileBlock]
607 8766 [iot_thread] [INFO ][DEMO][87660] State: WaitingForFileBlock Received: 201 Queued: 0 Processed: 0 Dropped: 0
608 8776 [OTA Agent Task] [prvIngestDataBlock] Received file block 200, size 4096
609 8777 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
610 8817 [OTA Agent Task] [prvIngestDataBlock] Received file block 201, size 4096
611 8818 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
612 8858 [OTA Agent Task] [prvIngestDataBlock] Received file block 202, size 4096
613 8859 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
614 8866 [iot_thread] [INFO ][DEMO][88660] State: WaitingForFileBlock Received: 204 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
615 8898 [OTA Agent Task] [prvIngestDataBlock] Received file block 203, size 4096
616 8899 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
617 8901 [OTA Agent Task] [prvIngestDataBlock] Received file block 205, size 4096
618 8902 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
619 8940 [OTA Agent Task] [prvIngestDataBlock] Received file block 206, size 3728
620 8941 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
621 8966 [iot_thread] [INFO ][DEMO][89660] State: WaitingForFileBlock Received: 207 Queued: 0 Processed: 0 Dropped: 0
622 8981 [OTA Agent Task] [prvIngestDataBlock] Received file block 204, size 4096
623 8982 [OTA Agent Task] [prvExecuteHandler] Called handler. Current State [WaitingForFileBlock] Event [ReceivedFileBlock] New state [WaitingForFileBlock]
624 9066 [iot_thread] [INFO ][DEMO][90660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
625 9166 [iot_thread] [INFO ][DEMO][91660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
626 9266 [iot_thread] [INFO ][DEMO][92660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
627 9366 [iot_thread] [INFO ][DEMO][93660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
628 9466 [iot_thread] [INFO ][DEMO][94660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
629 9566 [iot_thread] [INFO ][DEMO][95660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
630 9666 [iot_thread] [INFO ][DEMO][96660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
631 9766 [iot_thread] [INFO ][DEMO][97660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
632 9866 [iot_thread] [INFO ][DEMO][98660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
633 9966 [iot_thread] [INFO ][DEMO][99660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
634 9981 [OTA Agent Task] [prvExecuteHandler] Handler failed. Current State [WaitingForFileBlock] Event [RequestTimer] Error Code [-16777216]
635 10066 [iot_thread] [INFO ][DEMO][100660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
636 10166 [iot_thread] [INFO ][DEMO][101660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
637 10266 [iot_thread] [INFO ][DEMO][102660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
638 10366 [iot_thread] [INFO ][DEMO][103660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
639 10466 [iot_thread] [INFO ][DEMO][104660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
640 10566 [iot_thread] [INFO ][DEMO][105660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
641 10666 [iot_thread] [INFO ][DEMO][106660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
642 10766 [iot_thread] [INFO ][DEMO][107660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
643 10866 [iot_thread] [INFO ][DEMO][108660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
644 10966 [iot_thread] [INFO ][DEMO][109660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
645 11066 [iot_thread] [INFO ][DEMO][110660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
646 11166 [iot_thread] [INFO ][DEMO][111660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
647 11266 [iot_thread] [INFO ][DEMO][112660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
648 11366 [iot_thread] [INFO ][DEMO][113660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
649 11466 [iot_thread] [INFO ][DEMO][114660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
650 11566 [iot_thread] [INFO ][DEMO][115660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
651 11666 [iot_thread] [INFO ][DEMO][116660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
652 11766 [iot_thread] [INFO ][DEMO][117660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
653 11866 [iot_thread] [INFO ][DEMO][118660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
654 11966 [iot_thread] [INFO ][DEMO][119660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
655 12066 [iot_thread] [INFO ][DEMO][120660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
656 12166 [iot_thread] [INFO ][DEMO][121660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
657 12266 [iot_thread] [INFO ][DEMO][122660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
658 12366 [iot_thread] [INFO ][DEMO][123660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
659 12466 [iot_thread] [INFO ][DEMO][124660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
660 12566 [iot_thread] [INFO ][DEMO][125660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
661 12666 [iot_thread] [INFO ][DEMO][126660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
662 12766 [iot_thread] [INFO ][DEMO][127660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
663 12866 [iot_thread] [INFO ][DEMO][128660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
664 12966 [iot_thread] [INFO ][DEMO][129660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
665 13066 [iot_thread] [INFO ][DEMO][130660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
666 13166 [iot_thread] [INFO ][DEMO][131660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
667 13266 [iot_thread] [INFO ][DEMO][132660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
668 13366 [iot_thread] [INFO ][DEMO][133660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
669 13466 [iot_thread] [INFO ][DEMO][134660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
670 13566 [iot_thread] [INFO ][DEMO][135660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
671 13666 [iot_thread] [INFO ][DEMO][136660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
672 13766 [iot_thread] [INFO ][DEMO][137660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
673 13866 [iot_thread] [INFO ][DEMO][138660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
674 13966 [iot_thread] [INFO ][DEMO][139660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
675 14066 [iot_thread] [INFO ][DEMO][140660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
676 14166 [iot_thread] [INFO ][DEMO][141660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
677 14266 [iot_thread] [INFO ][DEMO][142660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
678 14366 [iot_thread] [INFO ][DEMO][143660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
679 14466 [iot_thread] [INFO ][DEMO][144660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
680 14566 [iot_thread] [INFO ][DEMO][145660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
Hello, from loop!
681 14666 [iot_thread] [INFO ][DEMO][146660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
682 14766 [iot_thread] [INFO ][DEMO][147660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
683 14866 [iot_thread] [INFO ][DEMO][148660] State: WaitingForFileBlock Received: 208 Queued: 0 Processed: 0 Dropped: 0
