arm-user wrote on Tuesday, March 14, 2006:
Hello Everybody,
<p>
I have a AT91SAM7S-EK Board, running FreeRTOS 3.2.4 (based on the lwIP_Demo_Rowley_ARM7) and
using Crossworks GCC.
<p>
Now I wanted to use the Serial-Files from
ARM7_AT91SAM7S64_IAR. Here my problems/questions:
<p>
- is it generally possible to port ISRs from IAR
with s79 Assembler Files to GCC?
<p>
- serial.c seems to work, except the function
__arm void vSerialISR( void ) - for this I made
a own file which is compiled in arm mode?
<p>
- serialISR.s79: how is the assembler directive
RSEG ICODE:CODE ported to GCC?
I tryed .section icode:code and
.section icode, "ax" and many others…
Some are linked, some not, but none of them
work on the SAM7S (he is hanging up…)
<p>
<p>
I know there are some other ways the implement the serial interface to the SAM7S with GCC (like ARM7_AT91FR40008_GCC), but I want to know if its possible to use IAR Code with GCC.
<p>
Thanks in advance…
Thomas
