Description
In stream_buffer.c, the function xStreamBufferSend() (also invoked via the xMessageBufferSend() macro) adds sbBYTES_TO_STORE_MESSAGE_LENGTH to xRequiredSpace without a runtime overflow check. The only protection is a configASSERT, which is compiled out in release builds.
With the analysis help of AI, it says “this is the same class of integer overflow vulnerability that was fixed in xStreamBufferGenericCreate() (CVE-2021-31572), but the fix was not applied to the send path.”
Affected Version
FreeRTOS Kernel V10.6.2.
Location
stream_buffer.c, inside xStreamBufferSend():
// Line ~677
size_t xRequiredSpace = xDataLengthBytes;
// Line ~692-697
if( ( pxStreamBuffer->ucFlags & sbFLAGS_IS_MESSAGE_BUFFER ) != ( uint8_t ) 0 )
xRequiredSpace += sbBYTES_TO_STORE_MESSAGE_LENGTH; // <-- can wrap on 32-bit
/* Overflow? */
configASSERT( xRequiredSpace > xDataLengthBytes ); // <-- ONLY protection
