jengoreda wrote on Thursday, September 13, 2007:
Hi all,
I am new to FreeRTOS. recently i try to compile the freertos port for keil lpc2129 demo.
i am using uVision3 3.53.
1. during compile an error code — Error: failed to execute ‘C:\Keil\ARM\BIN\CA’ . where can i get the CA compiler?
2. i goto Project -> manage -> component,environment,book —> folder/extensions
change to use RealView compiler. alot of error n warning.
3. where should i put the downloaded FreeRTOS folder(contain the source code of the demos)? i install the uVision in partition C. but i put the download folder in partition D. will this cos the problem? i did try to put the folder in keil folder but still the same error and warning.
Thank you very much for your helps
