Description
In stream_buffer.c, the function xStreamBufferSendFromISR() (also invoked via xMessageBufferSendFromISR()) adds sbBYTES_TO_STORE_MESSAGE_LENGTH to xRequiredSpace with no overflow check , also no configASSERT.
This is a variant of the same issue in xStreamBufferSend(), where a configASSERT is present. Both are the same class of vulnerability as CVE-2021-31572.
Affected Version
FreeRTOS Kernel V10.6.2. The missing configASSERT was added in V11.2.0, but lack of the underlying runtime check.
Location
stream_buffer.c, inside xStreamBufferSendFromISR():
// Line ~808
size_t xRequiredSpace = xDataLengthBytes;
// Line ~817-820
if( ( pxStreamBuffer->ucFlags & sbFLAGS_IS_MESSAGE_BUFFER ) != ( uint8_t ) 0 )
xRequiredSpace += sbBYTES_TO_STORE_MESSAGE_LENGTH; // <-- can wrap, NO check
// Directly proceeds to:
xSpace = xStreamBufferSpacesAvailable( pxStreamBuffer );
xReturn = prvWriteMessageToBuffer( pxStreamBuffer, pvTxData, xDataLengthBytes, xSpace, xRequiredSpace );
