lwip task start
maufil wrote on Wednesday, May 21, 2008:
Hi all,
I’m doing a demo on udp lwip working for Str91x with Rowley. My demo is not getting send packages udp, in my opinion there is a problem when the FreeRTOS launches task. Below is my code, to understand how to launch the task I have taken inspiration from demo WebServer included in the package FreeRTOS 5.
someone can help me? it’s my code ok?
===========================================MAIN.C=========
#ifdef STACK_LWIP
        /* Create the lwIP task.  This uses the lwIP RTOS abstraction layer.*/
          vlwIPInit();
        sys_set_state(    ( signed portCHAR * ) "httpd", lwipBASIC_SERVER_STACK_SIZE );
          sys_thread_new( vBasicWEBServer, ( void * ) NULL, ( tskIDLE_PRIORITY + 2 )basicwebWEBSERVER_PRIORITY );
        sys_set_default_state();
=========================================UDP_SENDER.H========
#ifndef UDP_SENDER_H
#define UDP_SENDER_H
#include <91x_type.h>
/*                            MACROS                                             */
#define basicudp_SENDER_PRIORITY      ( tskIDLE_PRIORITY + 2 )
/* The port on which we listen. */
#define webUDP_PORT        ( 1234 )
/* Delay on close error. */
#define webSHORT_DELAY        ( 10 / portTICK_RATE_MS )
/* The IP address being used. */
#define emacIPADDR0            10
#define emacIPADDR1         200
#define emacIPADDR2           200
#define emacIPADDR3           2
/* The gateway address being used. */
#define emacGATEWAY_ADDR0   10
#define emacGATEWAY_ADDR1   200
#define emacGATEWAY_ADDR2   200
#define emacGATEWAY_ADDR3   1
/* The network mask being used. */
#define emacNET_MASK0         255
#define emacNET_MASK1         255
#define emacNET_MASK2         255
#define emacNET_MASK3         252
#define STATIC_IP   1
#define DHCP_IP     2
#define lwipBASIC_SERVER_STACK_SIZE    250
/*                            PROTOTYPES                                        */
/* The function that implements the WEB server task. */
void vBasicUDPSender( void *pvParameters );
/* Initialisation required by lwIP. */
void vlwIPInit( void );
=========================================UDP_SENDER.C==========================
#define basicwebWEBSERVER_PRIORITY      ( tskIDLE_PRIORITY + 2 )
#define lwipTCP_STACK_SIZE            600
/* Standard includes. */
#include <stdio.h>
#include <string.h>
/* Scheduler includes. */
#include "FreeRTOS.h"
#include "task.h"
#include "semphr.h"
/* Demo includes. */
#include "lwIPWebServer/BasicWEB.h"
#include "udpecho-sender.h"
/* lwIP includes. */
#include "lwip/api.h"
#include "lwip/tcpip.h"
#include "lwip/memp.h"
#include "lwip/stats.h"
#include "Dnetif/loopif.h"
//#include "lcd.h"
#include "httpd.h"
//#define lwipTCP_STACK_SIZE            600
//XXXXXXXXXXXXXXXXXXXXXXXXXXXX
#include "lwip/udp.h"
#include "lwip/mem.h"
#include "lwip/debug.h"
/*                            GLOBALS                                          */
static struct netif EMAC_if;
/*                            FUNCTIONS                                         */
    /* Initialize lwIP and its interface layer. */
    sys_init();
    mem_init();
    memp_init();
    pbuf_init();
    netif_init();
    ip_init();
    sys_set_state(( signed portCHAR * ) "lwIP", lwipTCP_STACK_SIZE);
    udp_init();
void udp_echo_recv(void *arg, struct udp_pcb *pcb, struct pbuf *p, struct ip_addr *addr, u16_t port)
    if (p != NULL)
        /* send received packet back to sender */
        udp_sendto(pcb, p, addr, port);
        /* free the pbuf */
        pbuf_free(p);
void udp_echo_init(void)
    struct udp_pcb * pcb;
    /* get new pcb */
    pcb = udp_new();
    if (pcb == NULL) {
        LWIP_DEBUGF(UDP_DEBUG, ("udp_new failed!\n"));
        return;
    /* bind to any IP address on port 7 */
    if (udp_bind(pcb, IP_ADDR_ANY, UDP_PORT) != ERR_OK) {
        LWIP_DEBUGF(UDP_DEBUG, ("udp_bind failed!\n"));
        return;
    /* set udp_echo_recv() as callback function
       for received packets */
    udp_recv(pcb, udp_echo_recv, NULL);
void vBasicWEBServer( void *pvParameters )
struct ip_addr xIpAddr, xNetMast, xGateway;
extern err_t ethernetif_init( struct netif *netif );
    /* Parameters are not used - suppress compiler error. */
    ( void ) pvParameters;
    /* Create and configure the EMAC interface. */
    IP4_ADDR( &xIpAddr, emacIPADDR0, emacIPADDR1, emacIPADDR2, emacIPADDR3 );
    IP4_ADDR( &xNetMast, emacNET_MASK0, emacNET_MASK1, emacNET_MASK2, emacNET_MASK3 );
    IP4_ADDR( &xGateway, emacGATEWAY_ADDR0, emacGATEWAY_ADDR1, emacGATEWAY_ADDR2, emacGATEWAY_ADDR3 );
    netif_add( &EMAC_if, &xIpAddr, &xNetMast, &xGateway, NULL, ethernetif_init, tcpip_input );
    /* make it the default interface */
    netif_set_default( &EMAC_if );
    /* bring it up */
    netif_set_up(&EMAC_if);
    /* Initialize HTTP */
   udp_echo_init();//httpd_init();
    /* Nothing else to do.  No point hanging around. */
    vTaskDelete( NULL );
