vicui wrote on Thursday, May 10, 2012:
Hi Richard:
thank you for your reply !
frankly, I think you are right ! because LWIP and FreeRTOS are mature very much . and I also found that the problem disapparent with LWIP standalone. FreeRTOS also is good enough . I don’t know if the discussion in LWIP mail list is the following http://groups.google.com/group/osdeve_mirror_tcpip_lwip/browse_thread/thread/ca5738144b1f382d.
for FreeRTOS and LWIP integrity, the only porting file is sys_arch.c . i write mbox, semophare, mutex as following
err_t sys_mbox_new(sys_mbox_t *mbox, int size)
*mbox = xQueueCreate( archMESG_QUEUE_LENGTH, sizeof( void * ) );
if (*mbox == NULL)
return ERR_MEM;
return ERR_OK;
void sys_mbox_free(sys_mbox_t *mbox)
if (*mbox != NULL)
vQueueDelete( *mbox );
void sys_mbox_post(sys_mbox_t *mbox, void *msg)
if (*mbox != NULL)
while ( xQueueSendToBack(*mbox, &msg, portMAX_DELAY ) != pdTRUE );
err_t sys_mbox_trypost(sys_mbox_t *mbox, void *msg)
if ( xQueueSend( *mbox, &msg, 0 ) == pdPASS )
return ERR_OK;
return ERR_MEM;
u32_t sys_arch_mbox_fetch(sys_mbox_t *mbox, void **msg, u32_t timeout)
void *dummyptr = NULL;
portTickType StartTime, EndTime, Elapsed;
StartTime = xTaskGetTickCount();
if ( msg == NULL )
msg = &dummyptr;
if (*mbox == NULL)
return SYS_MBOX_EMPTY;
if ( timeout != 0 )
if ( pdTRUE == xQueueReceive( *mbox, &(*msg), timeout / portTICK_RATE_MS ) )
EndTime = xTaskGetTickCount();
Elapsed = (EndTime - StartTime) * portTICK_RATE_MS;
return ( Elapsed );
*msg = NULL;
return SYS_ARCH_TIMEOUT;
while( pdTRUE != xQueueReceive( *mbox, &(*msg), portMAX_DELAY ));
if (Elapsed == 0)
Elapsed = 1;
return ( Elapsed );
u32_t sys_arch_mbox_tryfetch(sys_mbox_t *mbox, void **msg)
if ( msg == NULL )
msg = &dummyptr;
if (*mbox == NULL)
if ( xQueueReceive( *mbox, &(*msg), 0 ) == pdPASS )
return ERR_OK;
int sys_mbox_valid(sys_mbox_t *mbox)
return (*mbox != NULL);
void sys_mbox_set_invalid(sys_mbox_t *mbox)
*mbox = SYS_SEM_NULL;
err_t sys_sem_new(sys_sem_t *sem, u8_t count)
vSemaphoreCreateBinary( *sem );
if( sem == NULL )
return ERR_MEM;
if(count == 0)
xSemaphoreTake(*sem, 1);
return ERR_OK;
u32_t sys_arch_sem_wait(sys_sem_t *sem, u32_t timeout)
if( timeout != 0)
if( xSemaphoreTake( *sem, timeout / portTICK_RATE_MS ) == pdTRUE )
return (Elapsed);
while( xSemaphoreTake( *sem, portMAX_DELAY ) != pdTRUE ){}
if (Elapsed == 0)
Elapsed = 1;
return ( Elapsed );
void sys_sem_signal(sys_sem_t *sem)
if (*sem != NULL)
xSemaphoreGive( *sem );
void sys_sem_free(sys_sem_t *sem)
if (sem != NULL)
vQueueDelete( *sem );
int sys_sem_valid(sys_sem_t *sem)
return (*sem != NULL);
void sys_sem_set_invalid(sys_sem_t *sem)
*sem = SYS_SEM_NULL;
err_t sys_mutex_new( sys_mutex_t *pxMutex )
err_t xReturn = ERR_MEM;
*pxMutex = xSemaphoreCreateMutex();
if( *pxMutex != NULL )
xReturn = ERR_OK;
return xReturn;
void sys_mutex_lock( sys_mutex_t *pxMutex )
while( xSemaphoreTake( *pxMutex, portMAX_DELAY ) != pdPASS );
void sys_mutex_unlock(sys_mutex_t *pxMutex )
xSemaphoreGive( *pxMutex );
void sys_mutex_free( sys_mutex_t *pxMutex )
vQueueDelete( *pxMutex );
would you have a look for this ?
thank you very much
