nobody wrote on Friday, January 21, 2005:
hi everibody,
I’m using the IAR KickStart Card for Philips
LPC2106, can i use the Freertos?
Thanks
Leo
hi everibody,
Thanks
Leo
rtel wrote on Friday, January 21, 2005:
Did you recently send me an email regarding the KickStart board? If so can you send it again (address from WEB site) as I some how managed to miss place it - thanks.
The FreeRTOS download currently has ports for the LPC2000 series using CrossWords, plain GCC and Keil - but not IAR. However, there is an IAR port for the Atmel SAM7S - which is also has an ARM7 core so is very similar.
Using IAR with the LPC2000 would require setting up a project. This would be a combination: The setup and syntax as per the SAM7 port, with the peripheral configuration as per the LPC2000 ports.
So, having rambled for a while, the quick answer is Yes, but not "straight out of the box".
Regards,
Richard.
