nobody wrote on Friday, November 17, 2006:
I have downloaded FreeRTOSV4.1.2 and even 4.1.1 and keep experiencing the same error, with IAR 4.30A (Using Kickstart4.0) gives the same error message when first opening the project:
Broken Links Detected
A backup copy will be made
Here are the error messages:
LOAD: Configuration ‘Flash Debug’ in the project ‘rtosdemo’ contains broken options for tool ‘XLINK’:
The format of this file is not supported by this version of the workbench. It appears to have been written by a newer version of the workbench.
Diagnostics: ‘Settings ‘XLINK’: unsupported version - 18’.
Options for ‘XLINK’ will be set to default.
Creating backup of original project file.
LOAD: Configuration ‘Flash Release’ in the project ‘rtosdemo’ contains broken options for tool ‘XLINK’:
WTD: Unavailable option selection: ‘Atmel AT91SAM7X256’.
WTD: Changed to default selection: ‘None’.
I have built a couple of the other projects just to check IAR and all build OK. Any light you can shine would be greatly appreciated.
