I have a problem with initializing the lwip.
I want to intialise components for my board in a function before the task scheduler starts. I have a problem with it: the lwIP initialization works if initialized with a task, but the same code doesn’t work when run as function. What I mean with this is that the application crashes when I wish to use the stack. The netconn_recv() or netconn_send() functions simply make the board freeeze.
This works (main.c):
/* Write your code here */
/* Initialize and configure clocks */
CLOCK_SYS_Init(g_clockManConfigsArr, (uint8_t)CLOCK_MANAGER_CONFIG_CNT, g_clockManCallbacksArr, (uint8_t)CLOCK_MANAGER_CALLBACK_CNT);
CLOCK_SYS_UpdateConfiguration(0U, CLOCK_MANAGER_POLICY_AGREEMENT);
/* Initialize pins */
PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr);
/* generate a struct with paramaters for the init function, and place it on the heap */
taskParams *initParams;
initParams = (taskParams*) pvPortMalloc(sizeof(taskParams));
SemaphoreHandle_t ptr_binary_sem;
ptr_binary_sem = xSemaphoreCreateBinary();
initParams->binary_sem_ptr = ptr_binary_sem;
/* create Tasks */
xTaskCreate(vInitTask, "InitTask", 256U, (void*)(initParams), 10, NULL);
xTaskCreate(vUDPpingpong, "UDPpingpong", 256U, (void*)(initParams), 9, NULL);
xTaskCreate(vBlinkLEDTask, "blinkLEDTask", 256U, NULL, 1, NULL);
vTaskStartScheduler();
/*** Don't write any code pass this line, or it will be deleted during code generation. ***/
And this doesn’t work (also main.c):
/* initialize tcpip */
initFunc();
/* create Tasks */
I am pasting underneath the code I use for initalisation - as you can see it is the same code for a task or for a function:
void initFunc(void){
/*init the internet stack */
tcpip_init(NULL, NULL);
enetif_init();
VS
void vInitTask(void* pvParameters){
enetif_init();
vTaskDelete(NULL);
I tried to debug the code, but it simply crashes when I wish to recieve or send packets over UDP. It is difficult to say what is the reason - all the functions are called with correct arguments and all function calls looks exactly the same in both cases. I do not understand the assembly debugger enough to be able to figure out any differences.
I am using MPC5748G board from NXP.
Does anybody know what could be the reason of such behaviour?
One more piece of code - my enetif_init() function:
static void enetif_init(void)
for(int i = 0; i < ENETIF_NUMBER; i++)
ip4_addr_t ipaddr, netmask, gw;
struct netif *mynetif;
ip4_addr_set_zero(&gw);
ip4_addr_set_zero(&ipaddr);
ip4_addr_set_zero(&netmask);
/* network_interfaces[i] takes the IPV4 addresses from the respective configuration */
if ((!netif_cfg[i]->has_dhcp) && (!netif_cfg[i]->has_auto_ip))
IP4_ADDR((&gw), netif_cfg[i]->gw[0], netif_cfg[i]->gw[1], netif_cfg[i]->gw[2], netif_cfg[i]->gw[3]);
IP4_ADDR((&ipaddr), netif_cfg[i]->ip_addr[0], netif_cfg[i]->ip_addr[1], netif_cfg[i]->ip_addr[2], netif_cfg[i]->ip_addr[3]);
IP4_ADDR((&netmask), netif_cfg[i]->netmask[0], netif_cfg[i]->netmask[1], netif_cfg[i]->netmask[2], netif_cfg[i]->netmask[3]);
mynetif = netif_add(&network_interfaces[i], &ipaddr, &netmask, &gw, NULL, enet_ethernetif_init, tcpip_input);
netif_set_up(&network_interfaces[i]);
netif_set_default(&network_interfaces[i]);
