1) Which compiler are you using?
2) Which version of the compiler are you using?
3) Which version of FreeRTOS are you using?
4) Have you made any changes to the example project, however trivial?
1) IAR C/C++ Compiler for ARM
2) 5.40.0.31500 (5.40.0.31500)
3) V4.5.0 (And in answering your questions, I’ve discovered this is out of date)
4) No changes
I’ve downloaded version V6.0.5 and now it builds with no errors. Sorry about that and thank you for your help.
