I wonder if any one can tell me how to generate a httpd_fsdata.c and httpd_strings.c files from the shtml files if they are modified. I saw there are two files, makefsdata and makefsstrings, under the webserver subdirectory, but I don’t have idea how to use them. What is the command syntax or usage?
I am using the demo project of CORTEX_LM3Sxxxx_IAR_Keil from FreeRTOS v5.03.
makefsdata is a perl script so you need to have perl installed to use it. If you are using Linux you can probably just type “makefsdata”. If you are using windows then you will have to type “perl makefsdata”.
Thank you for your help, but I wonder if there is any option associated with this makefsdata command. I also curious why FREERTOS put this webserver sample in to the demo without any description of how to use/modify the webserver, for example, a README file. I saw Luminary StellarisWare demo that there is a makefsdata file with usages to explain how to use it. I wonder if they (from FREERTOS and Luminary) are the similar to or comparable, so I just use it to generate a http_fsdata.c?
Hi Bill,
I make a simple Windows GUI to generate the read-only file system image suitable with lwIP web server.
Launch it and then press the Open button, select the root_folder of your web server files and then select the output C source file. That’s all. It should work.
If you want to try, you find it (Make_fsdata) as attachment at the bottom of the following web page: http://developers.stf12.net/Ethernet-demo
